[U-Boot] Pull request - net
Wolfgang,
Sorry this took so long...
The following changes since commit 4185ae7a7146a77a792e5ba49845e5ca6e95b038: Wolfgang Denk (1): Merge branch 'master' of ssh://gemini/home/wd/git/u-boot/master
git://git.denx.de/u-boot-net.git master
Andy Fleming (1): tsec: Wait for both RX and TX to stop
Ben Warren (1): Program net device MAC addresses after initializing
Detlev Zundel (3): net: Trivial coding style issue with empty for statement Remove unused "local_crc32" function. mpc512x_fec: Move PHY initialization from probe into init routine.
Eric Jarrige (1): fec_mxc.c: Fix MX27 FEC MAC validity check
Heiko Schocher (1): net: fec_mxc: add write_hwaddr support
John Rigby (1): fec_mxc don't use internal eeprom on MX25
Mike Frysinger (2): net: dm9000x: use standard I/O accessors Blackfin: bfin_mac: hook up new write_hwaddr function
Prafulla Wadaskar (3): net: Kirkwood_egiga.c: fixed build warnings net: Kirkwood_egiga.c bugfixes for rx path net:kirkwood_egiga.c: MAC addresses programming using write_hwaddr
Richard Retanubun (1): 83xx: UEC: Added support for bitBang MII driver access to PHYs
Robin Getz (1): ./net/net.c - make Microsoft dns servers happy with random_port() numbers
Thomas Chou (4): net: add opencore 10/100 ethernet mac driver net: add altera triple speeds ethernet mac driver net: altera_tse: add write_hwaddr support net: ethoc: add write_hwaddr support
Valentin Yakovenkov (1): smc911x driver frame alignment patch
Wolfgang Wegner (1): fix lockup in mcfmii/mii_discover_phy() in case communication fails
README | 5 + arch/powerpc/cpu/mpc8220/fec.c | 41 +-- doc/README.drivers.eth | 7 +- doc/README.enetaddr | 10 +- drivers/net/Makefile | 2 + drivers/net/altera_tse.c | 942 ++++++++++++++++++++++++++++++++++++++++ drivers/net/altera_tse.h | 494 +++++++++++++++++++++ drivers/net/bfin_mac.c | 28 +- drivers/net/bfin_mac.h | 3 +- drivers/net/dm9000x.c | 12 +- drivers/net/ethoc.c | 511 ++++++++++++++++++++++ drivers/net/fec_mxc.c | 8 +- drivers/net/kirkwood_egiga.c | 24 +- drivers/net/kirkwood_egiga.h | 2 +- drivers/net/mcfmii.c | 45 +- drivers/net/mpc512x_fec.c | 70 +--- drivers/net/mpc5xxx_fec.c | 41 +-- drivers/net/smc911x.c | 2 +- drivers/net/tsec.c | 3 +- drivers/qe/uec.c | 6 +- drivers/qe/uec_phy.c | 47 ++ include/net.h | 1 + include/netdev.h | 3 + net/eth.c | 18 +- net/net.c | 6 +- 25 files changed, 2120 insertions(+), 211 deletions(-) create mode 100644 drivers/net/altera_tse.c create mode 100644 drivers/net/altera_tse.h create mode 100644 drivers/net/ethoc.c
Dear Ben Warren,
In message 4BDF48DB.6080802@gmail.com you wrote:
Wolfgang,
Applied, thanks.
Ben Warren
