[U-Boot] [RFC PATCH] ARM: print gcc version
It might be useful to see what compiler version was used to compile u-boot. --- arch/arm/lib/board.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 96c0e30..df90b5e 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -75,7 +75,7 @@ extern void dataflash_print_info(void); #endif
const char version_string[] = - U_BOOT_VERSION" (" U_BOOT_DATE " - " U_BOOT_TIME ")"CONFIG_IDENT_STRING; + U_BOOT_VERSION" (" U_BOOT_DATE " - " U_BOOT_TIME ", gcc " __VERSION__ ")"CONFIG_IDENT_STRING;
#ifdef CONFIG_DRIVER_RTL8019 extern void rtl8019_get_enetaddr (uchar * addr);
Dear Alexander Holler,
- U_BOOT_VERSION" (" U_BOOT_DATE " - " U_BOOT_TIME ", gcc " __VERSION__ ")"CONFIG_IDENT_STRING;
I understand your intention, but I'm not really happy with it.
So far, the version_string is mostly architecture and system independent. I haven't seen any comments about this, but I can imagine that we want such information globally.
On the other hand, that would require changes to many files, and the gcc __VERSION__ string is pretty long on some systems, which may cause additional problems.
I also doubt that we need this information with each boot message (where it just slows down booting).
Would it not be sufficient to add this to the code of do_version() so we can get this information when we want it, i. e. when running the "version" command?
Am 09.01.2011 22:03, schrieb Wolfgang Denk:
Hmm, here it includes only "4.5.2", the plain version and not the vendor version. Therfore I was happy with that, because the vendor version would be too long to display at startup.
Hmm, I haven't counted the time needed to display additional 9 characters, but displaying the version at startup is handy for "screen dumps" (e.g. stuff pasted by people with problems).
I would like that. But as you said, my intention was really only because of the current problems with gcc for arm.
Besides that, I would found it handy to see the used compiler for u-boot's where I don't have the source by hand, e.g. those already found on boards. But that might be because I'm curious by default. ;)
Anyway, I would found it a nice feature, at startup or when running the version command, but both aren't a must.
Regards,
Alexander
Well, what I see is for example "4.5.1 20100924 (Red Hat 4.5.1-4)" with the native GCC on Fedora 14; some other tool chains provide similar long results.
It's about 1 millisecond at 115 kbps, or 10 milliseconds at 9600 ;-)
I think we're already printing way too muc information- and still people don't include even the most vital information like which version of U-Boot they are running.
So will you prepare a patch? [TIA!]
Well, eventually we should print more than __VERSION__, then. Becasue if you see "4.4.1" - what does it tell you? You don't see that this is the Sourcery G++ Lite 2010q1-202 version of GCC, or that ""4.5.0 20100729 (prerelease)" is a specific Poky release?
I think it would be a really useful extension to the version command. Looking forwad to seeing your patch.
Hello,
Am 17.01.2011 23:28, schrieb Wolfgang Denk:
Maybe if someone could feed me with what to use for the version. E.g. my gcc here defines __VERSION__ as "4.5.2" but when I'm looking at u-boot/lib/asm-offsets.s I see
.ident "GCC: (Gentoo 4.5.2 p1.0, pie-0.4.5) 4.5.2"
So I would like to display that which would be in line with the comment section of generated binaries.
But when I use "gcc -E -dM empty.c" to print all predefined macros, I don't see the text found in .ident. Not even something else which includes "Gentoo".
Regards,
Alexander
I believe the output of "$(CC) --version" should contain the same data as your .ident string. You could echo it into a file like: diff --git a/Makefile b/Makefile index 0685ef9..e070d40 100644 --- a/Makefile +++ b/Makefile @@ -416,6 +416,8 @@ $(U_BOOT_ONENAND): $(ONENAND_IPL) $(obj)u-boot.bin $(VERSION_FILE): @( printf '#define U_BOOT_VERSION "U-Boot %s%s"\n' "$(U_BOOT_VERSION)" \ '$(shell $(TOPDIR)/tools/setlocalversion $(TOPDIR))' ) > $@.tmp + @( printf '#define CC_VERSION_STRING "%s"\n' \ + '$(shell $(CC) --version | head -1)' ) >> $@.tmp @cmp -s $@ $@.tmp && rm -f $@.tmp || mv -f $@.tmp $@
$(TIMESTAMP_FILE):
Best, Peter
Am 18.01.2011 17:20, schrieb Peter Tyser:
I believe the output of "$(CC) --version" should contain the same data as your .ident string. You could echo it into a file like: diff --git a/Makefile b/Makefile index 0685ef9..e070d40 100644 --- a/Makefile +++ b/Makefile @@ -416,6 +416,8 @@ $(U_BOOT_ONENAND): $(ONENAND_IPL) $(obj)u-boot.bin $(VERSION_FILE): @( printf '#define U_BOOT_VERSION "U-Boot %s%s"\n' "$(U_BOOT_VERSION)" \ '$(shell $(TOPDIR)/tools/setlocalversion $(TOPDIR))' )> $@.tmp
'$(shell $(CC) --version | head -1)' )>> $@.tmp @cmp -s $@ $@.tmp&& rm -f $@.tmp || mv -f $@.tmp $@
$(TIMESTAMP_FILE):
That would the trick. The first line of gcc --version includes here the correct string. Thanks. (Btw. I would use head -n 1)
But I will wait for a comment from one of the maintainers about defining CC_VERSION_STRING.
If someone gives me an ok, I will write a patch including your suggestion and will print that version in the command version.
Regards,
Alexander
$(TIMESTAMP_FILE):
Looks good to me - please go on.
Hm... while we are at it... the bintuils (especially linker) version is probably equally interesting, so eventually we should also add a LD_VERSION_STRING.
Alexander Holler
Peter Tyser
