[PATCH] dts: Re-add aliases for imx6qdl-sabrelite devices
In commit d0399a46e7cda63c07e3eb8558bef84cfb068028, the device tree was synchronized from linux and the aliases were dropped.
They need to be kept so that the mmc cards are in the right order. Without the aliases, u-boot reports: MMC: FSL_SDHC: 2, FSL_SDHC: 3
With the aliases, u-boot reports: MMC: FSL_SDHC: 0, FSL_SDHC: 1
Signed-off-by: Detlev Casanova detlev.casanova@collabora.com --- arch/arm/dts/imx6qdl-sabrelite.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-sabrelite.dtsi b/arch/arm/dts/imx6qdl-sabrelite.dtsi index 22f8e2783c..6564e3b82c 100644 --- a/arch/arm/dts/imx6qdl-sabrelite.dtsi +++ b/arch/arm/dts/imx6qdl-sabrelite.dtsi @@ -10,6 +10,13 @@ #include <dt-bindings/input/input.h>
/ { + aliases { + mmc0 = &usdhc3; + mmc1 = &usdhc4; + pwm_lcd = &pwm1; + pwm_lvds = &pwm4; + }; + chosen { stdout-path = &uart2; };
- aliases {
mmc0 = &usdhc3;
mmc1 = &usdhc4;
pwm_lcd = &pwm1;
pwm_lvds = &pwm4;
- chosen { stdout-path = &uart2; };
This really belongs in the upstream dts file so they aren't lost again and again.
aliases {
mmc0 = &usdhc3;
mmc1 = &usdhc4;
pwm_lcd = &pwm1;
pwm_lvds = &pwm4;
chosen {
Forwaded to upstream kernel: https://lore.kernel.org/lkml/20221028141811.101122-1-detlev.casanova@collabo...]
Would it make sense to still add this one in u-boot before the devices trees are copied again ?
Detlev.
-------- [1] https://lore.kernel.org/lkml/20221028141811.101122-1-detlev.casanova@collabo...
aliases {
mmc0 = &usdhc3;
mmc1 = &usdhc4;
pwm_lcd = &pwm1;
pwm_lvds = &pwm4;
chosen {
Yes, it would make sense to pick it up now to fix the regression here. Thanks for pushing it upstream!
aliases {
mmc0 = &usdhc3;
mmc1 = &usdhc4;
pwm_lcd = &pwm1;
pwm_lvds = &pwm4;
chosen {
Forwaded to upstream kernel: https://lore.kernel.org/lkml/20221028141811.101122-1-detlev.casanova@coll abora.com/[1]
Upstream linux won't apply it as they want to keep the already established order in linux (the SD card has to stay at mmc2). See https://lore.kernel.org/all/a13c2e92-cfa6-04fd-c32a-c4d444894660@pengutronix...]
I guess we will have to adapt u-boot environment when these dts are synced again.
Detlev.
-------- [1] https://lore.kernel.org/all/a13c2e92-cfa6-04fd-c32a-c4d444894660@pengutronix...
aliases {
mmc0 = &usdhc3;
mmc1 = &usdhc4;
pwm_lcd = &pwm1;
pwm_lvds = &pwm4;
chosen {
Detlev.
Not being overly familiar with the board in question in production (it was quite a long back when I last was involved in a design based on one of these), I don't know which order got more widespread real life usage, so, OK, we'll defer to what upstream kernel has now as indeed following the data sheet for order is reasonable. Whatever migrations need to be done to match this should be started on sooner rather than later I would suggest.
[Adding Troy]
On Fri, Dec 2, 2022 at 4:06 PM Detlev Casanova detlev.casanova@collabora.com wrote:
I would suggest adding the mmc alias into arch/arm/dts/imx6qdl-sabrelite-u-boot.dtsi
On Fri, Dec 02, 2022 at 08:20:11PM -0300, Fabio Estevam wrote:
[Adding Troy]
No, upstream has different aliases and doesn't want these. That's the point of the above thread, right?
Upstream is correct in not accepting new alias for this board, as this could break existing setups.
In U-Boot, we had alias for this board originally. After the sync with Linux they are gone.
To fix U-Boot, the less invasive change is to add the alias into arch/arm/dts/imx6qdl-sabrelite-u-boot.dtsi.
This way we can:
1. Keep the dtsi in sync with Linux
2. Do not break users in U-Boot
This is the same approach I did for wandboard in the following commit:
commit f827f84d3f5607d0b33e927f6127a888e7bd664f Author: Fabio Estevam festevam@denx.de Date: Fri Nov 4 08:12:54 2022 -0300
wandboard: Pass mmc aliases
Originally, the mmc aliases node was present in imx6qdl-wandboard.dtsi.
After the sync with Linux in commit d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux"), the aliases node is gone as the upstream version does not have it.
This causes a regression in which the SD card cannot be found anymore:
Since commit the aliases node has been removed U-Boot 2022.10-00999-gcca41ed3d63f-dirty (Nov 03 2022 - 22:07:38 -0300)
CPU: Freescale i.MX6QP rev1.0 at 792 MHz Reset cause: POR DRAM: 2 GiB Core: 62 devices, 17 uclasses, devicetree: separate PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... MMC: no card present *** Warning - No block device, using default environment
Fix it by passing the alias node in the u-boot.dtsi file to restore the original behaviour where the SD card (esdhc3) was mapped to mmc0.
Fixes: d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux") Signed-off-by: Fabio Estevam festevam@denx.de
This way we can:
wandboard: Pass mmc aliases Originally, the mmc aliases node was present in imx6qdl-wandboard.dtsi. After the sync with Linux in commit d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux"), the aliases node is gone as the upstream version does not have it. This causes a regression in which the SD card cannot be found anymore: Since commit the aliases node has been removed U-Boot 2022.10-00999-gcca41ed3d63f-dirty (Nov 03 2022 - 22:07:38 -0300) CPU: Freescale i.MX6QP rev1.0 at 792 MHz Reset cause: POR DRAM: 2 GiB Core: 62 devices, 17 uclasses, devicetree: separate PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... MMC: no card present *** Warning - No block device, using default environment Fix it by passing the alias node in the u-boot.dtsi file to restore the original behaviour where the SD card (esdhc3) was mapped to mmc0. Fixes: d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with
Ha good idea to use a u-boot specific dtsi. I'll send a new patch with that then.
Thanks !
Detlev.
This way we can:
wandboard: Pass mmc aliases Originally, the mmc aliases node was present in imx6qdl-wandboard.dtsi. After the sync with Linux in commit d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux"), the aliases node is gone as the upstream version does not have it. This causes a regression in which the SD card cannot be found anymore: Since commit the aliases node has been removed U-Boot 2022.10-00999-gcca41ed3d63f-dirty (Nov 03 2022 - 22:07:38 -0300) CPU: Freescale i.MX6QP rev1.0 at 792 MHz Reset cause: POR DRAM: 2 GiB Core: 62 devices, 17 uclasses, devicetree: separate PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... MMC: no card present *** Warning - No block device, using default environment Fix it by passing the alias node in the u-boot.dtsi file to restore the original behaviour where the SD card (esdhc3) was mapped to mmc0. Fixes: d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux") Signed-off-by: Fabio Estevam <festevam@denx.de>
I'm not really happy with this approach. It's not that upstream doesn't have aliases now, it's that it has different aliases, right? That's why they won't accept these?
But this also highlights that we really need to get these kind of aliases and similar (a) re-synced with upstream ASAP and (b) do that at the start. I don't know which group of "users are broken by this change" is bigger, the group that needs the aliases we have or the group that needs the other aliases, but the group that gets changes upstream first "wins" here is how the OSS world works.
imx6q.dtsi does have the default mmc aliases:
mmc0 = &usdhc1; mmc1 = &usdhc2; mmc2 = &usdhc3; mmc3 = &usdhc4;
Upstream does not want to change mmc alias because users may rely on this mmc aliases.
Changing it now may cause the board not to boot anymore as the rootfs cannot be found.
It is OK to change mmc alias for a newly introduced board, but please keep in mind that wandboard and sabrelite have been launched many many years ago.
So for upstream Linux the message was clear: don't change the mmc alias for these boards.
Now let's talk about U-Boot.
Prior to d0399a46e7cd ("imx6dl/imx6qdl: synchronise device trees with linux") the mmc alias for sabrelite was present:
mmc0 = &usdhc3; mmc1 = &usdhc4;
After this commit, the mmc alias is gone and causes the boot regression as reported by Detlev.
We don't want to cause regressions in U-Boot as well, so that's why I propose just adding the alias into u-boot.dtsi.
There are many boards that does the same.
imx6 dts files are already synced with Linux.
I prefer to not break things for anyone, hence my proposal.
If you are still not happy with it, please feel free to submit a patch with your proposal.
There is no SPL enabled for the imx.6 Sabrelite, Isn't that needed to use the *-u-boot.dtsi files ?
It is not clear to me how those are loaded.
Detlev.
The -u-boot.dtsi files are automatically included from scripts/Makefile.lib: u_boot_dtsi_options = $(strip $(wildcard $(dir $<)$(basename $(notdir $<))-u-boot.dtsi) \ $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \ $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \ $(wildcard $(dir $<)$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \ $(wildcard $(dir $<)u-boot.dtsi))
And then manually #included at times as the above logic will only pick one file and sometimes we do need to combine multiple.
I don't know what we can do about the existing boards, but we need to NOT do this moving forward. We need to use whatever the aliases are upstream already, or upstream the aliases we want to use.
linux") the mmc alias for sabrelite was present: mmc0 = &usdhc3; mmc1 = &usdhc4;
Yes, I agree that aliases should be kept in sync with the kernel. But this case is particular because this board has been using different aliases in u- boot and in linux for some time (maybe since forever).
So this should be kept to avoid breaking existing u-boot setups when they are upgraded.
I wonder just how many users would end up needing to be fixed here, but... since this is imx6 and not something brand new like 8 or 9, I'll just let it go, here.
This thread seems to be another reason *not* to put any aliases into a common dtsi file. They are board specific and should really go into the board dts.
-michael
Detlev Casanova
Fabio Estevam
Michael Walle
