Re: [U-Boot] TFTP timeout issue while downloading the linux kernel in openpxa vpac270 u-boot source code
Dne Pá 13. srpna 2010 12:27:12 StephenPaulraj Chinnadurai-ERS,HCLTech napsal(a):
Dear Marek,
YOU DROPPED THE MAILING LIST AGAIN !! HOW MANY TIMES DO I HAVE TO TELL YOU TO KEEP IT CCED ?!
Even if I assign 0x1234 to MSC2 I am getting the same timeout problem.
Because 0x1234 is 16 bit bus ... dont you use 32bit bus to that card ?
Can you suggest me some other solution?
Is this problem because of static memory configuration?
Check the bus with a scope I guess, that should give you some ideas.
Where should I concentrate for the solution, whether in net/tftp.c file or in drivers/net/smc91111.c file?
You can enable debuging output in the smc91111 driver.
Kindly guide me to come out the problem.
Thanks and Regards Stephen Paulraj C
HCL Technologies Ltd. D-12, Sidco Industrial Estate, Ambattur, Chennai -58 Tel: +91 44 42004800 Extn: 2319 Mob:+91 9962583934 www.hcl.in
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Marek Vasut Sent: Thursday, August 12, 2010 11:05 PM To: StephenPaulraj Chinnadurai-ERS,HCLTech Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] TFTP timeout issue while downloading the linux kernel in openpxa vpac270 u-boot source code
Dne Čt 12. srpna 2010 19:11:29 StephenPaulraj Chinnadurai-ERS,HCLTech
napsal(a):
Hello Marek,
I am using a customize board which has PXA270 controller. SMCS LAN91C111Ii-NU is connected to the static memory 4 (nCS4).
I see, so it's not vpac270 bug.
I have defined following macro value in the include/configs/<myboard.h> file.
#define CONFIG_SYS_GPDR2_VAL 0x70DF3FFF GPIO 80 is configured as output
#define CONFIG_SYS_GPSR2_VAL 0x10010000 /*nCS4*/ GPIO 80 is set
You don't really need to configure these if you then set it to AF2.
#define CONFIG_SYS_GAFR2_U_VAL 0x1504A176 Alternate function 2 is selected for GPIO 80
#define CONFIG_SYS_MSC2_VAL 0x0000B884
Zylonite 300 uses value 0x3c for the SMC91111 in the corresponding part of MSCx register in original Marvell sources, Zylonite320 uses 0x123c ... maybe you should review the MSCx configuration here. For pxa27x, I guess it might be something like 0x123c too.
From the log below, it really seems the ethernet chip is choking.
Cheers
RT4 = 4 Variable Latency I/O (VLIO)
ROM4 Bus Width 0 = 32 Bits
RDF4 = 8
RDN4 = 8
RRR4 = 3
RBUFF4 = 1 Faster device
#define CONFIG_SMC91111 #define CONFIG_SMC91111_BASE 0x10000300 /*nCS4*/ #define CONFIG_SMC_USE_32_BIT #undef CONFIG_SMC_91111_EXT_PHY
Ethernet controller is working fine. I can able to ping the machines connected to the network.
tftpboot command is also working fine, I can able to download the u-boot.bin to SDRAM.
But I have issue in downloading bigger files (zImage which is 2.5 MB) to the SDRAM. I am getting the following timeout messages and the download is not getting completed.
Loading: *########T T T T T T T T T T T T T T T T T T T T Retry count exceeded; starting again
Please help me to come out of this issue.
Kindly find the complete log below:
__
U-Boot 2010.06-rc1 (Aug 13 2010 - 09:11:31)
DRAM: 128 MiB
Flash: 64 MiB
In: serial
Out: serial
Err: serial
Net: SMC91111-0
Hit any key to stop autoboot: 2 ___ 0
MDT-Boot> print
bootargs=console=tty0 console=ttyS1, root=/dev/sda1 rootdelay=15
bootcmd=if mmc init && fatload mmc 0 0xa0000000 uImage; then bootm 0xa0000000; fi; if usb reset && fatload usb 0 0xa0000000 uImage; then bootm 0xa0000000; fi; bootm 0x150000;
bootdelay=2
baudrate=115200
ethaddr=00:00:70:26:1E:01
netmask=255.255.255.0
ethact=SMC91111-0
ipaddr=10.100.144.42
serverip=10.100.144.245
gatewayip=10.100.144.255
stdin=serial
stdout=serial
stderr=serial
Environment size: 445/32764 bytes
MDT-Boot> ping 10.100.144.245
SMC91111: MAC 00:00:70:26:1e:01
Using SMC91111-0 device
host 10.100.144.245 is alive
MDT-Boot> tftp a3000000 u-boot.bin
TFTP from server 10.100.144.245; our IP address is 10.100.144.42
Filename 'u-boot.bin'.
Load address: 0xa3000000
Loading: *_############
done
Bytes transferred = 335280 (51db0 hex)
MDT-Boot> tftp a3000000 zImage
Filename 'zImage'.
Loading: *_####################T T T T T T T T T T T T T T T T T T T T
Filename 'zImage'.
Loading: *_#######T ##T #T T T T T T T T T T T T T T T T T T
Filename 'zImage'.
Loading: *_#######################T T T T T T T T T T T T T T T T T T T T
