[U-Boot] [PATCH 1/1] efi_loader: deduplicate code in cmd/bootefi.c
Move duplicate initialization code to single instance.
Adjust comments of concerned functions.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 99 +++++++++++++++++++-------------------------------- 1 file changed, 37 insertions(+), 62 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 52116b308c..0b3c5cdb90 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -314,32 +314,15 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle) }
/** - * do_efibootmgr() - execute EFI Boot Manager + * do_efibootmgr() - execute EFI boot manager * - * @fdt_opt: string of fdt start address * Return: status code - * - * Execute EFI Boot Manager */ -static int do_efibootmgr(const char *fdt_opt) +static int do_efibootmgr(void) { efi_handle_t handle; efi_status_t ret;
- /* Initialize EFI drivers */ - ret = efi_init_obj_list(); - if (ret != EFI_SUCCESS) { - printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", - ret & ~EFI_ERROR_MASK); - return CMD_RET_FAILURE; - } - - ret = efi_install_fdt(fdt_opt); - if (ret == EFI_INVALID_PARAMETER) - return CMD_RET_USAGE; - else if (ret != EFI_SUCCESS) - return CMD_RET_FAILURE; - ret = efi_bootmgr_load(&handle); if (ret != EFI_SUCCESS) { printf("EFI boot manager: Cannot load any image\n"); @@ -355,16 +338,15 @@ static int do_efibootmgr(const char *fdt_opt) }
/* - * do_bootefi_image() - execute EFI binary from command line + * do_bootefi_image() - execute EFI binary + * + * Set up memory image for the binary to be loaded, prepare device path, and + * then call do_bootefi_exec() to execute it. * * @image_opt: string of image start address - * @fdt_opt: string of fdt start address * Return: status code - * - * Set up memory image for the binary to be loaded, prepare - * device path and then call do_bootefi_exec() to execute it. */ -static int do_bootefi_image(const char *image_opt, const char *fdt_opt) +static int do_bootefi_image(const char *image_opt) { void *image_buf; struct efi_device_path *device_path, *image_path; @@ -374,20 +356,6 @@ static int do_bootefi_image(const char *image_opt, const char *fdt_opt) efi_handle_t mem_handle = NULL, handle; efi_status_t ret;
- /* Initialize EFI drivers */ - ret = efi_init_obj_list(); - if (ret != EFI_SUCCESS) { - printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", - ret & ~EFI_ERROR_MASK); - return CMD_RET_FAILURE; - } - - ret = efi_install_fdt(fdt_opt); - if (ret == EFI_INVALID_PARAMETER) - return CMD_RET_USAGE; - else if (ret != EFI_SUCCESS) - return CMD_RET_FAILURE; - #ifdef CONFIG_CMD_BOOTEFI_HELLO if (!strcmp(image_opt, "hello")) { char *saddr; @@ -547,33 +515,16 @@ static void bootefi_run_finish(struct efi_loaded_image_obj *image_obj, }
/** - * do_efi_selftest() - execute EFI Selftest + * do_efi_selftest() - execute EFI selftest * - * @fdt_opt: string of fdt start address * Return: status code - * - * Execute EFI Selftest */ -static int do_efi_selftest(const char *fdt_opt) +static int do_efi_selftest(void) { struct efi_loaded_image_obj *image_obj; struct efi_loaded_image *loaded_image_info; efi_status_t ret;
- /* Initialize EFI drivers */ - ret = efi_init_obj_list(); - if (ret != EFI_SUCCESS) { - printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", - ret & ~EFI_ERROR_MASK); - return CMD_RET_FAILURE; - } - - ret = efi_install_fdt(fdt_opt); - if (ret == EFI_INVALID_PARAMETER) - return CMD_RET_USAGE; - else if (ret != EFI_SUCCESS) - return CMD_RET_FAILURE; - ret = bootefi_test_prepare(&image_obj, &loaded_image_info, "\selftest", "efi_selftest"); if (ret != EFI_SUCCESS) @@ -587,20 +538,44 @@ static int do_efi_selftest(const char *fdt_opt) } #endif /* CONFIG_CMD_BOOTEFI_SELFTEST */
-/* Interpreter command to boot an arbitrary EFI image from memory */ +/** + * do_bootefi() - execute `bootefi` command + * + * @cmdtp: table entry describing command + * @flag: bitmap indicating how the command was invoked + * @argc: number of arguments + * @argv: command line arguments + * Return: status code + */ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { + efi_status_t ret; + if (argc < 2) return CMD_RET_USAGE;
+ /* Initialize EFI drivers */ + ret = efi_init_obj_list(); + if (ret != EFI_SUCCESS) { + printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", + ret & ~EFI_ERROR_MASK); + return CMD_RET_FAILURE; + } + + ret = efi_install_fdt(argc > 2 ? argv[2] : NULL); + if (ret == EFI_INVALID_PARAMETER) + return CMD_RET_USAGE; + else if (ret != EFI_SUCCESS) + return CMD_RET_FAILURE; + if (!strcmp(argv[1], "bootmgr")) - return do_efibootmgr(argc > 2 ? argv[2] : NULL); + return do_efibootmgr(); #ifdef CONFIG_CMD_BOOTEFI_SELFTEST else if (!strcmp(argv[1], "selftest")) - return do_efi_selftest(argc > 2 ? argv[2] : NULL); + return do_efi_selftest(); #endif
- return do_bootefi_image(argv[1], argc > 2 ? argv[2] : NULL); + return do_bootefi_image(argv[1]); }
#ifdef CONFIG_SYS_LONGHELP -- 2.20.1
