Please pull u-boot-marvell/master
Hi Tom,
please pull the next batch of Marvell MVEBU related patches. Here the summary log:
---------------------------------------------------------------- - Convert GoFlex Home Ethernet and SATA to Driver Model (Tony) - mvebu: Automatically detect CONFIG_SYS_TCLK (Pavel) - mvebu: sata_mv: Fix HDD identication during cold start (Tony) - a37xx: pci: Fix handling PIO config error responses (Pavel) - Other minor misc changes and board maintainer updates ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=106&view=resu...
Thanks, Stefan
The following changes since commit 3e5b62f78888740530e6f3a2e989f4c361a9d52b:
configs: Resync with savedefconfig (2021-08-10 15:08:46 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to e21c74f24be5b6d0387d79cb8cf66de0b9b6b0d3:
arm: kirkwood: Goflex Home: Update board maintainer (2021-08-11 08:42:26 +0200)
---------------------------------------------------------------- Pali Rohár (7): arm: mvebu: a38x: Detect CONFIG_SYS_TCLK from SAR register arm: mvebu: a37x: Detect CONFIG_SYS_TCLK from SAR register arm: mvebu: msys: Set CONFIG_SYS_TCLK globally arm: mvebu: axp: Set CONFIG_SYS_TCLK globally arm: kirkwood: Do not overwrite CONFIG_SYS_TCLK arm: a37xx: pci: Fix handling PIO config error responses arm: mvebu: Hang if ddr3_init() fails
Tony Dinh (6): arm: kirkwood: GoFlex Home: Add DM Ethernet, remove IDE, and add DM SATA configs arm: kirkwood: GoFlex Home: Add DM SATA configs arm: kirkwood: GoFlex Home: Use Ethernet PHY name and address from device tree arm: mvebu: sata_mv failed to identify HDDs during cold start arm: kirkwood: Dockstar: Update board maintainer arm: kirkwood: Goflex Home: Update board maintainer
arch/arm/mach-kirkwood/include/mach/kw88f6281.h | 2 - arch/arm/mach-mvebu/include/mach/soc.h | 15 ++++--- arch/arm/mach-mvebu/spl.c | 6 ++- board/Seagate/dockstar/MAINTAINERS | 2 +- board/Seagate/goflexhome/MAINTAINERS | 2 +- board/Seagate/goflexhome/goflexhome.c | 57 +++++++++++++++++++------ configs/goflexhome_defconfig | 5 ++- drivers/ata/sata_mv.c | 29 ++++++++++++- drivers/pci/pci-aardvark.c | 52 +++++++++++----------- include/configs/clearfog.h | 1 - include/configs/controlcenterdc.h | 2 - include/configs/crs3xx-98dx3236.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 2 - include/configs/db-88f6820-gp.h | 2 - include/configs/db-mv784mp-gp.h | 1 - include/configs/db-xc3-24g4xg.h | 1 - include/configs/ds414.h | 1 - include/configs/goflexhome.h | 6 +++ include/configs/helios4.h | 1 - include/configs/lacie_kw.h | 5 --- include/configs/lsxl.h | 2 - include/configs/maxbcm.h | 1 - include/configs/theadorable.h | 1 - include/configs/turris_omnia.h | 1 - include/configs/x530.h | 2 - 26 files changed, 125 insertions(+), 76 deletions(-)
Stefan Roese
