[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit 8d8ee47e03ef23b0d0e842ea455a30bf0d2023b9:
env: Add CONFIG_SYS_RELOC_GD_ENV_ADDR symbol (2019-11-20 12:24:50 -0500)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to 0c14bb5ad3311de2c26e66e88f8a6886773b8e0a:
arm: socfpga: stratix10: Add alias for gmac0 in S10 dts (2019-11-22 03:08:12 +0100)
---------------------------------------------------------------- Ley Foon Tan (2): arm: dts: Stratix10: Fix memory node address and size cells configs: Stratix10: Disable CONFIG_SPL_USE_TINY_PRINTF
Marek Vasut (1): ARM: socfpga: Fix default mtdparts
Ooi, Joyce (2): arm: dts: Stratix10: change pad skew values for EMAC0 PHY driver arm: socfpga: stratix10: Add alias for gmac0 in S10 dts
Simon Goldschmidt (4): ddr: socfpga: gen5: constify altera_gen5_sdram_ops socfpga: fix include guard in misc.h (arch vs. global) timer: dw-apb: add reset handling spi: cadence_qspi: support DM_CLK
arch/arm/dts/socfpga_stratix10_socdk.dts | 5 ++++- arch/arm/mach-socfpga/include/mach/misc.h | 6 +++--- configs/socfpga_arria5_defconfig | 2 +- configs/socfpga_cyclone5_defconfig | 2 +- configs/socfpga_de0_nano_soc_defconfig | 2 +- configs/socfpga_is1_defconfig | 2 +- configs/socfpga_mcvevk_defconfig | 2 +- configs/socfpga_sockit_defconfig | 2 +- configs/socfpga_socrates_defconfig | 2 +- configs/socfpga_sr1500_defconfig | 2 +- configs/socfpga_stratix10_defconfig | 1 + drivers/ddr/altera/sdram_gen5.c | 2 +- drivers/spi/cadence_qspi.c | 21 +++++++++++++++++++-- drivers/spi/cadence_qspi.h | 1 + drivers/timer/dw-apb-timer.c | 18 +++++++++++++++++- 15 files changed, 54 insertions(+), 16 deletions(-)
