[PATCH] efi_loader: remove EFI_CALL from efi_file_from_path()
We now have internal functions for OpenVolume, EFI_FILE_PROTOCOL.Open() and EFI_FILE_PROTOCOL.Close(). So use these instead of wrapping the callsites with EFI_CALL()
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_file.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index c96a7f7ca371..8480ed3007c7 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -1111,7 +1111,7 @@ struct efi_file_handle *efi_file_from_path(struct efi_device_path *fp) if (!v) return NULL;
- EFI_CALL(ret = v->open_volume(v, &f)); + ret = efi_open_volume_int(v, &f); if (ret != EFI_SUCCESS) return NULL;
@@ -1131,22 +1131,21 @@ struct efi_file_handle *efi_file_from_path(struct efi_device_path *fp)
if (!EFI_DP_TYPE(fp, MEDIA_DEVICE, FILE_PATH)) { printf("bad file path!\n"); - f->close(f); + efi_file_close_int(f); return NULL; }
filename = u16_strdup(fdp->str); if (!filename) return NULL; - EFI_CALL(ret = f->open(f, &f2, filename, - EFI_FILE_MODE_READ, 0)); + ret = efi_file_open_int(f, &f2, filename, EFI_FILE_MODE_READ, 0); free(filename); if (ret != EFI_SUCCESS) return NULL;
fp = efi_dp_next(fp);
- EFI_CALL(f->close(f)); + efi_file_close_int(f); f = f2; }
- ret = efi_open_volume_int(v, &f); if (ret != EFI_SUCCESS) return NULL;
f->close(f);
We should not assume that the FileProtocol() is implemented by U-Boot.
An EFI binary that we execute may have implement its own simple file system protocol and file protocol and then call LoadImage() on it.
We do exactly this in lib/efi_selftest/efi_selftest_loadimage.c.
Best regards
Heinrich
f = f2;
Ilias Apalodimas
