[U-Boot] [PATCH] powerpc/t1023rdb: Add T1023 RDB board support
T1023RDB is a Freescale Reference Design Board that hosts the T1023 SoC.
T1023RDB board Overview ----------------------- - T1023 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - SDRAM memory: 2GB Micron MT40A512M8HX unbuffered 32-bit DDR4 without ECC - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - one 1G RGMII port on-board(RTL8211F PHY) - one 1G SGMII port on-board(RTL8211F PHY) - one 2.5G SGMII port on-board(AQR105 PHY) - PCIe: Two Mini-PCIe connectors on-board. - SerDes: 4 lanes up to 10.3125GHz - NOR: 128MB S29GL01GS110TFIV10 Spansion NOR Flash - NAND: 512MB S34MS04G200BFI000 Spansion NAND Flash - eSPI: 64MB S25FL512SAGMFI010 Spansion SPI flash. - USB: one Type-A USB 2.0 port with internal PHY - eSDHC: support SD/MMC and eMMC card - 256Kbit M24256 I2C EEPROM - RTC: Real-time clock DS1339 on I2C bus - UART: one serial port on-board with RJ45 connector - Debugging: JTAG/COP for T1023 debugging
As well updated T1024RDB to add T1023RDB.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- board/freescale/t102xrdb/Makefile | 2 +- board/freescale/t102xrdb/README | 89 +++++++++++++++++++++++++----- board/freescale/t102xrdb/eth_t102xrdb.c | 23 +++++++- board/freescale/t102xrdb/t1023_rcw.cfg | 8 +++ board/freescale/t102xrdb/t102xrdb.c | 98 +++++++++++++++++++++++++++++++-- board/freescale/t102xrdb/t102xrdb.h | 4 +- include/configs/T102xRDB.h | 73 ++++++++++++++++++++---- 7 files changed, 263 insertions(+), 34 deletions(-) create mode 100644 board/freescale/t102xrdb/t1023_rcw.cfg
diff --git a/board/freescale/t102xrdb/Makefile b/board/freescale/t102xrdb/Makefile index a0cf8f6..0520066 100644 --- a/board/freescale/t102xrdb/Makefile +++ b/board/freescale/t102xrdb/Makefile @@ -8,7 +8,7 @@ ifdef CONFIG_SPL_BUILD obj-y += spl.o else obj-y += t102xrdb.o -obj-y += cpld.o +obj-$(CONFIG_T1024RDB) += cpld.o obj-y += eth_t102xrdb.o obj-$(CONFIG_PCI) += pci.o endif diff --git a/board/freescale/t102xrdb/README b/board/freescale/t102xrdb/README index 2b17f50..775de06 100644 --- a/board/freescale/t102xrdb/README +++ b/board/freescale/t102xrdb/README @@ -98,6 +98,29 @@ T1024RDB board Overview - Four I2C ports
+T1023RDB board Overview +----------------------- +- T1023 SoC integrating two 64-bit e5500 cores up to 1.4GHz +- CoreNet fabric supporting coherent and noncoherent transactions with + prioritization and bandwidth allocation +- SDRAM memory: 2GB Micron MT40A512M8HX unbuffered 32-bit DDR4 w/o ECC +- Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC +- Ethernet interfaces: + - one 1G RGMII port on-board(RTL8211FS PHY) + - one 1G SGMII port on-board(RTL8211FS PHY) + - one 2.5G SGMII port on-board(AQR105 PHY) +- PCIe: Two Mini-PCIe connectors on-board. +- SerDes: 4 lanes up to 10.3125GHz +- NOR: 128MB S29GL01GS110TFIV10 Spansion NOR Flash +- NAND: 512MB S34MS04G200BFI000 Spansion NAND Flash +- eSPI: 64MB S25FL512SAGMFI010 Spansion SPI flash. +- USB: one Type-A USB 2.0 port with internal PHY +- eSDHC: support SD/MMC and eMMC card +- 256Kbit M24256 I2C EEPROM +- RTC: Real-time clock DS1339U on I2C bus +- UART: one serial port on-board with RJ45 connector +- Debugging: JTAG/COP for T1023 debugging + Memory map on T1024RDB ---------------------- Start Address End Address Description Size @@ -124,22 +147,32 @@ Start Address End Address Definition Max size 0xEFF20000 0xEFF3FFFF u-boot env (current bank) 128KB 0xEFF00000 0xEFF1FFFF FMAN Ucode (current bank) 128KB 0xEFE00000 0xEFE3FFFF QE firmware (current bank) 256KB -0xED300000 0xEFEFFFFF rootfs (alt bank) 44MB +0xED300000 0xEFDFFFFF rootfs (alt bank) 44MB +0xED000000 0xED2FFFFF Guest image #3 (alternate bank) 3MB +0xECD00000 0xECFFFFFF Guest image #2 (alternate bank) 3MB +0xECA00000 0xECCFFFFF Guest image #1 (alternate bank) 3MB +0xEC900000 0xEC9FFFFF HV config device tree(alt bank) 1MB 0xEC800000 0xEC8FFFFF Hardware device tree (alt bank) 1MB -0xEC020000 0xEC7FFFFF Linux.uImage (alt bank) 7MB + 875KB +0xEC700000 0xEC7FFFFF HV.uImage (alternate bank) 1MB +0xEC020000 0xEC6FFFFF Linux.uImage (alt bank) ~7MB 0xEC000000 0xEC01FFFF RCW (alt bank) 128KB 0xEBF40000 0xEBFFFFFF u-boot (alt bank) 768KB 0xEBF20000 0xEBF3FFFF u-boot env (alt bank) 128KB 0xEBF00000 0xEBF1FFFF FMAN ucode (alt bank) 128KB 0xEBE00000 0xEBE3FFFF QE firmware (alt bank) 256KB -0xE9300000 0xEBEFFFFF rootfs (current bank) 44MB +0xE9300000 0xEBDFFFFF rootfs (current bank) 44MB +0xE9000000 0xE92FFFFF Guest image #3 (current bank) 3MB +0xE8D00000 0xE8FFFFFF Guest image #2 (current bank) 3MB +0xE8A00000 0xE8CFFFFF Guest image #1 (current bank) 3MB +0xE8900000 0xE89FFFFF HV config device tree(cur bank) 1MB 0xE8800000 0xE88FFFFF Hardware device tree (cur bank) 1MB -0xE8020000 0xE86FFFFF Linux.uImage (current bank) 7MB + 875KB +0xE8700000 0xE87FFFFF HV.uImage (current bank) 1MB +0xE8020000 0xE86FFFFF Linux.uImage (current bank) ~7MB 0xE8000000 0xE801FFFF RCW (current bank) 128KB
-T1024 Clock frequency ---------------------- +T1024/T1023 Clock frequency +--------------------------- BIN Core DDR Platform FMan Bin1: 1400MHz 1600MT/s 400MHz 700MHz Bin2: 1200MHz 1600MT/s 400MHz 600MHz @@ -155,16 +188,27 @@ Software configurations and board settings b. program u-boot.bin image to NOR flash => tftp 1000000 u-boot.bin => pro off all;era eff40000 efffffff;cp.b 1000000 eff40000 $filesize - set SW1[1:8] = '00010011', SW2[1] = '1', SW3[4] = '0' for NOR boot + on T1024RDB: + set SW1[1:8] = '00010011', SW2[1] = '1', SW3[4] = '0' for NOR boot + on T1023RDB: + set SW1[1:8] = '00010110', SW2[1] = '0', SW3[4] = '0' for NOR boot
Switching between default bank0 and alternate bank4 on NOR flash To change boot source to vbank4: - via software: run command 'cpld reset altbank' in u-boot. - via DIP-switch: set SW3[5:7] = '100' + on T1024RDB: + via software: run command 'cpld reset altbank' in u-boot. + via DIP-switch: set SW3[5:7] = '100' + on T1023RDB: + via software: run command 'gpio vbank4' in u-boot. + via DIP-switch: set SW3[5:7] = '100'
To change boot source to vbank0: - via software: run command 'cpld reset' in u-boot. - via DIP-Switch: set SW3[5:7] = '000' + on T1024RDB: + via software: run command 'cpld reset' in u-boot. + via DIP-Switch: set SW3[5:7] = '000' + on T1023RDB: + via software: run command 'gpio vbank0' in u-boot. + via DIP-switch: set SW3[5:7] = '000'
2. NAND Boot: a. build PBL image for NAND boot @@ -183,8 +227,11 @@ Software configurations and board settings b. program u-boot-with-spl-pbl.bin to SPI flash => tftp 1000000 u-boot-with-spl-pbl.bin => sf probe 0 - => sf erase 0 f0000 + => sf erase 0 100000 => sf write 1000000 0 $filesize + => tftp 1000000 fsl_fman_ucode_t1024_xx.bin + => sf erase 100000 100000 + => sf write 1000000 110000 20000 set SW1[1:8] = '00100010', SW2[1] ='1' for SPI boot
4. SD Boot: @@ -236,6 +283,15 @@ Start End Definition Size 0x200000 0x27FFFF QE Firmware 512KB(1 block)
+NAND Flash memory Map on T1023RDB +------------------------------------------------------------- +Start End Definition Size +0x000000 0x0FFFFF u-boot 1MB +0x100000 0x15FFFF u-boot env 8KB +0x160000 0x17FFFF FMAN Ucode 128KB +0x180000 0x19FFFF QE Firmware 128KB + + SD Card memory Map on T1024RDB ---------------------------------------------------- Block #blocks Definition Size @@ -245,14 +301,17 @@ Block #blocks Definition Size 0x920 0256 QE Firmware 128KB
-SPI Flash memory Map on T1024RDB +64MB SPI Flash memory Map on T1024RDB/T1023RDB ---------------------------------------------------- Start End Definition Size 0x000000 0x0FFFFF u-boot img 1MB 0x100000 0x101FFF u-boot env 8KB 0x110000 0x12FFFF FMAN Ucode 128KB 0x130000 0x14FFFF QE Firmware 128KB +0x300000 0x3FFFFF device tree 128KB +0x400000 0x9FFFFF Linux kernel 6MB +0xa00000 0x3FFFFFF rootfs 54MB
-For more details, please refer to T1024RDB Reference Manual and access -website www.freescale.com and Freescale QorIQ SDK Infocenter document. +For more details, please refer to T1024RDB Reference Manual +and Freescale QorIQ SDK Infocenter document. diff --git a/board/freescale/t102xrdb/eth_t102xrdb.c b/board/freescale/t102xrdb/eth_t102xrdb.c index f611ff0..f091d75 100644 --- a/board/freescale/t102xrdb/eth_t102xrdb.c +++ b/board/freescale/t102xrdb/eth_t102xrdb.c @@ -56,6 +56,7 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY1_ADDR);
switch (srds_s1) { +#ifdef CONFIG_T1024RDB case 0x95: /* set the on-board RGMII2 PHY */ fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY2_ADDR); @@ -63,10 +64,17 @@ int board_eth_init(bd_t *bis) /* set 10G XFI with Aquantia AQR105 PHY */ fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); break; +#endif + case 0x6a: + case 0x6b: case 0x77: case 0x135: /* set the on-board 2.5G SGMII AQR105 PHY */ - fm_info_set_phy_address(FM1_DTSEC3, SGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC3, SGMII_AQR_PHY_ADDR); +#ifdef CONFIG_T1023RDB + /* set the on-board 1G SGMII RTL8211F PHY */ + fm_info_set_phy_address(FM1_DTSEC1, SGMII_RTK_PHY_ADDR); +#endif break; default: printf("SerDes protocol 0x%x is not supported on T102xRDB\n", @@ -81,6 +89,14 @@ int board_eth_init(bd_t *bis) dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); fm_info_set_mdio(i, dev); break; + case PHY_INTERFACE_MODE_SGMII: +#if defined(CONFIG_T1023RDB) + dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); +#elif defined(CONFIG_T1024RDB) + dev = miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME); +#endif + fm_info_set_mdio(i, dev); + break; case PHY_INTERFACE_MODE_SGMII_2500: dev = miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME); fm_info_set_mdio(i, dev); @@ -110,8 +126,9 @@ int board_eth_init(bd_t *bis) void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, enum fm_port port, int offset) { - if ((fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII_2500) && - (port == FM1_DTSEC3)) { + if (((fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII_2500) || + (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII)) && + (port == FM1_DTSEC3)) { fdt_set_phy_handle(fdt, compat, addr, "sg_2500_aqr105_phy4"); fdt_setprop(fdt, offset, "phy-connection-type", "sgmii-2500", 10); diff --git a/board/freescale/t102xrdb/t1023_rcw.cfg b/board/freescale/t102xrdb/t1023_rcw.cfg new file mode 100644 index 0000000..fa781d6 --- /dev/null +++ b/board/freescale/t102xrdb/t1023_rcw.cfg @@ -0,0 +1,8 @@ +#PBL preamble and RCW header for T1023RDB +aa55aa55 010e0100 +#SerDes Protocol: 0x77 +#Core/DDR: 1400Mhz/1600MT/s with single source clock +0810000e 00000000 00000000 00000000 +3b800003 00000012 e8104000 21000000 +00000000 00000000 00000000 00020800 +00000130 04020200 00000000 00000006 diff --git a/board/freescale/t102xrdb/t102xrdb.c b/board/freescale/t102xrdb/t102xrdb.c index e196f12..1841dea 100644 --- a/board/freescale/t102xrdb/t102xrdb.c +++ b/board/freescale/t102xrdb/t102xrdb.c @@ -18,11 +18,25 @@ #include <asm/fsl_liodn.h> #include <fm_eth.h> #include "t102xrdb.h" +#ifdef CONFIG_T1024RDB #include "cpld.h" +#endif #include "../common/sleep.h"
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_T1023RDB +enum { + GPIO1_SD_SEL = 0x00020000, /* GPIO1_14, 0: EMMC, 1:SD/MMC */ + GPIO1_EMMC_SEL, + GPIO1_VBANK0, + GPIO1_VBANK4 = 0x00008000, /* GPIO1_16/20/22, 100:vBank4 */ + GPIO1_VBANK_MASK = 0x00008a00, + GPIO1_DIR_OUTPUT = 0x00028a00, + GPIO1_GET_VAL, +}; +#endif + int checkboard(void) { struct cpu_type *cpu = gd->arch.cpu; @@ -34,14 +48,17 @@ int checkboard(void) srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT;
printf("Board: %sRDB, ", cpu->name); - printf("Board rev: 0x%02x CPLD ver: 0x%02x, boot from ", +#ifdef CONFIG_T1024RDB + printf("Board rev: 0x%02x CPLD ver: 0x%02x, ", CPLD_READ(hw_ver), CPLD_READ(sw_ver)); +#endif + printf("boot from ");
#ifdef CONFIG_SDCARD puts("SD/MMC\n"); #elif CONFIG_SPIFLASH puts("SPI\n"); -#else +#elif defined(CONFIG_T1024RDB) u8 reg;
reg = CPLD_READ(flash_csr); @@ -52,17 +69,28 @@ int checkboard(void) reg = ((reg & CPLD_LBMAP_MASK) >> CPLD_LBMAP_SHIFT); printf("NOR vBank%d\n", reg); } +#elif defined(CONFIG_T1023RDB) +#ifdef CONFIG_NAND + puts("NAND\n"); +#else + printf("NOR vBank%d\n", (t1023rdb_gpio_ctrl(GPIO1_GET_VAL) & + GPIO1_VBANK4) >> 15 ? 4 : 0); +#endif #endif
puts("SERDES Reference Clocks:\n"); +#if defined(CONFIG_T1024RDB) if (srds_s1 == 0x95) printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[2], freq[0]); else - printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[0], freq[0]); - + printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[1], freq[0]); +#elif defined(CONFIG_T1023RDB) + printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[0], freq[1]); +#endif return 0; }
+#ifdef CONFIG_T1024RDB static void board_mux_lane(void) { ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); @@ -82,6 +110,7 @@ static void board_mux_lane(void) } CPLD_WRITE(boot_override, CPLD_OVERRIDE_MUX_EN); } +#endif
int board_early_init_f(void) { @@ -124,7 +153,9 @@ int board_early_init_r(void) #ifdef CONFIG_SYS_DPAA_QBMAN setup_portals(); #endif +#ifdef CONFIG_T1024RDB board_mux_lane(); +#endif
return 0; } @@ -170,3 +201,62 @@ int ft_board_setup(void *blob, bd_t *bd)
return 0; } + + +#ifdef CONFIG_T1023RDB +static u32 t1023rdb_gpio_ctrl(u32 ctrl_type) +{ + ccsr_gpio_t *pgpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR); + u32 gpioval; + + setbits_be32(&pgpio->gpdir, GPIO1_DIR_OUTPUT); + gpioval = in_be32(&pgpio->gpdat); + + switch (ctrl_type) { + case GPIO1_SD_SEL: + gpioval |= GPIO1_SD_SEL; + break; + case GPIO1_EMMC_SEL: + gpioval &= ~GPIO1_SD_SEL; + break; + case GPIO1_VBANK0: + gpioval &= ~GPIO1_VBANK_MASK; + break; + case GPIO1_VBANK4: + gpioval &= ~GPIO1_VBANK_MASK; + gpioval |= GPIO1_VBANK4; + break; + case GPIO1_GET_VAL: + return gpioval; + default: + break; + } + out_be32(&pgpio->gpdat, gpioval); + + return 0; +} + +static int gpio_cmd(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + if (argc < 2) + return CMD_RET_USAGE; + if (!strcmp(argv[1], "vbank0")) + t1023rdb_gpio_ctrl(GPIO1_VBANK0); + else if (!strcmp(argv[1], "vbank4")) + t1023rdb_gpio_ctrl(GPIO1_VBANK4); + else if (!strcmp(argv[1], "sd")) + t1023rdb_gpio_ctrl(GPIO1_SD_SEL); + else if (!strcmp(argv[1], "EMMC")) + t1023rdb_gpio_ctrl(GPIO1_EMMC_SEL); + else + return CMD_RET_USAGE; + return 0; +} + +U_BOOT_CMD( + gpio, 2, 0, gpio_cmd, + "for vbank0/vbank4/SD/eMMC switch control in runtime", + "command (e.g. gpio vbank4)" +); +#endif diff --git a/board/freescale/t102xrdb/t102xrdb.h b/board/freescale/t102xrdb/t102xrdb.h index 2f23579..3f5d85a 100644 --- a/board/freescale/t102xrdb/t102xrdb.h +++ b/board/freescale/t102xrdb/t102xrdb.h @@ -9,5 +9,7 @@
void fdt_fixup_board_enet(void *blob); void pci_of_setup(void *blob, bd_t *bd); - +#ifdef CONFIG_T1023RDB +static u32 t1023rdb_gpio_ctrl(u32 ctrl_type); +#endif #endif diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index bd40d6a..af10163 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -11,6 +11,13 @@ #ifndef __T1024RDB_H #define __T1024RDB_H
+#if defined(CONFIG_PPC_T1024) +#define CONFIG_T1024RDB +#elif defined(CONFIG_PPC_T1023) +#define CONFIG_T1023RDB +#define CONFIG_SYS_NO_FLASH +#endif + /* High Level Configuration Options */ #define CONFIG_SYS_GENERIC_BOARD #define CONFIG_DISPLAY_BOARDINFO @@ -35,7 +42,9 @@ #define CONFIG_ENV_OVERWRITE
/* support deep sleep */ +#ifdef CONFIG_PPC_T1024 #define CONFIG_DEEP_SLEEP +#endif #if defined(CONFIG_DEEP_SLEEP) #define CONFIG_SILENT_CONSOLE #define CONFIG_BOARD_EARLY_INIT_F @@ -43,7 +52,11 @@
#ifdef CONFIG_RAMBOOT_PBL #define CONFIG_SYS_FSL_PBL_PBI board/freescale/t102xrdb/t1024_pbi.cfg +#if defined(CONFIG_PPC_T1024) #define CONFIG_SYS_FSL_PBL_RCW board/freescale/t102xrdb/t1024_rcw.cfg +#elif defined(CONFIG_PPC_T1023) +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/t102xrdb/t1023_rcw.cfg +#endif #define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT #define CONFIG_SPL_ENV_SUPPORT #define CONFIG_SPL_SERIAL_SUPPORT @@ -177,7 +190,11 @@ #define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#if defined(CONFIG_T1024RDB) #define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_T1023RDB) +#define CONFIG_ENV_SECT_SIZE 0x40000 +#endif #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_MMC @@ -188,7 +205,11 @@ #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 +#if defined(CONFIG_T1024RDB) #define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_T1023RDB) +#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) +#endif #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) #define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 @@ -209,7 +230,7 @@ unsigned long get_board_ddr_clk(void); #endif
#define CONFIG_SYS_CLK_FREQ 100000000 -#define CONFIG_DDR_CLK_FREQ 66660000 +#define CONFIG_DDR_CLK_FREQ 100000000
/* * These can be toggled for performance analysis, otherwise use default. @@ -224,6 +245,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif
+#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST @@ -265,13 +287,18 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE #define CONFIG_DIMM_SLOTS_PER_CTLR 1 #define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) +#define CONFIG_FSL_DDR_INTERACTIVE +#if defined(CONFIG_T1024RDB) #define CONFIG_DDR_SPD #define CONFIG_SYS_FSL_DDR3 - #define CONFIG_SYS_SPD_BUS_NUM 0 #define SPD_EEPROM_ADDRESS 0x51 - #define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ +#elif defined(CONFIG_T1023RDB) +#define CONFIG_SYS_FSL_DDR4 +#define CONFIG_SYS_DDR_RAW_TIMING +#define CONFIG_SYS_SDRAM_SIZE 2048 +#endif
/* * IFC Definitions @@ -291,7 +318,12 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024)
/* NOR Flash Timing Params */ +#if defined(CONFIG_T1024RDB) #define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 +#elif defined(CONFIG_T1023RDB) +#define CONFIG_SYS_NOR_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NAND_TRHZ_80 | CSOR_NOR_ADM_SHFT_MODE_EN) +#endif #define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ FTIM0_NOR_TEADC(0x5) | \ FTIM0_NOR_TEAHC(0x5)) @@ -315,6 +347,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS}
+#ifdef CONFIG_T1024RDB /* CPLD on IFC */ #define CONFIG_SYS_CPLD_BASE 0xffdf0000 #define CONFIG_SYS_CPLD_BASE_PHYS (0xf00000000ull | CONFIG_SYS_CPLD_BASE) @@ -336,6 +369,7 @@ unsigned long get_board_ddr_clk(void); FTIM2_GPCM_TCH(0x8) | \ FTIM2_GPCM_TWP(0x1f)) #define CONFIG_SYS_CS2_FTIM3 0x0 +#endif
/* NAND Flash on IFC */ #define CONFIG_NAND_FSL_IFC @@ -352,6 +386,7 @@ unsigned long get_board_ddr_clk(void); | CSPR_V) #define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024)
+#if defined(CONFIG_T1024RDB) #define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ @@ -359,9 +394,17 @@ unsigned long get_board_ddr_clk(void); | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ | CSOR_NAND_SPRZ_224 /* Spare size = 224 */ \ | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ +#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) +#elif defined(CONFIG_T1023RDB) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_RAL_3 /* RAL 3Bytes */ \ + | CSOR_NAND_RAL_3 /* RAL 3Bytes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_128 /* Spare size = 128 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) +#endif
#define CONFIG_SYS_NAND_ONFI_DETECTION - /* ONFI NAND Flash mode0 Timing Params */ #define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ FTIM0_NAND_TWP(0x18) | \ @@ -382,8 +425,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_MTD_NAND_VERIFY_WRITE #define CONFIG_CMD_NAND
-#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) - #if defined(CONFIG_NAND) #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR @@ -538,6 +579,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESPI #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_SPANSION #define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_SPEED 10000000 @@ -737,8 +779,13 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_QE_FW_ADDR (512 * 0x920) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#if defined(CONFIG_T1024RDB) #define CONFIG_SYS_FMAN_FW_ADDR (3 * CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_SYS_QE_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_T1023RDB) +#define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_QE_FW_ADDR (12 * CONFIG_SYS_NAND_BLOCK_SIZE) +#endif #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing @@ -763,10 +810,16 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_PHYLIB_10G #define CONFIG_PHY_REALTEK #define CONFIG_PHY_AQUANTIA +#if defined(CONFIG_T1024RDB) #define RGMII_PHY1_ADDR 0x2 #define RGMII_PHY2_ADDR 0x6 -#define SGMII_PHY1_ADDR 0x2 +#define SGMII_AQR_PHY_ADDR 0x2 #define FM1_10GEC1_PHY_ADDR 0x1 +#elif defined(CONFIG_T1023RDB) +#define RGMII_PHY1_ADDR 0x1 +#define SGMII_RTK_PHY_ADDR 0x3 +#define SGMII_AQR_PHY_ADDR 0x2 +#endif #endif
#ifdef CONFIG_FMAN_ENET @@ -856,16 +909,16 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_ROOTPATH "/opt/nfsroot" #define CONFIG_BOOTFILE "uImage" -#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server */ +#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ #define CONFIG_LOADADDR 1000000 /* default location for tftp, bootm */ #define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ #define CONFIG_BAUDRATE 115200 #define __USB_PHY_TYPE utmi
#ifdef CONFIG_PPC_T1024 -#define CONFIG_BOARDNAME "t1024rdb" +#define CONFIG_BOARDNAME t1024rdb #else -#define CONFIG_BOARDNAME "t1023rdb" +#define CONFIG_BOARDNAME t1023rdb #endif
#define CONFIG_EXTRA_ENV_SETTINGS \
Shengzhou Liu
