[U-Boot] [PATCH] fdt: allow address translation in case of SPL_OF_TRANSLATE
Signed-off-by: Vikas Manocha vikas.manocha@st.com --- lib/fdtdec.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 81f47ef..a1c4d16 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -112,7 +112,7 @@ fdt_addr_t fdtdec_get_addr_size_fixed(const void *blob, int node, return FDT_ADDR_T_NONE; }
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_OF_LIBFDT) +#if defined(CONFIG_SPL_OF_TRANSLATE) || defined(CONFIG_OF_LIBFDT) if (translate) addr = fdt_translate_address(blob, node, prop_addr); else
Hi Simon,
Just a reminder for your review whenever you get a chance.
Cheers, Vikas
-----Original Message----- From: Vikas MANOCHA Sent: Friday, March 24, 2017 3:19 PM To: u-boot@lists.denx.de Cc: Vikas MANOCHA vikas.manocha@st.com; Simon Glass sjg@chromium.org Subject: [PATCH] fdt: allow address translation in case of SPL_OF_TRANSLATE
-#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_OF_LIBFDT) +#if defined(CONFIG_SPL_OF_TRANSLATE) || defined(CONFIG_OF_LIBFDT) if (translate) addr = fdt_translate_address(blob, node, prop_addr); else -- 1.9.1
Please provide a commit message.
Hi Igor,
-----Original Message----- From: Igor Grinberg [mailto:grinberg@compulab.co.il] Sent: Thursday, March 30, 2017 1:59 AM To: Vikas MANOCHA vikas.manocha@st.com; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] fdt: allow address translation in case of SPL_OF_TRANSLATE
Ok, I will send v2 with commit message.
Cheers, Vikas
-- Regards, Igor.
Igor Grinberg
Vikas MANOCHA
Vikas Manocha
