[U-Boot] [PATCH 0/2] arm: zynq: add support for the zybo z7 board
This series adds support for the Digilent Zybo Z7 board
The only think, that I tested, and is not working yet, is reading the MAC address from the OTP region of the SPI flash memory, but I pretend to work on that
I decided to split this series in two patches because the first contains the ps7_init_* file generated by Vivado and is ~170 kB. I tried to strip as much as possible from the file (from ~520 kB), but I wanted to preserve Vivado's comments to compare its output on future versions (it might have bugfixes). If the patch doesn't make it to the mailing list, I hope to find another solution, or I'll just simply remove additional content (Vivado's comments)
Luis Araneda (2): arm: zynq: add ps7_init file for zybo z7 arm: zynq: add support for the zybo z7 board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/zynq-zybo-z7.dts | 91 + board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c | 3959 +++++++++++++++++ configs/zynq_zybo_z7_defconfig | 68 + 4 files changed, 4120 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/zynq-zybo-z7.dts create mode 100644 board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c create mode 100644 configs/zynq_zybo_z7_defconfig
Procedure to generate the "ps7_init_gpl.c" file: + Install Vivado Webpack 2018.2 + Download digilent/vivado-boards repository (commit 6a45981 from 2018-06-05) - Install board files: https://reference.digilentinc.com/vivado/installing-vivado/start#installing_... + Start Vivado and create a new RTL project with the Zybo-z7-20 board + Create a block design - Add "ZYNQ7 Processing System" IP - Run "Block Automation" (Check "Apply Board Preset") - Connect ports FCLK_CLK0 and M_AXI_GP0_ACLK - Save diagram changes - Go to sources view, select the block diagram, and select "Generate Output Products" + Copy the generated "ps7_init_gpl.c" file + Manual editions to "ps7_init_gpl.c" file: - Replace license header by SPDX identifier - Replicate changes made by commit a3b36c8 (arm: zynq: Remove ps7_debug code) - Remove array "ps7_debug_3_0" - Remove array "ps7_debug_2_0" - Remove array "ps7_debug_1_0" - Remove function "ps7_debug" - Replicate changes made by commit a3b36c8 (arm: zynq: Convert all board to use arch ps7_init code) - Modify the inclusion of "ps7_init_gpl.h" - Remove "PS7_MASK_POLL_TIME" macro - Remove "getPS7MessageInfo" function - Remove "ps7GetSiliconVersion" function - Remove "mask_write" function - Remove "mask_poll" function - Remove "mask_read" function - Remove "ps7_config" function - Remove "perf_start_clock" function - Remove "perf_reset_clock" function - Remove "get_number_of_cycles_for_delay" function - Remove "perf_disable_clock" function - Remove "perf_reset_and_start_timer" function - Remove functions/data related to silicon v1/v2: - Array "ps7_mio_init_data_2_0" - Array "ps7_pll_init_data_2_0" - Array "ps7_clock_init_data_2_0" - Array "ps7_ddr_init_data_2_0" - Array "ps7_peripherals_init_data_2_0" - Array "ps7_post_config_2_0" - Array "ps7_mio_init_data_1_0" - Array "ps7_pll_init_data_1_0" - Array "ps7_clock_init_data_1_0" - Array "ps7_ddr_init_data_1_0" - Array "ps7_peripherals_init_data_1_0" - Array "ps7_post_config_1_0"
Signed-off-by: Luis Araneda luaraneda@gmail.com --- board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c | 3959 +++++++++++++++++ 1 file changed, 3959 insertions(+) create mode 100644 board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c
diff --git a/board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c new file mode 100644 index 0000000000..44c1cfe893 --- /dev/null +++ b/board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c @@ -0,0 +1,3959 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. + */ + +#include <asm/arch/ps7_init_gpl.h> + +unsigned long ps7_pll_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: PLL SLCR REGISTERS + // .. .. START: ARM PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000110[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000110[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000110[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x28 + // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. ARM_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. SRCSEL = 0x0 + // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. .. DIVISOR = 0x2 + // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U + // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U + // .. .. .. CPU_6OR4XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U + // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. .. CPU_3OR2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U + // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U + // .. .. .. CPU_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U + // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. .. CPU_1XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U + // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. .. CPU_PERI_CLKACT = 0x1 + // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U + // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U), + // .. .. FINISH: ARM PLL INIT + // .. .. START: DDR PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000114[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000114[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x12c + // .. .. ==> 0XF8000114[21:12] = 0x0000012CU + // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U + // .. .. + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x20 + // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. DDR_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. DDR_3XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. DDR_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. DDR_3XCLK_DIVISOR = 0x2 + // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U + // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. .. DDR_2XCLK_DIVISOR = 0x3 + // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U + // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U), + // .. .. FINISH: DDR PLL INIT + // .. .. START: IO PLL INIT + // .. .. PLL_RES = 0xc + // .. .. ==> 0XF8000118[7:4] = 0x0000000CU + // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000118[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x145 + // .. .. ==> 0XF8000118[21:12] = 0x00000145U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00145000U + // .. .. + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x001452C0U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x1e + // .. .. .. ==> 0XF8000108[18:12] = 0x0000001EU + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0001E000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0001E000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. IO_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U + // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. FINISH: IO PLL INIT + // .. FINISH: PLL SLCR REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_clock_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: CLOCK CONTROL SLCR REGISTERS + // .. CLKACT = 0x1 + // .. ==> 0XF8000128[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. DIVISOR0 = 0xf + // .. ==> 0XF8000128[13:8] = 0x0000000FU + // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. DIVISOR1 = 0x7 + // .. ==> 0XF8000128[25:20] = 0x00000007U + // .. ==> MASK : 0x03F00000U VAL : 0x00700000U + // .. + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00700F01U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000138[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000138[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000138, 0x00000011U ,0x00000001U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000140[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000140[6:4] = 0x00000000U + // .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. DIVISOR = 0x8 + // .. ==> 0XF8000140[13:8] = 0x00000008U + // .. ==> MASK : 0x00003F00U VAL : 0x00000800U + // .. DIVISOR1 = 0x1 + // .. ==> 0XF8000140[25:20] = 0x00000001U + // .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U ,0x00100801U), + // .. CLKACT = 0x1 + // .. ==> 0XF800014C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF800014C[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x5 + // .. ==> 0XF800014C[13:8] = 0x00000005U + // .. ==> MASK : 0x00003F00U VAL : 0x00000500U + // .. + EMIT_MASKWRITE(0XF800014C, 0x00003F31U ,0x00000501U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000150[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x0 + // .. ==> 0XF8000150[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000150[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x14 + // .. ==> 0XF8000150[13:8] = 0x00000014U + // .. ==> MASK : 0x00003F00U VAL : 0x00001400U + // .. + EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00001401U), + // .. CLKACT0 = 0x0 + // .. ==> 0XF8000154[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000154[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000154[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xa + // .. ==> 0XF8000154[13:8] = 0x0000000AU + // .. ==> MASK : 0x00003F00U VAL : 0x00000A00U + // .. + EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000A02U), + // .. .. START: TRACE CLOCK + // .. .. FINISH: TRACE CLOCK + // .. .. CLKACT = 0x1 + // .. .. ==> 0XF8000168[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000168[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR = 0x5 + // .. .. ==> 0XF8000168[13:8] = 0x00000005U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000500U + // .. .. + EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000501U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000170[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x5 + // .. .. ==> 0XF8000170[13:8] = 0x00000005U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000500U + // .. .. DIVISOR1 = 0x4 + // .. .. ==> 0XF8000170[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00400500U), + // .. .. CLK_621_TRUE = 0x1 + // .. .. ==> 0XF80001C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U), + // .. .. DMA_CPU_2XCLKACT = 0x1 + // .. .. ==> 0XF800012C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. USB0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[2:2] = 0x00000001U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. USB1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. GEM0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[6:6] = 0x00000001U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000040U + // .. .. GEM1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. SDI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[10:10] = 0x00000001U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U + // .. .. SDI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. SPI0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. SPI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. CAN0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. CAN1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. I2C0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[18:18] = 0x00000001U + // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U + // .. .. I2C1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. UART0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. UART1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. GPIO_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[22:22] = 0x00000001U + // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U + // .. .. LQSPI_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[23:23] = 0x00000001U + // .. .. ==> MASK : 0x00800000U VAL : 0x00800000U + // .. .. SMC_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[24:24] = 0x00000001U + // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x01EC044DU), + // .. FINISH: CLOCK CONTROL SLCR REGISTERS + // .. START: THIS SHOULD BE BLANK + // .. FINISH: THIS SHOULD BE BLANK + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_ddr_init_data_3_0[] = { + // START: top + // .. START: DDR INITIALIZATION + // .. .. START: LOCK DDR + // .. .. reg_ddrc_soft_rstb = 0 + // .. .. ==> 0XF8006000[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 0x1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000080U), + // .. .. FINISH: LOCK DDR + // .. .. reg_ddrc_t_rfc_nom_x32 = 0x81 + // .. .. ==> 0XF8006004[11:0] = 0x00000081U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000081U + // .. .. reserved_reg_ddrc_active_ranks = 0x1 + // .. .. ==> 0XF8006004[13:12] = 0x00000001U + // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U + // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0 + // .. .. ==> 0XF8006004[18:14] = 0x00000000U + // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU ,0x00001081U), + // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf + // .. .. ==> 0XF8006008[10:0] = 0x0000000FU + // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU + // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf + // .. .. ==> 0XF8006008[21:11] = 0x0000000FU + // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U + // .. .. reg_ddrc_hpr_xact_run_length = 0xf + // .. .. ==> 0XF8006008[25:22] = 0x0000000FU + // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U + // .. .. + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU), + // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF800600C[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2 + // .. .. ==> 0XF800600C[21:11] = 0x00000002U + // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U + // .. .. reg_ddrc_lpr_xact_run_length = 0x8 + // .. .. ==> 0XF800600C[25:22] = 0x00000008U + // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U + // .. .. + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U), + // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF8006010[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_w_xact_run_length = 0x8 + // .. .. ==> 0XF8006010[14:11] = 0x00000008U + // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U + // .. .. reg_ddrc_w_max_starve_x32 = 0x2 + // .. .. ==> 0XF8006010[25:15] = 0x00000002U + // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U + // .. .. + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U), + // .. .. reg_ddrc_t_rc = 0x1a + // .. .. ==> 0XF8006014[5:0] = 0x0000001AU + // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001AU + // .. .. reg_ddrc_t_rfc_min = 0xa0 + // .. .. ==> 0XF8006014[13:6] = 0x000000A0U + // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002800U + // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10 + // .. .. ==> 0XF8006014[20:14] = 0x00000010U + // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004281AU), + // .. .. reg_ddrc_wr2pre = 0x12 + // .. .. ==> 0XF8006018[4:0] = 0x00000012U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000012U + // .. .. reg_ddrc_powerdown_to_x32 = 0x6 + // .. .. ==> 0XF8006018[9:5] = 0x00000006U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U + // .. .. reg_ddrc_t_faw = 0x16 + // .. .. ==> 0XF8006018[15:10] = 0x00000016U + // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U + // .. .. reg_ddrc_t_ras_max = 0x24 + // .. .. ==> 0XF8006018[21:16] = 0x00000024U + // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U + // .. .. reg_ddrc_t_ras_min = 0x13 + // .. .. ==> 0XF8006018[26:22] = 0x00000013U + // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U + // .. .. reg_ddrc_t_cke = 0x4 + // .. .. ==> 0XF8006018[31:28] = 0x00000004U + // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D2U), + // .. .. reg_ddrc_write_latency = 0x5 + // .. .. ==> 0XF800601C[4:0] = 0x00000005U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U + // .. .. reg_ddrc_rd2wr = 0x7 + // .. .. ==> 0XF800601C[9:5] = 0x00000007U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U + // .. .. reg_ddrc_wr2rd = 0xe + // .. .. ==> 0XF800601C[14:10] = 0x0000000EU + // .. .. ==> MASK : 0x00007C00U VAL : 0x00003800U + // .. .. reg_ddrc_t_xp = 0x4 + // .. .. ==> 0XF800601C[19:15] = 0x00000004U + // .. .. ==> MASK : 0x000F8000U VAL : 0x00020000U + // .. .. reg_ddrc_pad_pd = 0x0 + // .. .. ==> 0XF800601C[22:20] = 0x00000000U + // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U + // .. .. reg_ddrc_rd2pre = 0x4 + // .. .. ==> 0XF800601C[27:23] = 0x00000004U + // .. .. ==> MASK : 0x0F800000U VAL : 0x02000000U + // .. .. reg_ddrc_t_rcd = 0x7 + // .. .. ==> 0XF800601C[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x720238E5U), + // .. .. reg_ddrc_t_ccd = 0x4 + // .. .. ==> 0XF8006020[4:2] = 0x00000004U + // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U + // .. .. reg_ddrc_t_rrd = 0x6 + // .. .. ==> 0XF8006020[7:5] = 0x00000006U + // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U + // .. .. reg_ddrc_refresh_margin = 0x2 + // .. .. ==> 0XF8006020[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_rp = 0x7 + // .. .. ==> 0XF8006020[15:12] = 0x00000007U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U + // .. .. reg_ddrc_refresh_to_x32 = 0x8 + // .. .. ==> 0XF8006020[20:16] = 0x00000008U + // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U + // .. .. reg_ddrc_mobile = 0x0 + // .. .. ==> 0XF8006020[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reg_ddrc_en_dfi_dram_clk_disable = 0x0 + // .. .. ==> 0XF8006020[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reg_ddrc_read_latency = 0x7 + // .. .. ==> 0XF8006020[28:24] = 0x00000007U + // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U + // .. .. reg_phy_mode_ddr1_ddr2 = 0x1 + // .. .. ==> 0XF8006020[29:29] = 0x00000001U + // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U + // .. .. reg_ddrc_dis_pad_pd = 0x0 + // .. .. ==> 0XF8006020[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU ,0x270872D0U), + // .. .. reg_ddrc_en_2t_timing_mode = 0x0 + // .. .. ==> 0XF8006024[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_prefer_write = 0x0 + // .. .. ==> 0XF8006024[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_mr_wr = 0x0 + // .. .. ==> 0XF8006024[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_ddrc_mr_addr = 0x0 + // .. .. ==> 0XF8006024[8:7] = 0x00000000U + // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. .. reg_ddrc_mr_data = 0x0 + // .. .. ==> 0XF8006024[24:9] = 0x00000000U + // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U + // .. .. ddrc_reg_mr_wr_busy = 0x0 + // .. .. ==> 0XF8006024[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_type = 0x0 + // .. .. ==> 0XF8006024[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_rdata_valid = 0x0 + // .. .. ==> 0XF8006024[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U ,0x00000000U), + // .. .. reg_ddrc_final_wait_x32 = 0x7 + // .. .. ==> 0XF8006028[6:0] = 0x00000007U + // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U + // .. .. reg_ddrc_pre_ocd_x32 = 0x0 + // .. .. ==> 0XF8006028[10:7] = 0x00000000U + // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U + // .. .. reg_ddrc_t_mrd = 0x4 + // .. .. ==> 0XF8006028[13:11] = 0x00000004U + // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U + // .. .. + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U), + // .. .. reg_ddrc_emr2 = 0x8 + // .. .. ==> 0XF800602C[15:0] = 0x00000008U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U + // .. .. reg_ddrc_emr3 = 0x0 + // .. .. ==> 0XF800602C[31:16] = 0x00000000U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U), + // .. .. reg_ddrc_mr = 0x930 + // .. .. ==> 0XF8006030[15:0] = 0x00000930U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000930U + // .. .. reg_ddrc_emr = 0x4 + // .. .. ==> 0XF8006030[31:16] = 0x00000004U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040930U), + // .. .. reg_ddrc_burst_rdwr = 0x4 + // .. .. ==> 0XF8006034[3:0] = 0x00000004U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U + // .. .. reg_ddrc_pre_cke_x1024 = 0x16d + // .. .. ==> 0XF8006034[13:4] = 0x0000016DU + // .. .. ==> MASK : 0x00003FF0U VAL : 0x000016D0U + // .. .. reg_ddrc_post_cke_x1024 = 0x1 + // .. .. ==> 0XF8006034[25:16] = 0x00000001U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U + // .. .. reg_ddrc_burstchop = 0x0 + // .. .. ==> 0XF8006034[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x000116D4U), + // .. .. reg_ddrc_force_low_pri_n = 0x0 + // .. .. ==> 0XF8006038[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_dis_dq = 0x0 + // .. .. ==> 0XF8006038[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006038, 0x00000003U ,0x00000000U), + // .. .. reg_ddrc_addrmap_bank_b0 = 0x7 + // .. .. ==> 0XF800603C[3:0] = 0x00000007U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000007U + // .. .. reg_ddrc_addrmap_bank_b1 = 0x7 + // .. .. ==> 0XF800603C[7:4] = 0x00000007U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000070U + // .. .. reg_ddrc_addrmap_bank_b2 = 0x7 + // .. .. ==> 0XF800603C[11:8] = 0x00000007U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000700U + // .. .. reg_ddrc_addrmap_col_b5 = 0x0 + // .. .. ==> 0XF800603C[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b6 = 0x0 + // .. .. ==> 0XF800603C[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000777U), + // .. .. reg_ddrc_addrmap_col_b2 = 0x0 + // .. .. ==> 0XF8006040[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b3 = 0x0 + // .. .. ==> 0XF8006040[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b4 = 0x0 + // .. .. ==> 0XF8006040[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b7 = 0x0 + // .. .. ==> 0XF8006040[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b8 = 0x0 + // .. .. ==> 0XF8006040[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b9 = 0xf + // .. .. ==> 0XF8006040[23:20] = 0x0000000FU + // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U + // .. .. reg_ddrc_addrmap_col_b10 = 0xf + // .. .. ==> 0XF8006040[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. reg_ddrc_addrmap_col_b11 = 0xf + // .. .. ==> 0XF8006040[31:28] = 0x0000000FU + // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U + // .. .. + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFF00000U), + // .. .. reg_ddrc_addrmap_row_b0 = 0x6 + // .. .. ==> 0XF8006044[3:0] = 0x00000006U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U + // .. .. reg_ddrc_addrmap_row_b1 = 0x6 + // .. .. ==> 0XF8006044[7:4] = 0x00000006U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U + // .. .. reg_ddrc_addrmap_row_b2_11 = 0x6 + // .. .. ==> 0XF8006044[11:8] = 0x00000006U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U + // .. .. reg_ddrc_addrmap_row_b12 = 0x6 + // .. .. ==> 0XF8006044[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_addrmap_row_b13 = 0x6 + // .. .. ==> 0XF8006044[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_addrmap_row_b14 = 0x6 + // .. .. ==> 0XF8006044[23:20] = 0x00000006U + // .. .. ==> MASK : 0x00F00000U VAL : 0x00600000U + // .. .. reg_ddrc_addrmap_row_b15 = 0xf + // .. .. ==> 0XF8006044[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F666666U), + // .. .. reg_phy_rd_local_odt = 0x0 + // .. .. ==> 0XF8006048[13:12] = 0x00000000U + // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U + // .. .. reg_phy_wr_local_odt = 0x3 + // .. .. ==> 0XF8006048[15:14] = 0x00000003U + // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U + // .. .. reg_phy_idle_local_odt = 0x3 + // .. .. ==> 0XF8006048[17:16] = 0x00000003U + // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U + // .. .. reserved_reg_ddrc_rank0_wr_odt = 0x1 + // .. .. ==> 0XF8006048[5:3] = 0x00000001U + // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U + // .. .. reserved_reg_ddrc_rank0_rd_odt = 0x0 + // .. .. ==> 0XF8006048[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006048, 0x0003F03FU ,0x0003C008U), + // .. .. reg_phy_rd_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_wr_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_phy_rdc_we_to_re_delay = 0x8 + // .. .. ==> 0XF8006050[11:8] = 0x00000008U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U + // .. .. reg_phy_rdc_fifo_rst_disable = 0x0 + // .. .. ==> 0XF8006050[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_phy_use_fixed_re = 0x1 + // .. .. ==> 0XF8006050[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0 + // .. .. ==> 0XF8006050[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0 + // .. .. ==> 0XF8006050[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_phy_clk_stall_level = 0x0 + // .. .. ==> 0XF8006050[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[27:24] = 0x00000007U + // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U + // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U), + // .. .. reg_ddrc_dis_dll_calib = 0x0 + // .. .. ==> 0XF8006058[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006058, 0x00010000U ,0x00000000U), + // .. .. reg_ddrc_rd_odt_delay = 0x3 + // .. .. ==> 0XF800605C[3:0] = 0x00000003U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U + // .. .. reg_ddrc_wr_odt_delay = 0x0 + // .. .. ==> 0XF800605C[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_rd_odt_hold = 0x0 + // .. .. ==> 0XF800605C[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_hold = 0x5 + // .. .. ==> 0XF800605C[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U), + // .. .. reg_ddrc_pageclose = 0x0 + // .. .. ==> 0XF8006060[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_lpr_num_entries = 0x1f + // .. .. ==> 0XF8006060[6:1] = 0x0000001FU + // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU + // .. .. reg_ddrc_auto_pre_en = 0x0 + // .. .. ==> 0XF8006060[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_ddrc_refresh_update_level = 0x0 + // .. .. ==> 0XF8006060[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_ddrc_dis_wc = 0x0 + // .. .. ==> 0XF8006060[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_ddrc_dis_collision_page_opt = 0x0 + // .. .. ==> 0XF8006060[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_ddrc_selfref_en = 0x0 + // .. .. ==> 0XF8006060[12:12] = 0x00000000U + // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU), + // .. .. reg_ddrc_go2critical_hysteresis = 0x0 + // .. .. ==> 0XF8006064[12:5] = 0x00000000U + // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U + // .. .. reg_arb_go2critical_en = 0x1 + // .. .. ==> 0XF8006064[17:17] = 0x00000001U + // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U + // .. .. + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U), + // .. .. reg_ddrc_wrlvl_ww = 0x41 + // .. .. ==> 0XF8006068[7:0] = 0x00000041U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U + // .. .. reg_ddrc_rdlvl_rr = 0x41 + // .. .. ==> 0XF8006068[15:8] = 0x00000041U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U + // .. .. reg_ddrc_dfi_t_wlmrd = 0x28 + // .. .. ==> 0XF8006068[25:16] = 0x00000028U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U + // .. .. + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U), + // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10 + // .. .. ==> 0XF800606C[7:0] = 0x00000010U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U + // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16 + // .. .. ==> 0XF800606C[15:8] = 0x00000016U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U + // .. .. + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U), + // .. .. reg_ddrc_dfi_t_ctrl_delay = 0x1 + // .. .. ==> 0XF8006078[3:0] = 0x00000001U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000001U + // .. .. reg_ddrc_dfi_t_dram_clk_disable = 0x1 + // .. .. ==> 0XF8006078[7:4] = 0x00000001U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000010U + // .. .. reg_ddrc_dfi_t_dram_clk_enable = 0x1 + // .. .. ==> 0XF8006078[11:8] = 0x00000001U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000100U + // .. .. reg_ddrc_t_cksre = 0x6 + // .. .. ==> 0XF8006078[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_t_cksrx = 0x6 + // .. .. ==> 0XF8006078[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_t_ckesr = 0x4 + // .. .. ==> 0XF8006078[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU ,0x00466111U), + // .. .. reg_ddrc_t_ckpde = 0x2 + // .. .. ==> 0XF800607C[3:0] = 0x00000002U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000002U + // .. .. reg_ddrc_t_ckpdx = 0x2 + // .. .. ==> 0XF800607C[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. reg_ddrc_t_ckdpde = 0x2 + // .. .. ==> 0XF800607C[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_ckdpdx = 0x2 + // .. .. ==> 0XF800607C[15:12] = 0x00000002U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00002000U + // .. .. reg_ddrc_t_ckcsx = 0x3 + // .. .. ==> 0XF800607C[19:16] = 0x00000003U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00030000U + // .. .. + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU ,0x00032222U), + // .. .. reg_ddrc_dis_auto_zq = 0x0 + // .. .. ==> 0XF80060A4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_ddr3 = 0x1 + // .. .. ==> 0XF80060A4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reg_ddrc_t_mod = 0x200 + // .. .. ==> 0XF80060A4[11:2] = 0x00000200U + // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U + // .. .. reg_ddrc_t_zq_long_nop = 0x200 + // .. .. ==> 0XF80060A4[21:12] = 0x00000200U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U + // .. .. reg_ddrc_t_zq_short_nop = 0x40 + // .. .. ==> 0XF80060A4[31:22] = 0x00000040U + // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U), + // .. .. t_zq_short_interval_x1024 = 0xcb73 + // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U + // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U + // .. .. dram_rstn_x1024 = 0x69 + // .. .. ==> 0XF80060A8[27:20] = 0x00000069U + // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U + // .. .. + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U), + // .. .. deeppowerdown_en = 0x0 + // .. .. ==> 0XF80060AC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. deeppowerdown_to_x1024 = 0xff + // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU + // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU + // .. .. + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU), + // .. .. dfi_wrlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU + // .. .. dfi_rdlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U + // .. .. ddrc_reg_twrlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. ddrc_reg_trdlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_dfi_wr_level_en = 0x1 + // .. .. ==> 0XF80060B0[26:26] = 0x00000001U + // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF80060B0[27:27] = 0x00000001U + // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1 + // .. .. ==> 0XF80060B0[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU), + // .. .. reg_ddrc_skip_ocd = 0x1 + // .. .. ==> 0XF80060B4[9:9] = 0x00000001U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. .. + EMIT_MASKWRITE(0XF80060B4, 0x00000200U ,0x00000200U), + // .. .. reg_ddrc_dfi_t_rddata_en = 0x6 + // .. .. ==> 0XF80060B8[4:0] = 0x00000006U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U + // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3 + // .. .. ==> 0XF80060B8[14:5] = 0x00000003U + // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U + // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40 + // .. .. ==> 0XF80060B8[24:15] = 0x00000040U + // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U), + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. Clear_Correctable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U), + // .. .. CORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060C8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. ECC_CORRECTED_BIT_NUM = 0x0 + // .. .. ==> 0XF80060C8[7:1] = 0x00000000U + // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U), + // .. .. UNCORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060DC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U), + // .. .. STAT_NUM_CORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[15:8] = 0x00000000U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U + // .. .. STAT_NUM_UNCORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[7:0] = 0x00000000U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U), + // .. .. reg_ddrc_ecc_mode = 0x0 + // .. .. ==> 0XF80060F4[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_dis_scrub = 0x1 + // .. .. ==> 0XF80060F4[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U), + // .. .. reg_phy_dif_on = 0x0 + // .. .. ==> 0XF8006114[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_dif_off = 0x0 + // .. .. ==> 0XF8006114[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006118[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006118[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006118[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006118[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF800611C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF800611C[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF800611C[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF800611C[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006120[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006124[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006124[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006124[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006124[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF800612C[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x9c + // .. .. ==> 0XF800612C[19:10] = 0x0000009CU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027000U + // .. .. + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00027000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006130[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x9c + // .. .. ==> 0XF8006130[19:10] = 0x0000009CU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027000U + // .. .. + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00027000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006134[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x9b + // .. .. ==> 0XF8006134[19:10] = 0x0000009BU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00026C00U + // .. .. + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x00026C00U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006138[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0xa2 + // .. .. ==> 0XF8006138[19:10] = 0x000000A2U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00028800U + // .. .. + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x00028800U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006140[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006140[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006140[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006144[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006144[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006144[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006148[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006148[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006148[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF800614C[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF800614C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800614C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x7a + // .. .. ==> 0XF8006154[9:0] = 0x0000007AU + // .. .. ==> MASK : 0x000003FFU VAL : 0x0000007AU + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006154[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006154[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x0000007AU), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x7a + // .. .. ==> 0XF8006158[9:0] = 0x0000007AU + // .. .. ==> MASK : 0x000003FFU VAL : 0x0000007AU + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006158[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006158[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x0000007AU), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x7c + // .. .. ==> 0XF800615C[9:0] = 0x0000007CU + // .. .. ==> MASK : 0x000003FFU VAL : 0x0000007CU + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF800615C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800615C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x0000007CU), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x73 + // .. .. ==> 0XF8006160[9:0] = 0x00000073U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000073U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006160[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006160[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000073U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf1 + // .. .. ==> 0XF8006168[10:0] = 0x000000F1U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F1U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006168[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006168[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000F1U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf1 + // .. .. ==> 0XF800616C[10:0] = 0x000000F1U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F1U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF800616C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF800616C[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000F1U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf0 + // .. .. ==> 0XF8006170[10:0] = 0x000000F0U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F0U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006170[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006170[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000F0U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf7 + // .. .. ==> 0XF8006174[10:0] = 0x000000F7U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F7U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006174[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006174[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000F7U), + // .. .. reg_phy_wr_data_slave_ratio = 0xba + // .. .. ==> 0XF800617C[9:0] = 0x000000BAU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000BAU + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF800617C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF800617C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000BAU), + // .. .. reg_phy_wr_data_slave_ratio = 0xba + // .. .. ==> 0XF8006180[9:0] = 0x000000BAU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000BAU + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006180[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006180[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000BAU), + // .. .. reg_phy_wr_data_slave_ratio = 0xbc + // .. .. ==> 0XF8006184[9:0] = 0x000000BCU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000BCU + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006184[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006184[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000BCU), + // .. .. reg_phy_wr_data_slave_ratio = 0xb3 + // .. .. ==> 0XF8006188[9:0] = 0x000000B3U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000B3U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006188[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006188[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000B3U), + // .. .. reg_phy_bl2 = 0x0 + // .. .. ==> 0XF8006190[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_at_spd_atpg = 0x0 + // .. .. ==> 0XF8006190[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_bist_enable = 0x0 + // .. .. ==> 0XF8006190[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_force_err = 0x0 + // .. .. ==> 0XF8006190[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_bist_mode = 0x0 + // .. .. ==> 0XF8006190[6:5] = 0x00000000U + // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. .. reg_phy_invert_clkout = 0x1 + // .. .. ==> 0XF8006190[7:7] = 0x00000001U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. .. reg_phy_sel_logic = 0x0 + // .. .. ==> 0XF8006190[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_ratio = 0x100 + // .. .. ==> 0XF8006190[19:10] = 0x00000100U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U + // .. .. reg_phy_ctrl_slave_force = 0x0 + // .. .. ==> 0XF8006190[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006190[27:21] = 0x00000000U + // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U + // .. .. reg_phy_lpddr = 0x0 + // .. .. ==> 0XF8006190[29:29] = 0x00000000U + // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. .. reg_phy_cmd_latency = 0x0 + // .. .. ==> 0XF8006190[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU ,0x00040080U), + // .. .. reg_phy_wr_rl_delay = 0x2 + // .. .. ==> 0XF8006194[4:0] = 0x00000002U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U + // .. .. reg_phy_rd_rl_delay = 0x4 + // .. .. ==> 0XF8006194[9:5] = 0x00000004U + // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U + // .. .. reg_phy_dll_lock_diff = 0xf + // .. .. ==> 0XF8006194[13:10] = 0x0000000FU + // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U + // .. .. reg_phy_use_wr_level = 0x1 + // .. .. ==> 0XF8006194[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. reg_phy_use_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF8006194[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. reg_phy_use_rd_data_eye_level = 0x1 + // .. .. ==> 0XF8006194[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_dis_calib_rst = 0x0 + // .. .. ==> 0XF8006194[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006194[19:18] = 0x00000000U + // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U), + // .. .. reg_arb_page_addr_mask = 0x0 + // .. .. ==> 0XF8006204[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006208[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006208[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006208[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006208[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006208, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF800620C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF800620C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF800620C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF800620C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800620C, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006210[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006210[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006210[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006210[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006210, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006214[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006214[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006214[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006214[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006214, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006218[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006218[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006218[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006218[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006218[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF800621C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF800621C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF800621C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF800621C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF800621C[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006220[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006220[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006220[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006220[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006220[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006224[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006224[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006224[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006224[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006224[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU), + // .. .. reg_ddrc_lpddr2 = 0x0 + // .. .. ==> 0XF80062A8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_derate_enable = 0x0 + // .. .. ==> 0XF80062A8[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_ddrc_mr4_margin = 0x0 + // .. .. ==> 0XF80062A8[11:4] = 0x00000000U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U ,0x00000000U), + // .. .. reg_ddrc_mr4_read_interval = 0x0 + // .. .. ==> 0XF80062AC[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_ddrc_min_stable_clock_x1 = 0x5 + // .. .. ==> 0XF80062B0[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_idle_after_reset_x32 = 0x12 + // .. .. ==> 0XF80062B0[11:4] = 0x00000012U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U + // .. .. reg_ddrc_t_mrw = 0x5 + // .. .. ==> 0XF80062B0[21:12] = 0x00000005U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U), + // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8 + // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U + // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U + // .. .. reg_ddrc_dev_zqinit_x32 = 0x12 + // .. .. ==> 0XF80062B4[17:8] = 0x00000012U + // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U + // .. .. + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U), + // .. .. START: POLL ON DCI STATUS + // .. .. DONE = 1 + // .. .. ==> 0XF8000B74[13:13] = 0x00000001U + // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U + // .. .. + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + // .. .. FINISH: POLL ON DCI STATUS + // .. .. START: UNLOCK DDR + // .. .. reg_ddrc_soft_rstb = 0x1 + // .. .. ==> 0XF8006000[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000081U), + // .. .. FINISH: UNLOCK DDR + // .. .. START: CHECK DDR STATUS + // .. .. ddrc_reg_operating_mode = 1 + // .. .. ==> 0XF8006054[2:0] = 0x00000001U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U + // .. .. + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + // .. .. FINISH: CHECK DDR STATUS + // .. FINISH: DDR INITIALIZATION + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_mio_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: OCM REMAPPING + // .. FINISH: OCM REMAPPING + // .. START: DDRIOB SETTINGS + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B40[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B40[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B40[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B40[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B40[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B40[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B40[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B44[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B44[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B44[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B44[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B44[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B44[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B44[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B48[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B48[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B48[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B48[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B48[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B48[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B48[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B4C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B4C[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B4C[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B4C[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B4C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B4C[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B4C[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000672U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B50[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B50[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B50[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B50[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B50[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B50[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B50[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B54[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B54[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B54[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B54[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B54[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B54[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B54[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000674U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B58[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B58[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B58[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B58[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B58[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B58[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B58[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B5C[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B5C[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x3 + // .. ==> 0XF8000B5C[18:14] = 0x00000003U + // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U + // .. reserved_SLEW_N = 0x3 + // .. ==> 0XF8000B5C[23:19] = 0x00000003U + // .. ==> MASK : 0x00F80000U VAL : 0x00180000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B5C[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B5C[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B60[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B60[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B60[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B60[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B60[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B60[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B64[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B64[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B64[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B64[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B64[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B64[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B68[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B68[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B68[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B68[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B68[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B68[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U), + // .. VREF_INT_EN = 0x0 + // .. ==> 0XF8000B6C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. VREF_SEL = 0x0 + // .. ==> 0XF8000B6C[4:1] = 0x00000000U + // .. ==> MASK : 0x0000001EU VAL : 0x00000000U + // .. VREF_EXT_EN = 0x3 + // .. ==> 0XF8000B6C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. reserved_VREF_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[8:7] = 0x00000000U + // .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. REFIO_EN = 0x1 + // .. ==> 0XF8000B6C[9:9] = 0x00000001U + // .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. reserved_REFIO_TEST = 0x0 + // .. ==> 0XF8000B6C[11:10] = 0x00000000U + // .. ==> MASK : 0x00000C00U VAL : 0x00000000U + // .. reserved_REFIO_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. reserved_DRST_B_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. reserved_CKE_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[14:14] = 0x00000000U + // .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU ,0x00000260U), + // .. .. START: ASSERT RESET + // .. .. RESET = 1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000001U ,0x00000001U), + // .. .. FINISH: ASSERT RESET + // .. .. START: DEASSERT RESET + // .. .. RESET = 0 + // .. .. ==> 0XF8000B70[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reserved_VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U), + // .. .. FINISH: DEASSERT RESET + // .. .. RESET = 0x1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. ENABLE = 0x1 + // .. .. ==> 0XF8000B70[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reserved_VRP_TRI = 0x0 + // .. .. ==> 0XF8000B70[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reserved_VRN_TRI = 0x0 + // .. .. ==> 0XF8000B70[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reserved_VRP_OUT = 0x0 + // .. .. ==> 0XF8000B70[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reserved_VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. NREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[7:6] = 0x00000000U + // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. .. NREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[10:8] = 0x00000000U + // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U + // .. .. NREF_OPT4 = 0x1 + // .. .. ==> 0XF8000B70[13:11] = 0x00000001U + // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U + // .. .. PREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[15:14] = 0x00000000U + // .. .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. .. PREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[19:17] = 0x00000000U + // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U + // .. .. UPDATE_CONTROL = 0x0 + // .. .. ==> 0XF8000B70[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reserved_INIT_COMPLETE = 0x0 + // .. .. ==> 0XF8000B70[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. reserved_TST_CLK = 0x0 + // .. .. ==> 0XF8000B70[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reserved_TST_HLN = 0x0 + // .. .. ==> 0XF8000B70[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reserved_TST_HLP = 0x0 + // .. .. ==> 0XF8000B70[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. reserved_TST_RST = 0x0 + // .. .. ==> 0XF8000B70[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reserved_INT_DCI_EN = 0x0 + // .. .. ==> 0XF8000B70[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU ,0x00000823U), + // .. FINISH: DDRIOB SETTINGS + // .. START: MIO PROGRAMMING + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000700[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000700[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000700[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000700[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000700[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000700[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000700[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000700[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000700[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000704[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000704[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000704[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000704[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000704[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000704[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000704[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000704[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000704[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000708[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000708[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000708[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000708[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000708[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000708[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000708[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000708[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000708[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800070C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800070C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800070C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800070C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800070C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800070C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800070C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800070C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800070C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000710[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000710[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000710[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000710[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000710[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000710[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000710[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000710[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000710[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000714[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000714[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000714[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000714[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000714[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000714[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000714[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000714[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000714[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000718[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000718[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000718[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000718[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000718[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000718[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000718[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000718[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000718[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800071C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800071C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800071C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800071C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800071C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800071C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800071C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800071C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800071C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000720[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000720[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000720[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000720[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000720[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000720[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000720[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000720[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000720[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000724[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000724[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000724[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000724[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000724[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000724[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000724[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000724[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000724[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000728[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000728[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000728[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000728[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000728[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000728[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000728[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000728[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000728[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800072C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800072C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800072C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800072C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800072C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800072C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800072C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800072C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800072C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000730[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000730[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000730[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000730[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000730[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000730[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000730[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000730[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000730[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000734[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000734[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000734[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000734[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000734[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000734[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000734[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000734[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000734[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000738[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000738[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000738[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000738[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000738[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000738[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000738[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000738[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000738[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800073C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800073C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800073C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800073C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800073C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800073C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800073C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800073C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800073C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000740[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000740[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000740[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000740[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000740[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000740[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000740[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000740[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000740[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU ,0x00001302U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000744[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000744[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000744[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000744[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000744[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000744[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000744[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000744[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000744[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU ,0x00001302U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000748[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000748[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000748[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000748[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000748[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000748[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000748[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000748[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000748[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU ,0x00001302U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800074C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800074C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800074C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800074C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800074C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF800074C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF800074C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800074C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800074C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU ,0x00001302U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000750[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000750[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000750[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000750[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000750[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000750[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000750[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000750[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000750[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU ,0x00001302U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000754[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000754[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000754[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000754[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000754[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000754[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000754[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000754[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000754[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU ,0x00001302U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000758[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000758[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000758[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000758[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000758[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000758[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000758[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000758[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000758[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU ,0x00001303U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800075C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800075C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800075C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800075C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800075C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF800075C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF800075C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800075C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800075C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU ,0x00001303U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000760[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000760[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000760[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000760[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000760[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000760[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000760[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000760[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000760[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU ,0x00001303U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000764[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000764[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000764[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000764[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000764[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000764[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000764[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000764[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000764[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU ,0x00001303U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000768[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000768[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000768[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000768[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000768[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000768[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000768[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000768[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000768[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU ,0x00001303U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800076C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800076C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800076C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800076C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800076C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF800076C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF800076C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800076C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800076C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU ,0x00001303U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000770[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000770[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000770[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000770[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000770[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000770[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000770[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000770[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000770[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000774[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000774[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000774[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000774[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000774[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000774[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000774[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000774[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000774[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001305U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000778[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000778[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000778[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000778[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000778[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000778[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000778[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000778[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000778[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800077C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF800077C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800077C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800077C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800077C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF800077C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF800077C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800077C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800077C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001305U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000780[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000780[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000780[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000780[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000780[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000780[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000780[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000780[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000780[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000784[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000784[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000784[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000784[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000784[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000784[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000784[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000784[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000784[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000788[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000788[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000788[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000788[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000788[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000788[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000788[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000788[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000788[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800078C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800078C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800078C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800078C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800078C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF800078C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF800078C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800078C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800078C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000790[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000790[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000790[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000790[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000790[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000790[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000790[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000790[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000790[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001305U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000794[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000794[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000794[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000794[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000794[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000794[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000794[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000794[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000794[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000798[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000798[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000798[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000798[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000798[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF8000798[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF8000798[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000798[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000798[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800079C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800079C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800079C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800079C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800079C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 1 + // .. ==> 0XF800079C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. IO_Type = 1 + // .. ==> 0XF800079C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800079C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800079C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001304U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A8[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007AC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007AC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007AC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007AC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007AC[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007AC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007AC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007AC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007AC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007B8[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007B8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007BC[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. Speed = 0 + // .. ==> 0XF80007BC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007BC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007BC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007BC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007BC, 0x00003F01U ,0x00001201U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C0[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000012E0U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007C4[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF80007C4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C4[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000012E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007C8[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007C8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007CC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007CC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007CC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007CC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007CC[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007CC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007CC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007CC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007CC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001280U), + // .. SDIO0_WP_SEL = 55 + // .. ==> 0XF8000830[5:0] = 0x00000037U + // .. ==> MASK : 0x0000003FU VAL : 0x00000037U + // .. SDIO0_CD_SEL = 47 + // .. ==> 0XF8000830[21:16] = 0x0000002FU + // .. ==> MASK : 0x003F0000U VAL : 0x002F0000U + // .. + EMIT_MASKWRITE(0XF8000830, 0x003F003FU ,0x002F0037U), + // .. FINISH: MIO PROGRAMMING + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_peripherals_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000180U), + // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // .. START: SRAM/NOR SET OPMODE + // .. FINISH: SRAM/NOR SET OPMODE + // .. START: UART REGISTERS + // .. BDIV = 0x6 + // .. ==> 0XE0001034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0001018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0001000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0001000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0001000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0001000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0001000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0001000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0001000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0001000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0001000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U), + // .. CHMODE = 0x0 + // .. ==> 0XE0001004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0001004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0001004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0001004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0001004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0001004, 0x000003FFU ,0x00000020U), + // .. FINISH: UART REGISTERS + // .. START: QSPI REGISTERS + // .. Holdb_dr = 1 + // .. ==> 0XE000D000[19:19] = 0x00000001U + // .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. + EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U), + // .. FINISH: QSPI REGISTERS + // .. START: PL POWER ON RESET REGISTERS + // .. PCFG_POR_CNT_4K = 0 + // .. ==> 0XF8007000[29:29] = 0x00000000U + // .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U), + // .. FINISH: PL POWER ON RESET REGISTERS + // .. START: SMC TIMING CALCULATION REGISTER UPDATE + // .. .. START: NAND SET CYCLE + // .. .. FINISH: NAND SET CYCLE + // .. .. START: OPMODE + // .. .. FINISH: OPMODE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: SRAM/NOR CS0 SET CYCLE + // .. .. FINISH: SRAM/NOR CS0 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS0 BASE ADDRESS + // .. .. FINISH: NOR CS0 BASE ADDRESS + // .. .. START: SRAM/NOR CS1 SET CYCLE + // .. .. FINISH: SRAM/NOR CS1 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS1 BASE ADDRESS + // .. .. FINISH: NOR CS1 BASE ADDRESS + // .. .. START: USB RESET + // .. .. .. START: USB0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. DIRECTION_1 = 0x4000 + // .. .. .. .. ==> 0XE000A244[21:0] = 0x00004000U + // .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU ,0x00004000U), + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. MASK_1_LSW = 0xbfff + // .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U + // .. .. .. .. DATA_1_LSW = 0x4000 + // .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU ,0xBFFF4000U), + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. OP_ENABLE_1 = 0x4000 + // .. .. .. .. ==> 0XE000A248[21:0] = 0x00004000U + // .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU ,0x00004000U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. MASK_1_LSW = 0xbfff + // .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U + // .. .. .. .. DATA_1_LSW = 0x0 + // .. .. .. .. ==> 0XE000A008[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU ,0xBFFF0000U), + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. MASK_1_LSW = 0xbfff + // .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U + // .. .. .. .. DATA_1_LSW = 0x4000 + // .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU ,0xBFFF4000U), + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB0 RESET + // .. .. FINISH: USB RESET + // .. .. START: ENET RESET + // .. .. FINISH: ENET RESET + // .. .. START: I2C RESET + // .. .. FINISH: I2C RESET + // .. .. START: NOR CHIP SELECT + // .. .. .. START: DIR MODE BANK 0 + // .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. FINISH: NOR CHIP SELECT + // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_post_config_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: ENABLING LEVEL SHIFTER + // .. USER_LVL_INP_EN_0 = 1 + // .. ==> 0XF8000900[3:3] = 0x00000001U + // .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. USER_LVL_OUT_EN_0 = 1 + // .. ==> 0XF8000900[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. USER_LVL_INP_EN_1 = 1 + // .. ==> 0XF8000900[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. USER_LVL_OUT_EN_1 = 1 + // .. ==> 0XF8000900[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU), + // .. FINISH: ENABLING LEVEL SHIFTER + // .. START: FPGA RESETS TO 0 + // .. reserved_3 = 0 + // .. ==> 0XF8000240[31:25] = 0x00000000U + // .. ==> MASK : 0xFE000000U VAL : 0x00000000U + // .. reserved_FPGA_ACP_RST = 0 + // .. ==> 0XF8000240[24:24] = 0x00000000U + // .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS3_RST = 0 + // .. ==> 0XF8000240[23:23] = 0x00000000U + // .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS2_RST = 0 + // .. ==> 0XF8000240[22:22] = 0x00000000U + // .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS1_RST = 0 + // .. ==> 0XF8000240[21:21] = 0x00000000U + // .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS0_RST = 0 + // .. ==> 0XF8000240[20:20] = 0x00000000U + // .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. reserved_2 = 0 + // .. ==> 0XF8000240[19:18] = 0x00000000U + // .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. reserved_FSSW1_FPGA_RST = 0 + // .. ==> 0XF8000240[17:17] = 0x00000000U + // .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. reserved_FSSW0_FPGA_RST = 0 + // .. ==> 0XF8000240[16:16] = 0x00000000U + // .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. reserved_1 = 0 + // .. ==> 0XF8000240[15:14] = 0x00000000U + // .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. reserved_FPGA_FMSW1_RST = 0 + // .. ==> 0XF8000240[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. reserved_FPGA_FMSW0_RST = 0 + // .. ==> 0XF8000240[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. reserved_FPGA_DMA3_RST = 0 + // .. ==> 0XF8000240[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. reserved_FPGA_DMA2_RST = 0 + // .. ==> 0XF8000240[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. reserved_FPGA_DMA1_RST = 0 + // .. ==> 0XF8000240[9:9] = 0x00000000U + // .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. reserved_FPGA_DMA0_RST = 0 + // .. ==> 0XF8000240[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. reserved = 0 + // .. ==> 0XF8000240[7:4] = 0x00000000U + // .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. FPGA3_OUT_RST = 0 + // .. ==> 0XF8000240[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. FPGA2_OUT_RST = 0 + // .. ==> 0XF8000240[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. FPGA1_OUT_RST = 0 + // .. ==> 0XF8000240[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. FPGA0_OUT_RST = 0 + // .. ==> 0XF8000240[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U), + // .. FINISH: FPGA RESETS TO 0 + // .. START: AFI REGISTERS + // .. .. START: AFI0 REGISTERS + // .. .. FINISH: AFI0 REGISTERS + // .. .. START: AFI1 REGISTERS + // .. .. FINISH: AFI1 REGISTERS + // .. .. START: AFI2 REGISTERS + // .. .. FINISH: AFI2 REGISTERS + // .. .. START: AFI3 REGISTERS + // .. .. FINISH: AFI3 REGISTERS + // .. .. START: AFI2 SECURE REGISTER + // .. .. FINISH: AFI2 SECURE REGISTER + // .. FINISH: AFI REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + + +#include "xil_io.h" + +unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; +unsigned long *ps7_pll_init_data = ps7_pll_init_data_3_0; +unsigned long *ps7_clock_init_data = ps7_clock_init_data_3_0; +unsigned long *ps7_ddr_init_data = ps7_ddr_init_data_3_0; +unsigned long *ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + +int +ps7_post_config() +{ + int ret = -1; + // Silicon version 3 + ret = ps7_config (ps7_post_config_3_0); + if (ret != PS7_INIT_SUCCESS) return ret; + + return PS7_INIT_SUCCESS; +} + + +int +ps7_init() +{ + int ret; + + // Silicon version 3 + ps7_mio_init_data = ps7_mio_init_data_3_0; + ps7_pll_init_data = ps7_pll_init_data_3_0; + ps7_clock_init_data = ps7_clock_init_data_3_0; + ps7_ddr_init_data = ps7_ddr_init_data_3_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + + // MIO init + ret = ps7_config (ps7_mio_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // PLL init + ret = ps7_config (ps7_pll_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // Clock init + ret = ps7_config (ps7_clock_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // DDR init + ret = ps7_config (ps7_ddr_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + + + // Peripherals init + ret = ps7_config (ps7_peripherals_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + //xil_printf ("\n PCW Silicon Version : %d.0", pcw_ver); + return PS7_INIT_SUCCESS; +} +
On 13.7.2018 17:44, Luis Araneda wrote:
Procedure to generate the "ps7_init_gpl.c" file:
- Install Vivado Webpack 2018.2
- Download digilent/vivado-boards repository (commit 6a45981 from 2018-06-05)
- Install board files: https://reference.digilentinc.com/vivado/installing-vivado/start#installing_...
- Start Vivado and create a new RTL project with the Zybo-z7-20 board
- Create a block design
- Add "ZYNQ7 Processing System" IP
- Run "Block Automation" (Check "Apply Board Preset")
- Connect ports FCLK_CLK0 and M_AXI_GP0_ACLK
- Save diagram changes
- Go to sources view, select the block diagram, and select "Generate Output Products"
- Copy the generated "ps7_init_gpl.c" file
- Manual editions to "ps7_init_gpl.c" file:
- Replace license header by SPDX identifier
- Replicate changes made by commit a3b36c8 (arm: zynq: Remove ps7_debug code)
- Remove array "ps7_debug_3_0"
- Remove array "ps7_debug_2_0"
- Remove array "ps7_debug_1_0"
- Remove function "ps7_debug"
- Replicate changes made by commit a3b36c8 (arm: zynq: Convert all board to use arch ps7_init code)
- Modify the inclusion of "ps7_init_gpl.h"
- Remove "PS7_MASK_POLL_TIME" macro
- Remove "getPS7MessageInfo" function
- Remove "ps7GetSiliconVersion" function
- Remove "mask_write" function
- Remove "mask_poll" function
- Remove "mask_read" function
- Remove "ps7_config" function
- Remove "perf_start_clock" function
- Remove "perf_reset_clock" function
- Remove "get_number_of_cycles_for_delay" function
- Remove "perf_disable_clock" function
- Remove "perf_reset_and_start_timer" function
- Remove functions/data related to silicon v1/v2:
- Array "ps7_mio_init_data_2_0"
- Array "ps7_pll_init_data_2_0"
- Array "ps7_clock_init_data_2_0"
- Array "ps7_ddr_init_data_2_0"
- Array "ps7_peripherals_init_data_2_0"
- Array "ps7_post_config_2_0"
- Array "ps7_mio_init_data_1_0"
- Array "ps7_pll_init_data_1_0"
- Array "ps7_clock_init_data_1_0"
- Array "ps7_ddr_init_data_1_0"
- Array "ps7_peripherals_init_data_1_0"
- Array "ps7_post_config_1_0"
Signed-off-by: Luis Araneda luaraneda@gmail.com
board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c | 3959 +++++++++++++++++ 1 file changed, 3959 insertions(+) create mode 100644 board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c
diff --git a/board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c new file mode 100644 index 0000000000..44c1cfe893 --- /dev/null +++ b/board/xilinx/zynq/zynq-zybo-z7/ps7_init_gpl.c @@ -0,0 +1,3959 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved.
+#include <asm/arch/ps7_init_gpl.h>
+unsigned long ps7_pll_init_data_3_0[] = {
- // START: top
- // .. START: SLCR SETTINGS
- // .. UNLOCK_KEY = 0XDF0D
- // .. ==> 0XF8000008[15:0] = 0x0000DF0DU
- // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU
- EMIT_WRITE(0XF8000008, 0x0000DF0DU),
- // .. FINISH: SLCR SETTINGS
- // .. START: PLL SLCR REGISTERS
- // .. .. START: ARM PLL INIT
- // .. .. PLL_RES = 0x2
- // .. .. ==> 0XF8000110[7:4] = 0x00000002U
- // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U
- // .. .. PLL_CP = 0x2
- // .. .. ==> 0XF8000110[11:8] = 0x00000002U
- // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U
- // .. .. LOCK_CNT = 0xfa
- // .. .. ==> 0XF8000110[21:12] = 0x000000FAU
- // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U
- EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U),
- // .. .. .. START: UPDATE FB_DIV
- // .. .. .. PLL_FDIV = 0x28
- // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U
- // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U
- EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U),
- // .. .. .. FINISH: UPDATE FB_DIV
- // .. .. .. START: BY PASS PLL
- // .. .. .. PLL_BYPASS_FORCE = 1
- // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U
- // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U
- EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U),
- // .. .. .. FINISH: BY PASS PLL
- // .. .. .. START: ASSERT RESET
- // .. .. .. PLL_RESET = 1
- // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U
- // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U
- EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U),
- // .. .. .. FINISH: ASSERT RESET
- // .. .. .. START: DEASSERT RESET
- // .. .. .. PLL_RESET = 0
- // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U
- // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U),
- // .. .. .. FINISH: DEASSERT RESET
- // .. .. .. START: CHECK PLL STATUS
- // .. .. .. ARM_PLL_LOCK = 1
- // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U
- EMIT_MASKPOLL(0XF800010C, 0x00000001U),
- // .. .. .. FINISH: CHECK PLL STATUS
- // .. .. .. START: REMOVE PLL BY PASS
- // .. .. .. PLL_BYPASS_FORCE = 0
- // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U
- // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U),
- // .. .. .. FINISH: REMOVE PLL BY PASS
- // .. .. .. SRCSEL = 0x0
- // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U
- // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U
- // .. .. .. DIVISOR = 0x2
- // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U
- // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U
- // .. .. .. CPU_6OR4XCLKACT = 0x1
- // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U
- // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U
- // .. .. .. CPU_3OR2XCLKACT = 0x1
- // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U
- // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U
- // .. .. .. CPU_2XCLKACT = 0x1
- // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U
- // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U
- // .. .. .. CPU_1XCLKACT = 0x1
- // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U
- // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U
- // .. .. .. CPU_PERI_CLKACT = 0x1
- // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U
- // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U
- EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U),
- // .. .. FINISH: ARM PLL INIT
- // .. .. START: DDR PLL INIT
- // .. .. ==> 0XF8000114[7:4] = 0x00000002U
- // .. .. ==> 0XF8000114[11:8] = 0x00000002U
- // .. .. LOCK_CNT = 0x12c
- // .. .. ==> 0XF8000114[21:12] = 0x0000012CU
- // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U
- EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U),
- // .. .. .. PLL_FDIV = 0x20
- // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U
- // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U
- EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U),
- // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U
- EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U),
- // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U
- EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U),
- // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U
- EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U),
- // .. .. .. DDR_PLL_LOCK = 1
- // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U
- // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U
- EMIT_MASKPOLL(0XF800010C, 0x00000002U),
- // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U
- EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U),
- // .. .. .. DDR_3XCLKACT = 0x1
- // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U
- // .. .. .. DDR_2XCLKACT = 0x1
- // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U
- // .. .. .. DDR_3XCLK_DIVISOR = 0x2
- // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U
- // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U
- // .. .. .. DDR_2XCLK_DIVISOR = 0x3
- // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U
- // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U
- EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U),
- // .. .. FINISH: DDR PLL INIT
- // .. .. START: IO PLL INIT
- // .. .. PLL_RES = 0xc
- // .. .. ==> 0XF8000118[7:4] = 0x0000000CU
- // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U
- // .. .. ==> 0XF8000118[11:8] = 0x00000002U
- // .. .. LOCK_CNT = 0x145
- // .. .. ==> 0XF8000118[21:12] = 0x00000145U
- // .. .. ==> MASK : 0x003FF000U VAL : 0x00145000U
- EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x001452C0U),
- // .. .. .. PLL_FDIV = 0x1e
- // .. .. .. ==> 0XF8000108[18:12] = 0x0000001EU
- // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0001E000U
- EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0001E000U),
- // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U
- EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U),
- // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U
- EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U),
- // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U
- EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U),
- // .. .. .. IO_PLL_LOCK = 1
- // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U
- // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U
- EMIT_MASKPOLL(0XF800010C, 0x00000004U),
- // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U
- EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U),
- // .. .. FINISH: IO PLL INIT
- // .. FINISH: PLL SLCR REGISTERS
- // .. START: LOCK IT BACK
- // .. LOCK_KEY = 0X767B
- // .. ==> 0XF8000004[15:0] = 0x0000767BU
- // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU
- EMIT_WRITE(0XF8000004, 0x0000767BU),
- // .. FINISH: LOCK IT BACK
- // FINISH: top
- EMIT_EXIT(),
+unsigned long ps7_clock_init_data_3_0[] = {
- // START: top
- // .. START: CLOCK CONTROL SLCR REGISTERS
- // .. CLKACT = 0x1
- // .. ==> 0XF8000128[0:0] = 0x00000001U
- // .. ==> MASK : 0x00000001U VAL : 0x00000001U
- // .. DIVISOR0 = 0xf
- // .. ==> 0XF8000128[13:8] = 0x0000000FU
- // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U
- // .. DIVISOR1 = 0x7
- // .. ==> 0XF8000128[25:20] = 0x00000007U
- // .. ==> MASK : 0x03F00000U VAL : 0x00700000U
- EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00700F01U),
- // .. ==> 0XF8000138[0:0] = 0x00000001U
- // .. SRCSEL = 0x0
- // .. ==> 0XF8000138[4:4] = 0x00000000U
- // .. ==> MASK : 0x00000010U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8000138, 0x00000011U ,0x00000001U),
- // .. ==> 0XF8000140[0:0] = 0x00000001U
- // .. ==> 0XF8000140[6:4] = 0x00000000U
- // .. ==> MASK : 0x00000070U VAL : 0x00000000U
- // .. DIVISOR = 0x8
- // .. ==> 0XF8000140[13:8] = 0x00000008U
- // .. ==> MASK : 0x00003F00U VAL : 0x00000800U
- // .. DIVISOR1 = 0x1
- // .. ==> 0XF8000140[25:20] = 0x00000001U
- // .. ==> MASK : 0x03F00000U VAL : 0x00100000U
- EMIT_MASKWRITE(0XF8000140, 0x03F03F71U ,0x00100801U),
- // .. ==> 0XF800014C[0:0] = 0x00000001U
- // .. ==> 0XF800014C[5:4] = 0x00000000U
- // .. ==> MASK : 0x00000030U VAL : 0x00000000U
- // .. DIVISOR = 0x5
- // .. ==> 0XF800014C[13:8] = 0x00000005U
- // .. ==> MASK : 0x00003F00U VAL : 0x00000500U
- EMIT_MASKWRITE(0XF800014C, 0x00003F31U ,0x00000501U),
- // .. CLKACT0 = 0x1
- // .. ==> 0XF8000150[0:0] = 0x00000001U
- // .. CLKACT1 = 0x0
- // .. ==> 0XF8000150[1:1] = 0x00000000U
- // .. ==> MASK : 0x00000002U VAL : 0x00000000U
- // .. ==> 0XF8000150[5:4] = 0x00000000U
- // .. DIVISOR = 0x14
- // .. ==> 0XF8000150[13:8] = 0x00000014U
- // .. ==> MASK : 0x00003F00U VAL : 0x00001400U
- EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00001401U),
- // .. CLKACT0 = 0x0
- // .. ==> 0XF8000154[0:0] = 0x00000000U
- // .. ==> MASK : 0x00000001U VAL : 0x00000000U
- // .. CLKACT1 = 0x1
- // .. ==> 0XF8000154[1:1] = 0x00000001U
- // .. ==> MASK : 0x00000002U VAL : 0x00000002U
- // .. ==> 0XF8000154[5:4] = 0x00000000U
- // .. DIVISOR = 0xa
- // .. ==> 0XF8000154[13:8] = 0x0000000AU
- // .. ==> MASK : 0x00003F00U VAL : 0x00000A00U
- EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000A02U),
- // .. .. START: TRACE CLOCK
- // .. .. FINISH: TRACE CLOCK
- // .. .. CLKACT = 0x1
- // .. .. ==> 0XF8000168[0:0] = 0x00000001U
- // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U
- // .. .. SRCSEL = 0x0
- // .. .. ==> 0XF8000168[5:4] = 0x00000000U
- // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U
- // .. .. DIVISOR = 0x5
- // .. .. ==> 0XF8000168[13:8] = 0x00000005U
- // .. .. ==> MASK : 0x00003F00U VAL : 0x00000500U
- EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000501U),
- // .. .. ==> 0XF8000170[5:4] = 0x00000000U
- // .. .. DIVISOR0 = 0x5
- // .. .. ==> 0XF8000170[13:8] = 0x00000005U
- // .. .. DIVISOR1 = 0x4
- // .. .. ==> 0XF8000170[25:20] = 0x00000004U
- // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U
- EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00400500U),
- // .. .. CLK_621_TRUE = 0x1
- // .. .. ==> 0XF80001C4[0:0] = 0x00000001U
- EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U),
- // .. .. DMA_CPU_2XCLKACT = 0x1
- // .. .. ==> 0XF800012C[0:0] = 0x00000001U
- // .. .. USB0_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[2:2] = 0x00000001U
- // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U
- // .. .. USB1_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[3:3] = 0x00000001U
- // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U
- // .. .. GEM0_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[6:6] = 0x00000001U
- // .. .. ==> MASK : 0x00000040U VAL : 0x00000040U
- // .. .. GEM1_CPU_1XCLKACT = 0x0
- // .. .. ==> 0XF800012C[7:7] = 0x00000000U
- // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U
- // .. .. SDI0_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[10:10] = 0x00000001U
- // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U
- // .. .. SDI1_CPU_1XCLKACT = 0x0
- // .. .. ==> 0XF800012C[11:11] = 0x00000000U
- // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U
- // .. .. SPI0_CPU_1XCLKACT = 0x0
- // .. .. ==> 0XF800012C[14:14] = 0x00000000U
- // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U
- // .. .. SPI1_CPU_1XCLKACT = 0x0
- // .. .. ==> 0XF800012C[15:15] = 0x00000000U
- // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U
- // .. .. CAN0_CPU_1XCLKACT = 0x0
- // .. .. ==> 0XF800012C[16:16] = 0x00000000U
- // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U
- // .. .. CAN1_CPU_1XCLKACT = 0x0
- // .. .. ==> 0XF800012C[17:17] = 0x00000000U
- // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U
- // .. .. I2C0_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[18:18] = 0x00000001U
- // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U
- // .. .. I2C1_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[19:19] = 0x00000001U
- // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U
- // .. .. UART0_CPU_1XCLKACT = 0x0
- // .. .. ==> 0XF800012C[20:20] = 0x00000000U
- // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U
- // .. .. UART1_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[21:21] = 0x00000001U
- // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U
- // .. .. GPIO_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[22:22] = 0x00000001U
- // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U
- // .. .. LQSPI_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[23:23] = 0x00000001U
- // .. .. ==> MASK : 0x00800000U VAL : 0x00800000U
- // .. .. SMC_CPU_1XCLKACT = 0x1
- // .. .. ==> 0XF800012C[24:24] = 0x00000001U
- // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U
- EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x01EC044DU),
- // .. FINISH: CLOCK CONTROL SLCR REGISTERS
- // .. START: THIS SHOULD BE BLANK
- // .. FINISH: THIS SHOULD BE BLANK
- // FINISH: top
- EMIT_EXIT(),
+unsigned long ps7_ddr_init_data_3_0[] = {
- // START: top
- // .. START: DDR INITIALIZATION
- // .. .. START: LOCK DDR
- // .. .. reg_ddrc_soft_rstb = 0
- // .. .. ==> 0XF8006000[0:0] = 0x00000000U
- // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U
- // .. .. reg_ddrc_powerdown_en = 0x0
- // .. .. ==> 0XF8006000[1:1] = 0x00000000U
- // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U
- // .. .. reg_ddrc_data_bus_width = 0x0
- // .. .. ==> 0XF8006000[3:2] = 0x00000000U
- // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U
- // .. .. reg_ddrc_burst8_refresh = 0x0
- // .. .. ==> 0XF8006000[6:4] = 0x00000000U
- // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U
- // .. .. reg_ddrc_rdwr_idle_gap = 0x1
- // .. .. ==> 0XF8006000[13:7] = 0x00000001U
- // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U
- // .. .. reg_ddrc_dis_rd_bypass = 0x0
- // .. .. ==> 0XF8006000[14:14] = 0x00000000U
- // .. .. reg_ddrc_dis_act_bypass = 0x0
- // .. .. ==> 0XF8006000[15:15] = 0x00000000U
- // .. .. reg_ddrc_dis_auto_refresh = 0x0
- // .. .. ==> 0XF8006000[16:16] = 0x00000000U
- EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000080U),
- // .. .. FINISH: LOCK DDR
- // .. .. reg_ddrc_t_rfc_nom_x32 = 0x81
- // .. .. ==> 0XF8006004[11:0] = 0x00000081U
- // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000081U
- // .. .. reserved_reg_ddrc_active_ranks = 0x1
- // .. .. ==> 0XF8006004[13:12] = 0x00000001U
- // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U
- // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0
- // .. .. ==> 0XF8006004[18:14] = 0x00000000U
- // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU ,0x00001081U),
- // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf
- // .. .. ==> 0XF8006008[10:0] = 0x0000000FU
- // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU
- // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf
- // .. .. ==> 0XF8006008[21:11] = 0x0000000FU
- // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U
- // .. .. reg_ddrc_hpr_xact_run_length = 0xf
- // .. .. ==> 0XF8006008[25:22] = 0x0000000FU
- // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U
- EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU),
- // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1
- // .. .. ==> 0XF800600C[10:0] = 0x00000001U
- // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U
- // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2
- // .. .. ==> 0XF800600C[21:11] = 0x00000002U
- // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U
- // .. .. reg_ddrc_lpr_xact_run_length = 0x8
- // .. .. ==> 0XF800600C[25:22] = 0x00000008U
- // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U
- EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U),
- // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1
- // .. .. ==> 0XF8006010[10:0] = 0x00000001U
- // .. .. reg_ddrc_w_xact_run_length = 0x8
- // .. .. ==> 0XF8006010[14:11] = 0x00000008U
- // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U
- // .. .. reg_ddrc_w_max_starve_x32 = 0x2
- // .. .. ==> 0XF8006010[25:15] = 0x00000002U
- // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U
- EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U),
- // .. .. reg_ddrc_t_rc = 0x1a
- // .. .. ==> 0XF8006014[5:0] = 0x0000001AU
- // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001AU
- // .. .. reg_ddrc_t_rfc_min = 0xa0
- // .. .. ==> 0XF8006014[13:6] = 0x000000A0U
- // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002800U
- // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10
- // .. .. ==> 0XF8006014[20:14] = 0x00000010U
- // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U
- EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004281AU),
- // .. .. reg_ddrc_wr2pre = 0x12
- // .. .. ==> 0XF8006018[4:0] = 0x00000012U
- // .. .. ==> MASK : 0x0000001FU VAL : 0x00000012U
- // .. .. reg_ddrc_powerdown_to_x32 = 0x6
- // .. .. ==> 0XF8006018[9:5] = 0x00000006U
- // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U
- // .. .. reg_ddrc_t_faw = 0x16
- // .. .. ==> 0XF8006018[15:10] = 0x00000016U
- // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U
- // .. .. reg_ddrc_t_ras_max = 0x24
- // .. .. ==> 0XF8006018[21:16] = 0x00000024U
- // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U
- // .. .. reg_ddrc_t_ras_min = 0x13
- // .. .. ==> 0XF8006018[26:22] = 0x00000013U
- // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U
- // .. .. reg_ddrc_t_cke = 0x4
- // .. .. ==> 0XF8006018[31:28] = 0x00000004U
- // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U
- EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D2U),
- // .. .. reg_ddrc_write_latency = 0x5
- // .. .. ==> 0XF800601C[4:0] = 0x00000005U
- // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U
- // .. .. reg_ddrc_rd2wr = 0x7
- // .. .. ==> 0XF800601C[9:5] = 0x00000007U
- // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U
- // .. .. reg_ddrc_wr2rd = 0xe
- // .. .. ==> 0XF800601C[14:10] = 0x0000000EU
- // .. .. ==> MASK : 0x00007C00U VAL : 0x00003800U
- // .. .. reg_ddrc_t_xp = 0x4
- // .. .. ==> 0XF800601C[19:15] = 0x00000004U
- // .. .. ==> MASK : 0x000F8000U VAL : 0x00020000U
- // .. .. reg_ddrc_pad_pd = 0x0
- // .. .. ==> 0XF800601C[22:20] = 0x00000000U
- // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U
- // .. .. reg_ddrc_rd2pre = 0x4
- // .. .. ==> 0XF800601C[27:23] = 0x00000004U
- // .. .. ==> MASK : 0x0F800000U VAL : 0x02000000U
- // .. .. reg_ddrc_t_rcd = 0x7
- // .. .. ==> 0XF800601C[31:28] = 0x00000007U
- // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U
- EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x720238E5U),
- // .. .. reg_ddrc_t_ccd = 0x4
- // .. .. ==> 0XF8006020[4:2] = 0x00000004U
- // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U
- // .. .. reg_ddrc_t_rrd = 0x6
- // .. .. ==> 0XF8006020[7:5] = 0x00000006U
- // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U
- // .. .. reg_ddrc_refresh_margin = 0x2
- // .. .. ==> 0XF8006020[11:8] = 0x00000002U
- // .. .. reg_ddrc_t_rp = 0x7
- // .. .. ==> 0XF8006020[15:12] = 0x00000007U
- // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U
- // .. .. reg_ddrc_refresh_to_x32 = 0x8
- // .. .. ==> 0XF8006020[20:16] = 0x00000008U
- // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U
- // .. .. reg_ddrc_mobile = 0x0
- // .. .. ==> 0XF8006020[22:22] = 0x00000000U
- // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U
- // .. .. reg_ddrc_en_dfi_dram_clk_disable = 0x0
- // .. .. ==> 0XF8006020[23:23] = 0x00000000U
- // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U
- // .. .. reg_ddrc_read_latency = 0x7
- // .. .. ==> 0XF8006020[28:24] = 0x00000007U
- // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U
- // .. .. reg_phy_mode_ddr1_ddr2 = 0x1
- // .. .. ==> 0XF8006020[29:29] = 0x00000001U
- // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U
- // .. .. reg_ddrc_dis_pad_pd = 0x0
- // .. .. ==> 0XF8006020[30:30] = 0x00000000U
- // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU ,0x270872D0U),
- // .. .. reg_ddrc_en_2t_timing_mode = 0x0
- // .. .. ==> 0XF8006024[0:0] = 0x00000000U
- // .. .. reg_ddrc_prefer_write = 0x0
- // .. .. ==> 0XF8006024[1:1] = 0x00000000U
- // .. .. reg_ddrc_mr_wr = 0x0
- // .. .. ==> 0XF8006024[6:6] = 0x00000000U
- // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U
- // .. .. reg_ddrc_mr_addr = 0x0
- // .. .. ==> 0XF8006024[8:7] = 0x00000000U
- // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U
- // .. .. reg_ddrc_mr_data = 0x0
- // .. .. ==> 0XF8006024[24:9] = 0x00000000U
- // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U
- // .. .. ddrc_reg_mr_wr_busy = 0x0
- // .. .. ==> 0XF8006024[25:25] = 0x00000000U
- // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U
- // .. .. reg_ddrc_mr_type = 0x0
- // .. .. ==> 0XF8006024[26:26] = 0x00000000U
- // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U
- // .. .. reg_ddrc_mr_rdata_valid = 0x0
- // .. .. ==> 0XF8006024[27:27] = 0x00000000U
- // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U ,0x00000000U),
- // .. .. reg_ddrc_final_wait_x32 = 0x7
- // .. .. ==> 0XF8006028[6:0] = 0x00000007U
- // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U
- // .. .. reg_ddrc_pre_ocd_x32 = 0x0
- // .. .. ==> 0XF8006028[10:7] = 0x00000000U
- // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U
- // .. .. reg_ddrc_t_mrd = 0x4
- // .. .. ==> 0XF8006028[13:11] = 0x00000004U
- // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U
- EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U),
- // .. .. reg_ddrc_emr2 = 0x8
- // .. .. ==> 0XF800602C[15:0] = 0x00000008U
- // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U
- // .. .. reg_ddrc_emr3 = 0x0
- // .. .. ==> 0XF800602C[31:16] = 0x00000000U
- // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U),
- // .. .. reg_ddrc_mr = 0x930
- // .. .. ==> 0XF8006030[15:0] = 0x00000930U
- // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000930U
- // .. .. reg_ddrc_emr = 0x4
- // .. .. ==> 0XF8006030[31:16] = 0x00000004U
- // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U
- EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040930U),
- // .. .. reg_ddrc_burst_rdwr = 0x4
- // .. .. ==> 0XF8006034[3:0] = 0x00000004U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U
- // .. .. reg_ddrc_pre_cke_x1024 = 0x16d
- // .. .. ==> 0XF8006034[13:4] = 0x0000016DU
- // .. .. ==> MASK : 0x00003FF0U VAL : 0x000016D0U
- // .. .. reg_ddrc_post_cke_x1024 = 0x1
- // .. .. ==> 0XF8006034[25:16] = 0x00000001U
- // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U
- // .. .. reg_ddrc_burstchop = 0x0
- // .. .. ==> 0XF8006034[28:28] = 0x00000000U
- // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x000116D4U),
- // .. .. reg_ddrc_force_low_pri_n = 0x0
- // .. .. ==> 0XF8006038[0:0] = 0x00000000U
- // .. .. reg_ddrc_dis_dq = 0x0
- // .. .. ==> 0XF8006038[1:1] = 0x00000000U
- EMIT_MASKWRITE(0XF8006038, 0x00000003U ,0x00000000U),
- // .. .. reg_ddrc_addrmap_bank_b0 = 0x7
- // .. .. ==> 0XF800603C[3:0] = 0x00000007U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000007U
- // .. .. reg_ddrc_addrmap_bank_b1 = 0x7
- // .. .. ==> 0XF800603C[7:4] = 0x00000007U
- // .. .. ==> MASK : 0x000000F0U VAL : 0x00000070U
- // .. .. reg_ddrc_addrmap_bank_b2 = 0x7
- // .. .. ==> 0XF800603C[11:8] = 0x00000007U
- // .. .. ==> MASK : 0x00000F00U VAL : 0x00000700U
- // .. .. reg_ddrc_addrmap_col_b5 = 0x0
- // .. .. ==> 0XF800603C[15:12] = 0x00000000U
- // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U
- // .. .. reg_ddrc_addrmap_col_b6 = 0x0
- // .. .. ==> 0XF800603C[19:16] = 0x00000000U
- // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000777U),
- // .. .. reg_ddrc_addrmap_col_b2 = 0x0
- // .. .. ==> 0XF8006040[3:0] = 0x00000000U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U
- // .. .. reg_ddrc_addrmap_col_b3 = 0x0
- // .. .. ==> 0XF8006040[7:4] = 0x00000000U
- // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U
- // .. .. reg_ddrc_addrmap_col_b4 = 0x0
- // .. .. ==> 0XF8006040[11:8] = 0x00000000U
- // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U
- // .. .. reg_ddrc_addrmap_col_b7 = 0x0
- // .. .. ==> 0XF8006040[15:12] = 0x00000000U
- // .. .. reg_ddrc_addrmap_col_b8 = 0x0
- // .. .. ==> 0XF8006040[19:16] = 0x00000000U
- // .. .. reg_ddrc_addrmap_col_b9 = 0xf
- // .. .. ==> 0XF8006040[23:20] = 0x0000000FU
- // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U
- // .. .. reg_ddrc_addrmap_col_b10 = 0xf
- // .. .. ==> 0XF8006040[27:24] = 0x0000000FU
- // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U
- // .. .. reg_ddrc_addrmap_col_b11 = 0xf
- // .. .. ==> 0XF8006040[31:28] = 0x0000000FU
- // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U
- EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFF00000U),
- // .. .. reg_ddrc_addrmap_row_b0 = 0x6
- // .. .. ==> 0XF8006044[3:0] = 0x00000006U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U
- // .. .. reg_ddrc_addrmap_row_b1 = 0x6
- // .. .. ==> 0XF8006044[7:4] = 0x00000006U
- // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U
- // .. .. reg_ddrc_addrmap_row_b2_11 = 0x6
- // .. .. ==> 0XF8006044[11:8] = 0x00000006U
- // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U
- // .. .. reg_ddrc_addrmap_row_b12 = 0x6
- // .. .. ==> 0XF8006044[15:12] = 0x00000006U
- // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U
- // .. .. reg_ddrc_addrmap_row_b13 = 0x6
- // .. .. ==> 0XF8006044[19:16] = 0x00000006U
- // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U
- // .. .. reg_ddrc_addrmap_row_b14 = 0x6
- // .. .. ==> 0XF8006044[23:20] = 0x00000006U
- // .. .. ==> MASK : 0x00F00000U VAL : 0x00600000U
- // .. .. reg_ddrc_addrmap_row_b15 = 0xf
- // .. .. ==> 0XF8006044[27:24] = 0x0000000FU
- EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F666666U),
- // .. .. reg_phy_rd_local_odt = 0x0
- // .. .. ==> 0XF8006048[13:12] = 0x00000000U
- // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U
- // .. .. reg_phy_wr_local_odt = 0x3
- // .. .. ==> 0XF8006048[15:14] = 0x00000003U
- // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U
- // .. .. reg_phy_idle_local_odt = 0x3
- // .. .. ==> 0XF8006048[17:16] = 0x00000003U
- // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U
- // .. .. reserved_reg_ddrc_rank0_wr_odt = 0x1
- // .. .. ==> 0XF8006048[5:3] = 0x00000001U
- // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U
- // .. .. reserved_reg_ddrc_rank0_rd_odt = 0x0
- // .. .. ==> 0XF8006048[2:0] = 0x00000000U
- // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006048, 0x0003F03FU ,0x0003C008U),
- // .. .. reg_phy_rd_cmd_to_data = 0x0
- // .. .. ==> 0XF8006050[3:0] = 0x00000000U
- // .. .. reg_phy_wr_cmd_to_data = 0x0
- // .. .. ==> 0XF8006050[7:4] = 0x00000000U
- // .. .. reg_phy_rdc_we_to_re_delay = 0x8
- // .. .. ==> 0XF8006050[11:8] = 0x00000008U
- // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U
- // .. .. reg_phy_rdc_fifo_rst_disable = 0x0
- // .. .. ==> 0XF8006050[15:15] = 0x00000000U
- // .. .. reg_phy_use_fixed_re = 0x1
- // .. .. ==> 0XF8006050[16:16] = 0x00000001U
- // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U
- // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0
- // .. .. ==> 0XF8006050[17:17] = 0x00000000U
- // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0
- // .. .. ==> 0XF8006050[18:18] = 0x00000000U
- // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U
- // .. .. reg_phy_clk_stall_level = 0x0
- // .. .. ==> 0XF8006050[19:19] = 0x00000000U
- // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U
- // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7
- // .. .. ==> 0XF8006050[27:24] = 0x00000007U
- // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U
- // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7
- // .. .. ==> 0XF8006050[31:28] = 0x00000007U
- EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U),
- // .. .. reg_ddrc_dis_dll_calib = 0x0
- // .. .. ==> 0XF8006058[16:16] = 0x00000000U
- EMIT_MASKWRITE(0XF8006058, 0x00010000U ,0x00000000U),
- // .. .. reg_ddrc_rd_odt_delay = 0x3
- // .. .. ==> 0XF800605C[3:0] = 0x00000003U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U
- // .. .. reg_ddrc_wr_odt_delay = 0x0
- // .. .. ==> 0XF800605C[7:4] = 0x00000000U
- // .. .. reg_ddrc_rd_odt_hold = 0x0
- // .. .. ==> 0XF800605C[11:8] = 0x00000000U
- // .. .. reg_ddrc_wr_odt_hold = 0x5
- // .. .. ==> 0XF800605C[15:12] = 0x00000005U
- // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U
- EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U),
- // .. .. reg_ddrc_pageclose = 0x0
- // .. .. ==> 0XF8006060[0:0] = 0x00000000U
- // .. .. reg_ddrc_lpr_num_entries = 0x1f
- // .. .. ==> 0XF8006060[6:1] = 0x0000001FU
- // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU
- // .. .. reg_ddrc_auto_pre_en = 0x0
- // .. .. ==> 0XF8006060[7:7] = 0x00000000U
- // .. .. reg_ddrc_refresh_update_level = 0x0
- // .. .. ==> 0XF8006060[8:8] = 0x00000000U
- // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U
- // .. .. reg_ddrc_dis_wc = 0x0
- // .. .. ==> 0XF8006060[9:9] = 0x00000000U
- // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U
- // .. .. reg_ddrc_dis_collision_page_opt = 0x0
- // .. .. ==> 0XF8006060[10:10] = 0x00000000U
- // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U
- // .. .. reg_ddrc_selfref_en = 0x0
- // .. .. ==> 0XF8006060[12:12] = 0x00000000U
- // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU),
- // .. .. reg_ddrc_go2critical_hysteresis = 0x0
- // .. .. ==> 0XF8006064[12:5] = 0x00000000U
- // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U
- // .. .. reg_arb_go2critical_en = 0x1
- // .. .. ==> 0XF8006064[17:17] = 0x00000001U
- // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U
- EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U),
- // .. .. reg_ddrc_wrlvl_ww = 0x41
- // .. .. ==> 0XF8006068[7:0] = 0x00000041U
- // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U
- // .. .. reg_ddrc_rdlvl_rr = 0x41
- // .. .. ==> 0XF8006068[15:8] = 0x00000041U
- // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U
- // .. .. reg_ddrc_dfi_t_wlmrd = 0x28
- // .. .. ==> 0XF8006068[25:16] = 0x00000028U
- // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U
- EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U),
- // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10
- // .. .. ==> 0XF800606C[7:0] = 0x00000010U
- // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U
- // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16
- // .. .. ==> 0XF800606C[15:8] = 0x00000016U
- // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U
- EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U),
- // .. .. reg_ddrc_dfi_t_ctrl_delay = 0x1
- // .. .. ==> 0XF8006078[3:0] = 0x00000001U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000001U
- // .. .. reg_ddrc_dfi_t_dram_clk_disable = 0x1
- // .. .. ==> 0XF8006078[7:4] = 0x00000001U
- // .. .. ==> MASK : 0x000000F0U VAL : 0x00000010U
- // .. .. reg_ddrc_dfi_t_dram_clk_enable = 0x1
- // .. .. ==> 0XF8006078[11:8] = 0x00000001U
- // .. .. ==> MASK : 0x00000F00U VAL : 0x00000100U
- // .. .. reg_ddrc_t_cksre = 0x6
- // .. .. ==> 0XF8006078[15:12] = 0x00000006U
- // .. .. reg_ddrc_t_cksrx = 0x6
- // .. .. ==> 0XF8006078[19:16] = 0x00000006U
- // .. .. reg_ddrc_t_ckesr = 0x4
- // .. .. ==> 0XF8006078[25:20] = 0x00000004U
- EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU ,0x00466111U),
- // .. .. reg_ddrc_t_ckpde = 0x2
- // .. .. ==> 0XF800607C[3:0] = 0x00000002U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000002U
- // .. .. reg_ddrc_t_ckpdx = 0x2
- // .. .. ==> 0XF800607C[7:4] = 0x00000002U
- // .. .. reg_ddrc_t_ckdpde = 0x2
- // .. .. ==> 0XF800607C[11:8] = 0x00000002U
- // .. .. reg_ddrc_t_ckdpdx = 0x2
- // .. .. ==> 0XF800607C[15:12] = 0x00000002U
- // .. .. ==> MASK : 0x0000F000U VAL : 0x00002000U
- // .. .. reg_ddrc_t_ckcsx = 0x3
- // .. .. ==> 0XF800607C[19:16] = 0x00000003U
- // .. .. ==> MASK : 0x000F0000U VAL : 0x00030000U
- EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU ,0x00032222U),
- // .. .. reg_ddrc_dis_auto_zq = 0x0
- // .. .. ==> 0XF80060A4[0:0] = 0x00000000U
- // .. .. reg_ddrc_ddr3 = 0x1
- // .. .. ==> 0XF80060A4[1:1] = 0x00000001U
- // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U
- // .. .. reg_ddrc_t_mod = 0x200
- // .. .. ==> 0XF80060A4[11:2] = 0x00000200U
- // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U
- // .. .. reg_ddrc_t_zq_long_nop = 0x200
- // .. .. ==> 0XF80060A4[21:12] = 0x00000200U
- // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U
- // .. .. reg_ddrc_t_zq_short_nop = 0x40
- // .. .. ==> 0XF80060A4[31:22] = 0x00000040U
- // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U
- EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U),
- // .. .. t_zq_short_interval_x1024 = 0xcb73
- // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U
- // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U
- // .. .. dram_rstn_x1024 = 0x69
- // .. .. ==> 0XF80060A8[27:20] = 0x00000069U
- // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U
- EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U),
- // .. .. deeppowerdown_en = 0x0
- // .. .. ==> 0XF80060AC[0:0] = 0x00000000U
- // .. .. deeppowerdown_to_x1024 = 0xff
- // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU
- // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU
- EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU),
- // .. .. dfi_wrlvl_max_x1024 = 0xfff
- // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU
- // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU
- // .. .. dfi_rdlvl_max_x1024 = 0xfff
- // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU
- // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U
- // .. .. ddrc_reg_twrlvl_max_error = 0x0
- // .. .. ==> 0XF80060B0[24:24] = 0x00000000U
- // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U
- // .. .. ddrc_reg_trdlvl_max_error = 0x0
- // .. .. ==> 0XF80060B0[25:25] = 0x00000000U
- // .. .. reg_ddrc_dfi_wr_level_en = 0x1
- // .. .. ==> 0XF80060B0[26:26] = 0x00000001U
- // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U
- // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1
- // .. .. ==> 0XF80060B0[27:27] = 0x00000001U
- // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U
- // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1
- // .. .. ==> 0XF80060B0[28:28] = 0x00000001U
- // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U
- EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU),
- // .. .. reg_ddrc_skip_ocd = 0x1
- // .. .. ==> 0XF80060B4[9:9] = 0x00000001U
- // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U
- EMIT_MASKWRITE(0XF80060B4, 0x00000200U ,0x00000200U),
- // .. .. reg_ddrc_dfi_t_rddata_en = 0x6
- // .. .. ==> 0XF80060B8[4:0] = 0x00000006U
- // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U
- // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3
- // .. .. ==> 0XF80060B8[14:5] = 0x00000003U
- // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U
- // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40
- // .. .. ==> 0XF80060B8[24:15] = 0x00000040U
- // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U
- EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U),
- // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0
- // .. .. ==> 0XF80060C4[0:0] = 0x00000000U
- // .. .. Clear_Correctable_DRAM_ECC_error = 0x0
- // .. .. ==> 0XF80060C4[1:1] = 0x00000000U
- EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U),
- // .. .. CORR_ECC_LOG_VALID = 0x0
- // .. .. ==> 0XF80060C8[0:0] = 0x00000000U
- // .. .. ECC_CORRECTED_BIT_NUM = 0x0
- // .. .. ==> 0XF80060C8[7:1] = 0x00000000U
- // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U
- EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U),
- // .. .. UNCORR_ECC_LOG_VALID = 0x0
- // .. .. ==> 0XF80060DC[0:0] = 0x00000000U
- EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U),
- // .. .. STAT_NUM_CORR_ERR = 0x0
- // .. .. ==> 0XF80060F0[15:8] = 0x00000000U
- // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U
- // .. .. STAT_NUM_UNCORR_ERR = 0x0
- // .. .. ==> 0XF80060F0[7:0] = 0x00000000U
- // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U
- EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U),
- // .. .. reg_ddrc_ecc_mode = 0x0
- // .. .. ==> 0XF80060F4[2:0] = 0x00000000U
- // .. .. reg_ddrc_dis_scrub = 0x1
- // .. .. ==> 0XF80060F4[3:3] = 0x00000001U
- EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U),
- // .. .. reg_phy_dif_on = 0x0
- // .. .. ==> 0XF8006114[3:0] = 0x00000000U
- // .. .. reg_phy_dif_off = 0x0
- // .. .. ==> 0XF8006114[7:4] = 0x00000000U
- EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U),
- // .. .. reg_phy_data_slice_in_use = 0x1
- // .. .. ==> 0XF8006118[0:0] = 0x00000001U
- // .. .. reg_phy_rdlvl_inc_mode = 0x0
- // .. .. ==> 0XF8006118[1:1] = 0x00000000U
- // .. .. reg_phy_gatelvl_inc_mode = 0x0
- // .. .. ==> 0XF8006118[2:2] = 0x00000000U
- // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U
- // .. .. reg_phy_wrlvl_inc_mode = 0x0
- // .. .. ==> 0XF8006118[3:3] = 0x00000000U
- // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U
- // .. .. reg_phy_bist_shift_dq = 0x0
- // .. .. ==> 0XF8006118[14:6] = 0x00000000U
- // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U
- // .. .. reg_phy_bist_err_clr = 0x0
- // .. .. ==> 0XF8006118[23:15] = 0x00000000U
- // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U
- // .. .. reg_phy_dq_offset = 0x40
- // .. .. ==> 0XF8006118[30:24] = 0x00000040U
- // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U
- EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU ,0x40000001U),
- // .. .. ==> 0XF800611C[0:0] = 0x00000001U
- // .. .. ==> 0XF800611C[1:1] = 0x00000000U
- // .. .. ==> 0XF800611C[2:2] = 0x00000000U
- // .. .. ==> 0XF800611C[3:3] = 0x00000000U
- // .. .. ==> 0XF800611C[14:6] = 0x00000000U
- // .. .. ==> 0XF800611C[23:15] = 0x00000000U
- // .. .. ==> 0XF800611C[30:24] = 0x00000040U
- EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU ,0x40000001U),
- // .. .. ==> 0XF8006120[0:0] = 0x00000001U
- // .. .. ==> 0XF8006120[1:1] = 0x00000000U
- // .. .. ==> 0XF8006120[2:2] = 0x00000000U
- // .. .. ==> 0XF8006120[3:3] = 0x00000000U
- // .. .. ==> 0XF8006120[14:6] = 0x00000000U
- // .. .. ==> 0XF8006120[23:15] = 0x00000000U
- // .. .. ==> 0XF8006120[30:24] = 0x00000040U
- EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU ,0x40000001U),
- // .. .. ==> 0XF8006124[0:0] = 0x00000001U
- // .. .. ==> 0XF8006124[1:1] = 0x00000000U
- // .. .. ==> 0XF8006124[2:2] = 0x00000000U
- // .. .. ==> 0XF8006124[3:3] = 0x00000000U
- // .. .. ==> 0XF8006124[14:6] = 0x00000000U
- // .. .. ==> 0XF8006124[23:15] = 0x00000000U
- // .. .. ==> 0XF8006124[30:24] = 0x00000040U
- EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU ,0x40000001U),
- // .. .. reg_phy_wrlvl_init_ratio = 0x0
- // .. .. ==> 0XF800612C[9:0] = 0x00000000U
- // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U
- // .. .. reg_phy_gatelvl_init_ratio = 0x9c
- // .. .. ==> 0XF800612C[19:10] = 0x0000009CU
- // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027000U
- EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00027000U),
- // .. .. ==> 0XF8006130[9:0] = 0x00000000U
- // .. .. ==> 0XF8006130[19:10] = 0x0000009CU
- EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00027000U),
- // .. .. ==> 0XF8006134[9:0] = 0x00000000U
- // .. .. reg_phy_gatelvl_init_ratio = 0x9b
- // .. .. ==> 0XF8006134[19:10] = 0x0000009BU
- // .. .. ==> MASK : 0x000FFC00U VAL : 0x00026C00U
- EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x00026C00U),
- // .. .. ==> 0XF8006138[9:0] = 0x00000000U
- // .. .. reg_phy_gatelvl_init_ratio = 0xa2
- // .. .. ==> 0XF8006138[19:10] = 0x000000A2U
- // .. .. ==> MASK : 0x000FFC00U VAL : 0x00028800U
- EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x00028800U),
- // .. .. reg_phy_rd_dqs_slave_ratio = 0x35
- // .. .. ==> 0XF8006140[9:0] = 0x00000035U
- // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U
- // .. .. reg_phy_rd_dqs_slave_force = 0x0
- // .. .. ==> 0XF8006140[10:10] = 0x00000000U
- // .. .. reg_phy_rd_dqs_slave_delay = 0x0
- // .. .. ==> 0XF8006140[19:11] = 0x00000000U
- // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U),
- // .. .. ==> 0XF8006144[9:0] = 0x00000035U
- // .. .. ==> 0XF8006144[10:10] = 0x00000000U
- // .. .. ==> 0XF8006144[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U),
- // .. .. ==> 0XF8006148[9:0] = 0x00000035U
- // .. .. ==> 0XF8006148[10:10] = 0x00000000U
- // .. .. ==> 0XF8006148[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U),
- // .. .. ==> 0XF800614C[9:0] = 0x00000035U
- // .. .. ==> 0XF800614C[10:10] = 0x00000000U
- // .. .. ==> 0XF800614C[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U),
- // .. .. reg_phy_wr_dqs_slave_ratio = 0x7a
- // .. .. ==> 0XF8006154[9:0] = 0x0000007AU
- // .. .. ==> MASK : 0x000003FFU VAL : 0x0000007AU
- // .. .. reg_phy_wr_dqs_slave_force = 0x0
- // .. .. ==> 0XF8006154[10:10] = 0x00000000U
- // .. .. reg_phy_wr_dqs_slave_delay = 0x0
- // .. .. ==> 0XF8006154[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x0000007AU),
- // .. .. ==> 0XF8006158[9:0] = 0x0000007AU
- // .. .. ==> 0XF8006158[10:10] = 0x00000000U
- // .. .. ==> 0XF8006158[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x0000007AU),
- // .. .. reg_phy_wr_dqs_slave_ratio = 0x7c
- // .. .. ==> 0XF800615C[9:0] = 0x0000007CU
- // .. .. ==> MASK : 0x000003FFU VAL : 0x0000007CU
- // .. .. ==> 0XF800615C[10:10] = 0x00000000U
- // .. .. ==> 0XF800615C[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x0000007CU),
- // .. .. reg_phy_wr_dqs_slave_ratio = 0x73
- // .. .. ==> 0XF8006160[9:0] = 0x00000073U
- // .. .. ==> MASK : 0x000003FFU VAL : 0x00000073U
- // .. .. ==> 0XF8006160[10:10] = 0x00000000U
- // .. .. ==> 0XF8006160[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000073U),
- // .. .. reg_phy_fifo_we_slave_ratio = 0xf1
- // .. .. ==> 0XF8006168[10:0] = 0x000000F1U
- // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F1U
- // .. .. reg_phy_fifo_we_in_force = 0x0
- // .. .. ==> 0XF8006168[11:11] = 0x00000000U
- // .. .. reg_phy_fifo_we_in_delay = 0x0
- // .. .. ==> 0XF8006168[20:12] = 0x00000000U
- // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000F1U),
- // .. .. ==> 0XF800616C[10:0] = 0x000000F1U
- // .. .. ==> 0XF800616C[11:11] = 0x00000000U
- // .. .. ==> 0XF800616C[20:12] = 0x00000000U
- EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000F1U),
- // .. .. reg_phy_fifo_we_slave_ratio = 0xf0
- // .. .. ==> 0XF8006170[10:0] = 0x000000F0U
- // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F0U
- // .. .. ==> 0XF8006170[11:11] = 0x00000000U
- // .. .. ==> 0XF8006170[20:12] = 0x00000000U
- EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000F0U),
- // .. .. reg_phy_fifo_we_slave_ratio = 0xf7
- // .. .. ==> 0XF8006174[10:0] = 0x000000F7U
- // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F7U
- // .. .. ==> 0XF8006174[11:11] = 0x00000000U
- // .. .. ==> 0XF8006174[20:12] = 0x00000000U
- EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000F7U),
- // .. .. reg_phy_wr_data_slave_ratio = 0xba
- // .. .. ==> 0XF800617C[9:0] = 0x000000BAU
- // .. .. ==> MASK : 0x000003FFU VAL : 0x000000BAU
- // .. .. reg_phy_wr_data_slave_force = 0x0
- // .. .. ==> 0XF800617C[10:10] = 0x00000000U
- // .. .. reg_phy_wr_data_slave_delay = 0x0
- // .. .. ==> 0XF800617C[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000BAU),
- // .. .. ==> 0XF8006180[9:0] = 0x000000BAU
- // .. .. ==> 0XF8006180[10:10] = 0x00000000U
- // .. .. ==> 0XF8006180[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000BAU),
- // .. .. reg_phy_wr_data_slave_ratio = 0xbc
- // .. .. ==> 0XF8006184[9:0] = 0x000000BCU
- // .. .. ==> MASK : 0x000003FFU VAL : 0x000000BCU
- // .. .. ==> 0XF8006184[10:10] = 0x00000000U
- // .. .. ==> 0XF8006184[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000BCU),
- // .. .. reg_phy_wr_data_slave_ratio = 0xb3
- // .. .. ==> 0XF8006188[9:0] = 0x000000B3U
- // .. .. ==> MASK : 0x000003FFU VAL : 0x000000B3U
- // .. .. ==> 0XF8006188[10:10] = 0x00000000U
- // .. .. ==> 0XF8006188[19:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000B3U),
- // .. .. reg_phy_bl2 = 0x0
- // .. .. ==> 0XF8006190[1:1] = 0x00000000U
- // .. .. reg_phy_at_spd_atpg = 0x0
- // .. .. ==> 0XF8006190[2:2] = 0x00000000U
- // .. .. reg_phy_bist_enable = 0x0
- // .. .. ==> 0XF8006190[3:3] = 0x00000000U
- // .. .. reg_phy_bist_force_err = 0x0
- // .. .. ==> 0XF8006190[4:4] = 0x00000000U
- // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U
- // .. .. reg_phy_bist_mode = 0x0
- // .. .. ==> 0XF8006190[6:5] = 0x00000000U
- // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U
- // .. .. reg_phy_invert_clkout = 0x1
- // .. .. ==> 0XF8006190[7:7] = 0x00000001U
- // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U
- // .. .. reg_phy_sel_logic = 0x0
- // .. .. ==> 0XF8006190[9:9] = 0x00000000U
- // .. .. reg_phy_ctrl_slave_ratio = 0x100
- // .. .. ==> 0XF8006190[19:10] = 0x00000100U
- // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U
- // .. .. reg_phy_ctrl_slave_force = 0x0
- // .. .. ==> 0XF8006190[20:20] = 0x00000000U
- // .. .. reg_phy_ctrl_slave_delay = 0x0
- // .. .. ==> 0XF8006190[27:21] = 0x00000000U
- // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U
- // .. .. reg_phy_lpddr = 0x0
- // .. .. ==> 0XF8006190[29:29] = 0x00000000U
- // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U
- // .. .. reg_phy_cmd_latency = 0x0
- // .. .. ==> 0XF8006190[30:30] = 0x00000000U
- EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU ,0x00040080U),
- // .. .. reg_phy_wr_rl_delay = 0x2
- // .. .. ==> 0XF8006194[4:0] = 0x00000002U
- // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U
- // .. .. reg_phy_rd_rl_delay = 0x4
- // .. .. ==> 0XF8006194[9:5] = 0x00000004U
- // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U
- // .. .. reg_phy_dll_lock_diff = 0xf
- // .. .. ==> 0XF8006194[13:10] = 0x0000000FU
- // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U
- // .. .. reg_phy_use_wr_level = 0x1
- // .. .. ==> 0XF8006194[14:14] = 0x00000001U
- // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U
- // .. .. reg_phy_use_rd_dqs_gate_level = 0x1
- // .. .. ==> 0XF8006194[15:15] = 0x00000001U
- // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U
- // .. .. reg_phy_use_rd_data_eye_level = 0x1
- // .. .. ==> 0XF8006194[16:16] = 0x00000001U
- // .. .. reg_phy_dis_calib_rst = 0x0
- // .. .. ==> 0XF8006194[17:17] = 0x00000000U
- // .. .. ==> 0XF8006194[19:18] = 0x00000000U
- // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U),
- // .. .. reg_arb_page_addr_mask = 0x0
- // .. .. ==> 0XF8006204[31:0] = 0x00000000U
- // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U),
- // .. .. reg_arb_pri_wr_portn = 0x3ff
- // .. .. ==> 0XF8006208[9:0] = 0x000003FFU
- // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU
- // .. .. reg_arb_disable_aging_wr_portn = 0x0
- // .. .. ==> 0XF8006208[16:16] = 0x00000000U
- // .. .. reg_arb_disable_urgent_wr_portn = 0x0
- // .. .. ==> 0XF8006208[17:17] = 0x00000000U
- // .. .. reg_arb_dis_page_match_wr_portn = 0x0
- // .. .. ==> 0XF8006208[18:18] = 0x00000000U
- EMIT_MASKWRITE(0XF8006208, 0x000703FFU ,0x000003FFU),
- // .. .. ==> 0XF800620C[9:0] = 0x000003FFU
- // .. .. ==> 0XF800620C[16:16] = 0x00000000U
- // .. .. ==> 0XF800620C[17:17] = 0x00000000U
- // .. .. ==> 0XF800620C[18:18] = 0x00000000U
- EMIT_MASKWRITE(0XF800620C, 0x000703FFU ,0x000003FFU),
- // .. .. ==> 0XF8006210[9:0] = 0x000003FFU
- // .. .. ==> 0XF8006210[16:16] = 0x00000000U
- // .. .. ==> 0XF8006210[17:17] = 0x00000000U
- // .. .. ==> 0XF8006210[18:18] = 0x00000000U
- EMIT_MASKWRITE(0XF8006210, 0x000703FFU ,0x000003FFU),
- // .. .. ==> 0XF8006214[9:0] = 0x000003FFU
- // .. .. ==> 0XF8006214[16:16] = 0x00000000U
- // .. .. ==> 0XF8006214[17:17] = 0x00000000U
- // .. .. ==> 0XF8006214[18:18] = 0x00000000U
- EMIT_MASKWRITE(0XF8006214, 0x000703FFU ,0x000003FFU),
- // .. .. reg_arb_pri_rd_portn = 0x3ff
- // .. .. ==> 0XF8006218[9:0] = 0x000003FFU
- // .. .. reg_arb_disable_aging_rd_portn = 0x0
- // .. .. ==> 0XF8006218[16:16] = 0x00000000U
- // .. .. reg_arb_disable_urgent_rd_portn = 0x0
- // .. .. ==> 0XF8006218[17:17] = 0x00000000U
- // .. .. reg_arb_dis_page_match_rd_portn = 0x0
- // .. .. ==> 0XF8006218[18:18] = 0x00000000U
- // .. .. reg_arb_set_hpr_rd_portn = 0x0
- // .. .. ==> 0XF8006218[19:19] = 0x00000000U
- EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU),
- // .. .. ==> 0XF800621C[9:0] = 0x000003FFU
- // .. .. ==> 0XF800621C[16:16] = 0x00000000U
- // .. .. ==> 0XF800621C[17:17] = 0x00000000U
- // .. .. ==> 0XF800621C[18:18] = 0x00000000U
- // .. .. ==> 0XF800621C[19:19] = 0x00000000U
- EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU),
- // .. .. ==> 0XF8006220[9:0] = 0x000003FFU
- // .. .. ==> 0XF8006220[16:16] = 0x00000000U
- // .. .. ==> 0XF8006220[17:17] = 0x00000000U
- // .. .. ==> 0XF8006220[18:18] = 0x00000000U
- // .. .. ==> 0XF8006220[19:19] = 0x00000000U
- EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU),
- // .. .. ==> 0XF8006224[9:0] = 0x000003FFU
- // .. .. ==> 0XF8006224[16:16] = 0x00000000U
- // .. .. ==> 0XF8006224[17:17] = 0x00000000U
- // .. .. ==> 0XF8006224[18:18] = 0x00000000U
- // .. .. ==> 0XF8006224[19:19] = 0x00000000U
- EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU),
- // .. .. reg_ddrc_lpddr2 = 0x0
- // .. .. ==> 0XF80062A8[0:0] = 0x00000000U
- // .. .. reg_ddrc_derate_enable = 0x0
- // .. .. ==> 0XF80062A8[2:2] = 0x00000000U
- // .. .. reg_ddrc_mr4_margin = 0x0
- // .. .. ==> 0XF80062A8[11:4] = 0x00000000U
- // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U ,0x00000000U),
- // .. .. reg_ddrc_mr4_read_interval = 0x0
- // .. .. ==> 0XF80062AC[31:0] = 0x00000000U
- EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U),
- // .. .. reg_ddrc_min_stable_clock_x1 = 0x5
- // .. .. ==> 0XF80062B0[3:0] = 0x00000005U
- // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U
- // .. .. reg_ddrc_idle_after_reset_x32 = 0x12
- // .. .. ==> 0XF80062B0[11:4] = 0x00000012U
- // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U
- // .. .. reg_ddrc_t_mrw = 0x5
- // .. .. ==> 0XF80062B0[21:12] = 0x00000005U
- // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U
- EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U),
- // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8
- // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U
- // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U
- // .. .. reg_ddrc_dev_zqinit_x32 = 0x12
- // .. .. ==> 0XF80062B4[17:8] = 0x00000012U
- // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U
- EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U),
- // .. .. START: POLL ON DCI STATUS
- // .. .. DONE = 1
- // .. .. ==> 0XF8000B74[13:13] = 0x00000001U
- // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U
- EMIT_MASKPOLL(0XF8000B74, 0x00002000U),
- // .. .. FINISH: POLL ON DCI STATUS
- // .. .. START: UNLOCK DDR
- // .. .. reg_ddrc_soft_rstb = 0x1
- // .. .. ==> 0XF8006000[0:0] = 0x00000001U
- // .. .. reg_ddrc_rdwr_idle_gap = 1
- EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000081U),
- // .. .. FINISH: UNLOCK DDR
- // .. .. START: CHECK DDR STATUS
- // .. .. ddrc_reg_operating_mode = 1
- // .. .. ==> 0XF8006054[2:0] = 0x00000001U
- // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U
- EMIT_MASKPOLL(0XF8006054, 0x00000007U),
- // .. .. FINISH: CHECK DDR STATUS
- // .. FINISH: DDR INITIALIZATION
- // FINISH: top
- EMIT_EXIT(),
+unsigned long ps7_mio_init_data_3_0[] = {
- // START: top
- // .. START: OCM REMAPPING
- // .. FINISH: OCM REMAPPING
- // .. START: DDRIOB SETTINGS
- // .. reserved_INP_POWER = 0x0
- // .. ==> 0XF8000B40[0:0] = 0x00000000U
- // .. INP_TYPE = 0x0
- // .. ==> 0XF8000B40[2:1] = 0x00000000U
- // .. ==> MASK : 0x00000006U VAL : 0x00000000U
- // .. DCI_UPDATE_B = 0x0
- // .. ==> 0XF8000B40[3:3] = 0x00000000U
- // .. ==> MASK : 0x00000008U VAL : 0x00000000U
- // .. TERM_EN = 0x0
- // .. ==> 0XF8000B40[4:4] = 0x00000000U
- // .. DCI_TYPE = 0x0
- // .. ==> 0XF8000B40[6:5] = 0x00000000U
- // .. ==> MASK : 0x00000060U VAL : 0x00000000U
- // .. IBUF_DISABLE_MODE = 0x0
- // .. ==> 0XF8000B40[7:7] = 0x00000000U
- // .. ==> MASK : 0x00000080U VAL : 0x00000000U
- // .. TERM_DISABLE_MODE = 0x0
- // .. ==> 0XF8000B40[8:8] = 0x00000000U
- // .. ==> MASK : 0x00000100U VAL : 0x00000000U
- // .. OUTPUT_EN = 0x3
- // .. ==> 0XF8000B40[10:9] = 0x00000003U
- // .. ==> MASK : 0x00000600U VAL : 0x00000600U
- // .. PULLUP_EN = 0x0
- // .. ==> 0XF8000B40[11:11] = 0x00000000U
- // .. ==> MASK : 0x00000800U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U),
- // .. ==> 0XF8000B44[0:0] = 0x00000000U
- // .. ==> 0XF8000B44[2:1] = 0x00000000U
- // .. ==> 0XF8000B44[3:3] = 0x00000000U
- // .. ==> 0XF8000B44[4:4] = 0x00000000U
- // .. ==> 0XF8000B44[6:5] = 0x00000000U
- // .. ==> 0XF8000B44[7:7] = 0x00000000U
- // .. ==> 0XF8000B44[8:8] = 0x00000000U
- // .. ==> 0XF8000B44[10:9] = 0x00000003U
- // .. ==> 0XF8000B44[11:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U),
- // .. ==> 0XF8000B48[0:0] = 0x00000000U
- // .. INP_TYPE = 0x1
- // .. ==> 0XF8000B48[2:1] = 0x00000001U
- // .. ==> MASK : 0x00000006U VAL : 0x00000002U
- // .. ==> 0XF8000B48[3:3] = 0x00000000U
- // .. TERM_EN = 0x1
- // .. ==> 0XF8000B48[4:4] = 0x00000001U
- // .. ==> MASK : 0x00000010U VAL : 0x00000010U
- // .. DCI_TYPE = 0x3
- // .. ==> 0XF8000B48[6:5] = 0x00000003U
- // .. ==> MASK : 0x00000060U VAL : 0x00000060U
- // .. ==> 0XF8000B48[7:7] = 0x00000000U
- // .. ==> 0XF8000B48[8:8] = 0x00000000U
- // .. ==> 0XF8000B48[10:9] = 0x00000003U
- // .. ==> 0XF8000B48[11:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U),
- // .. ==> 0XF8000B4C[0:0] = 0x00000000U
- // .. ==> 0XF8000B4C[2:1] = 0x00000001U
- // .. ==> 0XF8000B4C[3:3] = 0x00000000U
- // .. ==> 0XF8000B4C[4:4] = 0x00000001U
- // .. ==> 0XF8000B4C[6:5] = 0x00000003U
- // .. ==> 0XF8000B4C[7:7] = 0x00000000U
- // .. ==> 0XF8000B4C[8:8] = 0x00000000U
- // .. ==> 0XF8000B4C[10:9] = 0x00000003U
- // .. ==> 0XF8000B4C[11:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000672U),
- // .. ==> 0XF8000B50[0:0] = 0x00000000U
- // .. INP_TYPE = 0x2
- // .. ==> 0XF8000B50[2:1] = 0x00000002U
- // .. ==> MASK : 0x00000006U VAL : 0x00000004U
- // .. ==> 0XF8000B50[3:3] = 0x00000000U
- // .. ==> 0XF8000B50[4:4] = 0x00000001U
- // .. ==> 0XF8000B50[6:5] = 0x00000003U
- // .. ==> 0XF8000B50[7:7] = 0x00000000U
- // .. ==> 0XF8000B50[8:8] = 0x00000000U
- // .. ==> 0XF8000B50[10:9] = 0x00000003U
- // .. ==> 0XF8000B50[11:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U),
- // .. ==> 0XF8000B54[0:0] = 0x00000000U
- // .. ==> 0XF8000B54[2:1] = 0x00000002U
- // .. ==> 0XF8000B54[3:3] = 0x00000000U
- // .. ==> 0XF8000B54[4:4] = 0x00000001U
- // .. ==> 0XF8000B54[6:5] = 0x00000003U
- // .. ==> 0XF8000B54[7:7] = 0x00000000U
- // .. ==> 0XF8000B54[8:8] = 0x00000000U
- // .. ==> 0XF8000B54[10:9] = 0x00000003U
- // .. ==> 0XF8000B54[11:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000674U),
- // .. ==> 0XF8000B58[0:0] = 0x00000000U
- // .. ==> 0XF8000B58[2:1] = 0x00000000U
- // .. ==> 0XF8000B58[3:3] = 0x00000000U
- // .. ==> 0XF8000B58[4:4] = 0x00000000U
- // .. ==> 0XF8000B58[6:5] = 0x00000000U
- // .. ==> 0XF8000B58[7:7] = 0x00000000U
- // .. ==> 0XF8000B58[8:8] = 0x00000000U
- // .. ==> 0XF8000B58[10:9] = 0x00000003U
- // .. ==> 0XF8000B58[11:11] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U),
- // .. reserved_DRIVE_P = 0x68
- // .. ==> 0XF8000B5C[6:0] = 0x00000068U
- // .. ==> MASK : 0x0000007FU VAL : 0x00000068U
- // .. reserved_DRIVE_N = 0x0
- // .. ==> 0XF8000B5C[13:7] = 0x00000000U
- // .. ==> MASK : 0x00003F80U VAL : 0x00000000U
- // .. reserved_SLEW_P = 0x3
- // .. ==> 0XF8000B5C[18:14] = 0x00000003U
- // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U
- // .. reserved_SLEW_N = 0x3
- // .. ==> 0XF8000B5C[23:19] = 0x00000003U
- // .. ==> MASK : 0x00F80000U VAL : 0x00180000U
- // .. reserved_GTL = 0x0
- // .. ==> 0XF8000B5C[26:24] = 0x00000000U
- // .. ==> MASK : 0x07000000U VAL : 0x00000000U
- // .. reserved_RTERM = 0x0
- // .. ==> 0XF8000B5C[31:27] = 0x00000000U
- // .. ==> MASK : 0xF8000000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U),
- // .. ==> 0XF8000B60[6:0] = 0x00000068U
- // .. ==> 0XF8000B60[13:7] = 0x00000000U
- // .. reserved_SLEW_P = 0x6
- // .. ==> 0XF8000B60[18:14] = 0x00000006U
- // .. ==> MASK : 0x0007C000U VAL : 0x00018000U
- // .. reserved_SLEW_N = 0x1f
- // .. ==> 0XF8000B60[23:19] = 0x0000001FU
- // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U
- // .. ==> 0XF8000B60[26:24] = 0x00000000U
- // .. ==> 0XF8000B60[31:27] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U),
- // .. ==> 0XF8000B64[6:0] = 0x00000068U
- // .. ==> 0XF8000B64[13:7] = 0x00000000U
- // .. ==> 0XF8000B64[18:14] = 0x00000006U
- // .. ==> 0XF8000B64[23:19] = 0x0000001FU
- // .. ==> 0XF8000B64[26:24] = 0x00000000U
- // .. ==> 0XF8000B64[31:27] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U),
- // .. ==> 0XF8000B68[6:0] = 0x00000068U
- // .. ==> 0XF8000B68[13:7] = 0x00000000U
- // .. ==> 0XF8000B68[18:14] = 0x00000006U
- // .. ==> 0XF8000B68[23:19] = 0x0000001FU
- // .. ==> 0XF8000B68[26:24] = 0x00000000U
- // .. ==> 0XF8000B68[31:27] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U),
- // .. VREF_INT_EN = 0x0
- // .. ==> 0XF8000B6C[0:0] = 0x00000000U
- // .. VREF_SEL = 0x0
- // .. ==> 0XF8000B6C[4:1] = 0x00000000U
- // .. ==> MASK : 0x0000001EU VAL : 0x00000000U
- // .. VREF_EXT_EN = 0x3
- // .. ==> 0XF8000B6C[6:5] = 0x00000003U
- // .. reserved_VREF_PULLUP_EN = 0x0
- // .. ==> 0XF8000B6C[8:7] = 0x00000000U
- // .. ==> MASK : 0x00000180U VAL : 0x00000000U
- // .. REFIO_EN = 0x1
- // .. ==> 0XF8000B6C[9:9] = 0x00000001U
- // .. ==> MASK : 0x00000200U VAL : 0x00000200U
- // .. reserved_REFIO_TEST = 0x0
- // .. ==> 0XF8000B6C[11:10] = 0x00000000U
- // .. ==> MASK : 0x00000C00U VAL : 0x00000000U
- // .. reserved_REFIO_PULLUP_EN = 0x0
- // .. ==> 0XF8000B6C[12:12] = 0x00000000U
- // .. ==> MASK : 0x00001000U VAL : 0x00000000U
- // .. reserved_DRST_B_PULLUP_EN = 0x0
- // .. ==> 0XF8000B6C[13:13] = 0x00000000U
- // .. ==> MASK : 0x00002000U VAL : 0x00000000U
- // .. reserved_CKE_PULLUP_EN = 0x0
- // .. ==> 0XF8000B6C[14:14] = 0x00000000U
- // .. ==> MASK : 0x00004000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU ,0x00000260U),
- // .. .. START: ASSERT RESET
- // .. .. RESET = 1
- // .. .. ==> 0XF8000B70[0:0] = 0x00000001U
- EMIT_MASKWRITE(0XF8000B70, 0x00000001U ,0x00000001U),
- // .. .. FINISH: ASSERT RESET
- // .. .. START: DEASSERT RESET
- // .. .. RESET = 0
- // .. .. ==> 0XF8000B70[0:0] = 0x00000000U
- // .. .. reserved_VRN_OUT = 0x1
- // .. .. ==> 0XF8000B70[5:5] = 0x00000001U
- // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U
- EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U),
- // .. .. FINISH: DEASSERT RESET
- // .. .. RESET = 0x1
- // .. .. ENABLE = 0x1
- // .. .. ==> 0XF8000B70[1:1] = 0x00000001U
- // .. .. reserved_VRP_TRI = 0x0
- // .. .. ==> 0XF8000B70[2:2] = 0x00000000U
- // .. .. reserved_VRN_TRI = 0x0
- // .. .. ==> 0XF8000B70[3:3] = 0x00000000U
- // .. .. reserved_VRP_OUT = 0x0
- // .. .. ==> 0XF8000B70[4:4] = 0x00000000U
- // .. .. NREF_OPT1 = 0x0
- // .. .. ==> 0XF8000B70[7:6] = 0x00000000U
- // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U
- // .. .. NREF_OPT2 = 0x0
- // .. .. ==> 0XF8000B70[10:8] = 0x00000000U
- // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U
- // .. .. NREF_OPT4 = 0x1
- // .. .. ==> 0XF8000B70[13:11] = 0x00000001U
- // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U
- // .. .. PREF_OPT1 = 0x0
- // .. .. ==> 0XF8000B70[15:14] = 0x00000000U
- // .. .. ==> MASK : 0x0000C000U VAL : 0x00000000U
- // .. .. PREF_OPT2 = 0x0
- // .. .. ==> 0XF8000B70[19:17] = 0x00000000U
- // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U
- // .. .. UPDATE_CONTROL = 0x0
- // .. .. ==> 0XF8000B70[20:20] = 0x00000000U
- // .. .. reserved_INIT_COMPLETE = 0x0
- // .. .. ==> 0XF8000B70[21:21] = 0x00000000U
- // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U
- // .. .. reserved_TST_CLK = 0x0
- // .. .. ==> 0XF8000B70[22:22] = 0x00000000U
- // .. .. reserved_TST_HLN = 0x0
- // .. .. ==> 0XF8000B70[23:23] = 0x00000000U
- // .. .. reserved_TST_HLP = 0x0
- // .. .. ==> 0XF8000B70[24:24] = 0x00000000U
- // .. .. reserved_TST_RST = 0x0
- // .. .. ==> 0XF8000B70[25:25] = 0x00000000U
- // .. .. reserved_INT_DCI_EN = 0x0
- // .. .. ==> 0XF8000B70[26:26] = 0x00000000U
- EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU ,0x00000823U),
- // .. FINISH: DDRIOB SETTINGS
- // .. START: MIO PROGRAMMING
- // .. TRI_ENABLE = 0
- // .. ==> 0XF8000700[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000700[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF8000700[2:2] = 0x00000000U
- // .. ==> MASK : 0x00000004U VAL : 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000700[4:3] = 0x00000000U
- // .. ==> MASK : 0x00000018U VAL : 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000700[7:5] = 0x00000000U
- // .. ==> MASK : 0x000000E0U VAL : 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000700[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000700[11:9] = 0x00000003U
- // .. ==> MASK : 0x00000E00U VAL : 0x00000600U
- // .. PULLUP = 1
- // .. ==> 0XF8000700[12:12] = 0x00000001U
- // .. ==> MASK : 0x00001000U VAL : 0x00001000U
- // .. DisableRcvr = 0
- // .. ==> 0XF8000700[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000700, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF8000704[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000704[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000704[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000704[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000704[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000704[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000704[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF8000704[12:12] = 0x00000001U
- // .. ==> 0XF8000704[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001602U),
- // .. ==> 0XF8000708[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000708[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000708[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000708[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000708[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000708[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000708[11:9] = 0x00000003U
- // .. PULLUP = 0
- // .. ==> 0XF8000708[12:12] = 0x00000000U
- // .. ==> 0XF8000708[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000602U),
- // .. ==> 0XF800070C[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF800070C[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF800070C[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF800070C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800070C[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF800070C[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF800070C[11:9] = 0x00000003U
- // .. PULLUP = 0
- // .. ==> 0XF800070C[12:12] = 0x00000000U
- // .. ==> 0XF800070C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000602U),
- // .. ==> 0XF8000710[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000710[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000710[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000710[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000710[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000710[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000710[11:9] = 0x00000003U
- // .. PULLUP = 0
- // .. ==> 0XF8000710[12:12] = 0x00000000U
- // .. ==> 0XF8000710[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000602U),
- // .. ==> 0XF8000714[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000714[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000714[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000714[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000714[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000714[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000714[11:9] = 0x00000003U
- // .. PULLUP = 0
- // .. ==> 0XF8000714[12:12] = 0x00000000U
- // .. ==> 0XF8000714[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000602U),
- // .. ==> 0XF8000718[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000718[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000718[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000718[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000718[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000718[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000718[11:9] = 0x00000003U
- // .. PULLUP = 0
- // .. ==> 0XF8000718[12:12] = 0x00000000U
- // .. ==> 0XF8000718[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000602U),
- // .. ==> 0XF800071C[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF800071C[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF800071C[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF800071C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800071C[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF800071C[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF800071C[11:9] = 0x00000003U
- // .. PULLUP = 0
- // .. ==> 0XF800071C[12:12] = 0x00000000U
- // .. ==> 0XF800071C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000600U),
- // .. ==> 0XF8000720[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000720[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000720[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000720[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000720[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000720[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000720[11:9] = 0x00000003U
- // .. PULLUP = 0
- // .. ==> 0XF8000720[12:12] = 0x00000000U
- // .. ==> 0XF8000720[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000602U),
- // .. ==> 0XF8000724[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000724[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF8000724[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000724[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000724[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000724[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000724[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF8000724[12:12] = 0x00000001U
- // .. ==> 0XF8000724[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF8000728[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000728[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF8000728[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000728[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000728[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000728[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000728[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF8000728[12:12] = 0x00000001U
- // .. ==> 0XF8000728[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF800072C[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF800072C[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF800072C[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF800072C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800072C[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF800072C[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF800072C[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF800072C[12:12] = 0x00000001U
- // .. ==> 0XF800072C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF8000730[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000730[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF8000730[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000730[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000730[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000730[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000730[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF8000730[12:12] = 0x00000001U
- // .. ==> 0XF8000730[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF8000734[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000734[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF8000734[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000734[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000734[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000734[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000734[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF8000734[12:12] = 0x00000001U
- // .. ==> 0XF8000734[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF8000738[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000738[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF8000738[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000738[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000738[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF8000738[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF8000738[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF8000738[12:12] = 0x00000001U
- // .. ==> 0XF8000738[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF800073C[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF800073C[1:1] = 0x00000000U
- // .. ==> MASK : 0x00000002U VAL : 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF800073C[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF800073C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800073C[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF800073C[8:8] = 0x00000000U
- // .. IO_Type = 3
- // .. ==> 0XF800073C[11:9] = 0x00000003U
- // .. PULLUP = 1
- // .. ==> 0XF800073C[12:12] = 0x00000001U
- // .. ==> 0XF800073C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x00001600U),
- // .. ==> 0XF8000740[0:0] = 0x00000000U
- // .. ==> MASK : 0x00000001U VAL : 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000740[1:1] = 0x00000001U
- // .. ==> MASK : 0x00000002U VAL : 0x00000002U
- // .. L1_SEL = 0
- // .. ==> 0XF8000740[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000740[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000740[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000740[8:8] = 0x00000001U
- // .. ==> MASK : 0x00000100U VAL : 0x00000100U
- // .. IO_Type = 1
- // .. ==> 0XF8000740[11:9] = 0x00000001U
- // .. ==> MASK : 0x00000E00U VAL : 0x00000200U
- // .. PULLUP = 1
- // .. ==> 0XF8000740[12:12] = 0x00000001U
- // .. ==> 0XF8000740[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000740, 0x00003FFFU ,0x00001302U),
- // .. ==> 0XF8000744[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000744[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000744[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000744[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000744[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000744[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000744[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000744[12:12] = 0x00000001U
- // .. ==> 0XF8000744[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000744, 0x00003FFFU ,0x00001302U),
- // .. ==> 0XF8000748[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000748[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000748[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000748[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000748[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000748[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000748[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000748[12:12] = 0x00000001U
- // .. ==> 0XF8000748[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000748, 0x00003FFFU ,0x00001302U),
- // .. ==> 0XF800074C[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF800074C[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF800074C[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF800074C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800074C[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF800074C[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF800074C[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF800074C[12:12] = 0x00000001U
- // .. ==> 0XF800074C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800074C, 0x00003FFFU ,0x00001302U),
- // .. ==> 0XF8000750[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000750[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000750[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000750[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000750[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000750[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000750[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000750[12:12] = 0x00000001U
- // .. ==> 0XF8000750[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000750, 0x00003FFFU ,0x00001302U),
- // .. ==> 0XF8000754[0:0] = 0x00000000U
- // .. L0_SEL = 1
- // .. ==> 0XF8000754[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000754[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000754[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000754[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000754[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000754[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000754[12:12] = 0x00000001U
- // .. ==> 0XF8000754[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000754, 0x00003FFFU ,0x00001302U),
- // .. TRI_ENABLE = 1
- // .. ==> 0XF8000758[0:0] = 0x00000001U
- // .. ==> MASK : 0x00000001U VAL : 0x00000001U
- // .. L0_SEL = 1
- // .. ==> 0XF8000758[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000758[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000758[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000758[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000758[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000758[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000758[12:12] = 0x00000001U
- // .. ==> 0XF8000758[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000758, 0x00003FFFU ,0x00001303U),
- // .. ==> 0XF800075C[0:0] = 0x00000001U
- // .. L0_SEL = 1
- // .. ==> 0XF800075C[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF800075C[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF800075C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800075C[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF800075C[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF800075C[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF800075C[12:12] = 0x00000001U
- // .. ==> 0XF800075C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800075C, 0x00003FFFU ,0x00001303U),
- // .. ==> 0XF8000760[0:0] = 0x00000001U
- // .. L0_SEL = 1
- // .. ==> 0XF8000760[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000760[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000760[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000760[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000760[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000760[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000760[12:12] = 0x00000001U
- // .. ==> 0XF8000760[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000760, 0x00003FFFU ,0x00001303U),
- // .. ==> 0XF8000764[0:0] = 0x00000001U
- // .. L0_SEL = 1
- // .. ==> 0XF8000764[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000764[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000764[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000764[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000764[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000764[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000764[12:12] = 0x00000001U
- // .. ==> 0XF8000764[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000764, 0x00003FFFU ,0x00001303U),
- // .. ==> 0XF8000768[0:0] = 0x00000001U
- // .. L0_SEL = 1
- // .. ==> 0XF8000768[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF8000768[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF8000768[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000768[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000768[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000768[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000768[12:12] = 0x00000001U
- // .. ==> 0XF8000768[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000768, 0x00003FFFU ,0x00001303U),
- // .. ==> 0XF800076C[0:0] = 0x00000001U
- // .. L0_SEL = 1
- // .. ==> 0XF800076C[1:1] = 0x00000001U
- // .. L1_SEL = 0
- // .. ==> 0XF800076C[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF800076C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800076C[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF800076C[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF800076C[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF800076C[12:12] = 0x00000001U
- // .. ==> 0XF800076C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800076C, 0x00003FFFU ,0x00001303U),
- // .. ==> 0XF8000770[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000770[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000770[2:2] = 0x00000001U
- // .. ==> MASK : 0x00000004U VAL : 0x00000004U
- // .. L2_SEL = 0
- // .. ==> 0XF8000770[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000770[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000770[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000770[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000770[12:12] = 0x00000001U
- // .. ==> 0XF8000770[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF8000774[0:0] = 0x00000001U
- // .. L0_SEL = 0
- // .. ==> 0XF8000774[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000774[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000774[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000774[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000774[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000774[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000774[12:12] = 0x00000001U
- // .. ==> 0XF8000774[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001305U),
- // .. ==> 0XF8000778[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000778[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000778[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000778[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000778[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000778[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000778[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000778[12:12] = 0x00000001U
- // .. ==> 0XF8000778[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF800077C[0:0] = 0x00000001U
- // .. L0_SEL = 0
- // .. ==> 0XF800077C[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF800077C[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF800077C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800077C[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF800077C[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF800077C[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF800077C[12:12] = 0x00000001U
- // .. ==> 0XF800077C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001305U),
- // .. ==> 0XF8000780[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000780[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000780[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000780[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000780[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000780[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000780[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000780[12:12] = 0x00000001U
- // .. ==> 0XF8000780[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF8000784[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000784[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000784[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000784[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000784[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000784[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000784[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000784[12:12] = 0x00000001U
- // .. ==> 0XF8000784[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF8000788[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000788[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000788[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000788[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000788[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000788[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000788[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000788[12:12] = 0x00000001U
- // .. ==> 0XF8000788[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF800078C[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF800078C[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF800078C[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF800078C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800078C[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF800078C[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF800078C[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF800078C[12:12] = 0x00000001U
- // .. ==> 0XF800078C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF8000790[0:0] = 0x00000001U
- // .. L0_SEL = 0
- // .. ==> 0XF8000790[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000790[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000790[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000790[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000790[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000790[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000790[12:12] = 0x00000001U
- // .. ==> 0XF8000790[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001305U),
- // .. ==> 0XF8000794[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000794[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000794[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000794[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000794[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000794[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000794[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000794[12:12] = 0x00000001U
- // .. ==> 0XF8000794[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF8000798[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF8000798[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF8000798[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF8000798[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF8000798[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF8000798[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF8000798[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF8000798[12:12] = 0x00000001U
- // .. ==> 0XF8000798[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF800079C[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF800079C[1:1] = 0x00000000U
- // .. L1_SEL = 1
- // .. ==> 0XF800079C[2:2] = 0x00000001U
- // .. L2_SEL = 0
- // .. ==> 0XF800079C[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF800079C[7:5] = 0x00000000U
- // .. Speed = 1
- // .. ==> 0XF800079C[8:8] = 0x00000001U
- // .. IO_Type = 1
- // .. ==> 0XF800079C[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF800079C[12:12] = 0x00000001U
- // .. ==> 0XF800079C[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001304U),
- // .. ==> 0XF80007A0[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007A0[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007A0[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007A0[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007A0[7:5] = 0x00000004U
- // .. ==> MASK : 0x000000E0U VAL : 0x00000080U
- // .. Speed = 0
- // .. ==> 0XF80007A0[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007A0[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007A0[12:12] = 0x00000001U
- // .. ==> 0XF80007A0[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU ,0x00001280U),
- // .. ==> 0XF80007A4[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007A4[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007A4[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007A4[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007A4[7:5] = 0x00000004U
- // .. Speed = 0
- // .. ==> 0XF80007A4[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007A4[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007A4[12:12] = 0x00000001U
- // .. ==> 0XF80007A4[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU ,0x00001280U),
- // .. ==> 0XF80007A8[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007A8[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007A8[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007A8[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007A8[7:5] = 0x00000004U
- // .. Speed = 0
- // .. ==> 0XF80007A8[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007A8[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007A8[12:12] = 0x00000001U
- // .. ==> 0XF80007A8[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU ,0x00001280U),
- // .. ==> 0XF80007AC[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007AC[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007AC[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007AC[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007AC[7:5] = 0x00000004U
- // .. Speed = 0
- // .. ==> 0XF80007AC[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007AC[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007AC[12:12] = 0x00000001U
- // .. ==> 0XF80007AC[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU ,0x00001280U),
- // .. ==> 0XF80007B0[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007B0[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007B0[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007B0[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007B0[7:5] = 0x00000004U
- // .. Speed = 0
- // .. ==> 0XF80007B0[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007B0[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007B0[12:12] = 0x00000001U
- // .. ==> 0XF80007B0[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU ,0x00001280U),
- // .. ==> 0XF80007B4[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007B4[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007B4[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007B4[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007B4[7:5] = 0x00000004U
- // .. Speed = 0
- // .. ==> 0XF80007B4[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007B4[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007B4[12:12] = 0x00000001U
- // .. ==> 0XF80007B4[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU ,0x00001280U),
- // .. ==> 0XF80007B8[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007B8[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007B8[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007B8[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF80007B8[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF80007B8[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007B8[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007B8[12:12] = 0x00000001U
- // .. ==> 0XF80007B8[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU ,0x00001200U),
- // .. ==> 0XF80007BC[0:0] = 0x00000001U
- // .. Speed = 0
- // .. ==> 0XF80007BC[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007BC[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007BC[12:12] = 0x00000001U
- // .. ==> 0XF80007BC[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007BC, 0x00003F01U ,0x00001201U),
- // .. ==> 0XF80007C0[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007C0[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007C0[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007C0[4:3] = 0x00000000U
- // .. L3_SEL = 7
- // .. ==> 0XF80007C0[7:5] = 0x00000007U
- // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U
- // .. Speed = 0
- // .. ==> 0XF80007C0[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007C0[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007C0[12:12] = 0x00000001U
- // .. ==> 0XF80007C0[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000012E0U),
- // .. ==> 0XF80007C4[0:0] = 0x00000001U
- // .. L0_SEL = 0
- // .. ==> 0XF80007C4[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007C4[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007C4[4:3] = 0x00000000U
- // .. L3_SEL = 7
- // .. ==> 0XF80007C4[7:5] = 0x00000007U
- // .. Speed = 0
- // .. ==> 0XF80007C4[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007C4[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007C4[12:12] = 0x00000001U
- // .. ==> 0XF80007C4[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000012E1U),
- // .. ==> 0XF80007C8[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007C8[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007C8[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007C8[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF80007C8[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF80007C8[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007C8[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007C8[12:12] = 0x00000001U
- // .. ==> 0XF80007C8[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU ,0x00001200U),
- // .. ==> 0XF80007CC[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007CC[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007CC[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007CC[4:3] = 0x00000000U
- // .. L3_SEL = 0
- // .. ==> 0XF80007CC[7:5] = 0x00000000U
- // .. Speed = 0
- // .. ==> 0XF80007CC[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007CC[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007CC[12:12] = 0x00000001U
- // .. ==> 0XF80007CC[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU ,0x00001200U),
- // .. ==> 0XF80007D0[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007D0[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007D0[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007D0[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007D0[7:5] = 0x00000004U
- // .. Speed = 0
- // .. ==> 0XF80007D0[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007D0[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007D0[12:12] = 0x00000001U
- // .. ==> 0XF80007D0[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001280U),
- // .. ==> 0XF80007D4[0:0] = 0x00000000U
- // .. L0_SEL = 0
- // .. ==> 0XF80007D4[1:1] = 0x00000000U
- // .. L1_SEL = 0
- // .. ==> 0XF80007D4[2:2] = 0x00000000U
- // .. L2_SEL = 0
- // .. ==> 0XF80007D4[4:3] = 0x00000000U
- // .. L3_SEL = 4
- // .. ==> 0XF80007D4[7:5] = 0x00000004U
- // .. Speed = 0
- // .. ==> 0XF80007D4[8:8] = 0x00000000U
- // .. IO_Type = 1
- // .. ==> 0XF80007D4[11:9] = 0x00000001U
- // .. PULLUP = 1
- // .. ==> 0XF80007D4[12:12] = 0x00000001U
- // .. ==> 0XF80007D4[13:13] = 0x00000000U
- EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001280U),
- // .. SDIO0_WP_SEL = 55
- // .. ==> 0XF8000830[5:0] = 0x00000037U
- // .. ==> MASK : 0x0000003FU VAL : 0x00000037U
- // .. SDIO0_CD_SEL = 47
- // .. ==> 0XF8000830[21:16] = 0x0000002FU
- // .. ==> MASK : 0x003F0000U VAL : 0x002F0000U
- EMIT_MASKWRITE(0XF8000830, 0x003F003FU ,0x002F0037U),
- // .. FINISH: MIO PROGRAMMING
- // .. START: LOCK IT BACK
- // .. LOCK_KEY = 0X767B
- // .. ==> 0XF8000004[15:0] = 0x0000767BU
- // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU
- EMIT_WRITE(0XF8000004, 0x0000767BU),
- // .. FINISH: LOCK IT BACK
- // FINISH: top
- EMIT_EXIT(),
+unsigned long ps7_peripherals_init_data_3_0[] = {
- // START: top
- // .. START: SLCR SETTINGS
- // .. UNLOCK_KEY = 0XDF0D
- // .. ==> 0XF8000008[15:0] = 0x0000DF0DU
- // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU
- EMIT_WRITE(0XF8000008, 0x0000DF0DU),
- // .. FINISH: SLCR SETTINGS
- // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS
- // .. IBUF_DISABLE_MODE = 0x1
- // .. ==> 0XF8000B48[7:7] = 0x00000001U
- // .. ==> MASK : 0x00000080U VAL : 0x00000080U
- // .. TERM_DISABLE_MODE = 0x1
- // .. ==> 0XF8000B48[8:8] = 0x00000001U
- EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U),
- // .. ==> 0XF8000B4C[7:7] = 0x00000001U
- // .. ==> 0XF8000B4C[8:8] = 0x00000001U
- EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000180U),
- // .. ==> 0XF8000B50[7:7] = 0x00000001U
- // .. ==> 0XF8000B50[8:8] = 0x00000001U
- EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U),
- // .. ==> 0XF8000B54[7:7] = 0x00000001U
- // .. ==> 0XF8000B54[8:8] = 0x00000001U
- EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000180U),
- // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS
- // .. START: SRAM/NOR SET OPMODE
- // .. FINISH: SRAM/NOR SET OPMODE
- // .. START: UART REGISTERS
- // .. BDIV = 0x6
- // .. ==> 0XE0001034[7:0] = 0x00000006U
- // .. ==> MASK : 0x000000FFU VAL : 0x00000006U
- EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U),
- // .. CD = 0x7c
- // .. ==> 0XE0001018[15:0] = 0x0000007CU
- // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU
- EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU),
- // .. STPBRK = 0x0
- // .. ==> 0XE0001000[8:8] = 0x00000000U
- // .. STTBRK = 0x0
- // .. ==> 0XE0001000[7:7] = 0x00000000U
- // .. RSTTO = 0x0
- // .. ==> 0XE0001000[6:6] = 0x00000000U
- // .. ==> MASK : 0x00000040U VAL : 0x00000000U
- // .. TXDIS = 0x0
- // .. ==> 0XE0001000[5:5] = 0x00000000U
- // .. ==> MASK : 0x00000020U VAL : 0x00000000U
- // .. TXEN = 0x1
- // .. ==> 0XE0001000[4:4] = 0x00000001U
- // .. RXDIS = 0x0
- // .. ==> 0XE0001000[3:3] = 0x00000000U
- // .. RXEN = 0x1
- // .. ==> 0XE0001000[2:2] = 0x00000001U
- // .. TXRES = 0x1
- // .. ==> 0XE0001000[1:1] = 0x00000001U
- // .. RXRES = 0x1
- // .. ==> 0XE0001000[0:0] = 0x00000001U
- EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U),
- // .. CHMODE = 0x0
- // .. ==> 0XE0001004[9:8] = 0x00000000U
- // .. ==> MASK : 0x00000300U VAL : 0x00000000U
- // .. NBSTOP = 0x0
- // .. ==> 0XE0001004[7:6] = 0x00000000U
- // .. ==> MASK : 0x000000C0U VAL : 0x00000000U
- // .. PAR = 0x4
- // .. ==> 0XE0001004[5:3] = 0x00000004U
- // .. ==> MASK : 0x00000038U VAL : 0x00000020U
- // .. CHRL = 0x0
- // .. ==> 0XE0001004[2:1] = 0x00000000U
- // .. CLKS = 0x0
- // .. ==> 0XE0001004[0:0] = 0x00000000U
- EMIT_MASKWRITE(0XE0001004, 0x000003FFU ,0x00000020U),
- // .. FINISH: UART REGISTERS
- // .. START: QSPI REGISTERS
- // .. Holdb_dr = 1
- // .. ==> 0XE000D000[19:19] = 0x00000001U
- // .. ==> MASK : 0x00080000U VAL : 0x00080000U
- EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U),
- // .. FINISH: QSPI REGISTERS
- // .. START: PL POWER ON RESET REGISTERS
- // .. PCFG_POR_CNT_4K = 0
- // .. ==> 0XF8007000[29:29] = 0x00000000U
- // .. ==> MASK : 0x20000000U VAL : 0x00000000U
- EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U),
- // .. FINISH: PL POWER ON RESET REGISTERS
- // .. START: SMC TIMING CALCULATION REGISTER UPDATE
- // .. .. START: NAND SET CYCLE
- // .. .. FINISH: NAND SET CYCLE
- // .. .. START: OPMODE
- // .. .. FINISH: OPMODE
- // .. .. START: DIRECT COMMAND
- // .. .. FINISH: DIRECT COMMAND
- // .. .. START: SRAM/NOR CS0 SET CYCLE
- // .. .. FINISH: SRAM/NOR CS0 SET CYCLE
- // .. .. START: NOR CS0 BASE ADDRESS
- // .. .. FINISH: NOR CS0 BASE ADDRESS
- // .. .. START: SRAM/NOR CS1 SET CYCLE
- // .. .. FINISH: SRAM/NOR CS1 SET CYCLE
- // .. .. START: NOR CS1 BASE ADDRESS
- // .. .. FINISH: NOR CS1 BASE ADDRESS
- // .. .. START: USB RESET
- // .. .. .. START: USB0 RESET
- // .. .. .. .. START: DIR MODE BANK 0
- // .. .. .. .. FINISH: DIR MODE BANK 0
- // .. .. .. .. START: DIR MODE BANK 1
- // .. .. .. .. DIRECTION_1 = 0x4000
- // .. .. .. .. ==> 0XE000A244[21:0] = 0x00004000U
- // .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U
- EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU ,0x00004000U),
- // .. .. .. .. FINISH: DIR MODE BANK 1
- // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0]
- // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0]
- // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16]
- // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16]
- // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32]
- // .. .. .. .. MASK_1_LSW = 0xbfff
- // .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU
- // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U
- // .. .. .. .. DATA_1_LSW = 0x4000
- // .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U
- // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U
- EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU ,0xBFFF4000U),
- // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32]
- // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48]
- // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48]
- // .. .. .. .. START: OUTPUT ENABLE BANK 0
- // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0
- // .. .. .. .. START: OUTPUT ENABLE BANK 1
- // .. .. .. .. OP_ENABLE_1 = 0x4000
- // .. .. .. .. ==> 0XE000A248[21:0] = 0x00004000U
- EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU ,0x00004000U),
- // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1
- // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0]
- // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0]
- // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16]
- // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16]
- // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32]
- // .. .. .. .. DATA_1_LSW = 0x0
- // .. .. .. .. ==> 0XE000A008[15:0] = 0x00000000U
- // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U
- EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU ,0xBFFF0000U),
- // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32]
- // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48]
- // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48]
- // .. .. .. .. START: ADD 1 MS DELAY
- EMIT_MASKDELAY(0XF8F00200, 1),
- // .. .. .. .. FINISH: ADD 1 MS DELAY
- // .. .. .. FINISH: USB0 RESET
- // .. .. FINISH: USB RESET
- // .. .. START: ENET RESET
- // .. .. FINISH: ENET RESET
- // .. .. START: I2C RESET
- // .. .. FINISH: I2C RESET
- // .. .. START: NOR CHIP SELECT
- // .. .. .. START: DIR MODE BANK 0
- // .. .. .. FINISH: DIR MODE BANK 0
- // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0]
- // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0]
- // .. .. .. START: OUTPUT ENABLE BANK 0
- // .. .. .. FINISH: OUTPUT ENABLE BANK 0
- // .. .. FINISH: NOR CHIP SELECT
- // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE
- // FINISH: top
- EMIT_EXIT(),
+unsigned long ps7_post_config_3_0[] = {
- // START: top
- // .. START: ENABLING LEVEL SHIFTER
- // .. USER_LVL_INP_EN_0 = 1
- // .. ==> 0XF8000900[3:3] = 0x00000001U
- // .. ==> MASK : 0x00000008U VAL : 0x00000008U
- // .. USER_LVL_OUT_EN_0 = 1
- // .. ==> 0XF8000900[2:2] = 0x00000001U
- // .. USER_LVL_INP_EN_1 = 1
- // .. ==> 0XF8000900[1:1] = 0x00000001U
- // .. USER_LVL_OUT_EN_1 = 1
- // .. ==> 0XF8000900[0:0] = 0x00000001U
- EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU),
- // .. FINISH: ENABLING LEVEL SHIFTER
- // .. START: FPGA RESETS TO 0
- // .. reserved_3 = 0
- // .. ==> 0XF8000240[31:25] = 0x00000000U
- // .. ==> MASK : 0xFE000000U VAL : 0x00000000U
- // .. reserved_FPGA_ACP_RST = 0
- // .. ==> 0XF8000240[24:24] = 0x00000000U
- // .. ==> MASK : 0x01000000U VAL : 0x00000000U
- // .. reserved_FPGA_AXDS3_RST = 0
- // .. ==> 0XF8000240[23:23] = 0x00000000U
- // .. ==> MASK : 0x00800000U VAL : 0x00000000U
- // .. reserved_FPGA_AXDS2_RST = 0
- // .. ==> 0XF8000240[22:22] = 0x00000000U
- // .. ==> MASK : 0x00400000U VAL : 0x00000000U
- // .. reserved_FPGA_AXDS1_RST = 0
- // .. ==> 0XF8000240[21:21] = 0x00000000U
- // .. ==> MASK : 0x00200000U VAL : 0x00000000U
- // .. reserved_FPGA_AXDS0_RST = 0
- // .. ==> 0XF8000240[20:20] = 0x00000000U
- // .. ==> MASK : 0x00100000U VAL : 0x00000000U
- // .. reserved_2 = 0
- // .. ==> 0XF8000240[19:18] = 0x00000000U
- // .. ==> MASK : 0x000C0000U VAL : 0x00000000U
- // .. reserved_FSSW1_FPGA_RST = 0
- // .. ==> 0XF8000240[17:17] = 0x00000000U
- // .. ==> MASK : 0x00020000U VAL : 0x00000000U
- // .. reserved_FSSW0_FPGA_RST = 0
- // .. ==> 0XF8000240[16:16] = 0x00000000U
- // .. ==> MASK : 0x00010000U VAL : 0x00000000U
- // .. reserved_1 = 0
- // .. ==> 0XF8000240[15:14] = 0x00000000U
- // .. ==> MASK : 0x0000C000U VAL : 0x00000000U
- // .. reserved_FPGA_FMSW1_RST = 0
- // .. ==> 0XF8000240[13:13] = 0x00000000U
- // .. reserved_FPGA_FMSW0_RST = 0
- // .. ==> 0XF8000240[12:12] = 0x00000000U
- // .. reserved_FPGA_DMA3_RST = 0
- // .. ==> 0XF8000240[11:11] = 0x00000000U
- // .. reserved_FPGA_DMA2_RST = 0
- // .. ==> 0XF8000240[10:10] = 0x00000000U
- // .. ==> MASK : 0x00000400U VAL : 0x00000000U
- // .. reserved_FPGA_DMA1_RST = 0
- // .. ==> 0XF8000240[9:9] = 0x00000000U
- // .. ==> MASK : 0x00000200U VAL : 0x00000000U
- // .. reserved_FPGA_DMA0_RST = 0
- // .. ==> 0XF8000240[8:8] = 0x00000000U
- // .. reserved = 0
- // .. ==> 0XF8000240[7:4] = 0x00000000U
- // .. ==> MASK : 0x000000F0U VAL : 0x00000000U
- // .. FPGA3_OUT_RST = 0
- // .. ==> 0XF8000240[3:3] = 0x00000000U
- // .. FPGA2_OUT_RST = 0
- // .. ==> 0XF8000240[2:2] = 0x00000000U
- // .. FPGA1_OUT_RST = 0
- // .. ==> 0XF8000240[1:1] = 0x00000000U
- // .. FPGA0_OUT_RST = 0
- // .. ==> 0XF8000240[0:0] = 0x00000000U
- EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U),
- // .. FINISH: FPGA RESETS TO 0
- // .. START: AFI REGISTERS
- // .. .. START: AFI0 REGISTERS
- // .. .. FINISH: AFI0 REGISTERS
- // .. .. START: AFI1 REGISTERS
- // .. .. FINISH: AFI1 REGISTERS
- // .. .. START: AFI2 REGISTERS
- // .. .. FINISH: AFI2 REGISTERS
- // .. .. START: AFI3 REGISTERS
- // .. .. FINISH: AFI3 REGISTERS
- // .. .. START: AFI2 SECURE REGISTER
- // .. .. FINISH: AFI2 SECURE REGISTER
- // .. FINISH: AFI REGISTERS
- // FINISH: top
- EMIT_EXIT(),
+#include "xil_io.h"
+unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; +unsigned long *ps7_pll_init_data = ps7_pll_init_data_3_0; +unsigned long *ps7_clock_init_data = ps7_clock_init_data_3_0; +unsigned long *ps7_ddr_init_data = ps7_ddr_init_data_3_0; +unsigned long *ps7_peripherals_init_data = ps7_peripherals_init_data_3_0;
+int +ps7_post_config() +{
- int ret = -1;
- // Silicon version 3
- ret = ps7_config (ps7_post_config_3_0);
- if (ret != PS7_INIT_SUCCESS) return ret;
- return PS7_INIT_SUCCESS;
+int +ps7_init() +{
- int ret;
- ps7_mio_init_data = ps7_mio_init_data_3_0;
- ps7_pll_init_data = ps7_pll_init_data_3_0;
- ps7_clock_init_data = ps7_clock_init_data_3_0;
- ps7_ddr_init_data = ps7_ddr_init_data_3_0;
- ps7_peripherals_init_data = ps7_peripherals_init_data_3_0;
- // MIO init
- ret = ps7_config (ps7_mio_init_data);
- // PLL init
- ret = ps7_config (ps7_pll_init_data);
- // Clock init
- ret = ps7_config (ps7_clock_init_data);
- // DDR init
- ret = ps7_config (ps7_ddr_init_data);
- // Peripherals init
- ret = ps7_config (ps7_peripherals_init_data);
- //xil_printf ("\n PCW Silicon Version : %d.0", pcw_ver);
This can't pass checkpatch. All that comments should be fixed. Please take a look at others ps7_init files for things which should be removed.
Thanks, Michal
The board is manufactured by Digilent Main features: - Soc: XC7Z010 (Z7-10) or XC7Z020 (Z7-20) - RAM: 1 GB DDR3L - FLASH: 16 MB QSPI - 1 Gbps Ethernet - USB 2.0 - microSD slot - Pcam camera connector - HDMI Tx and Rx - Audio codec: stereo out, stereo in, mic - 5 (Z7-10) or 6 (Z7-20) Pmod ports - 6 push-buttons, 4 switches, 5 LEDs - 1 (Z7-10) or 2 (Z7-20) RGB LEDs
The device-tree was taken from Linux with some minor corrections
Signed-off-by: Luis Araneda luaraneda@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/zynq-zybo-z7.dts | 91 ++++++++++++++++++++++++++++++++++ configs/zynq_zybo_z7_defconfig | 68 +++++++++++++++++++++++++ 3 files changed, 161 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/zynq-zybo-z7.dts create mode 100644 configs/zynq_zybo_z7_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 946023093d..cee301a4c6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -145,7 +145,8 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-zc770-xm013.dtb \ zynq-zed.dtb \ zynq-zturn.dtb \ - zynq-zybo.dtb + zynq-zybo.dtb \ + zynq-zybo-z7.dtb dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-mini-emmc0.dtb \ zynqmp-mini-emmc1.dtb \ diff --git a/arch/arm/dts/zynq-zybo-z7.dts b/arch/arm/dts/zynq-zybo-z7.dts new file mode 100644 index 0000000000..ad9264e9b1 --- /dev/null +++ b/arch/arm/dts/zynq-zybo-z7.dts @@ -0,0 +1,91 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2011 - 2015 Xilinx + * Copyright (C) 2012 National Instruments Corp. + */ +/dts-v1/; +#include "zynq-7000.dtsi" +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Digilent Zybo Z7 board"; + compatible = "digilent,zynq-zybo-z7", "xlnx,zynq-7000"; + + aliases { + ethernet0 = &gem0; + serial0 = &uart1; + spi0 = &qspi; + i2c0 = &i2c0; + i2c1 = &i2c1; + mmc0 = &sdhci0; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x40000000>; + }; + + chosen { + bootargs = ""; + stdout-path = "serial0:115200n8"; + }; + + gpio-leds { + compatible = "gpio-leds"; + + ld4 { + label = "zynq-zybo-z7:green:ld4"; + gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>; + }; + }; + + usb_phy0: phy0 { + #phy-cells = <0>; + compatible = "usb-nop-xceiv"; + reset-gpios = <&gpio0 46 GPIO_ACTIVE_LOW>; + }; +}; + +&clkc { + ps-clk-frequency = <33333333>; +}; + +&gem0 { + status = "okay"; + phy-mode = "rgmii-id"; + phy-handle = <ðernet_phy>; + + ethernet_phy: ethernet-phy@0 { + reg = <0>; + device_type = "ethernet-phy"; + }; +}; + +&i2c0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +&qspi { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&sdhci0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&uart1 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&usb0 { + status = "okay"; + dr_mode = "host"; + usb-phy = <&usb_phy0>; +}; diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig new file mode 100644 index 0000000000..068a5a96e2 --- /dev/null +++ b/configs/zynq_zybo_z7_defconfig @@ -0,0 +1,68 @@ +CONFIG_ARM=y +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x4000000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xe0001000 +CONFIG_DEBUG_UART_CLOCK=50000000 +CONFIG_SPL_STACK_R_ADDR=0x200000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo-z7" +CONFIG_DEBUG_UART=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_BOOTCOMMAND="run $modeboot || run distro_bootcmd" +CONFIG_SPL_STACK_R=y +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_PROMPT="Zynq> " +CONFIG_CMD_THOR_DOWNLOAD=y +CONFIG_CMD_DFU=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FPGA_LOADBP=y +CONFIG_CMD_FPGA_LOADFS=y +CONFIG_CMD_FPGA_LOADMK=y +CONFIG_CMD_FPGA_LOADP=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_REALTEK=y +CONFIG_ZYNQ_GEM=y +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_ZYNQ_SERIAL=y +CONFIG_ZYNQ_QSPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_THOR=y +CONFIG_DISPLAY=y
- RAM: 1 GB DDR3L
- FLASH: 16 MB QSPI
- 1 Gbps Ethernet
- USB 2.0
- microSD slot
- HDMI Tx and Rx
- zynq-zybo.dtb
- zynq-zybo.dtb \
- zynq-zybo-z7.dtb
- Copyright (C) 2011 - 2015 Xilinx
- Copyright (C) 2012 National Instruments Corp.
- model = "Digilent Zybo Z7 board";
- compatible = "digilent,zynq-zybo-z7", "xlnx,zynq-7000";
- aliases {
ethernet0 = &gem0;
serial0 = &uart1;
spi0 = &qspi;
i2c0 = &i2c0;
i2c1 = &i2c1;
mmc0 = &sdhci0;
- memory@0 {
- chosen {
bootargs = "";
- gpio-leds {
ld4 {
- usb_phy0: phy0 {
#phy-cells = <0>;
+&clkc {
- ps-clk-frequency = <33333333>;
+&gem0 {
- status = "okay";
- phy-mode = "rgmii-id";
- phy-handle = <ðernet_phy>;
- ethernet_phy: ethernet-phy@0 {
reg = <0>;
+&i2c0 {
- status = "okay";
+&i2c1 {
- status = "okay";
+&qspi {
- u-boot,dm-pre-reloc;
- status = "okay";
+&sdhci0 {
- status = "okay";
+&uart1 {
- status = "okay";
+&usb0 {
- status = "okay";
- dr_mode = "host";
- usb-phy = <&usb_phy0>;
Not sure if make sense to enable this CONFIG_DISPLAY but the rest is fine.
Thanks, Michal
Hi Michal,
[...] +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_REALTEK=y +CONFIG_ZYNQ_GEM=y +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_ZYNQ_SERIAL=y +CONFIG_ZYNQ_QSPI=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03fd +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_THOR=y +CONFIG_DISPLAY=y
Probably not, I selected it because the Zybo had it selected. I'll remove it for v2.
Additionally, for v2 I'll will be using the zynq_i2c driver (not DM) because the I2C peripherals on this board are connected like the Zybo. For more details, refer to the reply of "[PATCH 4/4] arm: zynq: use i2c cadence DM driver"
Thanks,
Luis Araneda.
On Fri, Jul 13, 2018 at 11:45 AM Luis Araneda luaraneda@gmail.com wrote:
This series adds support for the Digilent Zybo Z7 board
The only think, that I tested, and is not working yet, is reading the MAC address from the OTP region of the SPI flash memory, but I pretend to work on that [...]
Ping. I'd like to get this reviewed, and hopefully merged, before v2018.09.
Also, I'd like an opinion/comments on something related to the board. The board has two variants, "Zybo Z7-10" and "Zybo Z7-20". The differences between them are the SoC (XC7Z010 vs XC7Z020) and some components (RGB LEDs, HDMI CEC support, GPIO port) connected to the FPGA fabric. Currently, there's only one device-tree for both variants on Linux, which I think is fine because the differences between them are components connected to the FPGA fabric.
Should the variants have separate defconfig files? I need to know at compile time the variant to include the correct FPGA bitstream (fit image). So I think two defconfig files are necessary.
Maybe, even though from a device-tree perspective the variants are the same, each variant should have a device-tree file because they are physically different boards. What do you think?
Thanks,
Luis Araneda.
Luis Araneda
Michal Simek
