I followed the following commands to achieve a successful booting of i.mx6 board using SD card dd if=u-boot.imx of=/dev/sdb bs=1k seek=1 The above command burnt the u-boot.imx image on the SD card though nothing was seen on SD card. Next the gtkterm configurations were set and after the board was started serial console output was interrupted(by pressing a key). U-Boot>> sf probe (to probe the flash memory) U-Boot>> sf erase 0 0x80000 (to erase the flash) U-Boot>>fatload mmc 1 12000000 u-boot.imx The above command throws an error -"Unable to read file u-boot.imx"
SO what can be the problem behind it and how can we overcome it?
Hello Jyoti,
I think you're confused about the use of un-partitioned space for booting (which is common on many other boards) and the use of the filesystem as a path to SPI-NOR used by our boards.
In English, this copies u-boot.imx to offset 0x400 of the SD card, over-writing whatever might be there.
This is a block-level operation, and your card partitioning must ensure that this is un-formatted space.
That's because you're not using the right glasses... You'll need to use dd to read things back:
~/$ sudo dd bs=1k skip=1 count=1 if=/dev/sdb | hexdump
And for comparison: ~/$ sudo dd if=u-boot.imx bs=1k count=1 | hexdump
You haven't written the "file" u-boot.imx, you wrote the content of u-boot.imx to un-named blocks on the SD card.
A. Partition your SD card with one partition B. Format the partition as FAT32, ext2/3/4 C. Use "cp" to copy u-boot.imx to the filesystem D. Use fatload or ext2load to load the file, or better yet, copy 6x_upgrade to the SD card and use the 'upgradeu' command: U-Boot > run upgradeu
See the README and 6x_upgrade.txt files in board/boundary/nitrogen6x for details.
Eric Nelson
JYOTI DUBEY
