[PATCH 1/2] mmc: fsl_esdhc: Set fallback mode to 1-bit
8-bit mode is not supported by SD cards and on P2020 are four SDHC pins shared with SPI (so if P2020 board have also SPI then only 4-bit SDHC mode is provided). So 8-bit SDHC mode is really bad default.
When max bus width is not provided then set mode to 1-bit. This mode is supported by all cards, so it is the best option for fallback mode.
Also P2020 bootrom sets mode to 1-bit when booting from SD/MMC card.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/mmc/fsl_esdhc.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 3b3587bd8d72..834f8933b0c6 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -963,9 +963,8 @@ int fsl_esdhc_initialize(struct bd_info *bis, struct fsl_esdhc_cfg *cfg) } else if (cfg->max_bus_width == 1) { mmc_cfg->host_caps |= MMC_MODE_1BIT; } else { - mmc_cfg->host_caps |= MMC_MODE_1BIT | MMC_MODE_4BIT | - MMC_MODE_8BIT; - printf("No max bus width provided. Assume 8-bit supported.\n"); + mmc_cfg->host_caps |= MMC_MODE_1BIT; + printf("No max bus width provided. Fallback to 1-bit mode.\n"); }
if (IS_ENABLED(CONFIG_ESDHC_DETECT_8_BIT_QUIRK))
Currently default fallback SDHC mode is 1-bit. Add new config option CONFIG_SYS_FSL_ESDHC_DEFAULT_BUS_WIDTH to allow specifying default fallback mode. This is useful e.g. for SPL builds which loads other parts from SD card during boot process.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/mmc/Kconfig | 5 +++++ drivers/mmc/fsl_esdhc.c | 1 + 2 files changed, 6 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index f04cc44e1973..df15dff6248f 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -826,6 +826,11 @@ config FSL_ESDHC_VS33_NOT_SUPPORT For eSDHC, power supply is through peripheral circuit. 3.3V support is common. Select this if 3.3V power supply not supported.
+config SYS_FSL_ESDHC_DEFAULT_BUS_WIDTH + int + depends on FSL_ESDHC + default 1 + config FSL_ESDHC_IMX bool "Freescale/NXP i.MX eSDHC controller support" help diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 834f8933b0c6..a4c22942c2be 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -988,6 +988,7 @@ int fsl_esdhc_mmc_init(struct bd_info *bis)
cfg = calloc(sizeof(struct fsl_esdhc_cfg), 1); cfg->esdhc_base = CONFIG_SYS_FSL_ESDHC_ADDR; + cfg->max_bus_width = CONFIG_SYS_FSL_ESDHC_DEFAULT_BUS_WIDTH; /* Prefer peripheral clock which provides higher frequency. */ if (gd->arch.sdhc_per_clk) cfg->sdhc_clk = gd->arch.sdhc_per_clk;
- int
- depends on FSL_ESDHC
- default 1
Is there any reason not to use dt?
Best Regards, Jaehoon Chung
- cfg->max_bus_width = CONFIG_SYS_FSL_ESDHC_DEFAULT_BUS_WIDTH; /* Prefer peripheral clock which provides higher frequency. */ if (gd->arch.sdhc_per_clk) cfg->sdhc_clk = gd->arch.sdhc_per_clk;
- int
- default 1
This is fallback value for function fsl_esdhc_mmc_init() which is called when DT is not parsed or used (yet). E.g. this applies for P2020 SPL.
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
- int
- default 1
Add minor comment.
MMC_MODE_8BIT;
I'm not sure that it really needs to use "|".
Jaehoon Chung
Pali Rohár
