[U-Boot] [PATCH v2 2/3] S5PC100: Function to configure the SROMC registers.
From: Naveen Krishna CH chnaveen@chnaveen.localdomain
Nand Flash, Ethernet, other features might need to configure the SROMC registers accordingly. The config_sromc() functions helps with this.
Signed-off-by: Naveen Krishna Ch ch.naveen@samsung.com --- Changes since V1:
1. Funtion config_sromc() is renamed to s5pc1xx_config_sromc(). Comments from Minkyu Kang are fixed
cpu/arm_cortexa8/s5pc1xx/Makefile | 1 + cpu/arm_cortexa8/s5pc1xx/sromc.c | 54 ++++++++++++++++++++++++++++++++++++ include/asm-arm/arch-s5pc1xx/smc.h | 3 ++ 3 files changed, 58 insertions(+), 0 deletions(-) create mode 100644 cpu/arm_cortexa8/s5pc1xx/sromc.c
diff --git a/cpu/arm_cortexa8/s5pc1xx/Makefile b/cpu/arm_cortexa8/s5pc1xx/Makefile index 4f922e6..0a6a9b4 100644 --- a/cpu/arm_cortexa8/s5pc1xx/Makefile +++ b/cpu/arm_cortexa8/s5pc1xx/Makefile @@ -34,6 +34,7 @@ SOBJS += reset.o COBJS += clock.o COBJS += cpu_info.o COBJS += timer.o +COBJS += sromc.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/cpu/arm_cortexa8/s5pc1xx/sromc.c b/cpu/arm_cortexa8/s5pc1xx/sromc.c new file mode 100644 index 0000000..1d6e738 --- /dev/null +++ b/cpu/arm_cortexa8/s5pc1xx/sromc.c @@ -0,0 +1,54 @@ +/* + * Copyright (C) 2010 Samsung Electronics + * Naveen Krishna Ch ch.naveen@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/smc.h> + +/* + * s5pc1xx_config_sromc() - select the proper SROMC Bank and configure the + * band width control and bank control registers + * srom_bank - SROM Bank 0 to 5 + * smc_bw_conf - SMC Band witdh reg configuration value + * smc_bc_conf - SMC Bank Control reg configuration value + */ +void s5pc1xx_config_sromc(u32 srom_bank, u32 smc_bw_conf, u32 smc_bc_conf) +{ + u32 tmp; +#if defined(CONFIG_S5PC100) + struct s5pc1xx_smc *const srom = + (struct s5pc1xx_smc *)S5PC100_SROMC_BASE; +#elif defined(CONFIG_S5PC110) + struct s5pc1xx_smc *const srom = + (struct s5pc1xx_smc *)S5PC110_SROMC_BASE; +#endif + + /* Configure SMC_BW register to handle proper SROMC bank */ + tmp = srom->bw; + tmp &= ~(0xF << (srom_bank * 4)); + tmp |= smc_bw_conf; + srom->bw = tmp; + + /* Configure SMC_BC register */ + srom->bc[srom_bank] = smc_bc_conf; +} diff --git a/include/asm-arm/arch-s5pc1xx/smc.h b/include/asm-arm/arch-s5pc1xx/smc.h index 2a1ee07..a280dc1 100644 --- a/include/asm-arm/arch-s5pc1xx/smc.h +++ b/include/asm-arm/arch-s5pc1xx/smc.h @@ -51,4 +51,7 @@ struct s5pc1xx_smc { }; #endif /* __ASSEMBLY__ */
+/* Configure the Band Width and Bank Control Regs for required SROMC Bank */ +void s5pc1xx_config_sromc(u32 srom_bank, u32 smc_bw_conf, u32 smc_bc_conf); + #endif /* __ASM_ARCH_SMC_H_ */
Dear Naveen Krishna Ch,
Changes since V1:
- Funtion config_sromc() is renamed to s5pc1xx_config_sromc().
- Copyright (C) 2010 Samsung Electronics
- Naveen Krishna Ch ch.naveen@samsung.com
- project.
- MA 02111-1307 USA
- s5pc1xx_config_sromc() - select the proper SROMC Bank and configure the
- band width control and bank control registers
- srom_bank - SROM Bank 0 to 5
- smc_bw_conf - SMC Band witdh reg configuration value
- smc_bc_conf - SMC Bank Control reg configuration value
- u32 tmp;
- struct s5pc1xx_smc *const srom =
- (struct s5pc1xx_smc *)S5PC100_SROMC_BASE;
- (struct s5pc1xx_smc *)S5PC110_SROMC_BASE;
NAK. please see other drivers and doc/README.s5pc1xx
- /* Configure SMC_BW register to handle proper SROMC bank */
- tmp = srom->bw;
- tmp &= ~(0xF << (srom_bank * 4));
- tmp |= smc_bw_conf;
- srom->bw = tmp;
- /* Configure SMC_BC register */
- srom->bc[srom_bank] = smc_bc_conf;
1.6.6
Thanks Minkyu Kang
HI Kang, Thanks for your comments. On 12 February 2010 13:50, Minkyu Kang promsoft@gmail.com wrote:
Changes since V1:
- project.
- MA 02111-1307 USA
the
smc_bc_conf)
u32 tmp;
I have seen your patch today, But i submited this one a day ago. So, i wil implement code accordingly in my next revision.
tmp = srom->bw;
tmp |= smc_bw_conf;
srom->bw = tmp;
Bank */
smc_bc_conf);
1.6.6
Thanks Minkyu Kang -- from. prom. www.promsoft.net _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On 12 February 2010 19:38, Naveen Krishna Ch naveenkrishna.ch@gmail.com wrote:
Changes since V1:
- project.
- MA 02111-1307 USA
the
- u32 tmp;
ok please use cpu_is_s5pc110() or cpu_is_s5pc100() function instead of if define.
- tmp = srom->bw;
- srom->bw = tmp;
1.6.6
-- Shine bright, (: Naveen Krishna Ch :)
Thanks Minkyu Kang
Minkyu Kang
Naveen Krishna Ch
Naveen Krishna Ch
