[PATCH 1/2] spi: ca_sflash: Remove redundant dependency
This is inside of an 'if DM_SPI' block, and thus always true.
Signed-off-by: Alexander Dahl ada@thorsis.com --- drivers/spi/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 96ea033082b..6555142a41e 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -135,7 +135,7 @@ config BCMSTB_SPI
config CORTINA_SFLASH bool "Cortina-Access Serial Flash controller driver" - depends on DM_SPI && SPI_MEM + depends on SPI_MEM help Enable the Cortina-Access Serial Flash controller driver. This driver can be used to access the SPI NOR/NAND flash on platforms embedding this
Alexander Dahl
