[U-Boot] Pull request: nand flash
The following changes since commit 7f202217356f19e519e6ec57a29de9af73067037: Wolfgang Denk (1): Merge branch 'master' of ssh://gemini/home/wd/git/u-boot/master
git://git.denx.de/u-boot-nand-flash.git master
Scott Wood (1): NAND: Mark the BBT as scanned prior to calling scan_bbt.
drivers/mtd/nand/nand_base.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
Scott, could you pick the patch [PATCH v3] nand: Fix cache and memory inconsistent issue
I'll apply it to the "next" branch, but it's not needed for the upcoming release because there's no board upstream with d-cache enabled.
-Scott
Dear Scott,
Done, thanks.
Liu Dave
Scott Wood
