[U-Boot-Users] help: images in example directory are invalid
Greetings folks
As I've mentioned, u-boot is running on the board now. However, I've so far failed to get a stand-alone application to run. For instance, when I load hello_world.srec, then check it with iminfo, I get "bad magic number".
Using mkimage -l hello_world.srec, I get 'Bad Magic Number: "hello_world.srec" is no valid image' I get the same result for hello_world (the elf format).
Using powerpc-linux-objdump -fs hello_world.srec, I see:
hello_world.srec: file format srec architecture: UNKNOWN!, flags 0x00000000:
start address 0x00040004
Contents of section .sec1: 40000 000182b0 9421ffd8 7c0802a6 429f0005 .....!..|...B... 40010 bf610014 7fc802a6 9001002c 801efff0 .a.........,.... 40020 7c7c1b78 7fc0f214 7c832378 7c9b2378 ||.x....|.#x|.#x
Can anyone explain why u-boot is building invalid images?
Thanks Ben
Re your subject: No, they are not.
What makes you think that a stand-alone application should have a valid header? Did you use mkimage to build it?
Of course.
These are vaid images. They just don't have a U-Boot image header as you didn't add one.
Benjamin Collar
