Hello Tom,
Please pull tag u-boot-at91-fixes-2023.01-a , the first set of at91 fixes for the 2023.01 cycle.
This small fixes set includes an indentation fix for sam9x60 DT and one name for one pin for sama7g5.
Thanks, Eugen
The following changes since commit 3724ddf157aab3bd009c1da234b9a1af1621b544:
Merge branch '2022-10-18-TI-platform-updates' (2022-10-18 18:13:39 -0400)
https://source.denx.de/u-boot/custodians/u-boot-at91.git tags/u-boot-at91-fixes-2023.01-a
for you to fetch changes up to 17e21d7cbfe7eff0b1916176f7a11492948122dc:
ARM: dts: at91: sama7g5: fix signal name of pin PB2 (2022-10-21 08:59:27 +0300)
---------------------------------------------------------------- First set of u-boot-at91 fixes for the 2023.01 cycle
---------------------------------------------------------------- Dario Binacchi (1): ARM: dts: at91: sam9x60ek: fix indentation for pinctrl sub-nodes
Mihai Sain (1): ARM: dts: at91: sama7g5: fix signal name of pin PB2
arch/arm/dts/sam9x60ek.dts | 36 ++++++++++++++++++------------------ arch/arm/dts/sama7g5-pinfunc.h | 2 +- 2 files changed, 19 insertions(+), 19 deletions(-)
On Fri, Oct 21, 2022 at 08:46:51AM +0000, Eugen.Hristev@microchip.com wrote:
Hello Tom,
Thanks, Eugen
