Re: [U-Boot] [U-Boot-Users] Compilation problem for TI3430 board.
Hi Radha,
Please don't top post.
Radha Krishna wrote:
Hi GVB, You are right. Could you tell me the solution.
Don't use DOS (aka Windows).
Since you already have a problem there, you can use "dos2unix" or equivalent. If you feel you must use Windows, many Windows editors (e.g. UltraEdit) allow you to control/convert line endings.
Best Regards, Kris.
[snip]
$ make CROSS_COMPILE=arm-none-linux-gnueabi-
omap3430sdp_config
./mkconfig: line 2: $'\r': command not
found
make: *** [omap3430sdp_config] Error 127
Is that telling you that you have DOS line endings (<CR>+<LF> i.e. \r\n) as opposed to unix line endings (\n only)?
$ make CROSS_COMPILE=arm-none-linux-gnueabi- System not configured - see README make: *** [all] Error 1
Could somebody tell me steps to compile U-Boot for TI3430.
Best Regards, Krishna.
My best guess, gvb
HTH, gvb
Hi GVB,
Thanks for your earlier help.
As you suggested I have DOS to UNIX conversion. It worked. I have another proble now.
make: arm-none-linux-gnueabi-gcc: Command not found
$ make CROSS_COMPILE=arm-none-linux-gnueabi- omap3430sdp_config Configuring for omap3430sdp board...
[SNIP] $ make CROSS_COMPILE=arm-none-linux-gnueabi- make: arm-none-linux-gnueabi-gcc: Command not found make[1]: arm-none-linux-gnueabi-gcc: Command not found make[1]: Entering directory `/cygdrive/c/u-boot/tools' make[1]: Entering directory `/cygdrive/c/u-boot/tools' ln -s ../common/environment.c environment.c ln -s ../lib_generic/crc32.c crc32.c
Could please somebody tell me the solution for this.
From: Jerry Van Baren gerald.vanbaren@ge.com Subject: Re: [U-Boot-Users] Compilation problem for TI3430 board. To: hi_krishna01@yahoo.com, "U-Boot user list" u-boot@lists.denx.de Date: Friday, October 17, 2008, 11:06 AM Hi Radha,
Best Regards, Kris.
[snip]
omap3430sdp_config
not
found
U-Boot for
TI3430.
My best guess, gvb
HTH, gvb
__________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Dear Radha Krishna,
You must install the arm-none-linux-gnueabitoolchain on your host system, and set up the PATH to include the directories wher eit was installed.
Hi Wolfgang Denk,
Thanks for the help.
Could you tell URL to download this toll chain arm-none-linux-gnueabi
Best Regards, Kris.
--- On Sat, 10/18/08, Wolfgang Denk wd@denx.de wrote:
From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot] [U-Boot-Users] Compilation problem for TI3430 board. To: hi_krishna01@yahoo.com Cc: "U-Boot user list" u-boot@lists.denx.de Date: Saturday, October 18, 2008, 12:48 AM Dear Radha Krishna,
worked.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Ahead warp factor 1" - Captain Kirk
Jerry Van Baren
Radha Krishna
