[U-Boot] [PATCH 1/2] Configs: Migrate I2C_BUS_MAX to CONFIG_SYS_I2C_BUS_MAX
For consistency with other platforms and in preparation of Kconfig migration, let's change Several TI platforms that use I2C_BUS_MAX to CONFIG_SYS_I2C_BUS_MAX
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/include/asm/arch-am33xx/i2c.h | 2 +- arch/arm/include/asm/arch-omap3/i2c.h | 2 +- arch/arm/include/asm/arch-omap4/i2c.h | 2 +- arch/arm/include/asm/arch-omap5/i2c.h | 2 +- drivers/i2c/davinci_i2c.c | 8 ++++---- drivers/i2c/omap24xx_i2c.c | 12 ++++++------ include/configs/ti_armv7_keystone2.h | 2 +- scripts/config_whitelist.txt | 2 +- 8 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/i2c.h b/arch/arm/include/asm/arch-am33xx/i2c.h index 8642c8f..a34282a 100644 --- a/arch/arm/include/asm/arch-am33xx/i2c.h +++ b/arch/arm/include/asm/arch-am33xx/i2c.h @@ -10,7 +10,7 @@ #define I2C_BASE1 0x44E0B000 #define I2C_BASE2 0x4802A000 #define I2C_BASE3 0x4819C000 -#define I2C_BUS_MAX 3 +#define CONFIG_SYS_I2C_BUS_MAX 3
#define I2C_DEFAULT_BASE I2C_BASE1
diff --git a/arch/arm/include/asm/arch-omap3/i2c.h b/arch/arm/include/asm/arch-omap3/i2c.h index 6b3a3da..d142175 100644 --- a/arch/arm/include/asm/arch-omap3/i2c.h +++ b/arch/arm/include/asm/arch-omap3/i2c.h @@ -7,7 +7,7 @@ #ifndef _OMAP3_I2C_H_ #define _OMAP3_I2C_H_
-#define I2C_BUS_MAX 3 +#define CONFIG_SYS_I2C_BUS_MAX 3 #define I2C_DEFAULT_BASE I2C_BASE1
struct i2c { diff --git a/arch/arm/include/asm/arch-omap4/i2c.h b/arch/arm/include/asm/arch-omap4/i2c.h index 463e979..1c5ed9b 100644 --- a/arch/arm/include/asm/arch-omap4/i2c.h +++ b/arch/arm/include/asm/arch-omap4/i2c.h @@ -7,7 +7,7 @@ #ifndef _OMAP4_I2C_H_ #define _OMAP4_I2C_H_
-#define I2C_BUS_MAX 4 +#define CONFIG_SYS_I2C_BUS_MAX 4 #define I2C_DEFAULT_BASE I2C_BASE1
struct i2c { diff --git a/arch/arm/include/asm/arch-omap5/i2c.h b/arch/arm/include/asm/arch-omap5/i2c.h index 2b55edf..5122cd6 100644 --- a/arch/arm/include/asm/arch-omap5/i2c.h +++ b/arch/arm/include/asm/arch-omap5/i2c.h @@ -7,7 +7,7 @@ #ifndef _OMAP5_I2C_H_ #define _OMAP5_I2C_H_
-#define I2C_BUS_MAX 5 +#define CONFIG_SYS_I2C_BUS_MAX 5 #define I2C_DEFAULT_BASE I2C_BASE1
struct i2c { diff --git a/drivers/i2c/davinci_i2c.c b/drivers/i2c/davinci_i2c.c index 2df07bb..a35ec46 100644 --- a/drivers/i2c/davinci_i2c.c +++ b/drivers/i2c/davinci_i2c.c @@ -343,11 +343,11 @@ static int _davinci_i2c_probe_chip(struct i2c_regs *i2c_base, uint8_t chip) static struct i2c_regs *davinci_get_base(struct i2c_adapter *adap) { switch (adap->hwadapnr) { -#if I2C_BUS_MAX >= 3 +#if CONFIG_SYS_I2C_BUS_MAX >= 3 case 2: return (struct i2c_regs *)I2C2_BASE; #endif -#if I2C_BUS_MAX >= 2 +#if CONFIG_SYS_I2C_BUS_MAX >= 2 case 1: return (struct i2c_regs *)I2C1_BASE; #endif @@ -412,7 +412,7 @@ U_BOOT_I2C_ADAP_COMPLETE(davinci_0, davinci_i2c_init, davinci_i2c_probe_chip, CONFIG_SYS_DAVINCI_I2C_SLAVE, 0)
-#if I2C_BUS_MAX >= 2 +#if CONFIG_SYS_I2C_BUS_MAX >= 2 U_BOOT_I2C_ADAP_COMPLETE(davinci_1, davinci_i2c_init, davinci_i2c_probe_chip, davinci_i2c_read, davinci_i2c_write, davinci_i2c_setspeed, @@ -421,7 +421,7 @@ U_BOOT_I2C_ADAP_COMPLETE(davinci_1, davinci_i2c_init, davinci_i2c_probe_chip, 1) #endif
-#if I2C_BUS_MAX >= 3 +#if CONFIG_SYS_I2C_BUS_MAX >= 3 U_BOOT_I2C_ADAP_COMPLETE(davinci_2, davinci_i2c_init, davinci_i2c_probe_chip, davinci_i2c_read, davinci_i2c_write, davinci_i2c_setspeed, diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index f71e0a5..c98c627 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -706,15 +706,15 @@ static struct i2c *omap24_get_base(struct i2c_adapter *adap) case 1: return (struct i2c *)I2C_BASE2; break; -#if (I2C_BUS_MAX > 2) +#if (CONFIG_SYS_I2C_BUS_MAX > 2) case 2: return (struct i2c *)I2C_BASE3; break; -#if (I2C_BUS_MAX > 3) +#if (CONFIG_SYS_I2C_BUS_MAX > 3) case 3: return (struct i2c *)I2C_BASE4; break; -#if (I2C_BUS_MAX > 4) +#if (CONFIG_SYS_I2C_BUS_MAX > 4) case 4: return (struct i2c *)I2C_BASE5; break; @@ -795,7 +795,7 @@ U_BOOT_I2C_ADAP_COMPLETE(omap24_1, omap24_i2c_init, omap24_i2c_probe, CONFIG_SYS_OMAP24_I2C_SPEED1, CONFIG_SYS_OMAP24_I2C_SLAVE1, 1) -#if (I2C_BUS_MAX > 2) +#if (CONFIG_SYS_I2C_BUS_MAX > 2) #if !defined(CONFIG_SYS_OMAP24_I2C_SPEED2) #define CONFIG_SYS_OMAP24_I2C_SPEED2 CONFIG_SYS_OMAP24_I2C_SPEED #endif @@ -808,7 +808,7 @@ U_BOOT_I2C_ADAP_COMPLETE(omap24_2, omap24_i2c_init, omap24_i2c_probe, CONFIG_SYS_OMAP24_I2C_SPEED2, CONFIG_SYS_OMAP24_I2C_SLAVE2, 2) -#if (I2C_BUS_MAX > 3) +#if (CONFIG_SYS_I2C_BUS_MAX > 3) #if !defined(CONFIG_SYS_OMAP24_I2C_SPEED3) #define CONFIG_SYS_OMAP24_I2C_SPEED3 CONFIG_SYS_OMAP24_I2C_SPEED #endif @@ -821,7 +821,7 @@ U_BOOT_I2C_ADAP_COMPLETE(omap24_3, omap24_i2c_init, omap24_i2c_probe, CONFIG_SYS_OMAP24_I2C_SPEED3, CONFIG_SYS_OMAP24_I2C_SLAVE3, 3) -#if (I2C_BUS_MAX > 4) +#if (CONFIG_SYS_I2C_BUS_MAX > 4) #if !defined(CONFIG_SYS_OMAP24_I2C_SPEED4) #define CONFIG_SYS_OMAP24_I2C_SPEED4 CONFIG_SYS_OMAP24_I2C_SPEED #endif diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 03e28fc..812ba51 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -160,7 +160,7 @@ #define CONFIG_SYS_DAVINCI_I2C_SLAVE1 0x10 /* SMBus host address */ #define CONFIG_SYS_DAVINCI_I2C_SPEED2 100000 #define CONFIG_SYS_DAVINCI_I2C_SLAVE2 0x10 /* SMBus host address */ -#define I2C_BUS_MAX 3 +#define CONFIG_SYS_I2C_BUS_MAX 3
/* EEPROM definitions */ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4689d63..1261c18 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3456,7 +3456,7 @@ CONFIG_SYS_I2C_BASE3 CONFIG_SYS_I2C_BASE4 CONFIG_SYS_I2C_BASE5 CONFIG_SYS_I2C_BUSES -CONFIG_SYS_I2C_BUS_MAX +CONFIG_SYS_CONFIG_SYS_I2C_BUS_MAX CONFIG_SYS_I2C_CLK_OFFSET CONFIG_SYS_I2C_DAVINCI CONFIG_SYS_I2C_DIRECT_BUS
Adam Ford
