[PATCH] arm64: dts: imx8m: Always name the generated fitImage u-boot.itb
Maintain backward compatibility with pre-binman u-boot file naming, the U-Boot fitImage used to be named u-boot.itb before, restore the file name after binman conversion.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Peng Fan peng.fan@nxp.com Cc: Rasmus Villemoes rasmus.villemoes@prevas.dk Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- arch/arm/dts/imx8mm-u-boot.dtsi | 1 + arch/arm/dts/imx8mn-u-boot.dtsi | 1 + arch/arm/dts/imx8mp-u-boot.dtsi | 1 + arch/arm/dts/imx8mq-u-boot.dtsi | 1 + 4 files changed, 4 insertions(+)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index c02e11def5f..d31bc822532 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -122,6 +122,7 @@
binman_imx_fit: fit { description = "Configuration to load ATF before U-Boot"; + filename = "u-boot.itb"; #ifndef CONFIG_IMX_HAB fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; #endif diff --git a/arch/arm/dts/imx8mn-u-boot.dtsi b/arch/arm/dts/imx8mn-u-boot.dtsi index 732191f5205..6875c6d44ff 100644 --- a/arch/arm/dts/imx8mn-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-u-boot.dtsi @@ -193,6 +193,7 @@
binman_imx_fit: fit { description = "Configuration to load ATF before U-Boot"; + filename = "u-boot.itb"; #ifndef CONFIG_IMX_HAB fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; #endif diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index f2655a4d0c8..56749ccacd2 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -148,6 +148,7 @@
binman_imx_fit: fit { description = "Configuration to load ATF before U-Boot"; + filename = "u-boot.itb"; #ifndef CONFIG_IMX_HAB fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; #endif diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 9b895a63857..d7a83a78f4d 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -106,6 +106,7 @@
Subject: [PATCH] arm64: dts: imx8m: Always name the generated fitImage u-boot.itb
Reviewed-by: Peng Fan peng.fan@nxp.com
Applied to u-boot-imx/next, thanks.
Fabio Estevam
Peng Fan
