[U-Boot] [PATCH] rockchip: add defconfig for firefly-rk3399
The file is from evb-rk3399_defconfig with changes: - use rk3399-firefly dtb - re-order by make savedefconfig
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
configs/firefly-rk3399_defconfig | 65 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 65 insertions(+) create mode 100644 configs/firefly-rk3399_defconfig
diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig new file mode 100644 index 0000000..fcd33ae --- /dev/null +++ b/configs/firefly-rk3399_defconfig @@ -0,0 +1,65 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_ROCKCHIP_RK3399_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK808=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK808=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Applied to u-boot-rockchip/next, thanks!
Kever Yang
sjg@google.com
