[PATCH v4 0/3] gpio: add possibility to search for gpio label name
search for gpio label if gpio name from bankname is not found.
This makes sense on boards with different hardware verions. You can now search for the gpio label name, and can give the gpio a unique name. The real gpio pin number is not needed in board code anymore.
while at it add basic gpio hog test functions in seperate patch.
Changes in v4: - new in version 4 - rebased to current master ac14bc4169 - rebased to current master ac14bc4169
Changes in v3: - add comment from Simon Glass make this new function configurable through Kconfig option DM_GPIO_LOOKUP_LABEL
Changes in v2: - add basic gpio hog test functions - add comment from Simon Glass move code into seperate function dm_gpio_lookup_label() add test if dm_gpio_lookup_label() works
Heiko Schocher (3): gpio-uclass.c: save the GPIOD flags also in the gpio descriptor sandbox, test: add test for GPIO_HOG function gpio: search for gpio label if gpio is not found through bank name
arch/sandbox/dts/test.dts | 20 ++++++++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + drivers/gpio/Kconfig | 22 +++++++++++++ drivers/gpio/gpio-uclass.c | 50 ++++++++++++++++++++++++++++++ test/dm/gpio.c | 30 ++++++++++++++++++ 8 files changed, 126 insertions(+)
save the GPIOD_ flags also in the gpio descriptor.
Signed-off-by: Heiko Schocher hs@denx.de
drivers/gpio/gpio-uclass.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 757ab7106e..fc94334160 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -572,6 +572,9 @@ static int _dm_gpio_set_dir_flags(struct gpio_desc *desc, ulong flags) return ret; }
+ /* save the flags also in descriptor */ + desc->flags = flags; + /* GPIOD_ are directly managed by driver in set_dir_flags*/ if (ops->set_dir_flags) { ret = ops->set_dir_flags(dev, desc->offset, flags);
currently gpio hog function is not tested with "ut dm gpio" so add some basic tests for gpio hog functionality.
For this enable GPIO_HOG in sandbox_defconfig, add in DTS some gpio hog entries, and add testcase in "ut dm gpio" command.
Changes in v4: - rebased to current master ac14bc4169
Changes in v3: None Changes in v2: - add basic gpio hog test functions
arch/sandbox/dts/test.dts | 20 ++++++++++++++++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + test/dm/gpio.c | 23 +++++++++++++++++++++++ 6 files changed, 47 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 15cd2330a3..39490dc6b0 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -341,6 +341,26 @@ #gpio-cells = <1>; gpio-bank-name = "a"; sandbox,gpio-count = <20>; + hog_input_active_low { + gpio-hog; + input; + gpios = <0 GPIO_ACTIVE_LOW>; + }; + hog_input_active_high { + gpio-hog; + input; + gpios = <1 GPIO_ACTIVE_HIGH>; + }; + hog_output_low { + gpio-hog; + output-low; + gpios = <2 GPIO_ACTIVE_HIGH>; + }; + hog_output_high { + gpio-hog; + output-high; + gpios = <3 GPIO_ACTIVE_HIGH>; + }; };
gpio_b: extra-gpios { diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index c1237ea296..39dc3dc687 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -98,6 +98,7 @@ CONFIG_DM_DEMO_SIMPLE=y CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 9445d78118..9015458070 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -115,6 +115,7 @@ CONFIG_BOARD_SANDBOX=y CONFIG_DMA=y CONFIG_DMA_CHANNELS=y CONFIG_SANDBOX_DMA=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_DM_HWSPINLOCK=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index a4a7ae8379..b5a85e1278 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -83,6 +83,7 @@ CONFIG_DM_DEMO_SIMPLE=y CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 945fe54d20..7341fa3221 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -102,6 +102,7 @@ CONFIG_DM_DEMO_SHAPE=y CONFIG_BOARD=y CONFIG_BOARD_SANDBOX=y CONFIG_SPL_FIRMWARE=y +CONFIG_GPIO_HOG=y CONFIG_PM8916_GPIO=y CONFIG_SANDBOX_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y diff --git a/test/dm/gpio.c b/test/dm/gpio.c index f5c7aaf3bc..bae1996962 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -19,6 +19,7 @@ static int dm_test_gpio(struct unit_test_state *uts) unsigned int offset, gpio; struct dm_gpio_ops *ops; struct udevice *dev; + struct gpio_desc *desc; const char *name; int offset_count; char buf[80]; @@ -108,6 +109,28 @@ static int dm_test_gpio(struct unit_test_state *uts) ut_asserteq_str("a", name); ut_asserteq(20, offset_count);
+ /* add gpio hog tests */ + ut_assertok(gpio_hog_lookup_name("hog_input_active_low", &desc)); + ut_asserteq(GPIOD_IS_IN | GPIOD_ACTIVE_LOW, desc->flags); + ut_asserteq(0, desc->offset); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_input_active_high", &desc)); + ut_asserteq(GPIOD_IS_IN, desc->flags); + ut_asserteq(1, desc->offset); + ut_asserteq(0, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_output_low", &desc)); + ut_asserteq(GPIOD_IS_OUT, desc->flags); + ut_asserteq(2, desc->offset); + ut_asserteq(0, dm_gpio_get_value(desc)); + ut_assertok(dm_gpio_set_value(desc, 1)); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(gpio_hog_lookup_name("hog_output_high", &desc)); + ut_asserteq(GPIOD_IS_OUT, desc->flags); + ut_asserteq(3, desc->offset); + ut_asserteq(1, dm_gpio_get_value(desc)); + ut_assertok(dm_gpio_set_value(desc, 0)); + ut_asserteq(0, dm_gpio_get_value(desc)); + return 0; } DM_TEST(dm_test_gpio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
dm_gpio_lookup_name() searches for a gpio through the bank name. But we have also gpio labels, and it makes sense to search for a gpio also in the labels we have defined, if no gpio is found through the bank name definition.
This is useful for example if you have a wp pin on different gpios on different board versions.
If dm_gpio_lookup_name() searches also for the gpio labels, you can give the gpio an unique label name and search for this label, and do not need to differ between board revisions.
Signed-off-by: Heiko Schocher hs@denx.de ---
Example on the aristainetos board:
=> gpio clear wp_spi_nor.gpio-hog gpio: pin wp_spi_nor.gpio-hog (gpio 47) value is 0 =>
before this patch, you need to know where your pin is:
=> gpio clear GPIO2_15 gpio: pin GPIO2_15 (gpio 47) value is 0 =>
travis build:
Changes in v2: - add comment from Simon Glass move code into seperate function dm_gpio_lookup_label() add test if dm_gpio_lookup_label() works
drivers/gpio/Kconfig | 22 ++++++++++++++++++ drivers/gpio/gpio-uclass.c | 47 ++++++++++++++++++++++++++++++++++++++ test/dm/gpio.c | 7 ++++++ 3 files changed, 76 insertions(+)
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 2081520f42..4a635b905c 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -46,6 +46,28 @@ config GPIO_HOG is a mechanism providing automatic GPIO request and config- uration as part of the gpio-controller's driver probe function.
+config DM_GPIO_LOOKUP_LABEL + bool "Enable searching for gpio labelnames" + depends on DM_GPIO + default y + help + This option enables searching for gpio names in + the defined gpio labels, if the search for the + gpio bank name failed. This makes sense if you use + different gpios on different hardware versions + for the same functionality in board code. + +config SPL_DM_GPIO_LOOKUP_LABEL + bool "Enable searching for gpio labelnames" + depends on DM_GPIO && SPL_DM && SPL_GPIO_SUPPORT + default n + help + This option enables searching for gpio names in + the defined gpio labels, if the search for the + gpio bank name failed. This makes sense if you use + different gpios on different hardware versions + for the same functionality in board code. + config ALTERA_PIO bool "Altera PIO driver" depends on DM_GPIO diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index fc94334160..8af41f15b5 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -67,6 +67,46 @@ static int gpio_to_device(unsigned int gpio, struct gpio_desc *desc) return ret ? ret : -ENOENT; }
+#if CONFIG_IS_ENABLED(DM_GPIO_LOOKUP_LABEL) +/** + * dm_gpio_lookup_label() - look for name in gpio device + * + * search in uc_priv, if there is a gpio with labelname same + * as name. + * + * @name: name which is searched + * @uc_priv: gpio_dev_priv pointer. + * @offset: gpio offset within the device + * @return: 0 if found, -ENOENT if not. + */ +static int +dm_gpio_lookup_label(const char *name, struct gpio_dev_priv *uc_priv, + ulong *offset) +{ + int len; + int i; + + *offset = -1; + len = strlen(name); + for (i = 0; i < uc_priv->gpio_count; i++) { + if (!uc_priv->name[i]) + continue; + if (!strncmp(name, uc_priv->name[i], len)) { + *offset = i; + return 0; + } + } + return -ENOENT; +} +#else +static int +dm_gpio_lookup_label(const char *name, struct gpio_dev_priv *uc_priv, + ulong *offset) +{ + return -ENOENT; +} +#endif + int dm_gpio_lookup_name(const char *name, struct gpio_desc *desc) { struct gpio_dev_priv *uc_priv = NULL; @@ -95,6 +135,13 @@ int dm_gpio_lookup_name(const char *name, struct gpio_desc *desc) if (!strict_strtoul(name + len, 10, &offset)) break; } + + /* + * if we did not found a gpio through its bank + * name, we search for a valid gpio label. + */ + if (!dm_gpio_lookup_label(name, uc_priv, &offset)) + break; }
if (!dev) diff --git a/test/dm/gpio.c b/test/dm/gpio.c index bae1996962..75eafaa866 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -131,6 +131,13 @@ static int dm_test_gpio(struct unit_test_state *uts) ut_assertok(dm_gpio_set_value(desc, 0)); ut_asserteq(0, dm_gpio_get_value(desc));
+ /* Check if lookup for labels work */ + ut_assertok(gpio_lookup_name("hog_input_active_low", &dev, &offset, + &gpio)); + ut_asserteq_str(dev->name, "base-gpios"); + ut_asserteq(0, offset); + ut_asserteq(CONFIG_SANDBOX_GPIO_COUNT + 0, gpio); + return 0; } DM_TEST(dm_test_gpio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Heiko Schocher
