[PATCHv2 0/2] omap4: convert panda board to DM
V2 of this series just drops some ehci init code from patch #2, which doesn't seem to really do anything right now. It is causing a couple of compile time warnings though, so get rid of it for now.
-Tero
-- Texas Instruments Finland Oy, Porkkalankatu 22, 00180 Helsinki. Y-tunnus/Business ID: 0615521-4. Kotipaikka/Domicile: Helsinki
Copy all device tree files required for omap4 panda support from mainline Linux.
Signed-off-by: Tero Kristo t-kristo@ti.com --- v2: * no changes
arch/arm/dts/elpida_ecb240abacn.dtsi | 68 + arch/arm/dts/omap4-l4-abe.dtsi | 489 +++++ arch/arm/dts/omap4-l4.dtsi | 2474 ++++++++++++++++++++++++++ arch/arm/dts/omap4-mcpdm.dtsi | 44 + arch/arm/dts/omap4-panda-common.dtsi | 573 ++++++ arch/arm/dts/omap4-panda-es.dts | 82 + arch/arm/dts/omap4-panda.dts | 13 + arch/arm/dts/omap4.dtsi | 657 +++++++ arch/arm/dts/omap443x-clocks.dtsi | 15 + arch/arm/dts/omap443x.dtsi | 76 + arch/arm/dts/omap4460.dtsi | 131 ++ arch/arm/dts/omap446x-clocks.dtsi | 24 + arch/arm/dts/omap44xx-clocks.dtsi | 1324 ++++++++++++++ arch/arm/dts/twl6030.dtsi | 105 ++ arch/arm/dts/twl6030_omap4.dtsi | 35 + include/dt-bindings/clock/omap4.h | 149 ++ 16 files changed, 6259 insertions(+) create mode 100644 arch/arm/dts/elpida_ecb240abacn.dtsi create mode 100644 arch/arm/dts/omap4-l4-abe.dtsi create mode 100644 arch/arm/dts/omap4-l4.dtsi create mode 100644 arch/arm/dts/omap4-mcpdm.dtsi create mode 100644 arch/arm/dts/omap4-panda-common.dtsi create mode 100644 arch/arm/dts/omap4-panda-es.dts create mode 100644 arch/arm/dts/omap4-panda.dts create mode 100644 arch/arm/dts/omap4.dtsi create mode 100644 arch/arm/dts/omap443x-clocks.dtsi create mode 100644 arch/arm/dts/omap443x.dtsi create mode 100644 arch/arm/dts/omap4460.dtsi create mode 100644 arch/arm/dts/omap446x-clocks.dtsi create mode 100644 arch/arm/dts/omap44xx-clocks.dtsi create mode 100644 arch/arm/dts/twl6030.dtsi create mode 100644 arch/arm/dts/twl6030_omap4.dtsi create mode 100644 include/dt-bindings/clock/omap4.h
diff --git a/arch/arm/dts/elpida_ecb240abacn.dtsi b/arch/arm/dts/elpida_ecb240abacn.dtsi new file mode 100644 index 0000000000..d87ee4794f --- /dev/null +++ b/arch/arm/dts/elpida_ecb240abacn.dtsi @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Common devices used in different OMAP boards + */ + +/ { + elpida_ECB240ABACN: lpddr2 { + compatible = "Elpida,ECB240ABACN","jedec,lpddr2-s4"; + density = <2048>; + io-width = <32>; + + tRPab-min-tck = <3>; + tRCD-min-tck = <3>; + tWR-min-tck = <3>; + tRASmin-min-tck = <3>; + tRRD-min-tck = <2>; + tWTR-min-tck = <2>; + tXP-min-tck = <2>; + tRTP-min-tck = <2>; + tCKE-min-tck = <3>; + tCKESR-min-tck = <3>; + tFAW-min-tck = <8>; + + timings_elpida_ECB240ABACN_400mhz: lpddr2-timings@0 { + compatible = "jedec,lpddr2-timings"; + min-freq = <10000000>; + max-freq = <400000000>; + tRPab = <21000>; + tRCD = <18000>; + tWR = <15000>; + tRAS-min = <42000>; + tRRD = <10000>; + tWTR = <7500>; + tXP = <7500>; + tRTP = <7500>; + tCKESR = <15000>; + tDQSCK-max = <5500>; + tFAW = <50000>; + tZQCS = <90000>; + tZQCL = <360000>; + tZQinit = <1000000>; + tRAS-max-ns = <70000>; + tDQSCK-max-derated = <6000>; + }; + + timings_elpida_ECB240ABACN_200mhz: lpddr2-timings@1 { + compatible = "jedec,lpddr2-timings"; + min-freq = <10000000>; + max-freq = <200000000>; + tRPab = <21000>; + tRCD = <18000>; + tWR = <15000>; + tRAS-min = <42000>; + tRRD = <10000>; + tWTR = <10000>; + tXP = <7500>; + tRTP = <7500>; + tCKESR = <15000>; + tDQSCK-max = <5500>; + tFAW = <50000>; + tZQCS = <90000>; + tZQCL = <360000>; + tZQinit = <1000000>; + tRAS-max-ns = <70000>; + tDQSCK-max-derated = <6000>; + }; + }; +}; diff --git a/arch/arm/dts/omap4-l4-abe.dtsi b/arch/arm/dts/omap4-l4-abe.dtsi new file mode 100644 index 0000000000..a6feb201c5 --- /dev/null +++ b/arch/arm/dts/omap4-l4-abe.dtsi @@ -0,0 +1,489 @@ +&l4_abe { /* 0x40100000 */ + compatible = "ti,omap4-l4-abe", "simple-bus"; + reg = <0x40100000 0x400>, + <0x40100400 0x400>; + reg-names = "la", "ap"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x40100000 0x100000>, /* segment 0 */ + <0x49000000 0x49000000 0x100000>; + segment@0 { /* 0x40100000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = + /* CPU to L4 ABE mapping */ + <0x00000000 0x00000000 0x000400>, /* ap 0 */ + <0x00000400 0x00000400 0x000400>, /* ap 1 */ + <0x00022000 0x00022000 0x001000>, /* ap 2 */ + <0x00023000 0x00023000 0x001000>, /* ap 3 */ + <0x00024000 0x00024000 0x001000>, /* ap 4 */ + <0x00025000 0x00025000 0x001000>, /* ap 5 */ + <0x00026000 0x00026000 0x001000>, /* ap 6 */ + <0x00027000 0x00027000 0x001000>, /* ap 7 */ + <0x00028000 0x00028000 0x001000>, /* ap 8 */ + <0x00029000 0x00029000 0x001000>, /* ap 9 */ + <0x0002a000 0x0002a000 0x001000>, /* ap 10 */ + <0x0002b000 0x0002b000 0x001000>, /* ap 11 */ + <0x0002e000 0x0002e000 0x001000>, /* ap 12 */ + <0x0002f000 0x0002f000 0x001000>, /* ap 13 */ + <0x00030000 0x00030000 0x001000>, /* ap 14 */ + <0x00031000 0x00031000 0x001000>, /* ap 15 */ + <0x00032000 0x00032000 0x001000>, /* ap 16 */ + <0x00033000 0x00033000 0x001000>, /* ap 17 */ + <0x00038000 0x00038000 0x001000>, /* ap 18 */ + <0x00039000 0x00039000 0x001000>, /* ap 19 */ + <0x0003a000 0x0003a000 0x001000>, /* ap 20 */ + <0x0003b000 0x0003b000 0x001000>, /* ap 21 */ + <0x0003c000 0x0003c000 0x001000>, /* ap 22 */ + <0x0003d000 0x0003d000 0x001000>, /* ap 23 */ + <0x0003e000 0x0003e000 0x001000>, /* ap 24 */ + <0x0003f000 0x0003f000 0x001000>, /* ap 25 */ + <0x00080000 0x00080000 0x010000>, /* ap 26 */ + <0x00080000 0x00080000 0x001000>, /* ap 27 */ + <0x000a0000 0x000a0000 0x010000>, /* ap 28 */ + <0x000a0000 0x000a0000 0x001000>, /* ap 29 */ + <0x000c0000 0x000c0000 0x010000>, /* ap 30 */ + <0x000c0000 0x000c0000 0x001000>, /* ap 31 */ + <0x000f1000 0x000f1000 0x001000>, /* ap 32 */ + <0x000f2000 0x000f2000 0x001000>, /* ap 33 */ + + /* L3 to L4 ABE mapping */ + <0x49000000 0x49000000 0x000400>, /* ap 0 */ + <0x49000400 0x49000400 0x000400>, /* ap 1 */ + <0x49022000 0x49022000 0x001000>, /* ap 2 */ + <0x49023000 0x49023000 0x001000>, /* ap 3 */ + <0x49024000 0x49024000 0x001000>, /* ap 4 */ + <0x49025000 0x49025000 0x001000>, /* ap 5 */ + <0x49026000 0x49026000 0x001000>, /* ap 6 */ + <0x49027000 0x49027000 0x001000>, /* ap 7 */ + <0x49028000 0x49028000 0x001000>, /* ap 8 */ + <0x49029000 0x49029000 0x001000>, /* ap 9 */ + <0x4902a000 0x4902a000 0x001000>, /* ap 10 */ + <0x4902b000 0x4902b000 0x001000>, /* ap 11 */ + <0x4902e000 0x4902e000 0x001000>, /* ap 12 */ + <0x4902f000 0x4902f000 0x001000>, /* ap 13 */ + <0x49030000 0x49030000 0x001000>, /* ap 14 */ + <0x49031000 0x49031000 0x001000>, /* ap 15 */ + <0x49032000 0x49032000 0x001000>, /* ap 16 */ + <0x49033000 0x49033000 0x001000>, /* ap 17 */ + <0x49038000 0x49038000 0x001000>, /* ap 18 */ + <0x49039000 0x49039000 0x001000>, /* ap 19 */ + <0x4903a000 0x4903a000 0x001000>, /* ap 20 */ + <0x4903b000 0x4903b000 0x001000>, /* ap 21 */ + <0x4903c000 0x4903c000 0x001000>, /* ap 22 */ + <0x4903d000 0x4903d000 0x001000>, /* ap 23 */ + <0x4903e000 0x4903e000 0x001000>, /* ap 24 */ + <0x4903f000 0x4903f000 0x001000>, /* ap 25 */ + <0x49080000 0x49080000 0x010000>, /* ap 26 */ + <0x49080000 0x49080000 0x001000>, /* ap 27 */ + <0x490a0000 0x490a0000 0x010000>, /* ap 28 */ + <0x490a0000 0x490a0000 0x001000>, /* ap 29 */ + <0x490c0000 0x490c0000 0x010000>, /* ap 30 */ + <0x490c0000 0x490c0000 0x001000>, /* ap 31 */ + <0x490f1000 0x490f1000 0x001000>, /* ap 32 */ + <0x490f2000 0x490f2000 0x001000>; /* ap 33 */ + + target-module@22000 { /* 0x40122000, ap 2 02.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2208c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCBSP1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x22000 0x1000>, + <0x49022000 0x49022000 0x1000>; + + mcbsp1: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49022000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 33>, + <&sdma 34>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@24000 { /* 0x40124000, ap 4 04.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2408c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCBSP2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x24000 0x1000>, + <0x49024000 0x49024000 0x1000>; + + mcbsp2: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49024000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 17>, + <&sdma 18>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@26000 { /* 0x40126000, ap 6 06.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2608c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCBSP3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x26000 0x1000>, + <0x49026000 0x49026000 0x1000>; + + mcbsp3: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49026000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 19>, + <&sdma 20>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@28000 { /* 0x40128000, ap 8 08.0 */ + compatible = "ti,sysc-mcasp", "ti,sysc"; + reg = <0x28000 0x4>, + <0x28004 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCASP_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x28000 0x1000>, + <0x49028000 0x49028000 0x1000>; + + /* + * Child device unsupported by davinci-mcasp. At least + * RX path is disabled for omap4, and only DIT mode + * works with no I2S. See also old Android kernel + * omap-mcasp driver for more information. + */ + }; + + target-module@2a000 { /* 0x4012a000, ap 10 0a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2a000 0x1000>, + <0x4902a000 0x4902a000 0x1000>; + }; + + target-module@2e000 { /* 0x4012e000, ap 12 0c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x2e000 0x4>, + <0x2e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_DMIC_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2e000 0x1000>, + <0x4902e000 0x4902e000 0x1000>; + + dmic: dmic@0 { + compatible = "ti,omap4-dmic"; + reg = <0x0 0x7f>, /* MPU private access */ + <0x4902e000 0x7f>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 67>; + dma-names = "up_link"; + status = "disabled"; + }; + }; + + target-module@30000 { /* 0x40130000, ap 14 0e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x30000 0x4>, + <0x30010 0x4>, + <0x30014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_WD_TIMER3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x30000 0x1000>, + <0x49030000 0x49030000 0x1000>; + + wdt3: wdt@0 { + compatible = "ti,omap4-wdt", "ti,omap3-wdt"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + mcpdm_module: target-module@32000 { /* 0x40132000, ap 16 10.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x32000 0x4>, + <0x32010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCPDM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x32000 0x1000>, + <0x49032000 0x49032000 0x1000>; + + /* Must be only enabled for boards with pdmclk wired */ + status = "disabled"; + + mcpdm: mcpdm@0 { + compatible = "ti,omap4-mcpdm"; + reg = <0x0 0x7f>, /* MPU private access */ + <0x49032000 0x7f>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 65>, + <&sdma 66>; + dma-names = "up_link", "dn_link"; + }; + }; + + target-module@38000 { /* 0x40138000, ap 18 12.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x38000 0x4>, + <0x38010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x38000 0x1000>, + <0x49038000 0x49038000 0x1000>; + + timer5: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x49038000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER5_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + }; + }; + + target-module@3a000 { /* 0x4013a000, ap 20 14.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3a000 0x4>, + <0x3a010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER6_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3a000 0x1000>, + <0x4903a000 0x4903a000 0x1000>; + + timer6: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x4903a000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER6_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + }; + }; + + target-module@3c000 { /* 0x4013c000, ap 22 16.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3c000 0x4>, + <0x3c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER7_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3c000 0x1000>, + <0x4903c000 0x4903c000 0x1000>; + + timer7: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x4903c000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER7_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + }; + }; + + target-module@3e000 { /* 0x4013e000, ap 24 18.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3e000 0x4>, + <0x3e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER8_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3e000 0x1000>, + <0x4903e000 0x4903e000 0x1000>; + + timer8: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x4903e000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER8_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + ti,timer-dsp; + }; + }; + + target-module@80000 { /* 0x40180000, ap 26 1a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x80000 0x10000>, + <0x49080000 0x49080000 0x10000>; + }; + + target-module@a0000 { /* 0x401a0000, ap 28 1c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa0000 0x10000>, + <0x490a0000 0x490a0000 0x10000>; + }; + + target-module@c0000 { /* 0x401c0000, ap 30 1e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc0000 0x10000>, + <0x490c0000 0x490c0000 0x10000>; + }; + + target-module@f1000 { /* 0x401f1000, ap 32 20.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xf1000 0x4>, + <0xf1010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_AESS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xf1000 0x1000>, + <0x490f1000 0x490f1000 0x1000>; + + /* + * No child device binding or driver in mainline. + * See Android tree and related upstreaming efforts + * for the old driver. + */ + }; + }; +}; + diff --git a/arch/arm/dts/omap4-l4.dtsi b/arch/arm/dts/omap4-l4.dtsi new file mode 100644 index 0000000000..ef59e4e97d --- /dev/null +++ b/arch/arm/dts/omap4-l4.dtsi @@ -0,0 +1,2474 @@ +// SPDX-License-Identifier: GPL-2.0 +&l4_cfg { /* 0x4a000000 */ + compatible = "ti,omap4-l4-cfg", "simple-bus"; + reg = <0x4a000000 0x800>, + <0x4a000800 0x800>, + <0x4a001000 0x1000>; + reg-names = "ap", "la", "ia0"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4a000000 0x080000>, /* segment 0 */ + <0x00080000 0x4a080000 0x080000>, /* segment 1 */ + <0x00100000 0x4a100000 0x080000>, /* segment 2 */ + <0x00180000 0x4a180000 0x080000>, /* segment 3 */ + <0x00200000 0x4a200000 0x080000>, /* segment 4 */ + <0x00280000 0x4a280000 0x080000>, /* segment 5 */ + <0x00300000 0x4a300000 0x080000>; /* segment 6 */ + + segment@0 { /* 0x4a000000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x001000>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00002000 0x00002000 0x001000>, /* ap 3 */ + <0x00003000 0x00003000 0x001000>, /* ap 4 */ + <0x00004000 0x00004000 0x001000>, /* ap 5 */ + <0x00005000 0x00005000 0x001000>, /* ap 6 */ + <0x00056000 0x00056000 0x001000>, /* ap 7 */ + <0x00057000 0x00057000 0x001000>, /* ap 8 */ + <0x0005c000 0x0005c000 0x001000>, /* ap 9 */ + <0x00058000 0x00058000 0x004000>, /* ap 10 */ + <0x00062000 0x00062000 0x001000>, /* ap 11 */ + <0x00063000 0x00063000 0x001000>, /* ap 12 */ + <0x00008000 0x00008000 0x002000>, /* ap 23 */ + <0x0000a000 0x0000a000 0x001000>, /* ap 24 */ + <0x00066000 0x00066000 0x001000>, /* ap 25 */ + <0x00067000 0x00067000 0x001000>, /* ap 26 */ + <0x0005e000 0x0005e000 0x002000>, /* ap 80 */ + <0x00060000 0x00060000 0x001000>, /* ap 81 */ + <0x00064000 0x00064000 0x001000>, /* ap 86 */ + <0x00065000 0x00065000 0x001000>; /* ap 87 */ + + target-module@2000 { /* 0x4a002000, ap 3 06.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_core"; + reg = <0x2000 0x4>, + <0x2010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + + omap4_scm_core: scm@0 { + compatible = "ti,omap4-scm-core", "simple-bus"; + reg = <0x0 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + + scm_conf: scm_conf@0 { + compatible = "syscon"; + reg = <0x0 0x800>; + #address-cells = <1>; + #size-cells = <1>; + }; + + omap_control_usb2phy: control-phy@300 { + compatible = "ti,control-phy-usb2"; + reg = <0x300 0x4>; + reg-names = "power"; + }; + + omap_control_usbotg: control-phy@33c { + compatible = "ti,control-phy-otghs"; + reg = <0x33c 0x4>; + reg-names = "otghs_control"; + }; + }; + }; + + target-module@4000 { /* 0x4a004000, ap 5 02.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x4000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + cm1: cm1@0 { + compatible = "ti,omap4-cm1", "simple-bus"; + reg = <0x0 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + cm1_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + cm1_clockdomains: clockdomains { + }; + }; + }; + + target-module@8000 { /* 0x4a008000, ap 23 32.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x8000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x2000>; + + cm2: cm2@0 { + compatible = "ti,omap4-cm2", "simple-bus"; + reg = <0x0 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + cm2_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + cm2_clockdomains: clockdomains { + }; + }; + }; + + target-module@56000 { /* 0x4a056000, ap 7 0a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x56000 0x4>, + <0x5602c 0x4>, + <0x56028 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l3_dma_clkdm */ + clocks = <&l3_dma_clkctrl OMAP4_DMA_SYSTEM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x56000 0x1000>; + + sdma: dma-controller@0 { + compatible = "ti,omap4430-sdma", "ti,omap-sdma"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + dma-channels = <32>; + dma-requests = <127>; + }; + }; + + target-module@58000 { /* 0x4a058000, ap 10 0e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x58000 0x4>, + <0x58010 0x4>, + <0x58014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_HSI_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x58000 0x5000>; + + hsi: hsi@0 { + compatible = "ti,omap4-hsi"; + reg = <0x0 0x4000>, + <0x5000 0x1000>; + reg-names = "sys", "gdd"; + + clocks = <&l3_init_clkctrl OMAP4_HSI_CLKCTRL 0>; + clock-names = "hsi_fck"; + + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gdd_mpu"; + + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x4000>; + + hsi_port1: hsi-port@2000 { + compatible = "ti,omap4-hsi-port"; + reg = <0x2000 0x800>, + <0x2800 0x800>; + reg-names = "tx", "rx"; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + }; + + hsi_port2: hsi-port@3000 { + compatible = "ti,omap4-hsi-port"; + reg = <0x3000 0x800>, + <0x3800 0x800>; + reg-names = "tx", "rx"; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + }; + + target-module@5e000 { /* 0x4a05e000, ap 80 68.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5e000 0x2000>; + }; + + target-module@62000 { /* 0x4a062000, ap 11 16.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + ti,hwmods = "usb_tll_hs"; + reg = <0x62000 0x4>, + <0x62010 0x4>, + <0x62014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_USB_TLL_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x62000 0x1000>; + + usbhstll: usbhstll@0 { + compatible = "ti,usbhs-tll"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@64000 { /* 0x4a064000, ap 86 1e.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "usb_host_hs"; + reg = <0x64000 0x4>, + <0x64010 0x4>, + <0x64014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_USB_HOST_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x64000 0x1000>; + + usbhshost: usbhshost@0 { + compatible = "ti,usbhs-host"; + reg = <0x0 0x800>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + clocks = <&init_60m_fclk>, + <&xclk60mhsp1_ck>, + <&xclk60mhsp2_ck>; + clock-names = "refclk_60m_int", + "refclk_60m_ext_p1", + "refclk_60m_ext_p2"; + + usbhsohci: ohci@800 { + compatible = "ti,ohci-omap3"; + reg = <0x800 0x400>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + remote-wakeup-connected; + }; + + usbhsehci: ehci@c00 { + compatible = "ti,ehci-omap"; + reg = <0xc00 0x400>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + }; + + target-module@66000 { /* 0x4a066000, ap 25 26.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x66000 0x4>, + <0x66010 0x4>, + <0x66014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, tesla_pwrdm, tesla_clkdm */ + clocks = <&tesla_clkctrl OMAP4_DSP_CLKCTRL 0>; + clock-names = "fck"; + resets = <&prm_tesla 1>; + reset-names = "rstctrl"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x66000 0x1000>; + + mmu_dsp: mmu@0 { + compatible = "ti,omap4-iommu"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <0>; + }; + }; + }; + + segment@80000 { /* 0x4a080000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00059000 0x000d9000 0x001000>, /* ap 13 */ + <0x0005a000 0x000da000 0x001000>, /* ap 14 */ + <0x0005b000 0x000db000 0x001000>, /* ap 15 */ + <0x0005c000 0x000dc000 0x001000>, /* ap 16 */ + <0x0005d000 0x000dd000 0x001000>, /* ap 17 */ + <0x0005e000 0x000de000 0x001000>, /* ap 18 */ + <0x00060000 0x000e0000 0x001000>, /* ap 19 */ + <0x00061000 0x000e1000 0x001000>, /* ap 20 */ + <0x00074000 0x000f4000 0x001000>, /* ap 27 */ + <0x00075000 0x000f5000 0x001000>, /* ap 28 */ + <0x00076000 0x000f6000 0x001000>, /* ap 29 */ + <0x00077000 0x000f7000 0x001000>, /* ap 30 */ + <0x00036000 0x000b6000 0x001000>, /* ap 69 */ + <0x00037000 0x000b7000 0x001000>, /* ap 70 */ + <0x0004d000 0x000cd000 0x001000>, /* ap 78 */ + <0x0004e000 0x000ce000 0x001000>, /* ap 79 */ + <0x00029000 0x000a9000 0x001000>, /* ap 82 */ + <0x0002a000 0x000aa000 0x001000>, /* ap 83 */ + <0x0002b000 0x000ab000 0x001000>, /* ap 84 */ + <0x0002c000 0x000ac000 0x001000>, /* ap 85 */ + <0x0002d000 0x000ad000 0x001000>, /* ap 88 */ + <0x0002e000 0x000ae000 0x001000>; /* ap 89 */ + + target-module@29000 { /* 0x4a0a9000, ap 82 04.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x29000 0x1000>; + }; + + target-module@2b000 { /* 0x4a0ab000, ap 84 12.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2b400 0x4>, + <0x2b404 0x4>, + <0x2b408 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_USB_OTG_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2b000 0x1000>; + + usb_otg_hs: usb_otg_hs@0 { + compatible = "ti,omap4-musb"; + reg = <0x0 0x7ff>; + interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc", "dma"; + usb-phy = <&usb2_phy>; + phys = <&usb2_phy>; + phy-names = "usb2-phy"; + multipoint = <1>; + num-eps = <16>; + ram-bits = <12>; + ctrl-module = <&omap_control_usbotg>; + }; + }; + + target-module@2d000 { /* 0x4a0ad000, ap 88 0c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2d000 0x4>, + <0x2d010 0x4>, + <0x2d014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_OCP2SCP_USB_PHY_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2d000 0x1000>; + + ocp2scp@0 { + compatible = "ti,omap-ocp2scp"; + reg = <0x0 0x1f>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + usb2_phy: usb2phy@80 { + compatible = "ti,omap-usb2"; + reg = <0x80 0x58>; + ctrl-module = <&omap_control_usb2phy>; + clocks = <&usb_phy_cm_clk32k>; + clock-names = "wkupclk"; + #phy-cells = <0>; + }; + }; + }; + + /* d2d mdm */ + target-module@36000 { /* 0x4a0b6000, ap 69 60.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x36000 0x4>, + <0x36010 0x4>, + <0x36014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, d2d_clkdm */ + clocks = <&d2d_clkctrl OMAP4_C2C_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x36000 0x1000>; + }; + + /* d2d mpu */ + target-module@4d000 { /* 0x4a0cd000, ap 78 58.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4d000 0x4>, + <0x4d010 0x4>, + <0x4d014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, d2d_clkdm */ + clocks = <&d2d_clkctrl OMAP4_C2C_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4d000 0x1000>; + }; + + target-module@59000 { /* 0x4a0d9000, ap 13 1a.0 */ + compatible = "ti,sysc-omap4-sr", "ti,sysc"; + reg = <0x59038 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <SYSC_OMAP3_SR_ENAWAKEUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, always_on_core_pwrdm, l4_ao_clkdm */ + clocks = <&l4_ao_clkctrl OMAP4_SMARTREFLEX_MPU_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x59000 0x1000>; + + smartreflex_mpu: smartreflex@0 { + compatible = "ti,omap4-smartreflex-mpu"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@5b000 { /* 0x4a0db000, ap 15 08.0 */ + compatible = "ti,sysc-omap4-sr", "ti,sysc"; + reg = <0x5b038 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <SYSC_OMAP3_SR_ENAWAKEUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, always_on_core_pwrdm, l4_ao_clkdm */ + clocks = <&l4_ao_clkctrl OMAP4_SMARTREFLEX_IVA_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5b000 0x1000>; + + smartreflex_iva: smartreflex@0 { + compatible = "ti,omap4-smartreflex-iva"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@5d000 { /* 0x4a0dd000, ap 17 22.0 */ + compatible = "ti,sysc-omap4-sr", "ti,sysc"; + reg = <0x5d038 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <SYSC_OMAP3_SR_ENAWAKEUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, always_on_core_pwrdm, l4_ao_clkdm */ + clocks = <&l4_ao_clkctrl OMAP4_SMARTREFLEX_CORE_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5d000 0x1000>; + + smartreflex_core: smartreflex@0 { + compatible = "ti,omap4-smartreflex-core"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@60000 { /* 0x4a0e0000, ap 19 1c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x60000 0x1000>; + }; + + target-module@74000 { /* 0x4a0f4000, ap 27 24.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x74000 0x4>, + <0x74010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + clocks = <&l4_cfg_clkctrl OMAP4_MAILBOX_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x74000 0x1000>; + + mailbox: mailbox@0 { + compatible = "ti,omap4-mailbox"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + #mbox-cells = <1>; + ti,mbox-num-users = <3>; + ti,mbox-num-fifos = <8>; + mbox_ipu: mbox_ipu { + ti,mbox-tx = <0 0 0>; + ti,mbox-rx = <1 0 0>; + }; + mbox_dsp: mbox_dsp { + ti,mbox-tx = <3 0 0>; + ti,mbox-rx = <2 0 0>; + }; + }; + }; + + target-module@76000 { /* 0x4a0f6000, ap 29 3a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x76000 0x4>, + <0x76010 0x4>, + <0x76014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + clocks = <&l4_cfg_clkctrl OMAP4_SPINLOCK_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x76000 0x1000>; + + hwspinlock: spinlock@0 { + compatible = "ti,omap4-hwspinlock"; + reg = <0x0 0x1000>; + #hwlock-cells = <1>; + }; + }; + }; + + segment@100000 { /* 0x4a100000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00100000 0x001000>, /* ap 21 */ + <0x00001000 0x00101000 0x001000>, /* ap 22 */ + <0x00002000 0x00102000 0x001000>, /* ap 61 */ + <0x00003000 0x00103000 0x001000>, /* ap 62 */ + <0x00008000 0x00108000 0x001000>, /* ap 63 */ + <0x00009000 0x00109000 0x001000>, /* ap 64 */ + <0x0000a000 0x0010a000 0x001000>, /* ap 65 */ + <0x0000b000 0x0010b000 0x001000>; /* ap 66 */ + + target-module@0 { /* 0x4a100000, ap 21 2a.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_pad_core"; + reg = <0x0 0x4>, + <0x10 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + + omap4_pmx_core: pinmux@40 { + compatible = "ti,omap4-padconf", + "pinctrl-single"; + reg = <0x40 0x0196>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0x7fff>; + }; + + omap4_padconf_global: omap4_padconf_global@5a0 { + compatible = "syscon", + "simple-bus"; + reg = <0x5a0 0x170>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x5a0 0x170>; + + pbias_regulator: pbias_regulator@60 { + compatible = "ti,pbias-omap4", "ti,pbias-omap"; + reg = <0x60 0x4>; + syscon = <&omap4_padconf_global>; + pbias_mmc_reg: pbias_mmc_omap4 { + regulator-name = "pbias_mmc_omap4"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + }; + }; + }; + }; + + target-module@2000 { /* 0x4a102000, ap 61 3c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + }; + + target-module@8000 { /* 0x4a108000, ap 63 62.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x1000>; + }; + + target-module@a000 { /* 0x4a10a000, ap 65 50.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xa000 0x4>, + <0xa010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-delay-us = <2>; + /* Domains (V, P, C): core, cam_pwrdm, iss_clkdm */ + clocks = <&iss_clkctrl OMAP4_FDIF_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + + /* No child device binding or driver in mainline */ + }; + }; + + segment@180000 { /* 0x4a180000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; + + segment@200000 { /* 0x4a200000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0001e000 0x0021e000 0x001000>, /* ap 31 */ + <0x0001f000 0x0021f000 0x001000>, /* ap 32 */ + <0x0000a000 0x0020a000 0x001000>, /* ap 33 */ + <0x0000b000 0x0020b000 0x001000>, /* ap 34 */ + <0x00004000 0x00204000 0x001000>, /* ap 35 */ + <0x00005000 0x00205000 0x001000>, /* ap 36 */ + <0x00006000 0x00206000 0x001000>, /* ap 37 */ + <0x00007000 0x00207000 0x001000>, /* ap 38 */ + <0x00012000 0x00212000 0x001000>, /* ap 39 */ + <0x00013000 0x00213000 0x001000>, /* ap 40 */ + <0x0000c000 0x0020c000 0x001000>, /* ap 41 */ + <0x0000d000 0x0020d000 0x001000>, /* ap 42 */ + <0x00010000 0x00210000 0x001000>, /* ap 43 */ + <0x00011000 0x00211000 0x001000>, /* ap 44 */ + <0x00016000 0x00216000 0x001000>, /* ap 45 */ + <0x00017000 0x00217000 0x001000>, /* ap 46 */ + <0x00014000 0x00214000 0x001000>, /* ap 47 */ + <0x00015000 0x00215000 0x001000>, /* ap 48 */ + <0x00018000 0x00218000 0x001000>, /* ap 49 */ + <0x00019000 0x00219000 0x001000>, /* ap 50 */ + <0x00020000 0x00220000 0x001000>, /* ap 51 */ + <0x00021000 0x00221000 0x001000>, /* ap 52 */ + <0x00026000 0x00226000 0x001000>, /* ap 53 */ + <0x00027000 0x00227000 0x001000>, /* ap 54 */ + <0x00028000 0x00228000 0x001000>, /* ap 55 */ + <0x00029000 0x00229000 0x001000>, /* ap 56 */ + <0x0002a000 0x0022a000 0x001000>, /* ap 57 */ + <0x0002b000 0x0022b000 0x001000>, /* ap 58 */ + <0x0001c000 0x0021c000 0x001000>, /* ap 59 */ + <0x0001d000 0x0021d000 0x001000>; /* ap 60 */ + + target-module@4000 { /* 0x4a204000, ap 35 42.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + }; + + target-module@6000 { /* 0x4a206000, ap 37 4a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6000 0x1000>; + }; + + target-module@a000 { /* 0x4a20a000, ap 33 2c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + }; + + target-module@c000 { /* 0x4a20c000, ap 41 20.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + }; + + target-module@10000 { /* 0x4a210000, ap 43 52.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x10000 0x1000>; + }; + + target-module@12000 { /* 0x4a212000, ap 39 18.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x12000 0x1000>; + }; + + target-module@14000 { /* 0x4a214000, ap 47 30.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x14000 0x1000>; + }; + + target-module@16000 { /* 0x4a216000, ap 45 28.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x16000 0x1000>; + }; + + target-module@18000 { /* 0x4a218000, ap 49 38.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x18000 0x1000>; + }; + + target-module@1c000 { /* 0x4a21c000, ap 59 5a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x1c000 0x1000>; + }; + + target-module@1e000 { /* 0x4a21e000, ap 31 10.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x1e000 0x1000>; + }; + + target-module@20000 { /* 0x4a220000, ap 51 40.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x20000 0x1000>; + }; + + target-module@26000 { /* 0x4a226000, ap 53 34.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x26000 0x1000>; + }; + + target-module@28000 { /* 0x4a228000, ap 55 2e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x28000 0x1000>; + }; + + target-module@2a000 { /* 0x4a22a000, ap 57 48.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2a000 0x1000>; + }; + }; + + segment@280000 { /* 0x4a280000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; + + l4_cfg_segment_300000: segment@300000 { /* 0x4a300000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00300000 0x020000>, /* ap 67 */ + <0x00040000 0x00340000 0x001000>, /* ap 68 */ + <0x00020000 0x00320000 0x004000>, /* ap 71 */ + <0x00024000 0x00324000 0x002000>, /* ap 72 */ + <0x00026000 0x00326000 0x001000>, /* ap 73 */ + <0x00027000 0x00327000 0x001000>, /* ap 74 */ + <0x00028000 0x00328000 0x001000>, /* ap 75 */ + <0x00029000 0x00329000 0x001000>, /* ap 76 */ + <0x00030000 0x00330000 0x010000>, /* ap 77 */ + <0x0002a000 0x0032a000 0x002000>, /* ap 90 */ + <0x0002c000 0x0032c000 0x004000>; /* ap 91 */ + + l4_cfg_target_0: target-module@0 { /* 0x4a300000, ap 67 14.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x00020000>, + <0x00020000 0x00020000 0x00004000>, + <0x00024000 0x00024000 0x00002000>, + <0x00026000 0x00026000 0x00001000>, + <0x00027000 0x00027000 0x00001000>, + <0x00028000 0x00028000 0x00001000>, + <0x00029000 0x00029000 0x00001000>, + <0x0002a000 0x0002a000 0x00002000>, + <0x0002c000 0x0002c000 0x00004000>, + <0x00030000 0x00030000 0x00010000>; + }; + }; +}; + +&l4_wkup { /* 0x4a300000 */ + compatible = "ti,omap4-l4-wkup", "simple-bus"; + reg = <0x4a300000 0x800>, + <0x4a300800 0x800>, + <0x4a301000 0x1000>; + reg-names = "ap", "la", "ia0"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4a300000 0x010000>, /* segment 0 */ + <0x00010000 0x4a310000 0x010000>, /* segment 1 */ + <0x00020000 0x4a320000 0x010000>; /* segment 2 */ + + segment@0 { /* 0x4a300000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x001000>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00006000 0x00006000 0x002000>, /* ap 3 */ + <0x00008000 0x00008000 0x001000>, /* ap 4 */ + <0x0000a000 0x0000a000 0x001000>, /* ap 15 */ + <0x0000b000 0x0000b000 0x001000>, /* ap 16 */ + <0x00004000 0x00004000 0x001000>, /* ap 17 */ + <0x00005000 0x00005000 0x001000>, /* ap 18 */ + <0x0000c000 0x0000c000 0x001000>, /* ap 19 */ + <0x0000d000 0x0000d000 0x001000>; /* ap 20 */ + + target-module@4000 { /* 0x4a304000, ap 17 24.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + ti,hwmods = "counter_32k"; + reg = <0x4000 0x4>, + <0x4004 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_COUNTER_32K_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + counter32k: counter@0 { + compatible = "ti,omap-counter32k"; + reg = <0x0 0x20>; + }; + }; + + target-module@6000 { /* 0x4a306000, ap 3 08.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x6000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6000 0x2000>; + + prm: prm@0 { + compatible = "ti,omap4-prm", "simple-bus"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + prm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + prm_clockdomains: clockdomains { + }; + }; + }; + + target-module@a000 { /* 0x4a30a000, ap 15 34.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xa000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + + scrm: scrm@0 { + compatible = "ti,omap4-scrm"; + reg = <0x0 0x2000>; + + scrm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + scrm_clockdomains: clockdomains { + }; + }; + }; + + target-module@c000 { /* 0x4a30c000, ap 19 2c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_wkup"; + reg = <0xc000 0x4>, + <0xc010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + + omap4_scm_wkup: scm@c000 { + compatible = "ti,omap4-scm-wkup"; + reg = <0xc000 0x1000>; + }; + }; + }; + + segment@10000 { /* 0x4a310000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00010000 0x001000>, /* ap 5 */ + <0x00001000 0x00011000 0x001000>, /* ap 6 */ + <0x00004000 0x00014000 0x001000>, /* ap 7 */ + <0x00005000 0x00015000 0x001000>, /* ap 8 */ + <0x00008000 0x00018000 0x001000>, /* ap 9 */ + <0x00009000 0x00019000 0x001000>, /* ap 10 */ + <0x0000c000 0x0001c000 0x001000>, /* ap 11 */ + <0x0000d000 0x0001d000 0x001000>, /* ap 12 */ + <0x0000e000 0x0001e000 0x001000>, /* ap 21 */ + <0x0000f000 0x0001f000 0x001000>; /* ap 22 */ + + gpio1_target: target-module@0 { /* 0x4a310000, ap 5 14.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x0 0x4>, + <0x10 0x4>, + <0x114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_GPIO1_CLKCTRL 0>, + <&l4_wkup_clkctrl OMAP4_GPIO1_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + + gpio1: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + ti,gpio-always-on; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@4000 { /* 0x4a314000, ap 7 18.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4000 0x4>, + <0x4010 0x4>, + <0x4014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_WD_TIMER2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + wdt2: wdt@0 { + compatible = "ti,omap4-wdt", "ti,omap3-wdt"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@8000 { /* 0x4a318000, ap 9 1c.0 */ + compatible = "ti,sysc-omap2-timer", "ti,sysc"; + ti,hwmods = "timer1"; + reg = <0x8000 0x4>, + <0x8010 0x4>, + <0x8014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_TIMER1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x1000>; + + timer1: timer@0 { + compatible = "ti,omap3430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_wkup_clkctrl OMAP4_TIMER1_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-alwon; + }; + }; + + target-module@c000 { /* 0x4a31c000, ap 11 20.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0xc000 0x4>, + <0xc010 0x4>, + <0xc014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_KBD_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + + keypad: keypad@0 { + compatible = "ti,omap4-keypad"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + reg-names = "mpu"; + }; + }; + + target-module@e000 { /* 0x4a31e000, ap 21 30.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_pad_wkup"; + reg = <0xe000 0x4>, + <0xe010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xe000 0x1000>; + + omap4_pmx_wkup: pinmux@40 { + compatible = "ti,omap4-padconf", + "pinctrl-single"; + reg = <0x40 0x0038>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0x7fff>; + }; + }; + }; + + segment@20000 { /* 0x4a320000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00006000 0x00026000 0x001000>, /* ap 13 */ + <0x0000a000 0x0002a000 0x001000>, /* ap 14 */ + <0x00000000 0x00020000 0x001000>, /* ap 23 */ + <0x00001000 0x00021000 0x001000>, /* ap 24 */ + <0x00002000 0x00022000 0x001000>, /* ap 25 */ + <0x00003000 0x00023000 0x001000>, /* ap 26 */ + <0x00004000 0x00024000 0x001000>, /* ap 27 */ + <0x00005000 0x00025000 0x001000>, /* ap 28 */ + <0x00007000 0x00027000 0x000400>, /* ap 29 */ + <0x00008000 0x00028000 0x000800>, /* ap 30 */ + <0x00009000 0x00029000 0x000400>; /* ap 31 */ + + target-module@0 { /* 0x4a320000, ap 23 04.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + }; + + target-module@2000 { /* 0x4a322000, ap 25 0c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + }; + + target-module@4000 { /* 0x4a324000, ap 27 10.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + }; + + target-module@6000 { /* 0x4a326000, ap 13 28.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00006000 0x00001000>, + <0x00001000 0x00007000 0x00000400>, + <0x00002000 0x00008000 0x00000800>, + <0x00003000 0x00009000 0x00000400>; + }; + }; +}; + +&l4_per { /* 0x48000000 */ + compatible = "ti,omap4-l4-per", "simple-bus"; + reg = <0x48000000 0x800>, + <0x48000800 0x800>, + <0x48001000 0x400>, + <0x48001400 0x400>, + <0x48001800 0x400>, + <0x48001c00 0x400>; + reg-names = "ap", "la", "ia0", "ia1", "ia2", "ia3"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x48000000 0x200000>, /* segment 0 */ + <0x00200000 0x48200000 0x200000>; /* segment 1 */ + + segment@0 { /* 0x48000000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x000400>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00020000 0x00020000 0x001000>, /* ap 3 */ + <0x00021000 0x00021000 0x001000>, /* ap 4 */ + <0x00032000 0x00032000 0x001000>, /* ap 5 */ + <0x00033000 0x00033000 0x001000>, /* ap 6 */ + <0x00034000 0x00034000 0x001000>, /* ap 7 */ + <0x00035000 0x00035000 0x001000>, /* ap 8 */ + <0x00036000 0x00036000 0x001000>, /* ap 9 */ + <0x00037000 0x00037000 0x001000>, /* ap 10 */ + <0x0003e000 0x0003e000 0x001000>, /* ap 11 */ + <0x0003f000 0x0003f000 0x001000>, /* ap 12 */ + <0x00040000 0x00040000 0x010000>, /* ap 13 */ + <0x00050000 0x00050000 0x001000>, /* ap 14 */ + <0x00055000 0x00055000 0x001000>, /* ap 15 */ + <0x00056000 0x00056000 0x001000>, /* ap 16 */ + <0x00057000 0x00057000 0x001000>, /* ap 17 */ + <0x00058000 0x00058000 0x001000>, /* ap 18 */ + <0x00059000 0x00059000 0x001000>, /* ap 19 */ + <0x0005a000 0x0005a000 0x001000>, /* ap 20 */ + <0x0005b000 0x0005b000 0x001000>, /* ap 21 */ + <0x0005c000 0x0005c000 0x001000>, /* ap 22 */ + <0x0005d000 0x0005d000 0x001000>, /* ap 23 */ + <0x0005e000 0x0005e000 0x001000>, /* ap 24 */ + <0x00060000 0x00060000 0x001000>, /* ap 25 */ + <0x0006a000 0x0006a000 0x001000>, /* ap 26 */ + <0x0006b000 0x0006b000 0x001000>, /* ap 27 */ + <0x0006c000 0x0006c000 0x001000>, /* ap 28 */ + <0x0006d000 0x0006d000 0x001000>, /* ap 29 */ + <0x0006e000 0x0006e000 0x001000>, /* ap 30 */ + <0x0006f000 0x0006f000 0x001000>, /* ap 31 */ + <0x00070000 0x00070000 0x001000>, /* ap 32 */ + <0x00071000 0x00071000 0x001000>, /* ap 33 */ + <0x00072000 0x00072000 0x001000>, /* ap 34 */ + <0x00073000 0x00073000 0x001000>, /* ap 35 */ + <0x00061000 0x00061000 0x001000>, /* ap 36 */ + <0x00096000 0x00096000 0x001000>, /* ap 37 */ + <0x00097000 0x00097000 0x001000>, /* ap 38 */ + <0x00076000 0x00076000 0x001000>, /* ap 39 */ + <0x00077000 0x00077000 0x001000>, /* ap 40 */ + <0x00078000 0x00078000 0x001000>, /* ap 41 */ + <0x00079000 0x00079000 0x001000>, /* ap 42 */ + <0x00086000 0x00086000 0x001000>, /* ap 43 */ + <0x00087000 0x00087000 0x001000>, /* ap 44 */ + <0x00088000 0x00088000 0x001000>, /* ap 45 */ + <0x00089000 0x00089000 0x001000>, /* ap 46 */ + <0x000b0000 0x000b0000 0x001000>, /* ap 47 */ + <0x000b1000 0x000b1000 0x001000>, /* ap 48 */ + <0x00098000 0x00098000 0x001000>, /* ap 49 */ + <0x00099000 0x00099000 0x001000>, /* ap 50 */ + <0x0009a000 0x0009a000 0x001000>, /* ap 51 */ + <0x0009b000 0x0009b000 0x001000>, /* ap 52 */ + <0x0009c000 0x0009c000 0x001000>, /* ap 53 */ + <0x0009d000 0x0009d000 0x001000>, /* ap 54 */ + <0x0009e000 0x0009e000 0x001000>, /* ap 55 */ + <0x0009f000 0x0009f000 0x001000>, /* ap 56 */ + <0x00090000 0x00090000 0x002000>, /* ap 57 */ + <0x00092000 0x00092000 0x001000>, /* ap 58 */ + <0x000a4000 0x000a4000 0x001000>, /* ap 59 */ + <0x000a6000 0x000a6000 0x001000>, /* ap 60 */ + <0x000a8000 0x000a8000 0x004000>, /* ap 61 */ + <0x000ac000 0x000ac000 0x001000>, /* ap 62 */ + <0x000ad000 0x000ad000 0x001000>, /* ap 63 */ + <0x000ae000 0x000ae000 0x001000>, /* ap 64 */ + <0x000b2000 0x000b2000 0x001000>, /* ap 65 */ + <0x000b3000 0x000b3000 0x001000>, /* ap 66 */ + <0x000b4000 0x000b4000 0x001000>, /* ap 67 */ + <0x000b5000 0x000b5000 0x001000>, /* ap 68 */ + <0x000b8000 0x000b8000 0x001000>, /* ap 69 */ + <0x000b9000 0x000b9000 0x001000>, /* ap 70 */ + <0x000ba000 0x000ba000 0x001000>, /* ap 71 */ + <0x000bb000 0x000bb000 0x001000>, /* ap 72 */ + <0x000d1000 0x000d1000 0x001000>, /* ap 73 */ + <0x000d2000 0x000d2000 0x001000>, /* ap 74 */ + <0x000d5000 0x000d5000 0x001000>, /* ap 75 */ + <0x000d6000 0x000d6000 0x001000>, /* ap 76 */ + <0x000a2000 0x000a2000 0x001000>, /* ap 79 */ + <0x000a3000 0x000a3000 0x001000>, /* ap 80 */ + <0x00001400 0x00001400 0x000400>, /* ap 81 */ + <0x00001800 0x00001800 0x000400>, /* ap 82 */ + <0x00001c00 0x00001c00 0x000400>, /* ap 83 */ + <0x000a5000 0x000a5000 0x001000>; /* ap 84 */ + + target-module@20000 { /* 0x48020000, ap 3 06.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x20050 0x4>, + <0x20054 0x4>, + <0x20058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x20000 0x1000>; + + uart3: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@32000 { /* 0x48032000, ap 5 02.0 */ + compatible = "ti,sysc-omap2-timer", "ti,sysc"; + reg = <0x32000 0x4>, + <0x32010 0x4>, + <0x32014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x32000 0x1000>; + + timer2: timer@0 { + compatible = "ti,omap3430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER2_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@34000 { /* 0x48034000, ap 7 04.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x34000 0x4>, + <0x34010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x34000 0x1000>; + + timer3: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER3_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@36000 { /* 0x48036000, ap 9 0e.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x36000 0x4>, + <0x36010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x36000 0x1000>; + + timer4: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER4_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@3e000 { /* 0x4803e000, ap 11 08.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3e000 0x4>, + <0x3e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER9_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3e000 0x1000>; + + timer9: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER9_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + /* Unused DSS L4 access, see L3 instead */ + target-module@40000 { /* 0x48040000, ap 13 0a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x40000 0x10000>; + }; + + target-module@55000 { /* 0x48055000, ap 15 0c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x55000 0x4>, + <0x55010 0x4>, + <0x55114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO2_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO2_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x55000 0x1000>; + + gpio2: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@57000 { /* 0x48057000, ap 17 16.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x57000 0x4>, + <0x57010 0x4>, + <0x57114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO3_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO3_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x57000 0x1000>; + + gpio3: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@59000 { /* 0x48059000, ap 19 10.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x59000 0x4>, + <0x59010 0x4>, + <0x59114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO4_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO4_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x59000 0x1000>; + + gpio4: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@5b000 { /* 0x4805b000, ap 21 12.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5b000 0x4>, + <0x5b010 0x4>, + <0x5b114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO5_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO5_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5b000 0x1000>; + + gpio5: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@5d000 { /* 0x4805d000, ap 23 14.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5d000 0x4>, + <0x5d010 0x4>, + <0x5d114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO6_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO6_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5d000 0x1000>; + + gpio6: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@60000 { /* 0x48060000, ap 25 1e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x60000 0x8>, + <0x60010 0x8>, + <0x60090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x60000 0x1000>; + + i2c3: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@6a000 { /* 0x4806a000, ap 26 18.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6a050 0x4>, + <0x6a054 0x4>, + <0x6a058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6a000 0x1000>; + + uart1: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@6c000 { /* 0x4806c000, ap 28 20.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6c050 0x4>, + <0x6c054 0x4>, + <0x6c058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6c000 0x1000>; + + uart2: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@6e000 { /* 0x4806e000, ap 30 1c.1 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6e050 0x4>, + <0x6e054 0x4>, + <0x6e058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6e000 0x1000>; + + uart4: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@70000 { /* 0x48070000, ap 32 28.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x70000 0x8>, + <0x70010 0x8>, + <0x70090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x70000 0x1000>; + + i2c1: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@72000 { /* 0x48072000, ap 34 30.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x72000 0x8>, + <0x72010 0x8>, + <0x72090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x72000 0x1000>; + + i2c2: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@76000 { /* 0x48076000, ap 39 38.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x76000 0x4>, + <0x76010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_SLIMBUS2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x76000 0x1000>; + + /* No child device binding or driver in mainline */ + }; + + target-module@78000 { /* 0x48078000, ap 41 1a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x78000 0x4>, + <0x78010 0x4>, + <0x78014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_ELM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x78000 0x1000>; + + elm: elm@0 { + compatible = "ti,am3352-elm"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + }; + + target-module@86000 { /* 0x48086000, ap 43 24.0 */ + compatible = "ti,sysc-omap2-timer", "ti,sysc"; + reg = <0x86000 0x4>, + <0x86010 0x4>, + <0x86014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER10_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x86000 0x1000>; + + timer10: timer@0 { + compatible = "ti,omap3430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER10_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + target-module@88000 { /* 0x48088000, ap 45 2e.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x88000 0x4>, + <0x88010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER11_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x88000 0x1000>; + + timer11: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER11_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + rng_target: target-module@90000 { /* 0x48090000, ap 57 2a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x91fe0 0x4>, + <0x91fe4 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_RNG_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x90000 0x2000>; + + rng: rng@0 { + compatible = "ti,omap4-rng"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@96000 { /* 0x48096000, ap 37 26.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x9608c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCBSP4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x96000 0x1000>; + + mcbsp4: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>; /* L4 Interconnect */ + reg-names = "mpu"; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 31>, + <&sdma 32>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@98000 { /* 0x48098000, ap 49 22.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x98000 0x4>, + <0x98010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x98000 0x1000>; + + mcspi1: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <4>; + dmas = <&sdma 35>, + <&sdma 36>, + <&sdma 37>, + <&sdma 38>, + <&sdma 39>, + <&sdma 40>, + <&sdma 41>, + <&sdma 42>; + dma-names = "tx0", "rx0", "tx1", "rx1", + "tx2", "rx2", "tx3", "rx3"; + }; + }; + + target-module@9a000 { /* 0x4809a000, ap 51 2c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x9a000 0x4>, + <0x9a010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9a000 0x1000>; + + mcspi2: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <2>; + dmas = <&sdma 43>, + <&sdma 44>, + <&sdma 45>, + <&sdma 46>; + dma-names = "tx0", "rx0", "tx1", "rx1"; + }; + }; + + target-module@9c000 { /* 0x4809c000, ap 53 36.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x9c000 0x4>, + <0x9c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_MMC1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9c000 0x1000>; + + mmc1: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + ti,dual-volt; + ti,needs-special-reset; + dmas = <&sdma 61>, <&sdma 62>; + dma-names = "tx", "rx"; + pbias-supply = <&pbias_mmc_reg>; + }; + }; + + target-module@9e000 { /* 0x4809e000, ap 55 48.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9e000 0x1000>; + }; + + target-module@a2000 { /* 0x480a2000, ap 79 3a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa2000 0x1000>; + }; + + target-module@a4000 { /* 0x480a4000, ap 59 34.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x000a4000 0x00001000>, + <0x00001000 0x000a5000 0x00001000>; + }; + + des_target: target-module@a5000 { /* 0x480a5000 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0xa5030 0x4>, + <0xa5034 0x4>, + <0xa5038 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_DES3DES_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xa5000 0x00001000>; + + des: des@0 { + compatible = "ti,omap4-des"; + reg = <0 0xa0>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 117>, <&sdma 116>; + dma-names = "tx", "rx"; + }; + }; + + target-module@a8000 { /* 0x480a8000, ap 61 3e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa8000 0x4000>; + }; + + target-module@ad000 { /* 0x480ad000, ap 63 50.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xad000 0x4>, + <0xad010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MMC3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xad000 0x1000>; + + mmc3: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 77>, <&sdma 78>; + dma-names = "tx", "rx"; + }; + }; + + target-module@b0000 { /* 0x480b0000, ap 47 40.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb0000 0x1000>; + }; + + target-module@b2000 { /* 0x480b2000, ap 65 3c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0xb2000 0x4>, + <0xb2014 0x4>, + <0xb2018 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + ti,no-reset-on-init; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_HDQ1W_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb2000 0x1000>; + + hdqw1w: 1w@0 { + compatible = "ti,omap3-1w"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@b4000 { /* 0x480b4000, ap 67 46.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xb4000 0x4>, + <0xb4010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_MMC2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb4000 0x1000>; + + mmc2: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 47>, <&sdma 48>; + dma-names = "tx", "rx"; + }; + }; + + target-module@b8000 { /* 0x480b8000, ap 69 58.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xb8000 0x4>, + <0xb8010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb8000 0x1000>; + + mcspi3: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <2>; + dmas = <&sdma 15>, <&sdma 16>; + dma-names = "tx0", "rx0"; + }; + }; + + target-module@ba000 { /* 0x480ba000, ap 71 32.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xba000 0x4>, + <0xba010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xba000 0x1000>; + + mcspi4: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <1>; + dmas = <&sdma 70>, <&sdma 71>; + dma-names = "tx0", "rx0"; + }; + }; + + target-module@d1000 { /* 0x480d1000, ap 73 44.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xd1000 0x4>, + <0xd1010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MMC4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xd1000 0x1000>; + + mmc4: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 57>, <&sdma 58>; + dma-names = "tx", "rx"; + }; + }; + + target-module@d5000 { /* 0x480d5000, ap 75 4e.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xd5000 0x4>, + <0xd5010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MMC5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xd5000 0x1000>; + + mmc5: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 59>, <&sdma 60>; + dma-names = "tx", "rx"; + }; + }; + }; + + segment@200000 { /* 0x48200000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00150000 0x00350000 0x001000>, /* ap 77 */ + <0x00151000 0x00351000 0x001000>; /* ap 78 */ + + target-module@150000 { /* 0x48350000, ap 77 4c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x150000 0x8>, + <0x150010 0x8>, + <0x150090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x150000 0x1000>; + + i2c4: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; +}; + diff --git a/arch/arm/dts/omap4-mcpdm.dtsi b/arch/arm/dts/omap4-mcpdm.dtsi new file mode 100644 index 0000000000..915a9b31a3 --- /dev/null +++ b/arch/arm/dts/omap4-mcpdm.dtsi @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Common omap4 mcpdm configuration + * + * Only include this file if your board has pdmclk wired from the + * pmic to ABE as mcpdm uses an external clock for the module. + */ + +&omap4_pmx_core { + mcpdm_pins: pinmux_mcpdm_pins { + pinctrl-single,pins = < + /* 0x4a100106 abe_pdm_ul_data.abe_pdm_ul_data ag25 */ + OMAP4_IOPAD(0x106, PIN_INPUT_PULLDOWN | MUX_MODE0) + + /* 0x4a100108 abe_pdm_dl_data.abe_pdm_dl_data af25 */ + OMAP4_IOPAD(0x108, PIN_INPUT_PULLDOWN | MUX_MODE0) + + /* 0x4a10010a abe_pdm_frame.abe_pdm_frame ae25 */ + OMAP4_IOPAD(0x10a, PIN_INPUT_PULLUP | MUX_MODE0) + + /* 0x4a10010c abe_pdm_lb_clk.abe_pdm_lb_clk af26 */ + OMAP4_IOPAD(0x10c, PIN_INPUT_PULLDOWN | MUX_MODE0) + + /* 0x4a10010e abe_clks.abe_clks ah26 */ + OMAP4_IOPAD(0x10e, PIN_INPUT_PULLDOWN | MUX_MODE0) + >; + }; +}; + +&mcpdm_module { + /* + * McPDM pads must be muxed at the interconnect target module + * level as the module on the SoC needs external clock from + * the PMIC + */ + pinctrl-names = "default"; + pinctrl-0 = <&mcpdm_pins>; + status = "okay"; +}; + +&mcpdm { + clocks = <&twl6040>; + clock-names = "pdmclk"; +}; diff --git a/arch/arm/dts/omap4-panda-common.dtsi b/arch/arm/dts/omap4-panda-common.dtsi new file mode 100644 index 0000000000..55ea8b6189 --- /dev/null +++ b/arch/arm/dts/omap4-panda-common.dtsi @@ -0,0 +1,573 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011-2013 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include <dt-bindings/input/input.h> +#include "elpida_ecb240abacn.dtsi" +#include "omap4-mcpdm.dtsi" + +/ { + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x40000000>; /* 1 GB */ + }; + + chosen { + stdout-path = &uart3; + }; + + aliases { + display0 = &dvi0; + display1 = &hdmi0; + ethernet = ðernet; + }; + + leds: leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = < + &led_wkgpio_pins + >; + + heartbeat { + label = "pandaboard::status1"; + gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + mmc { + label = "pandaboard::status2"; + gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + }; + + gpio_keys: gpio_keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = < + &button_pins + >; + + buttonS2 { + label = "button S2"; + gpios = <&gpio4 25 GPIO_ACTIVE_LOW>; /* gpio_121 */ + linux,code = <BTN_0>; + wakeup-source; + }; + }; + + sound: sound { + compatible = "ti,abe-twl6040"; + ti,model = "PandaBoard"; + + ti,mclk-freq = <38400000>; + + ti,mcpdm = <&mcpdm>; + + ti,twl6040 = <&twl6040>; + + /* Audio routing */ + ti,audio-routing = + "Headset Stereophone", "HSOL", + "Headset Stereophone", "HSOR", + "Ext Spk", "HFL", + "Ext Spk", "HFR", + "Line Out", "AUXL", + "Line Out", "AUXR", + "HSMIC", "Headset Mic", + "Headset Mic", "Headset Mic Bias", + "AFML", "Line In", + "AFMR", "Line In"; + }; + + /* HS USB Port 1 Power */ + hsusb1_power: hsusb1_power_reg { + compatible = "regulator-fixed"; + regulator-name = "hsusb1_vbus"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 1 GPIO_ACTIVE_HIGH>; /* gpio_1 */ + startup-delay-us = <70000>; + enable-active-high; + /* + * boot-on is required along with always-on as the + * regulator framework doesn't enable the regulator + * if boot-on is not there. + */ + regulator-always-on; + regulator-boot-on; + }; + + /* HS USB Host PHY on PORT 1 */ + hsusb1_phy: hsusb1_phy { + compatible = "usb-nop-xceiv"; + reset-gpios = <&gpio2 30 GPIO_ACTIVE_LOW>; /* gpio_62 */ + #phy-cells = <0>; + vcc-supply = <&hsusb1_power>; + clocks = <&auxclk3_ck>; + clock-names = "main_clk"; + clock-frequency = <19200000>; + }; + + /* regulator for wl12xx on sdio5 */ + wl12xx_vmmc: wl12xx_vmmc { + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_gpio>; + compatible = "regulator-fixed"; + regulator-name = "vwl1271"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio2 11 GPIO_ACTIVE_HIGH>; + startup-delay-us = <70000>; + enable-active-high; + }; + + tfp410: encoder0 { + compatible = "ti,tfp410"; + powerdown-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>; /* gpio_0 */ + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tfp410_in: endpoint { + remote-endpoint = <&dpi_out>; + }; + }; + + port@1 { + reg = <1>; + + tfp410_out: endpoint { + remote-endpoint = <&dvi_connector_in>; + }; + }; + }; + }; + + dvi0: connector0 { + compatible = "dvi-connector"; + label = "dvi"; + + digital; + + ddc-i2c-bus = <&i2c3>; + + port { + dvi_connector_in: endpoint { + remote-endpoint = <&tfp410_out>; + }; + }; + }; + + tpd12s015: encoder1 { + compatible = "ti,tpd12s015"; + + gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>, /* 60, CT CP HPD */ + <&gpio2 9 GPIO_ACTIVE_HIGH>, /* 41, LS OE */ + <&gpio2 31 GPIO_ACTIVE_HIGH>; /* 63, HPD */ + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tpd12s015_in: endpoint { + remote-endpoint = <&hdmi_out>; + }; + }; + + port@1 { + reg = <1>; + + tpd12s015_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; + }; + }; + }; + + hdmi0: connector1 { + compatible = "hdmi-connector"; + label = "hdmi"; + + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&tpd12s015_out>; + }; + }; + }; +}; + +&omap4_pmx_core { + pinctrl-names = "default"; + pinctrl-0 = < + &dss_dpi_pins + &tfp410_pins + &dss_hdmi_pins + &tpd12s015_pins + &hsusbb1_pins + >; + + twl6040_pins: pinmux_twl6040_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x120, PIN_OUTPUT | MUX_MODE3) /* hdq_sio.gpio_127 */ + OMAP4_IOPAD(0x1a0, PIN_INPUT | MUX_MODE0) /* sys_nirq2.sys_nirq2 */ + >; + }; + + mcbsp1_pins: pinmux_mcbsp1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0fe, PIN_INPUT | MUX_MODE0) /* abe_mcbsp1_clkx.abe_mcbsp1_clkx */ + OMAP4_IOPAD(0x100, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp1_dr.abe_mcbsp1_dr */ + OMAP4_IOPAD(0x102, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp1_dx.abe_mcbsp1_dx */ + OMAP4_IOPAD(0x104, PIN_INPUT | MUX_MODE0) /* abe_mcbsp1_fsx.abe_mcbsp1_fsx */ + >; + }; + + dss_dpi_pins: pinmux_dss_dpi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x162, PIN_OUTPUT | MUX_MODE5) /* dispc2_data23 */ + OMAP4_IOPAD(0x164, PIN_OUTPUT | MUX_MODE5) /* dispc2_data22 */ + OMAP4_IOPAD(0x166, PIN_OUTPUT | MUX_MODE5) /* dispc2_data21 */ + OMAP4_IOPAD(0x168, PIN_OUTPUT | MUX_MODE5) /* dispc2_data20 */ + OMAP4_IOPAD(0x16a, PIN_OUTPUT | MUX_MODE5) /* dispc2_data19 */ + OMAP4_IOPAD(0x16c, PIN_OUTPUT | MUX_MODE5) /* dispc2_data18 */ + OMAP4_IOPAD(0x16e, PIN_OUTPUT | MUX_MODE5) /* dispc2_data15 */ + OMAP4_IOPAD(0x170, PIN_OUTPUT | MUX_MODE5) /* dispc2_data14 */ + OMAP4_IOPAD(0x172, PIN_OUTPUT | MUX_MODE5) /* dispc2_data13 */ + OMAP4_IOPAD(0x174, PIN_OUTPUT | MUX_MODE5) /* dispc2_data12 */ + OMAP4_IOPAD(0x176, PIN_OUTPUT | MUX_MODE5) /* dispc2_data11 */ + + OMAP4_IOPAD(0x1b4, PIN_OUTPUT | MUX_MODE5) /* dispc2_data10 */ + OMAP4_IOPAD(0x1b6, PIN_OUTPUT | MUX_MODE5) /* dispc2_data9 */ + OMAP4_IOPAD(0x1b8, PIN_OUTPUT | MUX_MODE5) /* dispc2_data16 */ + OMAP4_IOPAD(0x1ba, PIN_OUTPUT | MUX_MODE5) /* dispc2_data17 */ + OMAP4_IOPAD(0x1bc, PIN_OUTPUT | MUX_MODE5) /* dispc2_hsync */ + OMAP4_IOPAD(0x1be, PIN_OUTPUT | MUX_MODE5) /* dispc2_pclk */ + OMAP4_IOPAD(0x1c0, PIN_OUTPUT | MUX_MODE5) /* dispc2_vsync */ + OMAP4_IOPAD(0x1c2, PIN_OUTPUT | MUX_MODE5) /* dispc2_de */ + OMAP4_IOPAD(0x1c4, PIN_OUTPUT | MUX_MODE5) /* dispc2_data8 */ + OMAP4_IOPAD(0x1c6, PIN_OUTPUT | MUX_MODE5) /* dispc2_data7 */ + OMAP4_IOPAD(0x1c8, PIN_OUTPUT | MUX_MODE5) /* dispc2_data6 */ + OMAP4_IOPAD(0x1ca, PIN_OUTPUT | MUX_MODE5) /* dispc2_data5 */ + OMAP4_IOPAD(0x1cc, PIN_OUTPUT | MUX_MODE5) /* dispc2_data4 */ + OMAP4_IOPAD(0x1ce, PIN_OUTPUT | MUX_MODE5) /* dispc2_data3 */ + + OMAP4_IOPAD(0x1d0, PIN_OUTPUT | MUX_MODE5) /* dispc2_data2 */ + OMAP4_IOPAD(0x1d2, PIN_OUTPUT | MUX_MODE5) /* dispc2_data1 */ + OMAP4_IOPAD(0x1d4, PIN_OUTPUT | MUX_MODE5) /* dispc2_data0 */ + >; + }; + + tfp410_pins: pinmux_tfp410_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x184, PIN_OUTPUT | MUX_MODE3) /* gpio_0 */ + >; + }; + + dss_hdmi_pins: pinmux_dss_hdmi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x09a, PIN_INPUT | MUX_MODE0) /* hdmi_cec.hdmi_cec */ + OMAP4_IOPAD(0x09c, PIN_INPUT_PULLUP | MUX_MODE0) /* hdmi_scl.hdmi_scl */ + OMAP4_IOPAD(0x09e, PIN_INPUT_PULLUP | MUX_MODE0) /* hdmi_sda.hdmi_sda */ + >; + }; + + tpd12s015_pins: pinmux_tpd12s015_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x062, PIN_OUTPUT | MUX_MODE3) /* gpmc_a17.gpio_41 */ + OMAP4_IOPAD(0x088, PIN_OUTPUT | MUX_MODE3) /* gpmc_nbe1.gpio_60 */ + OMAP4_IOPAD(0x098, PIN_INPUT_PULLDOWN | MUX_MODE3) /* hdmi_hpd.gpio_63 */ + >; + }; + + hsusbb1_pins: pinmux_hsusbb1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0c2, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_clk.usbb1_ulpiphy_clk */ + OMAP4_IOPAD(0x0c4, PIN_OUTPUT | MUX_MODE4) /* usbb1_ulpitll_stp.usbb1_ulpiphy_stp */ + OMAP4_IOPAD(0x0c6, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dir.usbb1_ulpiphy_dir */ + OMAP4_IOPAD(0x0c8, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_nxt.usbb1_ulpiphy_nxt */ + OMAP4_IOPAD(0x0ca, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat0.usbb1_ulpiphy_dat0 */ + OMAP4_IOPAD(0x0cc, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat1.usbb1_ulpiphy_dat1 */ + OMAP4_IOPAD(0x0ce, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat2.usbb1_ulpiphy_dat2 */ + OMAP4_IOPAD(0x0d0, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat3.usbb1_ulpiphy_dat3 */ + OMAP4_IOPAD(0x0d2, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat4.usbb1_ulpiphy_dat4 */ + OMAP4_IOPAD(0x0d4, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat5.usbb1_ulpiphy_dat5 */ + OMAP4_IOPAD(0x0d6, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat6.usbb1_ulpiphy_dat6 */ + OMAP4_IOPAD(0x0d8, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat7.usbb1_ulpiphy_dat7 */ + >; + }; + + i2c1_pins: pinmux_i2c1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x122, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_scl */ + OMAP4_IOPAD(0x124, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_sda */ + >; + }; + + i2c2_pins: pinmux_i2c2_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x126, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c2_scl */ + OMAP4_IOPAD(0x128, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c2_sda */ + >; + }; + + i2c3_pins: pinmux_i2c3_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x12a, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c3_scl */ + OMAP4_IOPAD(0x12c, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c3_sda */ + >; + }; + + i2c4_pins: pinmux_i2c4_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x12e, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c4_scl */ + OMAP4_IOPAD(0x130, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c4_sda */ + >; + }; + + /* + * wl12xx GPIO outputs for WLAN_EN, BT_EN, FM_EN, BT_WAKEUP + * REVISIT: Are the pull-ups needed for GPIO 48 and 49? + */ + wl12xx_gpio: pinmux_wl12xx_gpio { + pinctrl-single,pins = < + OMAP4_IOPAD(0x066, PIN_OUTPUT | MUX_MODE3) /* gpmc_a19.gpio_43 */ + OMAP4_IOPAD(0x06c, PIN_OUTPUT | MUX_MODE3) /* gpmc_a22.gpio_46 */ + OMAP4_IOPAD(0x070, PIN_OUTPUT_PULLUP | MUX_MODE3) /* gpmc_a24.gpio_48 */ + OMAP4_IOPAD(0x072, PIN_OUTPUT_PULLUP | MUX_MODE3) /* gpmc_a25.gpio_49 */ + >; + }; + + /* wl12xx GPIO inputs and SDIO pins */ + wl12xx_pins: pinmux_wl12xx_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x078, PIN_INPUT | MUX_MODE3) /* gpmc_ncs2.gpio_52 */ + OMAP4_IOPAD(0x07a, PIN_INPUT | MUX_MODE3) /* gpmc_ncs3.gpio_53 */ + OMAP4_IOPAD(0x148, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_clk.sdmmc5_clk */ + OMAP4_IOPAD(0x14a, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_cmd.sdmmc5_cmd */ + OMAP4_IOPAD(0x14c, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat0.sdmmc5_dat0 */ + OMAP4_IOPAD(0x14e, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat1.sdmmc5_dat1 */ + OMAP4_IOPAD(0x150, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat2.sdmmc5_dat2 */ + OMAP4_IOPAD(0x152, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat3.sdmmc5_dat3 */ + >; + }; + + button_pins: pinmux_button_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x114, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio_121 */ + >; + }; +}; + +&omap4_pmx_wkup { + led_wkgpio_pins: pinmux_leds_wkpins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x05a, PIN_OUTPUT | MUX_MODE3) /* gpio_wk7 */ + OMAP4_IOPAD(0x05c, PIN_OUTPUT | MUX_MODE3) /* gpio_wk8 */ + >; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + + clock-frequency = <400000>; + + twl: twl@48 { + reg = <0x48>; + /* IRQ# = 7 */ + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; /* IRQ_SYS_1N cascaded to gic */ + }; + + twl6040: twl@4b { + compatible = "ti,twl6040"; + #clock-cells = <0>; + reg = <0x4b>; + + pinctrl-names = "default"; + pinctrl-0 = <&twl6040_pins>; + + /* IRQ# = 119 */ + interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; /* IRQ_SYS_2N cascaded to gic */ + ti,audpwron-gpio = <&gpio4 31 GPIO_ACTIVE_HIGH>; /* gpio line 127 */ + + vio-supply = <&v1v8>; + v2v1-supply = <&v2v1>; + enable-active-high; + }; +}; + +#include "twl6030.dtsi" +#include "twl6030_omap4.dtsi" + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; + + clock-frequency = <400000>; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_pins>; + + clock-frequency = <100000>; + + /* + * Display monitor features are burnt in their EEPROM as EDID data. + * The EEPROM is connected as I2C slave device. + */ + eeprom@50 { + compatible = "ti,eeprom"; + reg = <0x50>; + }; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c4_pins>; + + clock-frequency = <400000>; +}; + +&mmc1 { + vmmc-supply = <&vmmc>; + bus-width = <8>; +}; + +&mmc2 { + status = "disabled"; +}; + +&mmc3 { + status = "disabled"; +}; + +&mmc4 { + status = "disabled"; +}; + +&mmc5 { + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_pins>; + vmmc-supply = <&wl12xx_vmmc>; + interrupts-extended = <&wakeupgen GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core 0x10e>; + non-removable; + bus-width = <4>; + cap-power-off-card; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1271"; + reg = <2>; + /* gpio_53 with gpmc_ncs3 pad as wakeup */ + interrupts-extended = <&gpio2 21 IRQ_TYPE_LEVEL_HIGH>, + <&omap4_pmx_core 0x3a>; + interrupt-names = "irq", "wakeup"; + ref-clock-frequency = <38400000>; + }; +}; + +&emif1 { + cs1-used; + device-handle = <&elpida_ECB240ABACN>; +}; + +&emif2 { + cs1-used; + device-handle = <&elpida_ECB240ABACN>; +}; + +&mcbsp1 { + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp1_pins>; + status = "okay"; +}; + +&twl_usb_comparator { + usb-supply = <&vusb>; +}; + +&uart2 { + interrupts-extended = <&wakeupgen GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART2_RX>; +}; + +&uart3 { + interrupts-extended = <&wakeupgen GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART3_RX>; +}; + +&uart4 { + interrupts-extended = <&wakeupgen GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART4_RX>; +}; + +&usb_otg_hs { + interface-type = <1>; + mode = <3>; + power = <50>; +}; + +&usbhshost { + port1-mode = "ehci-phy"; +}; + +&usbhsehci { + phys = <&hsusb1_phy>; + + #address-cells = <1>; + #size-cells = <0>; + + hub@1 { + compatible = "usb424,9514"; + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + ethernet: usbether@1 { + compatible = "usb424,ec00"; + reg = <1>; + }; + }; +}; + +&dss { + status = "ok"; + + port { + dpi_out: endpoint { + remote-endpoint = <&tfp410_in>; + data-lines = <24>; + }; + }; +}; + +&dsi2 { + status = "ok"; + vdd-supply = <&vcxio>; +}; + +&hdmi { + status = "ok"; + vdda-supply = <&vdac>; + + port { + hdmi_out: endpoint { + remote-endpoint = <&tpd12s015_in>; + }; + }; +}; diff --git a/arch/arm/dts/omap4-panda-es.dts b/arch/arm/dts/omap4-panda-es.dts new file mode 100644 index 0000000000..9dd307b526 --- /dev/null +++ b/arch/arm/dts/omap4-panda-es.dts @@ -0,0 +1,82 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + */ +/dts-v1/; + +#include "omap4460.dtsi" +#include "omap4-panda-common.dtsi" + +/ { + model = "TI OMAP4 PandaBoard-ES"; + compatible = "ti,omap4-panda-es", "ti,omap4-panda", "ti,omap4460", "ti,omap4430", "ti,omap4"; +}; + +/* Audio routing is differnet between PandaBoard4430 and PandaBoardES */ +&sound { + ti,model = "PandaBoardES"; + + /* Audio routing */ + ti,audio-routing = + "Headset Stereophone", "HSOL", + "Headset Stereophone", "HSOR", + "Ext Spk", "HFL", + "Ext Spk", "HFR", + "Line Out", "AUXL", + "Line Out", "AUXR", + "AFML", "Line In", + "AFMR", "Line In"; +}; + +/* PandaboardES has external pullups on SCL & SDA */ +&dss_hdmi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x09a, PIN_INPUT | MUX_MODE0) /* hdmi_cec.hdmi_cec */ + OMAP4_IOPAD(0x09c, PIN_INPUT | MUX_MODE0) /* hdmi_scl.hdmi_scl */ + OMAP4_IOPAD(0x09e, PIN_INPUT | MUX_MODE0) /* hdmi_sda.hdmi_sda */ + >; +}; + +&omap4_pmx_core { + led_gpio_pins: gpio_led_pmx { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0f6, PIN_OUTPUT | MUX_MODE3) /* gpio_110 */ + >; + }; + + button_pins: pinmux_button_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x11b, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio_113 */ + >; + }; +}; + +&led_wkgpio_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x05c, PIN_OUTPUT | MUX_MODE3) /* gpio_wk8 */ + >; +}; + +&leds { + pinctrl-0 = < + &led_gpio_pins + &led_wkgpio_pins + >; + + heartbeat { + gpios = <&gpio4 14 GPIO_ACTIVE_HIGH>; + }; + mmc { + gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; + }; +}; + +&gpio_keys { + buttonS2 { + gpios = <&gpio4 17 GPIO_ACTIVE_LOW>; /* gpio_113 */ + }; +}; + +&gpio1_target { + ti,no-reset-on-init; +}; diff --git a/arch/arm/dts/omap4-panda.dts b/arch/arm/dts/omap4-panda.dts new file mode 100644 index 0000000000..fb2f47717b --- /dev/null +++ b/arch/arm/dts/omap4-panda.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + */ +/dts-v1/; + +#include "omap443x.dtsi" +#include "omap4-panda-common.dtsi" + +/ { + model = "TI OMAP4 PandaBoard"; + compatible = "ti,omap4-panda", "ti,omap4430", "ti,omap4"; +}; diff --git a/arch/arm/dts/omap4.dtsi b/arch/arm/dts/omap4.dtsi new file mode 100644 index 0000000000..763bdea8c8 --- /dev/null +++ b/arch/arm/dts/omap4.dtsi @@ -0,0 +1,657 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <dt-bindings/bus/ti-sysc.h> +#include <dt-bindings/clock/omap4.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/omap.h> +#include <dt-bindings/clock/omap4.h> + +/ { + compatible = "ti,omap4430", "ti,omap4"; + interrupt-parent = <&wakeupgen>; + #address-cells = <1>; + #size-cells = <1>; + chosen { }; + + aliases { + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + i2c3 = &i2c4; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + next-level-cache = <&L2>; + reg = <0x0>; + + clocks = <&dpll_mpu_ck>; + clock-names = "cpu"; + + clock-latency = <300000>; /* From omap-cpufreq driver */ + }; + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + next-level-cache = <&L2>; + reg = <0x1>; + }; + }; + + /* + * Note that 4430 needs cross trigger interface (CTI) supported + * before we can configure the interrupts. This means sampling + * events are not supported for pmu. Note that 4460 does not use + * CTI, see also 4460.dtsi. + */ + pmu { + compatible = "arm,cortex-a9-pmu"; + ti,hwmods = "debugss"; + }; + + gic: interrupt-controller@48241000 { + compatible = "arm,cortex-a9-gic"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x48241000 0x1000>, + <0x48240100 0x0100>; + interrupt-parent = <&gic>; + }; + + L2: l2-cache-controller@48242000 { + compatible = "arm,pl310-cache"; + reg = <0x48242000 0x1000>; + cache-unified; + cache-level = <2>; + }; + + local-timer@48240600 { + compatible = "arm,cortex-a9-twd-timer"; + clocks = <&mpu_periphclk>; + reg = <0x48240600 0x20>; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_EDGE_RISING)>; + interrupt-parent = <&gic>; + }; + + wakeupgen: interrupt-controller@48281000 { + compatible = "ti,omap4-wugen-mpu"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x48281000 0x1000>; + interrupt-parent = <&gic>; + }; + + /* + * The soc node represents the soc top level view. It is used for IPs + * that are not memory mapped in the MPU view or for the MPU itself. + */ + soc { + compatible = "ti,omap-infra"; + mpu { + compatible = "ti,omap4-mpu"; + ti,hwmods = "mpu"; + sram = <&ocmcram>; + }; + + dsp { + compatible = "ti,omap3-c64"; + }; + + iva { + compatible = "ti,ivahd"; + ti,hwmods = "iva"; + }; + }; + + /* + * XXX: Use a flat representation of the OMAP4 interconnect. + * The real OMAP interconnect network is quite complex. + * Since it will not bring real advantage to represent that in DT for + * the moment, just use a fake OCP bus entry to represent the whole bus + * hierarchy. + */ + ocp { + compatible = "ti,omap4-l3-noc", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + ti,hwmods = "l3_main_1", "l3_main_2", "l3_main_3"; + reg = <0x44000000 0x1000>, + <0x44800000 0x2000>, + <0x45000000 0x1000>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + + l4_wkup: interconnect@4a300000 { + }; + + l4_cfg: interconnect@4a000000 { + }; + + l4_per: interconnect@48000000 { + }; + + l4_abe: interconnect@40100000 { + }; + + ocmcram: sram@40304000 { + compatible = "mmio-sram"; + reg = <0x40304000 0xa000>; /* 40k */ + }; + + gpmc: gpmc@50000000 { + compatible = "ti,omap4430-gpmc"; + reg = <0x50000000 0x1000>; + #address-cells = <2>; + #size-cells = <1>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 4>; + dma-names = "rxtx"; + gpmc,num-cs = <8>; + gpmc,num-waitpins = <4>; + ti,hwmods = "gpmc"; + ti,no-idle-on-init; + clocks = <&l3_div_ck>; + clock-names = "fck"; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + }; + + target-module@52000000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "iss"; + reg = <0x52000000 0x4>, + <0x52000010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-delay-us = <2>; + clocks = <&iss_clkctrl OMAP4_ISS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x52000000 0x1000000>; + + /* No child device binding, driver in staging */ + }; + + target-module@55082000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x55082000 0x4>, + <0x55082010 0x4>, + <0x55082014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + clocks = <&ducati_clkctrl OMAP4_IPU_CLKCTRL 0>; + clock-names = "fck"; + resets = <&prm_core 2>; + reset-names = "rstctrl"; + ranges = <0x0 0x55082000 0x100>; + #size-cells = <1>; + #address-cells = <1>; + + mmu_ipu: mmu@0 { + compatible = "ti,omap4-iommu"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <0>; + ti,iommu-bus-err-back; + }; + }; + + target-module@4012c000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x4012c000 0x4>, + <0x4012c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + clocks = <&abe_clkctrl OMAP4_SLIMBUS1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4012c000 0x1000>, /* MPU */ + <0x4902c000 0x4902c000 0x1000>; /* L3 */ + + /* No child device binding or driver in mainline */ + }; + + dmm@4e000000 { + compatible = "ti,omap4-dmm"; + reg = <0x4e000000 0x800>; + interrupts = <0 113 0x4>; + ti,hwmods = "dmm"; + }; + + emif1: emif@4c000000 { + compatible = "ti,emif-4d"; + reg = <0x4c000000 0x100>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + ti,hwmods = "emif1"; + ti,no-idle-on-init; + phy-type = <1>; + hw-caps-read-idle-ctrl; + hw-caps-ll-interface; + hw-caps-temp-alert; + }; + + emif2: emif@4d000000 { + compatible = "ti,emif-4d"; + reg = <0x4d000000 0x100>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + ti,hwmods = "emif2"; + ti,no-idle-on-init; + phy-type = <1>; + hw-caps-read-idle-ctrl; + hw-caps-ll-interface; + hw-caps-temp-alert; + }; + + aes1_target: target-module@4b501000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4b501080 0x4>, + <0x4b501084 0x4>, + <0x4b501088 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_AES1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4b501000 0x1000>; + + aes1: aes@0 { + compatible = "ti,omap4-aes"; + reg = <0 0xa0>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 111>, <&sdma 110>; + dma-names = "tx", "rx"; + }; + }; + + aes2_target: target-module@4b701000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4b701080 0x4>, + <0x4b701084 0x4>, + <0x4b701088 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_AES2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4b701000 0x1000>; + + aes2: aes@0 { + compatible = "ti,omap4-aes"; + reg = <0 0xa0>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 114>, <&sdma 113>; + dma-names = "tx", "rx"; + }; + }; + + sham_target: target-module@4b100000 { + compatible = "ti,sysc-omap3-sham", "ti,sysc"; + reg = <0x4b100100 0x4>, + <0x4b100110 0x4>, + <0x4b100114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_SHA2MD5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4b100000 0x1000>; + + sham: sham@0 { + compatible = "ti,omap4-sham"; + reg = <0 0x300>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 119>; + dma-names = "rx"; + }; + }; + + abb_mpu: regulator-abb-mpu { + compatible = "ti,abb-v2"; + regulator-name = "abb_mpu"; + #address-cells = <0>; + #size-cells = <0>; + ti,tranxdone-status-mask = <0x80>; + clocks = <&sys_clkin_ck>; + ti,settling-time = <50>; + ti,clock-cycles = <16>; + + status = "disabled"; + }; + + abb_iva: regulator-abb-iva { + compatible = "ti,abb-v2"; + regulator-name = "abb_iva"; + #address-cells = <0>; + #size-cells = <0>; + ti,tranxdone-status-mask = <0x80000000>; + clocks = <&sys_clkin_ck>; + ti,settling-time = <50>; + ti,clock-cycles = <16>; + + status = "disabled"; + }; + + target-module@56000000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x5600fe00 0x4>, + <0x5600fe10 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + clocks = <&l3_gfx_clkctrl OMAP4_GPU_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x56000000 0x2000000>; + + /* + * Closed source PowerVR driver, no child device + * binding or driver in mainline + */ + }; + + /* + * DSS is only using l3 mapping without l4 as noted in the TRM + * "10.1.3 DSS Register Manual" for omap4460. + */ + target-module@58000000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x58000000 4>, + <0x58000014 4>; + reg-names = "rev", "syss"; + ti,syss-mask = <1>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 0>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 9>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 11>; + clock-names = "fck", "hdmi_clk", "sys_clk", "tv_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x58000000 0x1000000>; + + dss: dss@0 { + compatible = "ti,omap4-dss"; + reg = <0 0x80>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000000>; + + target-module@1000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x1000 0x4>, + <0x1010 0x4>, + <0x1014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000 0x1000>; + + dispc@0 { + compatible = "ti,omap4-dispc"; + reg = <0 0x1000>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + }; + }; + + target-module@2000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2000 0x4>, + <0x2010 0x4>, + <0x2014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x2000 0x1000>; + + rfbi: encoder@0 { + reg = <0 0x1000>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, <&l3_div_ck>; + clock-names = "fck", "ick"; + }; + }; + + target-module@3000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x3000 0x4>; + reg-names = "rev"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "sys_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x3000 0x1000>; + + venc: encoder@0 { + compatible = "ti,omap4-venc"; + reg = <0 0x1000>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 11>; + clock-names = "fck"; + }; + }; + + target-module@4000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4000 0x4>, + <0x4010 0x4>, + <0x4014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x4000 0x1000>; + + dsi1: encoder@0 { + compatible = "ti,omap4-dsi"; + reg = <0 0x200>, + <0x200 0x40>, + <0x300 0x20>; + reg-names = "proto", "phy", "pll"; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + }; + }; + + target-module@5000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5000 0x4>, + <0x5010 0x4>, + <0x5014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x5000 0x1000>; + + dsi2: encoder@0 { + compatible = "ti,omap4-dsi"; + reg = <0 0x200>, + <0x200 0x40>, + <0x300 0x20>; + reg-names = "proto", "phy", "pll"; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + }; + }; + + target-module@6000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x6000 0x4>, + <0x6010 0x4>; + reg-names = "rev", "sysc"; + /* + * Has SYSC_IDLE_SMART and SYSC_IDLE_SMART_WKUP + * but HDMI audio will fail with them. + */ + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + ti,sysc-mask = <(SYSC_OMAP4_SOFTRESET)>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 9>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>; + clock-names = "fck", "dss_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x6000 0x2000>; + + hdmi: encoder@0 { + compatible = "ti,omap4-hdmi"; + reg = <0 0x200>, + <0x200 0x100>, + <0x300 0x100>, + <0x400 0x1000>; + reg-names = "wp", "pll", "phy", "core"; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 9>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + dmas = <&sdma 76>; + dma-names = "audio_tx"; + }; + }; + }; + }; + }; +}; + +#include "omap4-l4.dtsi" +#include "omap4-l4-abe.dtsi" +#include "omap44xx-clocks.dtsi" + +&prm { + prm_tesla: prm@400 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0x400 0x100>; + #reset-cells = <1>; + }; + + prm_core: prm@700 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0x700 0x100>; + #reset-cells = <1>; + }; + + prm_ivahd: prm@f00 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0xf00 0x100>; + #reset-cells = <1>; + }; + + prm_device: prm@1b00 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0x1b00 0x40>; + #reset-cells = <1>; + }; +}; diff --git a/arch/arm/dts/omap443x-clocks.dtsi b/arch/arm/dts/omap443x-clocks.dtsi new file mode 100644 index 0000000000..39297868ec --- /dev/null +++ b/arch/arm/dts/omap443x-clocks.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Device Tree Source for OMAP4 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + */ +&prm_clocks { + bandgap_fclk: bandgap_fclk@1888 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_32k_ck>; + ti,bit-shift = <8>; + reg = <0x1888>; + }; +}; diff --git a/arch/arm/dts/omap443x.dtsi b/arch/arm/dts/omap443x.dtsi new file mode 100644 index 0000000000..cbcdcb4e7d --- /dev/null +++ b/arch/arm/dts/omap443x.dtsi @@ -0,0 +1,76 @@ +/* + * Device Tree Source for OMAP443x SoC + * + * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include "omap4.dtsi" + +/ { + cpus { + cpu0: cpu@0 { + /* OMAP443x variants OPP50-OPPNT */ + operating-points = < + /* kHz uV */ + 300000 1025000 + 600000 1200000 + 800000 1313000 + 1008000 1375000 + >; + clock-latency = <300000>; /* From legacy driver */ + + /* cooling options */ + #cooling-cells = <2>; /* min followed by max */ + }; + }; + + thermal-zones { + #include "omap4-cpu-thermal.dtsi" + }; + + ocp { + bandgap: bandgap@4a002260 { + reg = <0x4a002260 0x4 + 0x4a00232C 0x4>; + compatible = "ti,omap4430-bandgap"; + + #thermal-sensor-cells = <0>; + }; + }; + + ocp { + abb_mpu: regulator-abb-mpu { + status = "okay"; + + reg = <0x4a307bd0 0x8>, <0x4a306014 0x4>; + reg-names = "base-address", "int-address"; + + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1025000 0 0 0 0 0 + 1200000 0 0 0 0 0 + 1313000 0 0 0 0 0 + 1375000 1 0 0 0 0 + 1389000 1 0 0 0 0 + >; + }; + + /* Default unused, just provide register info for record */ + abb_iva: regulator-abb-iva { + reg = <0x4a307bd8 0x8>, <0x4a306010 0x4>; + reg-names = "base-address", "int-address"; + }; + + }; + +}; + +&cpu_thermal { + coefficients = <0 20000>; +}; + +/include/ "omap443x-clocks.dtsi" diff --git a/arch/arm/dts/omap4460.dtsi b/arch/arm/dts/omap4460.dtsi new file mode 100644 index 0000000000..2223dc0d63 --- /dev/null +++ b/arch/arm/dts/omap4460.dtsi @@ -0,0 +1,131 @@ +/* + * Device Tree Source for OMAP4460 SoC + * + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ +#include "omap4.dtsi" + +/ { + cpus { + /* OMAP446x 'standard device' variants OPP50 to OPPTurbo */ + cpu0: cpu@0 { + operating-points = < + /* kHz uV */ + 350000 1025000 + 700000 1200000 + 920000 1313000 + >; + clock-latency = <300000>; /* From legacy driver */ + + /* cooling options */ + #cooling-cells = <2>; /* min followed by max */ + }; + }; + + pmu { + compatible = "arm,cortex-a9-pmu"; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + ti,hwmods = "debugss"; + }; + + thermal-zones { + #include "omap4-cpu-thermal.dtsi" + }; + + ocp { + bandgap: bandgap@4a002260 { + reg = <0x4a002260 0x4 + 0x4a00232C 0x4 + 0x4a002378 0x18>; + compatible = "ti,omap4460-bandgap"; + interrupts = <0 126 IRQ_TYPE_LEVEL_HIGH>; /* talert */ + gpios = <&gpio3 22 GPIO_ACTIVE_HIGH>; /* tshut */ + + #thermal-sensor-cells = <0>; + }; + + abb_mpu: regulator-abb-mpu { + status = "okay"; + + reg = <0x4a307bd0 0x8>, <0x4a306014 0x4>, + <0x4A002268 0x4>; + reg-names = "base-address", "int-address", + "efuse-address"; + + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1025000 0 0 0 0 0 + 1200000 0 0 0 0 0 + 1313000 0 0 0x100000 0x40000 0 + 1375000 1 0 0 0 0 + 1389000 1 0 0 0 0 + >; + }; + + abb_iva: regulator-abb-iva { + status = "okay"; + + reg = <0x4a307bd8 0x8>, <0x4a306010 0x4>, + <0x4A002268 0x4>; + reg-names = "base-address", "int-address", + "efuse-address"; + + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 950000 0 0 0 0 0 + 1140000 0 0 0 0 0 + 1291000 0 0 0x200000 0 0 + 1375000 1 0 0 0 0 + 1376000 1 0 0 0 0 + >; + }; + }; + +}; + +&cpu_thermal { + coefficients = <348 (-9301)>; +}; + +/* Only some L4 CFG interconnect ranges are different on 4460 */ +&l4_cfg_segment_300000 { + ranges = <0x00000000 0x00300000 0x020000>, /* ap 67 */ + <0x00040000 0x00340000 0x001000>, /* ap 68 */ + <0x00020000 0x00320000 0x004000>, /* ap 71 */ + <0x00024000 0x00324000 0x002000>, /* ap 72 */ + <0x00026000 0x00326000 0x001000>, /* ap 73 */ + <0x00027000 0x00327000 0x001000>, /* ap 74 */ + <0x00028000 0x00328000 0x001000>, /* ap 75 */ + <0x00029000 0x00329000 0x001000>, /* ap 76 */ + <0x00030000 0x00330000 0x010000>, /* ap 77 */ + <0x0002a000 0x0032a000 0x002000>, /* ap 90 */ + <0x0002c000 0x0032c000 0x004000>, /* ap 91 */ + <0x00010000 0x00310000 0x008000>, /* ap 92 */ + <0x00018000 0x00318000 0x004000>, /* ap 93 */ + <0x0001c000 0x0031c000 0x002000>, /* ap 94 */ + <0x0001e000 0x0031e000 0x002000>; /* ap 95 */ +}; + +&l4_cfg_target_0 { + ranges = <0x00000000 0x00000000 0x00010000>, + <0x00010000 0x00010000 0x00008000>, + <0x00018000 0x00018000 0x00004000>, + <0x0001c000 0x0001c000 0x00002000>, + <0x0001e000 0x0001e000 0x00002000>, + <0x00020000 0x00020000 0x00004000>, + <0x00024000 0x00024000 0x00002000>, + <0x00026000 0x00026000 0x00001000>, + <0x00027000 0x00027000 0x00001000>, + <0x00028000 0x00028000 0x00001000>, + <0x00029000 0x00029000 0x00001000>, + <0x0002a000 0x0002a000 0x00002000>, + <0x0002c000 0x0002c000 0x00004000>, + <0x00030000 0x00030000 0x00010000>; +}; + +/include/ "omap446x-clocks.dtsi" diff --git a/arch/arm/dts/omap446x-clocks.dtsi b/arch/arm/dts/omap446x-clocks.dtsi new file mode 100644 index 0000000000..0f41714cff --- /dev/null +++ b/arch/arm/dts/omap446x-clocks.dtsi @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Device Tree Source for OMAP4 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + */ +&prm_clocks { + div_ts_ck: div_ts_ck@1888 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&l4_wkup_clk_mux_ck>; + ti,bit-shift = <24>; + reg = <0x1888>; + ti,dividers = <8>, <16>, <32>; + }; + + bandgap_ts_fclk: bandgap_ts_fclk@1888 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&div_ts_ck>; + ti,bit-shift = <8>; + reg = <0x1888>; + }; +}; diff --git a/arch/arm/dts/omap44xx-clocks.dtsi b/arch/arm/dts/omap44xx-clocks.dtsi new file mode 100644 index 0000000000..5328685911 --- /dev/null +++ b/arch/arm/dts/omap44xx-clocks.dtsi @@ -0,0 +1,1324 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Device Tree Source for OMAP4 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + */ +&cm1_clocks { + extalt_clkin_ck: extalt_clkin_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <59000000>; + }; + + pad_clks_src_ck: pad_clks_src_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + pad_clks_ck: pad_clks_ck@108 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&pad_clks_src_ck>; + ti,bit-shift = <8>; + reg = <0x0108>; + }; + + pad_slimbus_core_clks_ck: pad_slimbus_core_clks_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + secure_32k_clk_src_ck: secure_32k_clk_src_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + slimbus_src_clk: slimbus_src_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + slimbus_clk: slimbus_clk@108 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&slimbus_src_clk>; + ti,bit-shift = <10>; + reg = <0x0108>; + }; + + sys_32k_ck: sys_32k_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + virt_12000000_ck: virt_12000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + virt_13000000_ck: virt_13000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <13000000>; + }; + + virt_16800000_ck: virt_16800000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <16800000>; + }; + + virt_19200000_ck: virt_19200000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <19200000>; + }; + + virt_26000000_ck: virt_26000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <26000000>; + }; + + virt_27000000_ck: virt_27000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <27000000>; + }; + + virt_38400000_ck: virt_38400000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <38400000>; + }; + + tie_low_clock_ck: tie_low_clock_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; + + utmi_phy_clkout_ck: utmi_phy_clkout_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + xclk60mhsp1_ck: xclk60mhsp1_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + xclk60mhsp2_ck: xclk60mhsp2_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + xclk60motg_ck: xclk60motg_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + dpll_abe_ck: dpll_abe_ck@1e0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-m4xen-clock"; + clocks = <&abe_dpll_refclk_mux_ck>, <&abe_dpll_bypass_clk_mux_ck>; + reg = <0x01e0>, <0x01e4>, <0x01ec>, <0x01e8>; + }; + + dpll_abe_x2_ck: dpll_abe_x2_ck@1f0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_abe_ck>; + reg = <0x01f0>; + }; + + dpll_abe_m2x2_ck: dpll_abe_m2x2_ck@1f0 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01f0>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + abe_24m_fclk: abe_24m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2x2_ck>; + clock-mult = <1>; + clock-div = <8>; + }; + + abe_clk: abe_clk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_m2x2_ck>; + ti,max-div = <4>; + reg = <0x0108>; + ti,index-power-of-two; + }; + + + dpll_abe_m3x2_ck: dpll_abe_m3x2_ck@1f4 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01f4>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + core_hsd_byp_clk_mux_ck: core_hsd_byp_clk_mux_ck@12c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_abe_m3x2_ck>; + ti,bit-shift = <23>; + reg = <0x012c>; + }; + + dpll_core_ck: dpll_core_ck@120 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-core-clock"; + clocks = <&sys_clkin_ck>, <&core_hsd_byp_clk_mux_ck>; + reg = <0x0120>, <0x0124>, <0x012c>, <0x0128>; + }; + + dpll_core_x2_ck: dpll_core_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_core_ck>; + }; + + dpll_core_m6x2_ck: dpll_core_m6x2_ck@140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0140>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_core_m2_ck: dpll_core_m2_ck@130 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0130>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + ddrphy_ck: ddrphy_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_core_m2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + dpll_core_m5x2_ck: dpll_core_m5x2_ck@13c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x013c>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + div_core_ck: div_core_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_m5x2_ck>; + reg = <0x0100>; + ti,max-div = <2>; + }; + + div_iva_hs_clk: div_iva_hs_clk@1dc { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_m5x2_ck>; + ti,max-div = <4>; + reg = <0x01dc>; + ti,index-power-of-two; + }; + + div_mpu_hs_clk: div_mpu_hs_clk@19c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_m5x2_ck>; + ti,max-div = <4>; + reg = <0x019c>; + ti,index-power-of-two; + }; + + dpll_core_m4x2_ck: dpll_core_m4x2_ck@138 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0138>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dll_clk_div_ck: dll_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_core_m4x2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + dpll_abe_m2_ck: dpll_abe_m2_ck@1f0 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_ck>; + ti,max-div = <31>; + reg = <0x01f0>; + ti,index-starts-at-one; + }; + + dpll_core_m3x2_gate_ck: dpll_core_m3x2_gate_ck@134 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_x2_ck>; + ti,bit-shift = <8>; + reg = <0x0134>; + }; + + dpll_core_m3x2_div_ck: dpll_core_m3x2_div_ck@134 { + #clock-cells = <0>; + compatible = "ti,composite-divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + reg = <0x0134>; + ti,index-starts-at-one; + }; + + dpll_core_m3x2_ck: dpll_core_m3x2_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&dpll_core_m3x2_gate_ck>, <&dpll_core_m3x2_div_ck>; + }; + + dpll_core_m7x2_ck: dpll_core_m7x2_ck@144 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0144>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + iva_hsd_byp_clk_mux_ck: iva_hsd_byp_clk_mux_ck@1ac { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&div_iva_hs_clk>; + ti,bit-shift = <23>; + reg = <0x01ac>; + }; + + dpll_iva_ck: dpll_iva_ck@1a0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin_ck>, <&iva_hsd_byp_clk_mux_ck>; + reg = <0x01a0>, <0x01a4>, <0x01ac>, <0x01a8>; + assigned-clocks = <&dpll_iva_ck>; + assigned-clock-rates = <931200000>; + }; + + dpll_iva_x2_ck: dpll_iva_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_iva_ck>; + }; + + dpll_iva_m4x2_ck: dpll_iva_m4x2_ck@1b8 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_iva_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01b8>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + assigned-clocks = <&dpll_iva_m4x2_ck>; + assigned-clock-rates = <465600000>; + }; + + dpll_iva_m5x2_ck: dpll_iva_m5x2_ck@1bc { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_iva_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01bc>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + assigned-clocks = <&dpll_iva_m5x2_ck>; + assigned-clock-rates = <266100000>; + }; + + dpll_mpu_ck: dpll_mpu_ck@160 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin_ck>, <&div_mpu_hs_clk>; + reg = <0x0160>, <0x0164>, <0x016c>, <0x0168>; + }; + + dpll_mpu_m2_ck: dpll_mpu_m2_ck@170 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_mpu_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0170>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + per_hs_clk_div_ck: per_hs_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m3x2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + usb_hs_clk_div_ck: usb_hs_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m3x2_ck>; + clock-mult = <1>; + clock-div = <3>; + }; + + l3_div_ck: l3_div_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&div_core_ck>; + ti,bit-shift = <4>; + ti,max-div = <2>; + reg = <0x0100>; + }; + + l4_div_ck: l4_div_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&l3_div_ck>; + ti,bit-shift = <8>; + ti,max-div = <2>; + reg = <0x0100>; + }; + + lp_clk_div_ck: lp_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2x2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + mpu_periphclk: mpu_periphclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_mpu_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + ocp_abe_iclk: ocp_abe_iclk@528 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&abe_clkctrl OMAP4_AESS_CLKCTRL 24>; + ti,bit-shift = <24>; + reg = <0x0528>; + ti,dividers = <2>, <1>; + }; + + per_abe_24m_fclk: per_abe_24m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + dummy_ck: dummy_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; +}; + +&prm_clocks { + sys_clkin_ck: sys_clkin_ck@110 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&virt_12000000_ck>, <&virt_13000000_ck>, <&virt_16800000_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_27000000_ck>, <&virt_38400000_ck>; + reg = <0x0110>; + ti,index-starts-at-one; + }; + + abe_dpll_bypass_clk_mux_ck: abe_dpll_bypass_clk_mux_ck@108 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&sys_32k_ck>; + ti,bit-shift = <24>; + reg = <0x0108>; + }; + + abe_dpll_refclk_mux_ck: abe_dpll_refclk_mux_ck@10c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&sys_32k_ck>; + reg = <0x010c>; + }; + + dbgclk_mux_ck: dbgclk_mux_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&sys_clkin_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + l4_wkup_clk_mux_ck: l4_wkup_clk_mux_ck@108 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&lp_clk_div_ck>; + reg = <0x0108>; + }; + + syc_clk_div_ck: syc_clk_div_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&sys_clkin_ck>; + reg = <0x0100>; + ti,max-div = <2>; + }; + + usim_ck: usim_ck@1858 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m4x2_ck>; + ti,bit-shift = <24>; + reg = <0x1858>; + ti,dividers = <14>, <18>; + }; + + usim_fclk: usim_fclk@1858 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&usim_ck>; + ti,bit-shift = <8>; + reg = <0x1858>; + }; + + trace_clk_div_ck: trace_clk_div_ck { + #clock-cells = <0>; + compatible = "ti,clkdm-gate-clock"; + clocks = <&emu_sys_clkctrl OMAP4_DEBUGSS_CLKCTRL 24>; + }; +}; + +&prm_clockdomains { + emu_sys_clkdm: emu_sys_clkdm { + compatible = "ti,clockdomain"; + clocks = <&trace_clk_div_ck>; + }; +}; + +&cm2_clocks { + per_hsd_byp_clk_mux_ck: per_hsd_byp_clk_mux_ck@14c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&per_hs_clk_div_ck>; + ti,bit-shift = <23>; + reg = <0x014c>; + }; + + dpll_per_ck: dpll_per_ck@140 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin_ck>, <&per_hsd_byp_clk_mux_ck>; + reg = <0x0140>, <0x0144>, <0x014c>, <0x0148>; + }; + + dpll_per_m2_ck: dpll_per_m2_ck@150 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_ck>; + ti,max-div = <31>; + reg = <0x0150>; + ti,index-starts-at-one; + }; + + dpll_per_x2_ck: dpll_per_x2_ck@150 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_per_ck>; + reg = <0x0150>; + }; + + dpll_per_m2x2_ck: dpll_per_m2x2_ck@150 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0150>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m3x2_gate_ck: dpll_per_m3x2_gate_ck@154 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_per_x2_ck>; + ti,bit-shift = <8>; + reg = <0x0154>; + }; + + dpll_per_m3x2_div_ck: dpll_per_m3x2_div_ck@154 { + #clock-cells = <0>; + compatible = "ti,composite-divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + reg = <0x0154>; + ti,index-starts-at-one; + }; + + dpll_per_m3x2_ck: dpll_per_m3x2_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&dpll_per_m3x2_gate_ck>, <&dpll_per_m3x2_div_ck>; + }; + + dpll_per_m4x2_ck: dpll_per_m4x2_ck@158 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0158>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m5x2_ck: dpll_per_m5x2_ck@15c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x015c>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m6x2_ck: dpll_per_m6x2_ck@160 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0160>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m7x2_ck: dpll_per_m7x2_ck@164 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0164>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_usb_ck: dpll_usb_ck@180 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-j-type-clock"; + clocks = <&sys_clkin_ck>, <&usb_hs_clk_div_ck>; + reg = <0x0180>, <0x0184>, <0x018c>, <0x0188>; + }; + + dpll_usb_clkdcoldo_ck: dpll_usb_clkdcoldo_ck@1b4 { + #clock-cells = <0>; + compatible = "ti,fixed-factor-clock"; + clocks = <&dpll_usb_ck>; + ti,clock-div = <1>; + ti,autoidle-shift = <8>; + reg = <0x01b4>; + ti,clock-mult = <1>; + ti,invert-autoidle-bit; + }; + + dpll_usb_m2_ck: dpll_usb_m2_ck@190 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_usb_ck>; + ti,max-div = <127>; + ti,autoidle-shift = <8>; + reg = <0x0190>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + ducati_clk_mux_ck: ducati_clk_mux_ck@100 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&div_core_ck>, <&dpll_per_m6x2_ck>; + reg = <0x0100>; + }; + + func_12m_fclk: func_12m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + func_24m_clk: func_24m_clk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + func_24mc_fclk: func_24mc_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <8>; + }; + + func_48m_fclk: func_48m_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m2x2_ck>; + reg = <0x0108>; + ti,dividers = <4>, <8>; + }; + + func_48mc_fclk: func_48mc_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + func_64m_fclk: func_64m_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m4x2_ck>; + reg = <0x0108>; + ti,dividers = <2>, <4>; + }; + + func_96m_fclk: func_96m_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m2x2_ck>; + reg = <0x0108>; + ti,dividers = <2>, <4>; + }; + + init_60m_fclk: init_60m_fclk@104 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_usb_m2_ck>; + reg = <0x0104>; + ti,dividers = <1>, <8>; + }; + + per_abe_nc_fclk: per_abe_nc_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_m2_ck>; + reg = <0x0108>; + ti,max-div = <2>; + }; + + sha2md5_fck: sha2md5_fck@15c8 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&l3_div_ck>; + ti,bit-shift = <1>; + reg = <0x15c8>; + }; + + usb_phy_cm_clk32k: usb_phy_cm_clk32k@640 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_32k_ck>; + ti,bit-shift = <8>; + reg = <0x0640>; + }; +}; + +&cm2_clockdomains { + l3_init_clkdm: l3_init_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll_usb_ck>; + }; +}; + +&scrm_clocks { + auxclk0_src_gate_ck: auxclk0_src_gate_ck@310 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0310>; + }; + + auxclk0_src_mux_ck: auxclk0_src_mux_ck@310 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0310>; + }; + + auxclk0_src_ck: auxclk0_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk0_src_gate_ck>, <&auxclk0_src_mux_ck>; + }; + + auxclk0_ck: auxclk0_ck@310 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk0_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0310>; + }; + + auxclk1_src_gate_ck: auxclk1_src_gate_ck@314 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0314>; + }; + + auxclk1_src_mux_ck: auxclk1_src_mux_ck@314 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0314>; + }; + + auxclk1_src_ck: auxclk1_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk1_src_gate_ck>, <&auxclk1_src_mux_ck>; + }; + + auxclk1_ck: auxclk1_ck@314 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk1_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0314>; + }; + + auxclk2_src_gate_ck: auxclk2_src_gate_ck@318 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0318>; + }; + + auxclk2_src_mux_ck: auxclk2_src_mux_ck@318 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0318>; + }; + + auxclk2_src_ck: auxclk2_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk2_src_gate_ck>, <&auxclk2_src_mux_ck>; + }; + + auxclk2_ck: auxclk2_ck@318 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk2_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0318>; + }; + + auxclk3_src_gate_ck: auxclk3_src_gate_ck@31c { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x031c>; + }; + + auxclk3_src_mux_ck: auxclk3_src_mux_ck@31c { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x031c>; + }; + + auxclk3_src_ck: auxclk3_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk3_src_gate_ck>, <&auxclk3_src_mux_ck>; + }; + + auxclk3_ck: auxclk3_ck@31c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk3_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x031c>; + }; + + auxclk4_src_gate_ck: auxclk4_src_gate_ck@320 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0320>; + }; + + auxclk4_src_mux_ck: auxclk4_src_mux_ck@320 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0320>; + }; + + auxclk4_src_ck: auxclk4_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk4_src_gate_ck>, <&auxclk4_src_mux_ck>; + }; + + auxclk4_ck: auxclk4_ck@320 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk4_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0320>; + }; + + auxclk5_src_gate_ck: auxclk5_src_gate_ck@324 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0324>; + }; + + auxclk5_src_mux_ck: auxclk5_src_mux_ck@324 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0324>; + }; + + auxclk5_src_ck: auxclk5_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk5_src_gate_ck>, <&auxclk5_src_mux_ck>; + }; + + auxclk5_ck: auxclk5_ck@324 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk5_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0324>; + }; + + auxclkreq0_ck: auxclkreq0_ck@210 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0210>; + }; + + auxclkreq1_ck: auxclkreq1_ck@214 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0214>; + }; + + auxclkreq2_ck: auxclkreq2_ck@218 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0218>; + }; + + auxclkreq3_ck: auxclkreq3_ck@21c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x021c>; + }; + + auxclkreq4_ck: auxclkreq4_ck@220 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0220>; + }; + + auxclkreq5_ck: auxclkreq5_ck@224 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0224>; + }; +}; + +&cm1 { + mpuss_cm: mpuss_cm@300 { + compatible = "ti,omap4-cm"; + reg = <0x300 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x300 0x100>; + + mpuss_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + tesla_cm: tesla_cm@400 { + compatible = "ti,omap4-cm"; + reg = <0x400 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x400 0x100>; + + tesla_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + abe_cm: abe_cm@500 { + compatible = "ti,omap4-cm"; + reg = <0x500 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x500 0x100>; + + abe_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x6c>; + #clock-cells = <2>; + }; + }; + +}; + +&cm2 { + l4_ao_cm: l4_ao_cm@600 { + compatible = "ti,omap4-cm"; + reg = <0x600 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x600 0x100>; + + l4_ao_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x1c>; + #clock-cells = <2>; + }; + }; + + l3_1_cm: l3_1_cm@700 { + compatible = "ti,omap4-cm"; + reg = <0x700 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x700 0x100>; + + l3_1_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_2_cm: l3_2_cm@800 { + compatible = "ti,omap4-cm"; + reg = <0x800 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x800 0x100>; + + l3_2_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x14>; + #clock-cells = <2>; + }; + }; + + ducati_cm: ducati_cm@900 { + compatible = "ti,omap4-cm"; + reg = <0x900 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x900 0x100>; + + ducati_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_dma_cm: l3_dma_cm@a00 { + compatible = "ti,omap4-cm"; + reg = <0xa00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xa00 0x100>; + + l3_dma_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_emif_cm: l3_emif_cm@b00 { + compatible = "ti,omap4-cm"; + reg = <0xb00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xb00 0x100>; + + l3_emif_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x1c>; + #clock-cells = <2>; + }; + }; + + d2d_cm: d2d_cm@c00 { + compatible = "ti,omap4-cm"; + reg = <0xc00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xc00 0x100>; + + d2d_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l4_cfg_cm: l4_cfg_cm@d00 { + compatible = "ti,omap4-cm"; + reg = <0xd00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xd00 0x100>; + + l4_cfg_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x14>; + #clock-cells = <2>; + }; + }; + + l3_instr_cm: l3_instr_cm@e00 { + compatible = "ti,omap4-cm"; + reg = <0xe00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xe00 0x100>; + + l3_instr_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x24>; + #clock-cells = <2>; + }; + }; + + ivahd_cm: ivahd_cm@f00 { + compatible = "ti,omap4-cm"; + reg = <0xf00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xf00 0x100>; + + ivahd_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xc>; + #clock-cells = <2>; + }; + }; + + iss_cm: iss_cm@1000 { + compatible = "ti,omap4-cm"; + reg = <0x1000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000 0x100>; + + iss_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xc>; + #clock-cells = <2>; + }; + }; + + l3_dss_cm: l3_dss_cm@1100 { + compatible = "ti,omap4-cm"; + reg = <0x1100 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1100 0x100>; + + l3_dss_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_gfx_cm: l3_gfx_cm@1200 { + compatible = "ti,omap4-cm"; + reg = <0x1200 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1200 0x100>; + + l3_gfx_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_init_cm: l3_init_cm@1300 { + compatible = "ti,omap4-cm"; + reg = <0x1300 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1300 0x100>; + + l3_init_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xc4>; + #clock-cells = <2>; + }; + }; + + l4_per_cm: l4_per_cm@1400 { + compatible = "ti,omap4-cm"; + reg = <0x1400 0x200>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1400 0x200>; + + l4_per_clkctrl: clock@20 { + compatible = "ti,clkctrl-l4-per", "ti,clkctrl"; + reg = <0x20 0x144>; + #clock-cells = <2>; + }; + + l4_secure_clkctrl: clock@1a0 { + compatible = "ti,clkctrl-l4-secure", "ti,clkctrl"; + reg = <0x1a0 0x3c>; + #clock-cells = <2>; + }; + }; +}; + +&prm { + l4_wkup_cm: l4_wkup_cm@1800 { + compatible = "ti,omap4-cm"; + reg = <0x1800 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1800 0x100>; + + l4_wkup_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x5c>; + #clock-cells = <2>; + }; + }; + + emu_sys_cm: emu_sys_cm@1a00 { + compatible = "ti,omap4-cm"; + reg = <0x1a00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1a00 0x100>; + + emu_sys_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; +}; diff --git a/arch/arm/dts/twl6030.dtsi b/arch/arm/dts/twl6030.dtsi new file mode 100644 index 0000000000..9d588cfaa5 --- /dev/null +++ b/arch/arm/dts/twl6030.dtsi @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/* + * Integrated Power Management Chip + * http://www.ti.com/lit/ds/symlink/twl6030.pdf + */ +&twl { + compatible = "ti,twl6030"; + interrupt-controller; + #interrupt-cells = <1>; + + rtc { + compatible = "ti,twl4030-rtc"; + interrupts = <11>; + }; + + vaux1: regulator-vaux1 { + compatible = "ti,twl6030-vaux1"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + }; + + vaux2: regulator-vaux2 { + compatible = "ti,twl6030-vaux2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <2800000>; + }; + + vaux3: regulator-vaux3 { + compatible = "ti,twl6030-vaux3"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + }; + + vmmc: regulator-vmmc { + compatible = "ti,twl6030-vmmc"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <3000000>; + }; + + vpp: regulator-vpp { + compatible = "ti,twl6030-vpp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2500000>; + }; + + vusim: regulator-vusim { + compatible = "ti,twl6030-vusim"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <2900000>; + }; + + vdac: regulator-vdac { + compatible = "ti,twl6030-vdac"; + }; + + vana: regulator-vana { + compatible = "ti,twl6030-vana"; + }; + + vcxio: regulator-vcxio { + compatible = "ti,twl6030-vcxio"; + regulator-always-on; + }; + + vusb: regulator-vusb { + compatible = "ti,twl6030-vusb"; + }; + + v1v8: regulator-v1v8 { + compatible = "ti,twl6030-v1v8"; + regulator-always-on; + }; + + v2v1: regulator-v2v1 { + compatible = "ti,twl6030-v2v1"; + regulator-always-on; + }; + + twl_usb_comparator: usb-comparator { + compatible = "ti,twl6030-usb"; + interrupts = <4>, <10>; + }; + + twl_pwm: pwm { + /* provides two PWMs (id 0, 1 for PWM1 and PWM2) */ + compatible = "ti,twl6030-pwm"; + #pwm-cells = <2>; + }; + + twl_pwmled: pwmled { + /* provides one PWM (id 0 for Charging indicator LED) */ + compatible = "ti,twl6030-pwmled"; + #pwm-cells = <2>; + }; + + gpadc { + compatible = "ti,twl6030-gpadc"; + interrupts = <3>; + #io-channel-cells = <1>; + }; +}; diff --git a/arch/arm/dts/twl6030_omap4.dtsi b/arch/arm/dts/twl6030_omap4.dtsi new file mode 100644 index 0000000000..fc498d0bde --- /dev/null +++ b/arch/arm/dts/twl6030_omap4.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ + */ + +&twl { + /* + * On most OMAP4 platforms, the twl6030 IRQ line is connected + * to the SYS_NIRQ1 line on OMAP and the twl6030 MSECURE line is + * connected to the fref_clk0_out.sys_drm_msecure line. + * Therefore, configure the defaults for the SYS_NIRQ1 and + * fref_clk0_out.sys_drm_msecure pins here. + */ + pinctrl-names = "default"; + pinctrl-0 = < + &twl6030_pins + &twl6030_wkup_pins + >; +}; + +&omap4_pmx_wkup { + twl6030_wkup_pins: pinmux_twl6030_wkup_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x054, PIN_OUTPUT | MUX_MODE2) /* fref_clk0_out.sys_drm_msecure */ + >; + }; +}; + +&omap4_pmx_core { + twl6030_pins: pinmux_twl6030_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x19e, WAKEUP_EN | PIN_INPUT_PULLUP | MUX_MODE0) /* sys_nirq1.sys_nirq1 */ + >; + }; +}; diff --git a/include/dt-bindings/clock/omap4.h b/include/dt-bindings/clock/omap4.h new file mode 100644 index 0000000000..88d73be84b --- /dev/null +++ b/include/dt-bindings/clock/omap4.h @@ -0,0 +1,149 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2017 Texas Instruments, Inc. + */ +#ifndef __DT_BINDINGS_CLK_OMAP4_H +#define __DT_BINDINGS_CLK_OMAP4_H + +#define OMAP4_CLKCTRL_OFFSET 0x20 +#define OMAP4_CLKCTRL_INDEX(offset) ((offset) - OMAP4_CLKCTRL_OFFSET) + +/* mpuss clocks */ +#define OMAP4_MPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* tesla clocks */ +#define OMAP4_DSP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* abe clocks */ +#define OMAP4_L4_ABE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_AESS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_MCPDM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_DMIC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_MCASP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) +#define OMAP4_MCBSP1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x48) +#define OMAP4_MCBSP2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) +#define OMAP4_MCBSP3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) +#define OMAP4_SLIMBUS1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) +#define OMAP4_TIMER5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) +#define OMAP4_TIMER6_CLKCTRL OMAP4_CLKCTRL_INDEX(0x70) +#define OMAP4_TIMER7_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) +#define OMAP4_TIMER8_CLKCTRL OMAP4_CLKCTRL_INDEX(0x80) +#define OMAP4_WD_TIMER3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x88) + +/* l4_ao clocks */ +#define OMAP4_SMARTREFLEX_MPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_SMARTREFLEX_IVA_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_SMARTREFLEX_CORE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) + +/* l3_1 clocks */ +#define OMAP4_L3_MAIN_1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_2 clocks */ +#define OMAP4_L3_MAIN_2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_GPMC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_OCMC_RAM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) + +/* ducati clocks */ +#define OMAP4_IPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_dma clocks */ +#define OMAP4_DMA_SYSTEM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_emif clocks */ +#define OMAP4_DMM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_EMIF1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_EMIF2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) + +/* d2d clocks */ +#define OMAP4_C2C_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l4_cfg clocks */ +#define OMAP4_L4_CFG_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_SPINLOCK_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_MAILBOX_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) + +/* l3_instr clocks */ +#define OMAP4_L3_MAIN_3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_L3_INSTR_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_OCP_WP_NOC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) + +/* ivahd clocks */ +#define OMAP4_IVA_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_SL2IF_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) + +/* iss clocks */ +#define OMAP4_ISS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_FDIF_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) + +/* l3_dss clocks */ +#define OMAP4_DSS_CORE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_gfx clocks */ +#define OMAP4_GPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_init clocks */ +#define OMAP4_MMC1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_MMC2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_HSI_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_USB_HOST_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) +#define OMAP4_USB_OTG_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) +#define OMAP4_USB_TLL_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) +#define OMAP4_USB_HOST_FS_CLKCTRL OMAP4_CLKCTRL_INDEX(0xd0) +#define OMAP4_OCP2SCP_USB_PHY_CLKCTRL OMAP4_CLKCTRL_INDEX(0xe0) + +/* l4_per clocks */ +#define OMAP4_TIMER10_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_TIMER11_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_TIMER2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_TIMER3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) +#define OMAP4_TIMER4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x48) +#define OMAP4_TIMER9_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) +#define OMAP4_ELM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) +#define OMAP4_GPIO2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) +#define OMAP4_GPIO3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) +#define OMAP4_GPIO4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x70) +#define OMAP4_GPIO5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) +#define OMAP4_GPIO6_CLKCTRL OMAP4_CLKCTRL_INDEX(0x80) +#define OMAP4_HDQ1W_CLKCTRL OMAP4_CLKCTRL_INDEX(0x88) +#define OMAP4_I2C1_CLKCTRL OMAP4_CLKCTRL_INDEX(0xa0) +#define OMAP4_I2C2_CLKCTRL OMAP4_CLKCTRL_INDEX(0xa8) +#define OMAP4_I2C3_CLKCTRL OMAP4_CLKCTRL_INDEX(0xb0) +#define OMAP4_I2C4_CLKCTRL OMAP4_CLKCTRL_INDEX(0xb8) +#define OMAP4_L4_PER_CLKCTRL OMAP4_CLKCTRL_INDEX(0xc0) +#define OMAP4_MCBSP4_CLKCTRL OMAP4_CLKCTRL_INDEX(0xe0) +#define OMAP4_MCSPI1_CLKCTRL OMAP4_CLKCTRL_INDEX(0xf0) +#define OMAP4_MCSPI2_CLKCTRL OMAP4_CLKCTRL_INDEX(0xf8) +#define OMAP4_MCSPI3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x100) +#define OMAP4_MCSPI4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x108) +#define OMAP4_MMC3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x120) +#define OMAP4_MMC4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x128) +#define OMAP4_SLIMBUS2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x138) +#define OMAP4_UART1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x140) +#define OMAP4_UART2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x148) +#define OMAP4_UART3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x150) +#define OMAP4_UART4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x158) +#define OMAP4_MMC5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x160) + +/* l4_secure clocks */ +#define OMAP4_L4_SECURE_CLKCTRL_OFFSET 0x1a0 +#define OMAP4_L4_SECURE_CLKCTRL_INDEX(offset) ((offset) - OMAP4_L4_SECURE_CLKCTRL_OFFSET) +#define OMAP4_AES1_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1a0) +#define OMAP4_AES2_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1a8) +#define OMAP4_DES3DES_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1b0) +#define OMAP4_PKA_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1b8) +#define OMAP4_RNG_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1c0) +#define OMAP4_SHA2MD5_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1c8) +#define OMAP4_CRYPTODMA_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1d8) + +/* l4_wkup clocks */ +#define OMAP4_L4_WKUP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_WD_TIMER2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_GPIO1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_TIMER1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) +#define OMAP4_COUNTER_32K_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) +#define OMAP4_KBD_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) + +/* emu_sys clocks */ +#define OMAP4_DEBUGSS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +#endif
Convert omap4 panda to device model.
Signed-off-by: Tero Kristo t-kristo@ti.com --- v2: * dropped some apparently dead USB EHCI init code, this was just causing a compile time warning.
arch/arm/dts/Makefile | 4 +++ arch/arm/dts/omap4-u-boot.dtsi | 39 ++++++++++++++++++++++++++ board/ti/panda/panda.c | 50 ++++++++-------------------------- configs/omap4_panda_defconfig | 8 ++++++ 4 files changed, 63 insertions(+), 38 deletions(-) create mode 100644 arch/arm/dts/omap4-u-boot.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 12ec6c71dc..dd574f57fa 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -848,6 +848,10 @@ dtb-$(CONFIG_TARGET_OMAP3_BEAGLE) += \ dtb-$(CONFIG_TARGET_OMAP3_IGEP00X0) += \ omap3-igep0020.dtb
+dtb-$(CONFIG_TARGET_OMAP4_PANDA) += \ + omap4-panda.dtb \ + omap4-panda-es.dtb + dtb-$(CONFIG_TARGET_SAMA5D2_PTC_EK) += \ at91-sama5d2_ptc_ek.dtb
diff --git a/arch/arm/dts/omap4-u-boot.dtsi b/arch/arm/dts/omap4-u-boot.dtsi new file mode 100644 index 0000000000..4a6bafd6ed --- /dev/null +++ b/arch/arm/dts/omap4-u-boot.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * (C) Copyright 2020 Tero Kristo t-kristo@ti.com + */ + +&l4_cfg { + segment@0 { + /* SCM Core */ + target-module@2000 { + compatible = "simple-bus"; + }; + + /* USB HS */ + target-module@64000 { + compatible = "simple-bus"; + }; + }; +}; + +&l4_per { + segment@0 { + /* UART3 */ + target-module@20000 { + compatible = "simple-bus"; + }; + + /* I2C1 */ + target-module@70000 { + compatible = "simple-bus"; + }; + + /* MMC1 */ + target-module@9c000 { + compatible = "simple-bus"; + }; + }; +}; diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 9ebecfdbf5..232d999a29 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <serial.h> #include <asm/mach-types.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> @@ -19,12 +20,6 @@
#include "panda_mux_data.h"
-#ifdef CONFIG_USB_EHCI_HCD -#include <usb.h> -#include <asm/arch/ehci.h> -#include <asm/ehci-omap.h> -#endif - #define PANDA_ULPI_PHY_TYPE_GPIO 182 #define PANDA_BOARD_ID_1_GPIO 101 #define PANDA_ES_BOARD_ID_1_GPIO 48 @@ -55,6 +50,17 @@ int board_init(void) return 0; }
+#if defined(CONFIG_SPL_OS_BOOT) +int spl_start_uboot(void) +{ + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + + return 0; +} +#endif /* CONFIG_SPL_OS_BOOT */ + int board_eth_init(bd_t *bis) { return 0; @@ -305,38 +311,6 @@ void board_mmc_power_init(void) #endif #endif
-#ifdef CONFIG_USB_EHCI_HCD - -static struct omap_usbhs_board_data usbhs_bdata = { - .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY, - .port_mode[1] = OMAP_USBHS_PORT_MODE_UNUSED, - .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED, -}; - -int ehci_hcd_init(int index, enum usb_init_type init, - struct ehci_hccr **hccr, struct ehci_hcor **hcor) -{ - int ret; - unsigned int utmi_clk; - - /* Now we can enable our port clocks */ - utmi_clk = readl((void *)CM_L3INIT_HSUSBHOST_CLKCTRL); - utmi_clk |= HSUSBHOST_CLKCTRL_CLKSEL_UTMI_P1_MASK; - setbits_le32((void *)CM_L3INIT_HSUSBHOST_CLKCTRL, utmi_clk); - - ret = omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); - if (ret < 0) - return ret; - - return 0; -} - -int ehci_hcd_stop(int index) -{ - return omap_ehci_hcd_stop(); -} -#endif - /* * get_board_rev() - get board revision */ diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 3ac6319d2d..bf5f71c7a7 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -2,12 +2,14 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_PANDA=y +CONFIG_DEFAULT_DEVICE_TREE="omap4-panda" CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DEFAULT_FDT_FILE="omap4-panda.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C_SUPPORT is not set @@ -23,16 +25,20 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM=y +CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y @@ -40,3 +46,5 @@ CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_OF_LIBFDT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_DM_ETH=y
Tero Kristo
