[PATCH] spl: ymodem: Fix buffer overflow during Image copy
ymodem_read_fit() driver will end copying up to BUF_SIZE boundary even when requested size of copy operation is less than that. For example, if offset = 0, size = 1440B, ymodem_read_fit() ends up copying 2KB from offset = 0, to destination buffer addr
This causes data corruption when malloc'd buffer is passed during UART boot since commit 03f1f78a9b44 ("spl: fit: Prefer a malloc()'d buffer for loading images")
With this, UART boot works again on K3 (AM654, J7, AM64) family of devices.
Fixes: 03f1f78a9b44 ("spl: fit: Prefer a malloc()'d buffer for loading images") Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- common/spl/spl_ymodem.c | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_ymodem.c b/common/spl/spl_ymodem.c index 047df74856..fdd5261042 100644 --- a/common/spl/spl_ymodem.c +++ b/common/spl/spl_ymodem.c @@ -42,6 +42,7 @@ static ulong ymodem_read_fit(struct spl_load_info *load, ulong offset, int res, err, buf_offset; struct ymodem_fit_info *info = load->priv; char *buf = info->buf; + ulong copy_size = size;
while (info->image_read < offset) { res = xyzModem_stream_read(buf, BUF_SIZE, &err); @@ -57,8 +58,14 @@ static ulong ymodem_read_fit(struct spl_load_info *load, ulong offset, buf_offset = (info->image_read % BUF_SIZE); else buf_offset = BUF_SIZE; + + if (res > copy_size) { + memcpy(addr, &buf[buf_offset - res], copy_size); + goto done; + } memcpy(addr, &buf[buf_offset - res], res); addr = addr + res; + copy_size -= res; }
while (info->image_read < offset + size) { @@ -66,11 +73,17 @@ static ulong ymodem_read_fit(struct spl_load_info *load, ulong offset, if (res <= 0) break;
- memcpy(addr, buf, res); info->image_read += res; + if (res > copy_size) { + memcpy(addr, buf, copy_size); + goto done; + } + memcpy(addr, buf, res); addr += res; + copy_size -= res; }
+done: return size; }
Vignesh Raghavendra
