[U-Boot-Users] [PATCH 0/2] NE2000: Fix regresssion introduced by e710185aae90 on non AX88796
Move non-inlied functions into specific drivers file Set get_prom as weak
Coding Style Cleanup
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Signed-off-by: Vlad Lungu vlad@comsys.ro
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index d5e413b..4131aad 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -42,7 +42,10 @@ COBJS-y += lan91c96.o COBJS-y += macb.o COBJS-y += mcffec.o COBJS-y += natsemi.o -COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o +ifeq ($(CONFIG_DRIVER_NE2000),y) +COBJS-y += ne2000.o +COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o +endif COBJS-y += netarm_eth.o COBJS-y += netconsole.o COBJS-y += ns7520_eth.o diff --git a/drivers/net/ax88796.c b/drivers/net/ax88796.c new file mode 100644 index 0000000..39cd101 --- /dev/null +++ b/drivers/net/ax88796.c @@ -0,0 +1,156 @@ +/* + * (c) 2007 Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#include <common.h> +#include "ax88796.h" + +/* + * Set 1 bit data + */ +static void ax88796_bitset(u32 bit) +{ + /* DATA1 */ + if( bit ) + EEDI_HIGH; + else + EEDI_LOW; + + EECLK_LOW; + udelay(1000); + EECLK_HIGH; + udelay(1000); + EEDI_LOW; +} + +/* + * Get 1 bit data + */ +static u8 ax88796_bitget(void) +{ + u8 bit; + + EECLK_LOW; + udelay(1000); + /* DATA */ + bit = EEDO; + EECLK_HIGH; + udelay(1000); + + return bit; +} + +/* + * Send COMMAND to EEPROM + */ +static void ax88796_eep_cmd(u8 cmd) +{ + ax88796_bitset(BIT_DUMMY); + switch(cmd){ + case MAC_EEP_READ: + ax88796_bitset(1); + ax88796_bitset(1); + ax88796_bitset(0); + break; + + case MAC_EEP_WRITE: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(1); + break; + + case MAC_EEP_ERACE: + ax88796_bitset(1); + ax88796_bitset(1); + ax88796_bitset(1); + break; + + case MAC_EEP_EWEN: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(0); + break; + + case MAC_EEP_EWDS: + ax88796_bitset(1); + ax88796_bitset(0); + ax88796_bitset(0); + break; + default: + break; + } +} + +static void ax88796_eep_setaddr(u16 addr) +{ + int i ; + + for( i = 7 ; i >= 0 ; i-- ) + ax88796_bitset(addr & (1 << i)); +} + +/* + * Get data from EEPROM + */ +static u16 ax88796_eep_getdata(void) +{ + ushort data = 0; + int i; + + ax88796_bitget(); /* DUMMY */ + for( i = 0 ; i < 16 ; i++ ){ + data <<= 1; + data |= ax88796_bitget(); + } + return data; +} + +static void ax88796_mac_read(u8 *buff) +{ + int i ; + u16 data; + u16 addr = 0; + + for( i = 0 ; i < 3; i++ ) + { + EECS_HIGH; + EEDI_LOW; + udelay(1000); + /* READ COMMAND */ + ax88796_eep_cmd(MAC_EEP_READ); + /* ADDRESS */ + ax88796_eep_setaddr(addr++); + /* GET DATA */ + data = ax88796_eep_getdata(); + *buff++ = (uchar)(data & 0xff); + *buff++ = (uchar)((data >> 8) & 0xff); + EECLK_LOW; + EEDI_LOW; + EECS_LOW; + } +} + +int get_prom(u8* mac_addr) +{ + u8 prom[32]; + int i; + + ax88796_mac_read(prom); + for (i = 0; i < 6; i++){ + mac_addr[i] = prom[i]; + } + return 1; +} diff --git a/drivers/net/ax88796.h b/drivers/net/ax88796.h index 069ae80..aa342cb 100644 --- a/drivers/net/ax88796.h +++ b/drivers/net/ax88796.h @@ -79,139 +79,5 @@ #endif
-/* - * Set 1 bit data - */ -static void ax88796_bitset(u32 bit) -{ - /* DATA1 */ - if( bit ) - EEDI_HIGH; - else - EEDI_LOW; - - EECLK_LOW; - udelay(1000); - EECLK_HIGH; - udelay(1000); - EEDI_LOW; -} - -/* - * Get 1 bit data - */ -static u8 ax88796_bitget(void) -{ - u8 bit; - - EECLK_LOW; - udelay(1000); - /* DATA */ - bit = EEDO; - EECLK_HIGH; - udelay(1000); - - return bit; -} - -/* - * Send COMMAND to EEPROM - */ -static void ax88796_eep_cmd(u8 cmd) -{ - ax88796_bitset(BIT_DUMMY); - switch(cmd){ - case MAC_EEP_READ: - ax88796_bitset(1); - ax88796_bitset(1); - ax88796_bitset(0); - break; - - case MAC_EEP_WRITE: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(1); - break; - - case MAC_EEP_ERACE: - ax88796_bitset(1); - ax88796_bitset(1); - ax88796_bitset(1); - break; - - case MAC_EEP_EWEN: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(0); - break; - - case MAC_EEP_EWDS: - ax88796_bitset(1); - ax88796_bitset(0); - ax88796_bitset(0); - break; - default: - break; - } -} - -static void ax88796_eep_setaddr(u16 addr) -{ - int i ; - for( i = 7 ; i >= 0 ; i-- ) - ax88796_bitset(addr & (1 << i)); -} - -/* - * Get data from EEPROM - */ -static u16 ax88796_eep_getdata(void) -{ - ushort data = 0; - int i; - - ax88796_bitget(); /* DUMMY */ - for( i = 0 ; i < 16 ; i++ ){ - data <<= 1; - data |= ax88796_bitget(); - } - return data; -} - -static void ax88796_mac_read(u8 *buff) -{ - int i ; - u16 data, addr = 0; - - for( i = 0 ; i < 3; i++ ) - { - EECS_HIGH; - EEDI_LOW; - udelay(1000); - /* READ COMMAND */ - ax88796_eep_cmd(MAC_EEP_READ); - /* ADDRESS */ - ax88796_eep_setaddr(addr++); - /* GET DATA */ - data = ax88796_eep_getdata(); - *buff++ = (uchar)(data & 0xff); - *buff++ = (uchar)((data >> 8) & 0xff); - EECLK_LOW; - EEDI_LOW; - EECS_LOW; - } -} - -int get_prom(u8* mac_addr) -{ - u8 prom[32]; - int i; - - ax88796_mac_read(prom); - for (i = 0; i < 6; i++){ - mac_addr[i] = prom[i]; - } - return 1; -}
#endif /* __DRIVERS_AX88796L_H__ */ diff --git a/drivers/net/ne2000.c b/drivers/net/ne2000.c index 99baeea..3f32693 100644 --- a/drivers/net/ne2000.c +++ b/drivers/net/ne2000.c @@ -1,5 +1,5 @@ /* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com +Ported to U-Boot by Christian Pellegrin chri@ascensit.com
Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world @@ -23,7 +23,7 @@ Software Foundation; either version 2 or (at your option) any later version.
eCos is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or -FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along @@ -57,13 +57,13 @@ and are covered by the appropriate copyright disclaimers included herein. ========================================================================== #####DESCRIPTIONBEGIN####
-Author(s): gthomas -Contributors: gthomas, jskov, rsandifo -Date: 2001-06-13 +Author(s): gthomas +Contributors: gthomas, jskov, rsandifo +Date: 2001-06-13 Purpose: Description:
-FIXME: Will fail if pinged with large packets (1520 bytes) +FIXME: Will fail if pinged with large packets (1520 bytes) Add promisc config Add SNMP
@@ -77,24 +77,26 @@ Add SNMP #include <net.h> #include <malloc.h>
-#define mdelay(n) udelay((n)*1000) +#define mdelay(n) udelay((n)*1000) /* forward definition of function used for the uboot interface */ void uboot_push_packet_len(int len); void uboot_push_tx_done(int key, int val);
/* - ------------------------------------------------------------------------ - Debugging details - - Set to perms of: - 0 disables all debug output - 1 for process debug output - 2 for added data IO output: get_reg, put_reg - 4 for packet allocation/free output - 8 for only startup status, so we can tell we're installed OK -*/ -/*#define DEBUG 0xf*/ + * Debugging details + * + * Set to perms of: + * 0 disables all debug output + * 1 for process debug output + * 2 for added data IO output: get_reg, put_reg + * 4 for packet allocation/free output + * 8 for only startup status, so we can tell we're installed OK + */ +#if 0 +#define DEBUG 0xf +#else #define DEBUG 0 +#endif
#if DEBUG & 1 #define DEBUG_FUNCTION() do { printf("%s\n", __FUNCTION__); } while (0) @@ -124,31 +126,35 @@ dp83902a_init(void) { dp83902a_priv_data_t *dp = &nic; u8* base; +#if defined(NE2000_BASIC_INIT) + int i; +#endif
DEBUG_FUNCTION();
base = dp->base; - if (!base) return false; /* No device found */ + if (!base) + return false; /* No device found */
DEBUG_LINE();
#if defined(NE2000_BASIC_INIT) /* AX88796L doesn't need */ /* Prepare ESA */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ + DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ /* Use the address from the serial EEPROM */ for (i = 0; i < 6; i++) DP_IN(base, DP_P1_PAR0+i, dp->esa[i]); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */ + DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */
printf("NE2000 - %s ESA: %02x:%02x:%02x:%02x:%02x:%02x\n", - "eeprom", - dp->esa[0], - dp->esa[1], - dp->esa[2], - dp->esa[3], - dp->esa[4], - dp->esa[5] ); + "eeprom", + dp->esa[0], + dp->esa[1], + dp->esa[2], + dp->esa[3], + dp->esa[4], + dp->esa[5] );
#endif /* NE2000_BASIC_INIT */ return true; @@ -162,7 +168,7 @@ dp83902a_stop(void)
DEBUG_FUNCTION();
- DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ + DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ DP_OUT(base, DP_IMR, 0x00); /* Disable all interrupts */
@@ -170,11 +176,11 @@ dp83902a_stop(void) }
/* - This function is called to "start up" the interface. It may be called - multiple times, even when the hardware is already running. It will be - called whenever something "hardware oriented" changes and should leave - the hardware ready to send/receive packets. -*/ + * This function is called to "start up" the interface. It may be called + * multiple times, even when the hardware is already running. It will be + * called whenever something "hardware oriented" changes and should leave + * the hardware ready to send/receive packets. + */ static void dp83902a_start(u8 * enaddr) { @@ -196,16 +202,16 @@ dp83902a_start(u8 * enaddr) dp->tx_started = false; dp->running = true; DP_OUT(base, DP_PSTART, dp->rx_buf_start); /* Receive ring start page */ - DP_OUT(base, DP_BNDRY, dp->rx_buf_end-1); /* Receive ring boundary */ + DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); /* Receive ring boundary */ DP_OUT(base, DP_PSTOP, dp->rx_buf_end); /* Receive ring end page */ - dp->rx_next = dp->rx_buf_start-1; + dp->rx_next = dp->rx_buf_start - 1; dp->running = true; DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ DP_OUT(base, DP_IMR, DP_IMR_All); /* Enable all interrupts */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ - DP_OUT(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ + DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ + DP_OUT(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ dp->running = true; - for (i = 0; i < ETHER_ADDR_LEN; i++) { + for (i = 0; i < ETHER_ADDR_LEN; i++) { /* FIXME */ /*((vu_short*)( base + ((DP_P1_PAR0 + i) * 2) + * 0x1400)) = enaddr[i];*/ @@ -214,15 +220,15 @@ dp83902a_start(u8 * enaddr) /* Enable and start device */ DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); DP_OUT(base, DP_TCR, DP_TCR_NORMAL); /* Normal transmit operations */ - DP_OUT(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ + DP_OUT(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ dp->running = true; }
/* - This routine is called to start the transmitter. It is split out from the - data handling routine so it may be called either when data becomes first - available or when an Tx interrupt occurs -*/ + * This routine is called to start the transmitter. It is split out from the + * data handling routine so it may be called either when data becomes first + * available or when an Tx interrupt occurs + */
static void dp83902a_start_xmit(int start_page, int len) @@ -249,9 +255,9 @@ dp83902a_start_xmit(int start_page, int len) }
/* - This routine is called to send data to the hardware. It is known a-priori - that there is free buffer space (dp->tx_next). -*/ + * This routine is called to send data to the hardware. It is known a-priori + * that there is free buffer space (dp->tx_next). + */ static void dp83902a_send(u8 *data, int total_len, u32 key) { @@ -265,7 +271,8 @@ dp83902a_send(u8 *data, int total_len, u32 key) DEBUG_FUNCTION();
len = pkt_len = total_len; - if (pkt_len < IEEE_8023_MIN_FRAME) pkt_len = IEEE_8023_MIN_FRAME; + if (pkt_len < IEEE_8023_MIN_FRAME) + pkt_len = IEEE_8023_MIN_FRAME;
start_page = dp->tx_next; if (dp->tx_next == dp->tx_buf1) { @@ -284,17 +291,19 @@ dp83902a_send(u8 *data, int total_len, u32 key) printf("TX prep page %d len %d\n", start_page, pkt_len); #endif
- DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ + DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ { - /* Dummy read. The manual sez something slightly different, */ - /* but the code is extended a bit to do what Hitachi's monitor */ - /* does (i.e., also read data). */ + /* + * Dummy read. The manual sez something slightly different, + * but the code is extended a bit to do what Hitachi's monitor + * does (i.e., also read data). + */
u16 tmp; int len = 1;
- DP_OUT(base, DP_RSAL, 0x100-len); - DP_OUT(base, DP_RSAH, (start_page-1) & 0xff); + DP_OUT(base, DP_RSAL, 0x100 - len); + DP_OUT(base, DP_RSAH, (start_page - 1) & 0xff); DP_OUT(base, DP_RBCL, len); DP_OUT(base, DP_RBCH, 0); DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_RDMA | DP_CR_START); @@ -302,8 +311,10 @@ dp83902a_send(u8 *data, int total_len, u32 key) }
#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* Stall for a bit before continuing to work around random data */ - /* corruption problems on some platforms. */ + /* + * Stall for a bit before continuing to work around random data + * corruption problems on some platforms. + */ CYGACC_CALL_IF_DELAY_US(1); #endif
@@ -336,16 +347,18 @@ dp83902a_send(u8 *data, int total_len, u32 key) printf(" + %d bytes of padding\n", pkt_len - total_len); #endif /* Padding to 802.3 length was required */ - for (i = total_len; i < pkt_len;) { + for (i = total_len; i < pkt_len;) { i++; DP_OUT_DATA(dp->data, 0); } }
#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* After last data write, delay for a bit before accessing the */ - /* device again, or we may get random data corruption in the last */ - /* datum (on some platforms). */ + /* + * After last data write, delay for a bit before accessing the + * device again, or we may get random data corruption in the last + * datum (on some platforms). + */ CYGACC_CALL_IF_DELAY_US(1); #endif
@@ -360,21 +373,21 @@ dp83902a_send(u8 *data, int total_len, u32 key) /* Start transmit if not already going */ if (!dp->tx_started) { if (start_page == dp->tx1) { - dp->tx_int = 1; /* Expecting interrupt from BUF1 */ + dp->tx_int = 1; /* Expecting interrupt from BUF1 */ } else { - dp->tx_int = 2; /* Expecting interrupt from BUF2 */ + dp->tx_int = 2; /* Expecting interrupt from BUF2 */ } dp83902a_start_xmit(start_page, pkt_len); } }
/* - This function is called when a packet has been received. It's job is - to prepare to unload the packet from the hardware. Once the length of - the packet is known, the upper layer of the driver can be told. When - the upper layer is ready to unload the packet, the internal function - 'dp83902a_recv' will be called to actually fetch it from the hardware. -*/ + * This function is called when a packet has been received. It's job is + * to prepare to unload the packet from the hardware. Once the length of + * the packet is known, the upper layer of the driver can be told. When + * the upper layer is ready to unload the packet, the internal function + * 'dp83902a_recv' will be called to actually fetch it from the hardware. + */ static void dp83902a_RxEvent(void) { @@ -407,9 +420,9 @@ dp83902a_RxEvent(void) DP_OUT(base, DP_RSAH, pkt); if (dp->rx_next == pkt) { if (cur == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end-1); + DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); else - DP_OUT(base, DP_BNDRY, cur-1); /* Update pointer */ + DP_OUT(base, DP_BNDRY, cur - 1); /* Update pointer */ return; } dp->rx_next = pkt; @@ -420,13 +433,13 @@ dp83902a_RxEvent(void) #endif
/* read header (get data size)*/ - for (i = 0; i < sizeof(rcv_hdr);) { + for (i = 0; i < sizeof(rcv_hdr);) { DP_IN_DATA(dp->data, rcv_hdr[i++]); }
#if DEBUG & 5 printf("rx hdr %02x %02x %02x %02x\n", - rcv_hdr[0], rcv_hdr[1], rcv_hdr[2], rcv_hdr[3]); + rcv_hdr[0], rcv_hdr[1], rcv_hdr[2], rcv_hdr[3]); #endif len = ((rcv_hdr[3] << 8) | rcv_hdr[2]) - sizeof(rcv_hdr);
@@ -434,19 +447,19 @@ dp83902a_RxEvent(void) uboot_push_packet_len(len);
if (rcv_hdr[1] == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end-1); + DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); else - DP_OUT(base, DP_BNDRY, rcv_hdr[1]-1); /* Update pointer */ + DP_OUT(base, DP_BNDRY, rcv_hdr[1] - 1); /* Update pointer */ } }
/* - This function is called as a result of the "eth_drv_recv()" call above. - It's job is to actually fetch data for a packet from the hardware once - memory buffers have been allocated for the packet. Note that the buffers - may come in pieces, using a scatter-gather list. This allows for more - efficient processing in the upper layers of the stack. -*/ + * This function is called as a result of the "eth_drv_recv()" call above. + * It's job is to actually fetch data for a packet from the hardware once + * memory buffers have been allocated for the packet. Note that the buffers + * may come in pieces, using a scatter-gather list. This allows for more + * efficient processing in the upper layers of the stack. + */ static void dp83902a_recv(u8 *data, int len) { @@ -478,7 +491,7 @@ dp83902a_recv(u8 *data, int len) #endif
saved = false; - for (i = 0; i < 1; i++) { + for (i = 0; i < 1; i++) { if (data) { mlen = len; #if DEBUG & 4 @@ -545,8 +558,10 @@ dp83902a_TxEvent(void) uboot_push_tx_done(key, 0); }
-/* Read the tally counters to clear them. Called in response to a CNT */ -/* interrupt. */ +/* + * Read the tally counters to clear them. Called in response to a CNT + * interrupt. + */ static void dp83902a_ClearCounters(void) { @@ -560,8 +575,10 @@ dp83902a_ClearCounters(void) DP_OUT(base, DP_ISR, DP_ISR_CNT); }
-/* Deal with an overflow condition. This code follows the procedure set */ -/* out in section 7.0 of the datasheet. */ +/* + * Deal with an overflow condition. This code follows the procedure set + * out in section 7.0 of the datasheet. + */ static void dp83902a_Overflow(void) { @@ -581,9 +598,11 @@ dp83902a_Overflow(void) DP_OUT(base, DP_TCR, DP_TCR_LOCAL); DP_OUT(base, DP_CR, DP_CR_START | DP_CR_NODMA);
- /* Read in as many packets as we can and acknowledge any and receive */ - /* interrupts. Since the buffer has overflowed, a receive event of */ - /* some kind will have occured. */ + /* + * Read in as many packets as we can and acknowledge any and receive + * interrupts. Since the buffer has overflowed, a receive event of + * some kind will have occured. + */ dp83902a_RxEvent(); DP_OUT(base, DP_ISR, DP_ISR_RxP|DP_ISR_RxE);
@@ -591,8 +610,10 @@ dp83902a_Overflow(void) DP_OUT(base, DP_ISR, DP_ISR_OFLW); DP_OUT(base, DP_TCR, DP_TCR_NORMAL);
- /* If a transmit command was issued, but no transmit event has occured, */ - /* restart it here. */ + /* + * If a transmit command was issued, but no transmit event has occured, + * restart it here. + */ DP_IN(base, DP_ISR, isr); if (dp->tx_started && !(isr & (DP_ISR_TxP|DP_ISR_TxE))) { DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); @@ -609,25 +630,33 @@ dp83902a_poll(void) DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0 | DP_CR_START); DP_IN(base, DP_ISR, isr); while (0 != isr) { - /* The CNT interrupt triggers when the MSB of one of the error */ - /* counters is set. We don't much care about these counters, but */ - /* we should read their values to reset them. */ + /* + * The CNT interrupt triggers when the MSB of one of the error + * counters is set. We don't much care about these counters, but + * we should read their values to reset them. + */ if (isr & DP_ISR_CNT) { dp83902a_ClearCounters(); } - /* Check for overflow. It's a special case, since there's a */ - /* particular procedure that must be followed to get back into */ - /* a running state.a */ + /* + * Check for overflow. It's a special case, since there's a + * particular procedure that must be followed to get back into + * a running state.a + */ if (isr & DP_ISR_OFLW) { dp83902a_Overflow(); } else { - /* Other kinds of interrupts can be acknowledged simply by */ - /* clearing the relevant bits of the ISR. Do that now, then */ - /* handle the interrupts we care about. */ - DP_OUT(base, DP_ISR, isr); /* Clear set bits */ + /* + * Other kinds of interrupts can be acknowledged simply by + * clearing the relevant bits of the ISR. Do that now, then + * handle the interrupts we care about. + */ + DP_OUT(base, DP_ISR, isr); /* Clear set bits */ if (!dp->running) break; /* Is this necessary? */ - /* Check for tx_started on TX event since these may happen */ - /* spuriously it seems. */ + /* + * Check for tx_started on TX event since these may happen + * spuriously it seems. + */ if (isr & (DP_ISR_TxP|DP_ISR_TxE) && dp->tx_started) { dp83902a_TxEvent(); } @@ -658,8 +687,8 @@ typedef struct hw_info_t { #define HAS_MII 0x40 #define USE_SHMEM 0x80 /* autodetected */
-#define AM79C9XX_HOME_PHY 0x00006B90 /* HomePNA PHY */ -#define AM79C9XX_ETH_PHY 0x00006B70 /* 10baseT PHY */ +#define AM79C9XX_HOME_PHY 0x00006B90 /* HomePNA PHY */ +#define AM79C9XX_ETH_PHY 0x00006B70 /* 10baseT PHY */ #define MII_PHYID_REV_MASK 0xfffffff0 #define MII_PHYID_REG1 0x02 #define MII_PHYID_REG2 0x03 @@ -669,7 +698,7 @@ static hw_info_t hw_info[] = { { /* Allied Telesis LA-PCM */ 0x0ff0, 0x00, 0x00, 0xf4, 0 }, { /* APEX MultiCard */ 0x03f4, 0x00, 0x20, 0xe5, 0 }, { /* ASANTE FriendlyNet */ 0x4910, 0x00, 0x00, 0x94, - DELAY_OUTPUT | HAS_IBM_MISC }, + DELAY_OUTPUT | HAS_IBM_MISC }, { /* Danpex EN-6200P2 */ 0x0110, 0x00, 0x40, 0xc7, 0 }, { /* DataTrek NetCard */ 0x0ff0, 0x00, 0x20, 0xe8, 0 }, { /* Dayna CommuniCard E */ 0x0110, 0x00, 0x80, 0x19, 0 }, @@ -677,48 +706,48 @@ static hw_info_t hw_info[] = { { /* EP-210 Ethernet */ 0x0110, 0x00, 0x40, 0x33, 0 }, { /* EP4000 Ethernet */ 0x01c0, 0x00, 0x00, 0xb4, 0 }, { /* Epson EEN10B */ 0x0ff0, 0x00, 0x00, 0x48, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* ELECOM Laneed LD-CDWA */ 0xb8, 0x08, 0x00, 0x42, 0 }, { /* Hypertec Ethernet */ 0x01c0, 0x00, 0x40, 0x4c, 0 }, { /* IBM CCAE */ 0x0ff0, 0x08, 0x00, 0x5a, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM CCAE */ 0x0ff0, 0x00, 0x04, 0xac, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM CCAE */ 0x0ff0, 0x00, 0x06, 0x29, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM FME */ 0x0374, 0x08, 0x00, 0x5a, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* IBM FME */ 0x0374, 0x00, 0x04, 0xac, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Kansai KLA-PCM/T */ 0x0ff0, 0x00, 0x60, 0x87, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0374, 0x08, 0x00, 0x17, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0374, 0x00, 0xc0, 0xa8, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0374, 0x00, 0xa0, 0xb0, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* NSC DP83903 */ 0x0198, 0x00, 0x20, 0xe0, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* I-O DATA PCLA/T */ 0x0ff0, 0x00, 0xa0, 0xb0, 0 }, { /* Katron PE-520 */ 0x0110, 0x00, 0x40, 0xf6, 0 }, { /* Kingston KNE-PCM/x */ 0x0ff0, 0x00, 0xc0, 0xf0, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Kingston KNE-PCM/x */ 0x0ff0, 0xe2, 0x0c, 0x0f, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Kingston KNE-PC2 */ 0x0180, 0x00, 0xc0, 0xf0, 0 }, { /* Maxtech PCN2000 */ 0x5000, 0x00, 0x00, 0xe8, 0 }, { /* NDC Instant-Link */ 0x003a, 0x00, 0x80, 0xc6, 0 }, { /* NE2000 Compatible */ 0x0ff0, 0x00, 0xa0, 0x0c, 0 }, { /* Network General Sniffer */ 0x0ff0, 0x00, 0x00, 0x65, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* Panasonic VEL211 */ 0x0ff0, 0x00, 0x80, 0x45, - HAS_MISC_REG | HAS_IBM_MISC }, + HAS_MISC_REG | HAS_IBM_MISC }, { /* PreMax PE-200 */ 0x07f0, 0x00, 0x20, 0xe0, 0 }, { /* RPTI EP400 */ 0x0110, 0x00, 0x40, 0x95, 0 }, { /* SCM Ethernet */ 0x0ff0, 0x00, 0x20, 0xcb, 0 }, { /* Socket EA */ 0x4000, 0x00, 0xc0, 0x1b, - DELAY_OUTPUT | HAS_MISC_REG | USE_BIG_BUF }, + DELAY_OUTPUT | HAS_MISC_REG | USE_BIG_BUF }, { /* Socket LP-E CF+ */ 0x01c0, 0x00, 0xc0, 0x1b, 0 }, { /* SuperSocket RE450T */ 0x0110, 0x00, 0xe0, 0x98, 0 }, { /* Volktek NPL-402CT */ 0x0060, 0x00, 0x40, 0x05, 0 }, @@ -729,8 +758,6 @@ static hw_info_t hw_info[] = {
#define NR_INFO (sizeof(hw_info)/sizeof(hw_info_t))
-static hw_info_t default_info = { 0, 0, 0, 0, 0 }; - u8 dev_addr[6];
#define PCNET_CMD 0x00 @@ -738,17 +765,104 @@ u8 dev_addr[6]; #define PCNET_RESET 0x1f /* Issue a read to reset, a write to clear. */ #define PCNET_MISC 0x18 /* For IBM CCAE and Socket EA cards */
+static void pcnet_reset_8390(void) +{ + int i, r; + + PRINTK("nic base is %lx\n", nic_base); + + n2k_outb(E8390_NODMA + E8390_PAGE0+E8390_STOP, E8390_CMD); + PRINTK("cmd (at %lx) is %x\n", nic_base + E8390_CMD, n2k_inb(E8390_CMD)); + n2k_outb(E8390_NODMA+E8390_PAGE1+E8390_STOP, E8390_CMD); + PRINTK("cmd (at %lx) is %x\n", nic_base + E8390_CMD, n2k_inb(E8390_CMD)); + n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); + PRINTK("cmd (at %lx) is %x\n", nic_base + E8390_CMD, n2k_inb(E8390_CMD)); + n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); + + n2k_outb(n2k_inb(PCNET_RESET), PCNET_RESET); + + for (i = 0; i < 100; i++) { + if ((r = (n2k_inb(EN0_ISR) & ENISR_RESET)) != 0) + break; + PRINTK("got %x in reset\n", r); + udelay(100); + } + n2k_outb(ENISR_RESET, EN0_ISR); /* Ack intr. */ + + if (i == 100) + printf("pcnet_reset_8390() did not complete.\n"); +} /* pcnet_reset_8390 */ + +int get_prom(u8* mac_addr) __attribute__ ((weak, alias ("__get_prom"))); +int __get_prom(u8* mac_addr) +{ + u8 prom[32]; + int i, j; + struct { + u_char value, offset; + } program_seq[] = { + {E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD}, /* Select page 0*/ + {0x48, EN0_DCFG}, /* Set byte-wide (0x48) access. */ + {0x00, EN0_RCNTLO}, /* Clear the count regs. */ + {0x00, EN0_RCNTHI}, + {0x00, EN0_IMR}, /* Mask completion irq. */ + {0xFF, EN0_ISR}, + {E8390_RXOFF, EN0_RXCR}, /* 0x20 Set to monitor */ + {E8390_TXOFF, EN0_TXCR}, /* 0x02 and loopback mode. */ + {32, EN0_RCNTLO}, + {0x00, EN0_RCNTHI}, + {0x00, EN0_RSARLO}, /* DMA starting at 0x0000. */ + {0x00, EN0_RSARHI}, + {E8390_RREAD+E8390_START, E8390_CMD}, + }; + + PRINTK ("trying to get MAC via prom reading\n"); + + pcnet_reset_8390 (); + + mdelay (10); + + for (i = 0; i < sizeof (program_seq) / sizeof (program_seq[0]); i++) + n2k_outb (program_seq[i].value, program_seq[i].offset); + + PRINTK ("PROM:"); + for (i = 0; i < 32; i++) { + prom[i] = n2k_inb (PCNET_DATAPORT); + PRINTK (" %02x", prom[i]); + } + PRINTK ("\n"); + for (i = 0; i < NR_INFO; i++) { + if ((prom[0] == hw_info[i].a0) && + (prom[2] == hw_info[i].a1) && + (prom[4] == hw_info[i].a2)) { + PRINTK ("matched board %d\n", i); + break; + } + } + if ((i < NR_INFO) || ((prom[28] == 0x57) && (prom[30] == 0x57))) { + PRINTK ("on exit i is %d/%ld\n", i, NR_INFO); + PRINTK ("MAC address is "); + for (j = 0; j < 6; j++) { + mac_addr[j] = prom[j << 1]; + PRINTK ("%02x:", mac_addr[i]); + } + PRINTK ("\n"); + return (i < NR_INFO) ? i : 0; + } + return 0; +} + u32 nic_base;
/* U-boot specific routines */ static u8 *pbuf = NULL;
static int pkey = -1; -static int initialized=0; +static int initialized = 0;
void uboot_push_packet_len(int len) { PRINTK("pushed len = %d\n", len); - if (len>=2000) { + if (len >= 2000) { printf("NE2000: packet too big\n"); return; } @@ -764,7 +878,7 @@ void uboot_push_tx_done(int key, int val) { }
int eth_init(bd_t *bd) { - static hw_info_t * r; + int r; char ethaddr[20];
PRINTK("### eth_init\n"); @@ -779,7 +893,7 @@ int eth_init(bd_t *bd) {
#ifdef CONFIG_DRIVER_NE2000_CCR { - vu_char *p = (vu_char *) CONFIG_DRIVER_NE2000_CCR; + vu_char *p = (vu_char *) CONFIG_DRIVER_NE2000_CCR;
PRINTK("CCR before is %x\n", *p); *p = CONFIG_DRIVER_NE2000_VAL; @@ -811,7 +925,7 @@ int eth_init(bd_t *bd) { return -1;
dp83902a_start(dev_addr); - initialized=1; + initialized = 1;
return 0; } @@ -821,7 +935,7 @@ void eth_halt() { PRINTK("### eth_halt\n"); if(initialized) dp83902a_stop(); - initialized=0; + initialized = 0; }
int eth_rx() { diff --git a/drivers/net/ne2000.h b/drivers/net/ne2000.h index d324a00..0b21612 100644 --- a/drivers/net/ne2000.h +++ b/drivers/net/ne2000.h @@ -81,6 +81,7 @@ are GPL, so this is, of course, GPL.
#define DP_DATA 0x10 #define START_PG 0x50 /* First page of TX buffer */ +#define START_PG2 0x48 #define STOP_PG 0x80 /* Last page +1 of RX ring */
#define RX_START 0x50 @@ -90,90 +91,4 @@ are GPL, so this is, of course, GPL. #define DP_OUT(_b_, _o_, _d_) *( (vu_char *) ((_b_)+(_o_))) = (_d_) #define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_char *) ((_b_))) #define DP_OUT_DATA(_b_, _d_) *( (vu_char *) ((_b_))) = (_d_) - -static void pcnet_reset_8390(void) -{ - int i, r; - - PRINTK("nic base is %lx\n", nic_base); - - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic_base+ E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE1+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic_base+ E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", nic_base+ E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - - n2k_outb(n2k_inb(PCNET_RESET), PCNET_RESET); - - for (i = 0; i < 100; i++) { - if ((r = (n2k_inb(EN0_ISR) & ENISR_RESET)) != 0) - break; - PRINTK("got %x in reset\n", r); - udelay(100); - } - n2k_outb(ENISR_RESET, EN0_ISR); /* Ack intr. */ - - if (i == 100) - printf("pcnet_reset_8390() did not complete.\n"); -} /* pcnet_reset_8390 */ - -int get_prom(u8* mac_addr) -{ - u8 prom[32]; - int i, j; - struct { - u_char value, offset; - } program_seq[] = { - {E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD}, /* Select page 0*/ - {0x48, EN0_DCFG}, /* Set byte-wide (0x48) access. */ - {0x00, EN0_RCNTLO}, /* Clear the count regs. */ - {0x00, EN0_RCNTHI}, - {0x00, EN0_IMR}, /* Mask completion irq. */ - {0xFF, EN0_ISR}, - {E8390_RXOFF, EN0_RXCR}, /* 0x20 Set to monitor */ - {E8390_TXOFF, EN0_TXCR}, /* 0x02 and loopback mode. */ - {32, EN0_RCNTLO}, - {0x00, EN0_RCNTHI}, - {0x00, EN0_RSARLO}, /* DMA starting at 0x0000. */ - {0x00, EN0_RSARHI}, - {E8390_RREAD+E8390_START, E8390_CMD}, - }; - - PRINTK ("trying to get MAC via prom reading\n"); - - pcnet_reset_8390 (); - - mdelay (10); - - for (i = 0; i < sizeof (program_seq) / sizeof (program_seq[0]); i++) - n2k_outb (program_seq[i].value, program_seq[i].offset); - - PRINTK ("PROM:"); - for (i = 0; i < 32; i++) { - prom[i] = n2k_inb (PCNET_DATAPORT); - PRINTK (" %02x", prom[i]); - } - PRINTK ("\n"); - for (i = 0; i < NR_INFO; i++) { - if ((prom[0] == hw_info[i].a0) && - (prom[2] == hw_info[i].a1) && - (prom[4] == hw_info[i].a2)) { - PRINTK ("matched board %d\n", i); - break; - } - } - if ((i < NR_INFO) || ((prom[28] == 0x57) && (prom[30] == 0x57))) { - PRINTK ("on exit i is %d/%ld\n", i, NR_INFO); - PRINTK ("MAC address is "); - for (j = 0; j < 6; j++) { - mac_addr[j] = prom[j << 1]; - PRINTK ("%02x:", mac_addr[i]); - } - PRINTK ("\n"); - return (i < NR_INFO) ? i : 0; - } - return NULL; -} #endif /* __DRIVERS_NE2000_H__ */ diff --git a/drivers/net/ne2000_base.h b/drivers/net/ne2000_base.h index 1badf62..d8768e8 100644 --- a/drivers/net/ne2000_base.h +++ b/drivers/net/ne2000_base.h @@ -120,7 +120,6 @@ typedef struct dp83902a_priv_data { ------------------------------------------------------------------------ Some forward declarations */ -int get_prom( u8* mac_addr); static void dp83902a_poll(void);
add CONFIG_ENV_OVERWRITE
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index e164019..b775714 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -12,7 +12,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -28,13 +28,14 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_MIPS32 1 /* MIPS32 CPU core */ -#define CONFIG_QEMU_MIPS 1 +#define CONFIG_MIPS32 1 /* MIPS32 CPU core */ +#define CONFIG_QEMU_MIPS 1 #define CONFIG_MISC_INIT_R
/*IP address is default used by Qemu*/ -#define CONFIG_IPADDR 10.0.2.15 /* Our IP address */ -#define CONFIG_SERVERIP 10.0.2.2 /* Server IP address*/ +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_IPADDR 10.0.2.15 /* Our IP address */ +#define CONFIG_SERVERIP 10.0.2.2 /* Server IP address*/
#define CONFIG_BOOTDELAY 10 /* autoboot after 10 seconds */
@@ -56,7 +57,6 @@
#define CONFIG_BOOTCOMMAND "bootp;bootelf"
- /* * BOOTP options */ @@ -65,7 +65,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -74,21 +73,18 @@ #define CONFIG_CMD_ELF #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_LOADB -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS #define CONFIG_CMD_DHCP
#define CONFIG_DRIVER_NE2000 #define CONFIG_DRIVER_NE2000_BASE (0xb4000300)
-#define CFG_NO_FLASH #define CFG_NS16550 #define CFG_NS16550_SERIAL -#define CFG_NS16550_REG_SIZE 1 -#define CFG_NS16550_CLK 115200 -#define CFG_NS16550_COM1 (0xb40003f8) +#define CFG_NS16550_REG_SIZE 1 +#define CFG_NS16550_CLK 115200 +#define CFG_NS16550_COM1 (0xb40003f8) #define CONFIG_CONS_INDEX 1
#define CONFIG_CMD_IDE @@ -106,17 +102,17 @@ /* * Miscellaneous configurable options */ -#define CFG_LONGHELP /* undef to save memory */ +#define CFG_LONGHELP /* undef to save memory */
-#define CFG_PROMPT "qemu-mips # " /* Monitor Command Prompt */ +#define CFG_PROMPT "qemu-mips # " /* Monitor Command Prompt */
#define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> "
-#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ -#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ #define CFG_MAXARGS 16 /* max number of command args*/
#define CFG_MALLOC_LEN 128*1024 @@ -125,11 +121,11 @@
#define CFG_MHZ 132
-#define CFG_HZ (CFG_MHZ * 1000000) +#define CFG_HZ (CFG_MHZ * 1000000)
-#define CFG_SDRAM_BASE 0x80000000 /* Cached addr */ +#define CFG_SDRAM_BASE 0x80000000 /* Cached addr */
-#define CFG_LOAD_ADDR 0x81000000 /* default load address */ +#define CFG_LOAD_ADDR 0x81000000 /* default load address */
#define CFG_MEMTEST_START 0x80100000 #define CFG_MEMTEST_END 0x80800000 @@ -146,11 +142,17 @@
/* We boot from this flash, selected with dip switch */ #define CFG_FLASH_BASE 0xbfc00000 - -#define CFG_ENV_IS_NOWHERE 1 - +#define CFG_MAX_FLASH_BANKS 1 +#define CFG_MAX_FLASH_SECT 128 +#define CFG_FLASH_CFI 1 /* Flash memory is CFI compliant */ +#define CFG_FLASH_CFI_DRIVER 1 +#define CFG_FLASH_USE_BUFFER_WRITE 1 + +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_ADDR (CFG_FLASH_BASE+0x40000) /* Address and size of Primary Environment Sector */ -#define CFG_ENV_SIZE 0x10000 +#define CFG_ENV_SIZE 0x8000 + #undef CONFIG_NET_MULTI
#define MEM_SIZE 128
add support of : #define CONFIG_CMD_ASKENV #define CONFIG_CMD_LOADS #define CONFIG_CMD_LOADB #define CONFIG_CMD_PING #define CONFIG_CMD_CDP #define CONFIG_CMD_SAVES #define CONFIG_CMD_SETEXPR
and keep only : tftp and dhcp support when CONFIG_SMALLEST is active
diff --git a/Makefile b/Makefile index ab56831..f0cfd76 100644 --- a/Makefile +++ b/Makefile @@ -2720,8 +2720,13 @@ gth2_config: unconfig @echo "#define CONFIG_GTH2 1" >$(obj)include/config.h @$(MKCONFIG) -a gth2 mips mips gth2
+qemu_mips_smallest_config \ qemu_mips_config: unconfig @mkdir -p $(obj)include + @[ -z "$(findstring _smallest_,$@)" ] || \ + { echo "#define CONFIG_SMALLEST 1" >>$(obj)include/config.h ; \ + $(XECHO) "... config with the minimal functionalities" ; \ + } @echo "#define CONFIG_QEMU_MIPS 1" >$(obj)include/config.h @$(MKCONFIG) -a qemu-mips mips mips qemu-mips
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index b775714..6a15413 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -71,10 +71,20 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_ELF +#ifndef CONFIG_SMALLEST +#define CONFIG_CMD_ASKENV #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 -#undef CONFIG_CMD_LOADB +#define CONFIG_CMD_PING +#define CONFIG_CMD_CDP +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_SETEXPR +#else #undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_NFS +#endif +#undef CONFIG_CMD_FPGA #define CONFIG_CMD_DHCP
#define CONFIG_DRIVER_NE2000 @@ -87,6 +97,7 @@ #define CFG_NS16550_COM1 (0xb40003f8) #define CONFIG_CONS_INDEX 1
+#ifndef CONFIG_SMALLEST #define CONFIG_CMD_IDE #define CONFIG_DOS_PARTITION
@@ -103,13 +114,16 @@ * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ +#endif
+#ifndef CONFIG_SMALLEST #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " +#endif
#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- Makefile | 5 +++++ include/configs/qemu-mips.h | 16 +++++++++++++++- 2 files changed, 20 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index ab56831..202ddd9 100644 --- a/Makefile +++ b/Makefile @@ -2720,9 +2720,14 @@ gth2_config: unconfig @echo "#define CONFIG_GTH2 1" >$(obj)include/config.h @$(MKCONFIG) -a gth2 mips mips gth2
+qemu_mips_smallest_config \ qemu_mips_config: unconfig @mkdir -p $(obj)include @echo "#define CONFIG_QEMU_MIPS 1" >$(obj)include/config.h + @[ -z "$(findstring _smallest_,$@)" ] || \ + { echo "#define CONFIG_SMALLEST 1" >>$(obj)include/config.h ; \ + $(XECHO) "... config with the minimal functionalities" ; \ + } @$(MKCONFIG) -a qemu-mips mips mips qemu-mips
######################################################################### diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index b775714..6a15413 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -71,10 +71,20 @@ #include <config_cmd_default.h>
In message 1208800094-23117-1-git-send-email-plagnioj@jcrosoft.com you wrote:
What is the difference between the first patch and patch "V2"?
What is "CONFIG_SMALLEST" ?
What is "full functionnalty"?
I've invert on line in the Makefile
I've put @[ -z "$(findstring _smallest_,$@)" ] || \
before @echo "#define CONFIG_QEMU_MIPS 1" >$(obj)include/config.h
so the #define CONFIG_SMALLEST is overwrite
Built the minimal functionnality to create the smallest u-boot
Active everythink that we could.
Best regards, J.
You should explain such things when you post several versions of a patch. Otherwise it's extremely difficult to understand what exactly you want.
CONFIG_* reads like a standard option toi me, so I was lookign for appropriate documentation in the README for it. Now I tend to think this is something that is more private to your board?
Also, "smallest" is certainly not an absolute term ;-)
Actually I intended to point out that you might want to fix the spelling errors...
Although I said "(I) will push in a week or two" before, but I'll drop this patch from my pull-request list, since it needs to be logically sorted out a little more.
Jean, I recommend to change only CFI-support addition stuff. No need to make things complicated, no commands cleanups, no CodinStyle cleanups.
I'm sorry, incorrect thread...
No functional change.
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
include/configs/qemu-mips.h | 65 +++++++++++++++++++++---------------------- 1 files changed, 32 insertions(+), 33 deletions(-)
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index e164019..be00356 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -12,7 +12,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -28,25 +28,25 @@ #ifndef __CONFIG_H #define __CONFIG_H
/*IP address is default used by Qemu*/ -#define CONFIG_IPADDR 10.0.2.15 /* Our IP address */ -#define CONFIG_SERVERIP 10.0.2.2 /* Server IP address*/ +#define CONFIG_IPADDR 10.0.2.15 /* Our IP address */ +#define CONFIG_SERVERIP 10.0.2.2 /* Server IP address */
-#define CONFIG_BOOTDELAY 10 /* autoboot after 10 seconds */ +#define CONFIG_BOOTDELAY 10 /* autoboot after 10 seconds */
#define CONFIG_BAUDRATE 115200
/* valid baudrates */ #define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
-#define CONFIG_TIMESTAMP /* Print image info with timestamp */ -#undef CONFIG_BOOTARGS +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ +#undef CONFIG_BOOTARGS
-#define CONFIG_EXTRA_ENV_SETTINGS \ +#define CONFIG_EXTRA_ENV_SETTINGS \ "addmisc=setenv bootargs ${bootargs} " \ "console=ttyS0,${baudrate} " \ "panic=1\0" \ @@ -56,7 +56,6 @@
- /* * BOOTP options */ @@ -65,7 +64,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -74,10 +72,10 @@ #define CONFIG_CMD_ELF #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_FLASH -#undef CONFIG_CMD_LOADB -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS #define CONFIG_CMD_DHCP
#define CONFIG_DRIVER_NE2000 @@ -86,15 +84,15 @@ #define CFG_NO_FLASH #define CFG_NS16550 #define CFG_NS16550_SERIAL -#define CFG_NS16550_REG_SIZE 1 -#define CFG_NS16550_CLK 115200 -#define CFG_NS16550_COM1 (0xb40003f8) +#define CFG_NS16550_REG_SIZE 1 +#define CFG_NS16550_CLK 115200 +#define CFG_NS16550_COM1 (0xb40003f8) #define CONFIG_CONS_INDEX 1
-#define CFG_IDE_MAXBUS 2 +#define CFG_IDE_MAXBUS 2 #define CFG_ATA_IDE0_OFFSET (0x1f0) #define CFG_ATA_IDE1_OFFSET (0x170) #define CFG_ATA_DATA_OFFSET (0) @@ -106,18 +104,18 @@ /* * Miscellaneous configurable options */ -#define CFG_LONGHELP /* undef to save memory */ +#define CFG_LONGHELP /* undef to save memory */
-#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ -#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ -#define CFG_MAXARGS 16 /* max number of command args*/ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */
@@ -125,11 +123,11 @@
#define CFG_MHZ 132
#define CFG_MEMTEST_START 0x80100000 #define CFG_MEMTEST_END 0x80800000 @@ -139,21 +137,22 @@ */
/* The following #defines are needed to get flash environment right */ -#define CFG_MONITOR_BASE TEXT_BASE -#define CFG_MONITOR_LEN (192 << 10) +#define CFG_MONITOR_BASE TEXT_BASE +#define CFG_MONITOR_LEN (192 << 10)
#define CFG_INIT_SP_OFFSET 0x400000
-#define CFG_ENV_IS_NOWHERE 1 +#define CFG_ENV_IS_NOWHERE 1
-/* Address and size of Primary Environment Sector */ +/* Address and size of Primary Environment Sector */ #define CFG_ENV_SIZE 0x10000 + #undef CONFIG_NET_MULTI
-#define MEM_SIZE 128 +#define MEM_SIZE 128
#undef CONFIG_MEMSIZE_IN_BYTES
@@ -164,4 +163,4 @@ #define CFG_ICACHE_SIZE 16384 #define CFG_CACHELINE_SIZE 32
-#endif /* __CONFIG_H */ +#endif /* __CONFIG_H */
Why are you changing this? It is a good old tradition of typesetters to user wieder horizontal spacing after a full stop.
See for example the file COPYING which does this consequently.
Please leave this as is.
@@ -12,7 +12,7 @@
Didn't know that, sorry. Patch revised.
[MIPS] qemu-mips: Cleanup whiespaces, tab indentations, etc.
include/configs/qemu-mips.h | 63 +++++++++++++++++++++---------------------- 1 files changed, 31 insertions(+), 32 deletions(-)
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index e164019..c91525e 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -28,25 +28,25 @@ #ifndef __CONFIG_H #define __CONFIG_H
#define CFG_MHZ 132
Please add the sof of the first author of the patch from who you deriverd.
As example, I've done the same for the NE2000 fix.
Best Regards, J.
Sorry for that. Patch revised.
[MIPS] qemu-mips.h: Cleanup whiespaces, tab indentations, etc.
This patch was originally submitted by Jean-Christophe PLAGNIOL-VILLARD. Then I re-created from scratch, and changed more lines than the original.
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index e164019..931eccc 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -22,31 +22,31 @@ */
/* - * This file contains the configuration parameters for the dbau1x00 board. + * This file contains the configuration parameters for qemu-mips target. */
#define CFG_MHZ 132
Applied, thanks.
From: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
CONFIG_ENV_OVERWRITE is also added.
This patch is originally created by Jean-Christophe PLAGNIOL-VILLARD.
include/configs/qemu-mips.h | 15 ++++++++++----- 1 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index be00356..46bfee7 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -72,8 +72,6 @@ #define CONFIG_CMD_ELF #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_FLASH #undef CONFIG_CMD_LOADB #undef CONFIG_CMD_LOADS #define CONFIG_CMD_DHCP @@ -81,7 +79,6 @@ #define CONFIG_DRIVER_NE2000 #define CONFIG_DRIVER_NE2000_BASE (0xb4000300)
-#define CFG_NO_FLASH #define CFG_NS16550 #define CFG_NS16550_SERIAL #define CFG_NS16550_REG_SIZE 1 @@ -144,11 +141,19 @@
/* We boot from this flash, selected with dip switch */ #define CFG_FLASH_BASE 0xbfc00000 +#define CFG_MAX_FLASH_BANKS 1 +#define CFG_MAX_FLASH_SECT 128 +#define CFG_FLASH_CFI 1 /* Flash memory is CFI compliant */ +#define CFG_FLASH_CFI_DRIVER 1 +#define CFG_FLASH_USE_BUFFER_WRITE 1
-#define CFG_ENV_IS_NOWHERE 1 +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_ADDR (CFG_FLASH_BASE + 0x40000)
/* Address and size of Primary Environment Sector */ -#define CFG_ENV_SIZE 0x10000 +#define CFG_ENV_SIZE 0x8000 + +#define CONFIG_ENV_OVERWRITE 1
Applied, thanks.
In message 1208798540-22251-1-git-send-email-plagnioj@jcrosoft.com you wrote:
Please split in two (3?) separate patches. Thanks.
We could separate the Coding style in an other patch but if possible i'll let it in the same patch.
Seperate the moving of non-inlined functions and the setting of get_prom as weak is ine block to fix the regression
Best Regards, J.
Please split it up, because otherwise the changes are really difficult to see.
OK.
Shinya Kuribayashi
Shinya Kuribayashi
