[U-Boot-Users] PPC405EP CPC0_PCI init vs. update
Hi All,
In cpu/ppc4xx/start.S, the CPC0_PCI register is _initialized_, rather than being simply _updated_. This clears bits that are set during bootstrap from a serial eeprom. E.g. for the PerWE/PCI_INT mux, CPC0_PCI[SPE] always gets cleared.
I'm proposing a simple change and would like some feedback ... it's not clear to me if this will cause problems for existing boards.
Comments welcome :-)
Regards, --Scott =============================================================== --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -1539,7 +1539,8 @@ ppc405ep_init: mtdcr ebccfgd,r3 #endif
- addi r3,0,CPC0_PCI_HOST_CFG_EN + mfdcr r3, CPC0_PCI + ori r3,r3,CPC0_PCI_HOST_CFG_EN #ifdef CONFIG_BUBINGA /*
Hi Scott,
Seems reasonable to me. I second this patch. Most likely, the current 405ep platforms need those bits cleared or configure them in some board specific code.
If nobody objects, I will check your patch in, in a few days/weeks...
Best regards, Stefan
Scott McNutt
Stefan Roese
