[U-Boot] [PATCH] rockchip: rk3328: correct mem_region
According to rk3328 TRM: 0~0xff000000 is ddr space; 0xff000000~0xffffffff is device space.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/rk3328/rk3328.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3328/rk3328.c b/arch/arm/mach-rockchip/rk3328/rk3328.c index 857f014..cec6f90 100644 --- a/arch/arm/mach-rockchip/rk3328/rk3328.c +++ b/arch/arm/mach-rockchip/rk3328/rk3328.c @@ -13,13 +13,13 @@ static struct mm_region rk3328_mem_map[] = { { .virt = 0x0UL, .phys = 0x0UL, - .size = 0x80000000UL, + .size = 0xff000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, { - .virt = 0xf0000000UL, - .phys = 0xf0000000UL, - .size = 0x10000000UL, + .virt = 0xff000000UL, + .phys = 0xff000000UL, + .size = 0x1000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot-rockchip/next, thanks!
Kever Yang
Philipp Tomsich
