[PATCH v5 0/3] Add HopeRun HiHope RZ/G2M board support
This patch series adds the required board support to boot HopeRun HiHope RZ/G2M board. Also added configuration support for RZ/G2[HN] SoC.
Biju Das (3): arm: renesas: Add config option for R8A774B1 SoC arm: renesas: Add config option for R8A774E1 SoC arm: rmobile: Add HopeRun HiHope RZ/G2M board support
arch/arm/dts/Makefile | 1 + arch/arm/dts/hihope-common.dtsi | 377 ++++++++++++++++++ arch/arm/dts/hihope-rev4.dtsi | 124 ++++++ arch/arm/dts/hihope-rzg2-ex.dtsi | 92 +++++ arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts | 21 + arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dts | 27 ++ arch/arm/dts/r8a774a1-hihope-rzg2m.dts | 37 ++ arch/arm/dts/r8a774a1-u-boot.dtsi | 55 +++ arch/arm/mach-rmobile/Kconfig.64 | 22 +- board/hoperun/hihope-rzg2/Kconfig | 15 + board/hoperun/hihope-rzg2/MAINTAINERS | 6 + board/hoperun/hihope-rzg2/Makefile | 9 + board/hoperun/hihope-rzg2/hihope-rzg2.c | 75 ++++ configs/hihope_rzg2_defconfig | 75 ++++ include/configs/hihope-rzg2.h | 20 + 15 files changed, 955 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/hihope-common.dtsi create mode 100644 arch/arm/dts/hihope-rev4.dtsi create mode 100644 arch/arm/dts/hihope-rzg2-ex.dtsi create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dts create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m.dts create mode 100644 arch/arm/dts/r8a774a1-u-boot.dtsi create mode 100644 board/hoperun/hihope-rzg2/Kconfig create mode 100644 board/hoperun/hihope-rzg2/MAINTAINERS create mode 100644 board/hoperun/hihope-rzg2/Makefile create mode 100644 board/hoperun/hihope-rzg2/hihope-rzg2.c create mode 100644 configs/hihope_rzg2_defconfig create mode 100644 include/configs/hihope-rzg2.h
Add config support for RZ/G2N(a.k.a R8A774B1) SoC.
Also fixed the alignment issue on R8A774A1 config.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- * Rebased to u-boot-sh/next. --- arch/arm/mach-rmobile/Kconfig.64 | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 07f607dd9d..3b53266a61 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -3,7 +3,10 @@ if RCAR_GEN3 menu "Select Target SoC"
config R8A774A1 - bool "Renesas SoC R8A774A1" + bool "Renesas SoC R8A774A1" + +config R8A774B1 + bool "Renesas SoC R8A774B1"
config R8A7795 bool "Renesas SoC R8A7795"
Add config support for RZ/G2H(a.k.a R8A774E1) SoC.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- * Rebased to u-boot-sh/next. --- arch/arm/mach-rmobile/Kconfig.64 | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 3b53266a61..0d55b74c42 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -8,6 +8,9 @@ config R8A774A1 config R8A774B1 bool "Renesas SoC R8A774B1"
+config R8A774E1 + bool "Renesas SoC R8A774E1" + config R8A7795 bool "Renesas SoC R8A7795" imply CLK_R8A7795
The HiHope RZ/G2M board from HopeRun consists of main board (HopeRun HiHope RZ/G2M main board) and sub board(HopeRun HiHope RZ/G2M sub board). The HiHope RZ/G2M sub board sits below the HiHope RZ/G2M main board.
DTS files apart from r8a774a1-hihope-rzg2m-u-boot.dts and r8a774a1-u-boot.dtsi have been imported from Linux kernel 5.9-rc4 commit f4d51dffc6c0 ("Linux 5.9-rc4")
This patch adds the required board support to boot HopeRun HiHope RZ/G2M board.
Signed-off-by: Biju Das biju.das.jz@bp.renesas.com Reviewed-by: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- V4->V5 * Rebased to U-boot-sh/next
V3->V4 * Added USB0 channel0 Host support (Ref: https://patchwork.ozlabs.org/project/uboot/patch/20201001103658.4835-2-biju....) V2->V3 * Reworked as per Marek's suggestion * Added rzg2_get_cpu_type function to get cpu_type by matching TFA compatible string * Removed SoC family type Enum Ref: https://patchwork.ozlabs.org/project/uboot/patch/20200922160317.16296-3-biju...
V1->V2 * Fixed indentation for R8A774A1 config * Used GPIO hog for setting WLAN/BT REG ON * Removed USB related initialization Ref: https://patchwork.ozlabs.org/project/uboot/patch/20200918160307.14323-2-biju...
V1:- * New Patch Ref: https://patchwork.ozlabs.org/project/uboot/patch/20200915143630.7678-5-biju.... --- arch/arm/dts/Makefile | 1 + arch/arm/dts/hihope-common.dtsi | 377 ++++++++++++++++++ arch/arm/dts/hihope-rev4.dtsi | 124 ++++++ arch/arm/dts/hihope-rzg2-ex.dtsi | 92 +++++ arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts | 21 + arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dts | 27 ++ arch/arm/dts/r8a774a1-hihope-rzg2m.dts | 37 ++ arch/arm/dts/r8a774a1-u-boot.dtsi | 55 +++ arch/arm/mach-rmobile/Kconfig.64 | 14 + board/hoperun/hihope-rzg2/Kconfig | 15 + board/hoperun/hihope-rzg2/MAINTAINERS | 6 + board/hoperun/hihope-rzg2/Makefile | 9 + board/hoperun/hihope-rzg2/hihope-rzg2.c | 75 ++++ configs/hihope_rzg2_defconfig | 75 ++++ include/configs/hihope-rzg2.h | 20 + 15 files changed, 948 insertions(+) create mode 100644 arch/arm/dts/hihope-common.dtsi create mode 100644 arch/arm/dts/hihope-rev4.dtsi create mode 100644 arch/arm/dts/hihope-rzg2-ex.dtsi create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dts create mode 100644 arch/arm/dts/r8a774a1-hihope-rzg2m.dts create mode 100644 arch/arm/dts/r8a774a1-u-boot.dtsi create mode 100644 board/hoperun/hihope-rzg2/Kconfig create mode 100644 board/hoperun/hihope-rzg2/MAINTAINERS create mode 100644 board/hoperun/hihope-rzg2/Makefile create mode 100644 board/hoperun/hihope-rzg2/hihope-rzg2.c create mode 100644 configs/hihope_rzg2_defconfig create mode 100644 include/configs/hihope-rzg2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 72b6fe1a3e..0de6bce873 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -784,6 +784,7 @@ dtb-$(CONFIG_RCAR_GEN2) += \
dtb-$(CONFIG_RCAR_GEN3) += \ r8a774a1-beacon-rzg2m-kit.dtb \ + r8a774a1-hihope-rzg2m-u-boot.dtb \ r8a77950-ulcb-u-boot.dtb \ r8a77950-salvator-x-u-boot.dtb \ r8a77960-ulcb-u-boot.dtb \ diff --git a/arch/arm/dts/hihope-common.dtsi b/arch/arm/dts/hihope-common.dtsi new file mode 100644 index 0000000000..51eb74fbe9 --- /dev/null +++ b/arch/arm/dts/hihope-common.dtsi @@ -0,0 +1,377 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2H Rev.4.0 and + * HiHope RZ/G2[MN] Rev.[2.0/3.0/4.0] main board common parts + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include <dt-bindings/gpio/gpio.h> + +/ { + aliases { + serial0 = &scif2; + serial1 = &hscif0; + }; + + chosen { + bootargs = "ignore_loglevel"; + stdout-path = "serial0:115200n8"; + }; + + hdmi0-out { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi0_con: endpoint { + remote-endpoint = <&rcar_dw_hdmi0_out>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + led1 { + gpios = <&gpio6 12 GPIO_ACTIVE_HIGH>; + }; + + led2 { + gpios = <&gpio6 13 GPIO_ACTIVE_HIGH>; + }; + + led3 { + gpios = <&gpio0 0 GPIO_ACTIVE_HIGH>; + }; + + led4 { + gpios = <&gpio6 11 GPIO_ACTIVE_HIGH>; + }; + }; + + reg_1p8v: regulator0 { + compatible = "regulator-fixed"; + regulator-name = "fixed-1.8V"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + reg_3p3v: regulator1 { + compatible = "regulator-fixed"; + regulator-name = "fixed-3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + sound_card: sound { + compatible = "audio-graph-card"; + + label = "rcar-sound"; + + dais = <&rsnd_port>; + }; + + vbus0_usb2: regulator-vbus0-usb2 { + compatible = "regulator-fixed"; + + regulator-name = "USB20_VBUS0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + + gpio = <&gpio6 16 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vccq_sdhi0: regulator-vccq-sdhi0 { + compatible = "regulator-gpio"; + + regulator-name = "SDHI0 VccQ"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio6 30 GPIO_ACTIVE_HIGH>; + gpios-states = <1>; + states = <3300000 1>, <1800000 0>; + }; + + x302_clk: x302-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <33000000>; + }; + + x304_clk: x304-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; +}; + +&audio_clk_a { + clock-frequency = <22579200>; +}; + +&du { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&extal_clk { + clock-frequency = <16666666>; +}; + +&extalr_clk { + clock-frequency = <32768>; +}; + +&gpio6 { + usb1-reset { + gpio-hog; + gpios = <10 GPIO_ACTIVE_LOW>; + output-low; + line-name = "usb1-reset"; + }; +}; + +&hdmi0 { + status = "okay"; + + ports { + port@1 { + reg = <1>; + rcar_dw_hdmi0_out: endpoint { + remote-endpoint = <&hdmi0_con>; + }; + }; + port@2 { + reg = <2>; + dw_hdmi0_snd_in: endpoint { + remote-endpoint = <&rsnd_endpoint>; + }; + }; + }; +}; + +&hscif0 { + pinctrl-0 = <&hscif0_pins>; + pinctrl-names = "default"; + + uart-has-rtscts; + status = "okay"; +}; + +&hsusb { + dr_mode = "otg"; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <400000>; + status = "okay"; + + versaclock5: clock-generator@6a { + compatible = "idt,5p49v5923"; + reg = <0x6a>; + #clock-cells = <1>; + clocks = <&x304_clk>; + clock-names = "xin"; + }; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&pcie_bus_clk { + clock-frequency = <100000000>; +}; + +&pfc { + pinctrl-0 = <&scif_clk_pins>; + pinctrl-names = "default"; + + hscif0_pins: hscif0 { + groups = "hscif0_data", "hscif0_ctrl"; + function = "hscif0"; + }; + + scif2_pins: scif2 { + groups = "scif2_data_a"; + function = "scif2"; + }; + + scif_clk_pins: scif_clk { + groups = "scif_clk_a"; + function = "scif_clk"; + }; + + sdhi0_pins: sd0 { + groups = "sdhi0_data4", "sdhi0_ctrl"; + function = "sdhi0"; + power-source = <3300>; + }; + + sdhi0_pins_uhs: sd0_uhs { + groups = "sdhi0_data4", "sdhi0_ctrl"; + function = "sdhi0"; + power-source = <1800>; + }; + + sdhi2_pins: sd2 { + groups = "sdhi2_data4", "sdhi2_ctrl"; + function = "sdhi2"; + power-source = <1800>; + }; + + sdhi3_pins: sd3 { + groups = "sdhi3_data8", "sdhi3_ctrl", "sdhi3_ds"; + function = "sdhi3"; + power-source = <1800>; + }; + + usb0_pins: usb0 { + groups = "usb0"; + function = "usb0"; + }; + + usb1_pins: usb1 { + mux { + groups = "usb1"; + function = "usb1"; + }; + + ovc { + pins = "GP_6_27"; + bias-pull-up; + }; + }; + + usb30_pins: usb30 { + groups = "usb30"; + function = "usb30"; + }; +}; + +&rwdt { + timeout-sec = <60>; + status = "okay"; +}; + +&scif2 { + pinctrl-0 = <&scif2_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; + +&scif_clk { + clock-frequency = <14745600>; +}; + +&sdhi0 { + pinctrl-0 = <&sdhi0_pins>; + pinctrl-1 = <&sdhi0_pins_uhs>; + pinctrl-names = "default", "state_uhs"; + + vmmc-supply = <®_3p3v>; + vqmmc-supply = <&vccq_sdhi0>; + cd-gpios = <&gpio3 12 GPIO_ACTIVE_LOW>; + bus-width = <4>; + sd-uhs-sdr50; + sd-uhs-sdr104; + status = "okay"; +}; + +&sdhi2 { + status = "okay"; + pinctrl-0 = <&sdhi2_pins>; + pinctrl-names = "default"; + + vmmc-supply = <&wlan_en_reg>; + bus-width = <4>; + non-removable; + cap-power-off-card; + keep-power-in-suspend; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1837"; + reg = <2>; + interrupt-parent = <&gpio2>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH>; + }; +}; + +&sdhi3 { + pinctrl-0 = <&sdhi3_pins>; + pinctrl-1 = <&sdhi3_pins>; + pinctrl-names = "default", "state_uhs"; + + vmmc-supply = <®_3p3v>; + vqmmc-supply = <®_1p8v>; + bus-width = <8>; + mmc-hs200-1_8v; + non-removable; + fixed-emmc-driver-type = <1>; + status = "okay"; +}; + +&usb_extal_clk { + clock-frequency = <50000000>; +}; + +&usb2_phy0 { + pinctrl-0 = <&usb0_pins>; + pinctrl-names = "default"; + + vbus-supply = <&vbus0_usb2>; + status = "okay"; +}; + +&usb2_phy1 { + pinctrl-0 = <&usb1_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; + +&usb3_peri0 { + phys = <&usb3_phy0>; + phy-names = "usb"; + + companion = <&xhci0>; + + status = "okay"; +}; + +&usb3_phy0 { + status = "okay"; +}; + +&usb3s0_clk { + clock-frequency = <100000000>; +}; + +&xhci0 { + pinctrl-0 = <&usb30_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; diff --git a/arch/arm/dts/hihope-rev4.dtsi b/arch/arm/dts/hihope-rev4.dtsi new file mode 100644 index 0000000000..3046c07a28 --- /dev/null +++ b/arch/arm/dts/hihope-rev4.dtsi @@ -0,0 +1,124 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2H Rev.4.0 and + * HiHope RZ/G2[MN] Rev.3.0/4.0 main board common parts + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include <dt-bindings/gpio/gpio.h> +#include "hihope-common.dtsi" + +/ { + audio_clkout: audio-clkout { + /* + * This is same as <&rcar_sound 0> + * but needed to avoid cs2000/rcar_sound probe dead-lock + */ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <12288000>; + }; + + wlan_en_reg: regulator-wlan_en { + compatible = "regulator-fixed"; + regulator-name = "wlan-en-regulator"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us = <70000>; + + gpio = <&gpio4 6 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + x1801_clk: x1801-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24576000>; + }; +}; + +&hscif0 { + bluetooth { + compatible = "ti,wl1837-st"; + enable-gpios = <&gpio3 13 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c2 { + pinctrl-0 = <&i2c2_pins>; + pinctrl-names = "default"; + status = "okay"; + + cs2000: clk_multiplier@4f { + #clock-cells = <0>; + compatible = "cirrus,cs2000-cp"; + reg = <0x4f>; + clocks = <&audio_clkout>, <&x1801_clk>; + clock-names = "clk_in", "ref_clk"; + + assigned-clocks = <&cs2000>; + assigned-clock-rates = <24576000>; /* 1/1 divide */ + }; +}; + +&pfc { + i2c2_pins: i2c2 { + groups = "i2c2_a"; + function = "i2c2"; + }; + + sound_clk_pins: sound_clk { + groups = "audio_clk_a_a", "audio_clk_b_a", "audio_clkout_a"; + function = "audio_clk"; + }; + + sound_pins: sound { + groups = "ssi01239_ctrl", "ssi0_data", "ssi1_data_a"; + function = "ssi"; + }; +}; + +&rcar_sound { + pinctrl-0 = <&sound_pins &sound_clk_pins>; + pinctrl-names = "default"; + status = "okay"; + + /* Single DAI */ + #sound-dai-cells = <0>; + + /* audio_clkout0/1/2/3 */ + #clock-cells = <1>; + clock-frequency = <12288000 11289600>; + + /* update <audio_clk_b> to <cs2000> */ + clocks = <&cpg CPG_MOD 1005>, + <&cpg CPG_MOD 1006>, <&cpg CPG_MOD 1007>, + <&cpg CPG_MOD 1008>, <&cpg CPG_MOD 1009>, + <&cpg CPG_MOD 1010>, <&cpg CPG_MOD 1011>, + <&cpg CPG_MOD 1012>, <&cpg CPG_MOD 1013>, + <&cpg CPG_MOD 1014>, <&cpg CPG_MOD 1015>, + <&cpg CPG_MOD 1022>, <&cpg CPG_MOD 1023>, + <&cpg CPG_MOD 1024>, <&cpg CPG_MOD 1025>, + <&cpg CPG_MOD 1026>, <&cpg CPG_MOD 1027>, + <&cpg CPG_MOD 1028>, <&cpg CPG_MOD 1029>, + <&cpg CPG_MOD 1030>, <&cpg CPG_MOD 1031>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1020>, <&cpg CPG_MOD 1021>, + <&cpg CPG_MOD 1019>, <&cpg CPG_MOD 1018>, + <&audio_clk_a>, <&cs2000>, + <&audio_clk_c>, + <&cpg CPG_CORE CPG_AUDIO_CLK_I>; + + rsnd_port: port { + rsnd_endpoint: endpoint { + remote-endpoint = <&dw_hdmi0_snd_in>; + + dai-format = "i2s"; + bitclock-master = <&rsnd_endpoint>; + frame-master = <&rsnd_endpoint>; + + playback = <&ssi2>; + }; + }; +}; diff --git a/arch/arm/dts/hihope-rzg2-ex.dtsi b/arch/arm/dts/hihope-rzg2-ex.dtsi new file mode 100644 index 0000000000..73dd14245f --- /dev/null +++ b/arch/arm/dts/hihope-rzg2-ex.dtsi @@ -0,0 +1,92 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the RZ/G2[HMN] HiHope sub board common parts + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +/ { + aliases { + ethernet0 = &avb; + }; + + chosen { + bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; + }; +}; + +&avb { + pinctrl-0 = <&avb_pins>; + pinctrl-names = "default"; + phy-handle = <&phy0>; + phy-mode = "rgmii-txid"; + status = "okay"; + + phy0: ethernet-phy@0 { + reg = <0>; + interrupt-parent = <&gpio2>; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; + reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>; + }; +}; + +&can0 { + pinctrl-0 = <&can0_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + +&can1 { + pinctrl-0 = <&can1_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + +&pciec0 { + status = "okay"; +}; + +&pfc { + pinctrl-0 = <&scif_clk_pins>; + pinctrl-names = "default"; + + avb_pins: avb { + mux { + groups = "avb_link", "avb_mdio", "avb_mii"; + function = "avb"; + }; + + pins_mdio { + groups = "avb_mdio"; + drive-strength = <24>; + }; + + pins_mii_tx { + pins = "PIN_AVB_TX_CTL", "PIN_AVB_TXC", "PIN_AVB_TD0", + "PIN_AVB_TD1", "PIN_AVB_TD2", "PIN_AVB_TD3"; + drive-strength = <12>; + }; + }; + + can0_pins: can0 { + groups = "can0_data_a"; + function = "can0"; + }; + + can1_pins: can1 { + groups = "can1_data"; + function = "can1"; + }; + + pwm0_pins: pwm0 { + groups = "pwm0"; + function = "pwm0"; + }; +}; + +&pwm0 { + pinctrl-0 = <&pwm0_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts b/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts new file mode 100644 index 0000000000..a5ca86196a --- /dev/null +++ b/arch/arm/dts/r8a774a1-hihope-rzg2m-ex.dts @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2M Rev.3.0/4.0 connected to + * sub board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +#include "r8a774a1-hihope-rzg2m.dts" +#include "hihope-rzg2-ex.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2M with sub board"; + compatible = "hoperun,hihope-rzg2-ex", "hoperun,hihope-rzg2m", + "renesas,r8a774a1"; +}; + +/* SW43 should be OFF, if in ON state SATA port will be activated */ +&pciec1 { + status = "okay"; +}; diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dts b/arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dts new file mode 100644 index 0000000000..4881801eea --- /dev/null +++ b/arch/arm/dts/r8a774a1-hihope-rzg2m-u-boot.dts @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot for the Hihope RZ/G2M board + * + * Copyright (C) 2020 Renesas Electronics Corporation + */ + +#include "r8a774a1-hihope-rzg2m-ex.dts" +#include "r8a774a1-u-boot.dtsi" + +&gpio3 { + bt_reg_on{ + gpio-hog; + gpios = <13 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "bt-reg-on"; + }; +}; + +&gpio4 { + wlan_reg_on{ + gpio-hog; + gpios = <6 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "wlan-reg-on"; + }; +}; diff --git a/arch/arm/dts/r8a774a1-hihope-rzg2m.dts b/arch/arm/dts/r8a774a1-hihope-rzg2m.dts new file mode 100644 index 0000000000..25ae255de0 --- /dev/null +++ b/arch/arm/dts/r8a774a1-hihope-rzg2m.dts @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for the HiHope RZ/G2M Rev.3.0/4.0 main board + * + * Copyright (C) 2020 Renesas Electronics Corp. + */ + +/dts-v1/; +#include "r8a774a1.dtsi" +#include "hihope-rev4.dtsi" + +/ { + model = "HopeRun HiHope RZ/G2M main board based on r8a774a1"; + compatible = "hoperun,hihope-rzg2m", "renesas,r8a774a1"; + + memory@48000000 { + device_type = "memory"; + /* first 128MB is reserved for secure area. */ + reg = <0x0 0x48000000 0x0 0x78000000>; + }; + + memory@600000000 { + device_type = "memory"; + reg = <0x6 0x00000000 0x0 0x80000000>; + }; +}; + +&du { + clocks = <&cpg CPG_MOD 724>, + <&cpg CPG_MOD 723>, + <&cpg CPG_MOD 722>, + <&versaclock5 1>, + <&x302_clk>, + <&versaclock5 2>; + clock-names = "du.0", "du.1", "du.2", + "dclkin.0", "dclkin.1", "dclkin.2"; +}; diff --git a/arch/arm/dts/r8a774a1-u-boot.dtsi b/arch/arm/dts/r8a774a1-u-boot.dtsi new file mode 100644 index 0000000000..86be1af351 --- /dev/null +++ b/arch/arm/dts/r8a774a1-u-boot.dtsi @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source extras for U-Boot on RZ/G2 R8A774A1 SoC + * + * Copyright (C) 2020 Renesas Electronics Corporation + */ + +#include "r8a779x-u-boot.dtsi" + +&extalr_clk { + u-boot,dm-pre-reloc; +}; + +/delete-node/ &audma0; +/delete-node/ &audma1; +/delete-node/ &can0; +/delete-node/ &can1; +/delete-node/ &canfd; +/delete-node/ &csi20; +/delete-node/ &csi40; +/delete-node/ &du; +/delete-node/ &fcpf0; +/delete-node/ &fcpvb0; +/delete-node/ &fcpvd0; +/delete-node/ &fcpvd1; +/delete-node/ &fcpvd2; +/delete-node/ &fcpvi0; +/delete-node/ &hdmi0; +/delete-node/ &lvds0; +/delete-node/ &rcar_sound; +/delete-node/ &sdhi2; +/delete-node/ &sound_card; +/delete-node/ &vin0; +/delete-node/ &vin1; +/delete-node/ &vin2; +/delete-node/ &vin3; +/delete-node/ &vin4; +/delete-node/ &vin5; +/delete-node/ &vin6; +/delete-node/ &vin7; +/delete-node/ &vspb; +/delete-node/ &vspd0; +/delete-node/ &vspd1; +/delete-node/ &vspd2; +/delete-node/ &vspi0; + +/ { + /delete-node/ hdmi0-out; +}; + +/ { + soc { + /delete-node/ fdp1@fe940000; + }; +}; diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index 0d55b74c42..6b815b9fb4 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -4,6 +4,8 @@ menu "Select Target SoC"
config R8A774A1 bool "Renesas SoC R8A774A1" + imply CLK_R8A774A1 + imply PINCTRL_PFC_R8A774A1
config R8A774B1 bool "Renesas SoC R8A774B1" @@ -81,6 +83,15 @@ config TARGET_EBISU help Support for Renesas R-Car Gen3 Ebisu platform
+config TARGET_HIHOPE_RZG2 + bool "HiHope RZ/G2 board" + imply R8A774A1 + imply SYS_MALLOC_F + imply MULTI_DTB_FIT + imply MULTI_DTB_FIT_USER_DEFINED_AREA + help + Support for RZG2 HiHope platform + config TARGET_SALVATOR_X bool "Salvator-X board" imply R8A7795 @@ -115,12 +126,15 @@ source "board/renesas/ebisu/Kconfig" source "board/renesas/salvator-x/Kconfig" source "board/renesas/ulcb/Kconfig" source "board/beacon/beacon-rzg2m/Kconfig" +source "board/hoperun/hihope-rzg2/Kconfig"
config MULTI_DTB_FIT_UNCOMPRESS_SZ + default 0x80000 if TARGET_HIHOPE_RZG2 default 0x80000 if TARGET_SALVATOR_X default 0x80000 if TARGET_ULCB
config MULTI_DTB_FIT_USER_DEF_ADDR + default 0x49000000 if TARGET_HIHOPE_RZG2 default 0x49000000 if TARGET_SALVATOR_X default 0x49000000 if TARGET_ULCB
diff --git a/board/hoperun/hihope-rzg2/Kconfig b/board/hoperun/hihope-rzg2/Kconfig new file mode 100644 index 0000000000..ee422ba6c8 --- /dev/null +++ b/board/hoperun/hihope-rzg2/Kconfig @@ -0,0 +1,15 @@ +if TARGET_HIHOPE_RZG2 + +config SYS_SOC + default "rmobile" + +config SYS_BOARD + default "hihope-rzg2" + +config SYS_VENDOR + default "hoperun" + +config SYS_CONFIG_NAME + default "hihope-rzg2" + +endif diff --git a/board/hoperun/hihope-rzg2/MAINTAINERS b/board/hoperun/hihope-rzg2/MAINTAINERS new file mode 100644 index 0000000000..e3702fd12e --- /dev/null +++ b/board/hoperun/hihope-rzg2/MAINTAINERS @@ -0,0 +1,6 @@ +HIHOPE_RZG2 BOARD +M: Biju Das biju.das.jz@bp.renesas.com +S: Maintained +F: board/hoperun/hihope-rzg2/ +F: include/configs/hihope-rzg2.h +F: configs/hihope_rzg2_defconfig diff --git a/board/hoperun/hihope-rzg2/Makefile b/board/hoperun/hihope-rzg2/Makefile new file mode 100644 index 0000000000..44f5da227c --- /dev/null +++ b/board/hoperun/hihope-rzg2/Makefile @@ -0,0 +1,9 @@ +# +# board/hoperun/hihope-rzg2/Makefile +# +# Copyright (C) 2020 Renesas Electronics Corporation +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := hihope-rzg2.o ../../renesas/rcar-common/common.o diff --git a/board/hoperun/hihope-rzg2/hihope-rzg2.c b/board/hoperun/hihope-rzg2/hihope-rzg2.c new file mode 100644 index 0000000000..5a26764359 --- /dev/null +++ b/board/hoperun/hihope-rzg2/hihope-rzg2.c @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * board/hoperun/hihope-rzg2/hihope-rzg2.c + * This file is HiHope RZ/G2M board support. + * + * Copyright (C) 2020 Renesas Electronics Corporation + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/libfdt.h> + +#define RST_BASE 0xE6160000 +#define RST_CA57RESCNT (RST_BASE + 0x40) +#define RST_CA53RESCNT (RST_BASE + 0x44) +#define RST_CA57_CODE 0xA5A5000F +#define RST_CA53_CODE 0x5A5A000F + +DECLARE_GLOBAL_DATA_PTR; +#define HSUSB_MSTP704 BIT(4) /* HSUSB */ + +/* HSUSB block registers */ +#define HSUSB_REG_LPSTS 0xE6590102 +#define HSUSB_REG_LPSTS_SUSPM_NORMAL BIT(14) +#define HSUSB_REG_UGCTRL2 0xE6590184 +#define HSUSB_REG_UGCTRL2_USB0SEL_EHCI 0x10 +#define HSUSB_REG_UGCTRL2_RESERVED_3 0x1 /* bit[3:0] should be B'0001 */ + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_TEXT_BASE + 0x50000; + + /* Configure the HSUSB block */ + mstp_clrbits_le32(SMSTPCR7, SMSTPCR7, HSUSB_MSTP704); + udelay(2); + /* Select EHCI/OHCI host module for USB2.0 ch0 */ + writel(HSUSB_REG_UGCTRL2_USB0SEL_EHCI | HSUSB_REG_UGCTRL2_RESERVED_3, + HSUSB_REG_UGCTRL2); + /* low power status */ + setbits_le16(HSUSB_REG_LPSTS, HSUSB_REG_LPSTS_SUSPM_NORMAL); + + return 0; +} + +void reset_cpu(ulong addr) +{ + unsigned long midr, cputype; + + asm volatile("mrs %0, midr_el1" : "=r" (midr)); + cputype = (midr >> 4) & 0xfff; + + if (cputype == 0xd03) + writel(RST_CA53_CODE, RST_CA53RESCNT); + else + writel(RST_CA57_CODE, RST_CA57RESCNT); +} + +#if defined(CONFIG_MULTI_DTB_FIT) +int board_fit_config_name_match(const char *name) +{ + /* PRR driver is not available yet */ + u32 cpu_type = rmobile_get_cpu_type(); + + if (cpu_type == RMOBILE_CPU_TYPE_R8A774A1 && + !strcmp(name, "r8a774a1-hihope-rzg2m-u-boot")) + return 0; + + return -1; +} +#endif diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig new file mode 100644 index 0000000000..40bdd7d86e --- /dev/null +++ b/configs/hihope_rzg2_defconfig @@ -0,0 +1,75 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_RMOBILE=y +CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xFFFE0000 +CONFIG_DM_GPIO=y +CONFIG_GPIO_HOG=y +CONFIG_RCAR_GEN3=y +CONFIG_TARGET_HIHOPE_RZG2=y +# CONFIG_BOARD_EARLY_INIT_F is not set +# CONFIG_SPL is not set +CONFIG_DEFAULT_DEVICE_TREE="r8a774a1-hihope-rzg2m-u-boot" +CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_FIT=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_DEFAULT_FDT_FILE="r8a774a1-hihope-rzg2m.dtb" +CONFIG_VERSION_VARIABLE=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="r8a774a1-hihope-rzg2m-u-boot" +CONFIG_MULTI_DTB_FIT_LZO=y +CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +CONFIG_CLK_RENESAS=y +CONFIG_RCAR_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_RCAR_I2C=y +CONFIG_SYS_I2C_RCAR_IIC=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_RENESAS_SDHI=y +CONFIG_BITBANGMII=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_RENESAS_RAVB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_SCIF_CONSOLE=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SMBIOS_MANUFACTURER="" diff --git a/include/configs/hihope-rzg2.h b/include/configs/hihope-rzg2.h new file mode 100644 index 0000000000..68a51176e3 --- /dev/null +++ b/include/configs/hihope-rzg2.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * include/configs/hihope-rzg2.h + * This file is HOPERUN HiHope RZ/G2 board configuration. + * + * Copyright (C) 2020 Renesas Electronics Corporation + */ + +#ifndef __HIHOPE_RZG2_H +#define __HIHOPE_RZG2_H + +#include "rcar-gen3-common.h" + +/* Ethernet RAVB */ +#define CONFIG_BITBANGMII_MULTI + +/* Generic Timer Definitions (use in assembler source) */ +#define COUNTER_FREQUENCY 0xFE502A /* 16.66MHz from CPclk */ + +#endif /* __HIHOPE_RZG2_H */
Biju Das
