[U-Boot] [PATCH v3 1/4] Add support new arch: c6x
C6X (C6000) is Texas Instruments architecture of fixed and floating-point DSPs. This patch add basic support. Many of code in arch/c6x/include/asm come from c6x-linux project (http://linux-c6x.org)
Signed-off-by: Dmitry Bondar bond@inmys.ru Cc: Tom Rini trini@ti.com --- arch/c6x/config.mk | 1 + arch/c6x/include/asm/bitops.h | 88 ++++++++ arch/c6x/include/asm/byteorder.h | 1 + arch/c6x/include/asm/cache.h | 29 +++ arch/c6x/include/asm/config.h | 3 + arch/c6x/include/asm/errno.h | 1 + arch/c6x/include/asm/global_data.h | 96 +++++++++ arch/c6x/include/asm/gpio.h | 2 + arch/c6x/include/asm/io.h | 68 ++++++ arch/c6x/include/asm/posix_types.h | 72 +++++++ arch/c6x/include/asm/processor.h | 4 + arch/c6x/include/asm/ptrace.h | 310 +++++++++++++++++++++++++++ arch/c6x/include/asm/sizes.h | 51 +++++ arch/c6x/include/asm/string.h | 26 +++ arch/c6x/include/asm/types.h | 53 +++++ arch/c6x/include/asm/u-boot-c6x.h | 14 ++ arch/c6x/include/asm/u-boot.h | 57 +++++ arch/c6x/include/asm/unaligned.h | 1 + arch/c6x/lib/Makefile | 51 +++++ arch/c6x/lib/board.c | 196 +++++++++++++++++ arch/c6x/lib/bootm.c | 60 ++++++ arch/c6x/lib/csum_64plus.S | 408 ++++++++++++++++++++++++++++++++++++ arch/c6x/lib/delay.S | 39 ++++ arch/c6x/lib/divi.S | 54 +++++ arch/c6x/lib/divremi.S | 61 ++++++ arch/c6x/lib/divremu.S | 86 ++++++++ arch/c6x/lib/divu.S | 100 +++++++++ arch/c6x/lib/divull.c | 336 +++++++++++++++++++++++++++++ arch/c6x/lib/llshl.S | 36 ++++ arch/c6x/lib/llshr.S | 36 ++++ arch/c6x/lib/llshru.S | 36 ++++ arch/c6x/lib/memcmp.c | 24 ++ arch/c6x/lib/memcpy_64plus.S | 45 ++++ arch/c6x/lib/memmove.c | 30 +++ arch/c6x/lib/memset.c | 20 ++ arch/c6x/lib/mpyll.S | 47 ++++ arch/c6x/lib/negll.S | 29 +++ arch/c6x/lib/pop_rts.S | 30 +++ arch/c6x/lib/push_rts.S | 28 +++ arch/c6x/lib/remi.S | 78 +++++++ arch/c6x/lib/remu.S | 81 +++++++ arch/c6x/lib/strasgi.S | 88 ++++++++ arch/c6x/lib/strasgi_64plus.S | 37 ++++ arch/c6x/lib/unaligned.S | 117 ++++++++++ common/cmd_bdinfo.c | 5 + common/image.c | 4 + examples/standalone/stubs.c | 15 ++ 47 files changed, 3054 insertions(+), 0 deletions(-) create mode 100644 arch/c6x/config.mk create mode 100644 arch/c6x/include/asm/bitops.h create mode 100644 arch/c6x/include/asm/byteorder.h create mode 100644 arch/c6x/include/asm/cache.h create mode 100644 arch/c6x/include/asm/config.h create mode 100644 arch/c6x/include/asm/errno.h create mode 100644 arch/c6x/include/asm/global_data.h create mode 100644 arch/c6x/include/asm/gpio.h create mode 100644 arch/c6x/include/asm/io.h create mode 100644 arch/c6x/include/asm/posix_types.h create mode 100644 arch/c6x/include/asm/processor.h create mode 100644 arch/c6x/include/asm/ptrace.h create mode 100644 arch/c6x/include/asm/sizes.h create mode 100644 arch/c6x/include/asm/string.h create mode 100644 arch/c6x/include/asm/types.h create mode 100644 arch/c6x/include/asm/u-boot-c6x.h create mode 100644 arch/c6x/include/asm/u-boot.h create mode 100644 arch/c6x/include/asm/unaligned.h create mode 100644 arch/c6x/lib/Makefile create mode 100644 arch/c6x/lib/board.c create mode 100644 arch/c6x/lib/bootm.c create mode 100644 arch/c6x/lib/csum_64plus.S create mode 100644 arch/c6x/lib/delay.S create mode 100644 arch/c6x/lib/divi.S create mode 100644 arch/c6x/lib/divremi.S create mode 100644 arch/c6x/lib/divremu.S create mode 100644 arch/c6x/lib/divu.S create mode 100644 arch/c6x/lib/divull.c create mode 100644 arch/c6x/lib/llshl.S create mode 100644 arch/c6x/lib/llshr.S create mode 100644 arch/c6x/lib/llshru.S create mode 100644 arch/c6x/lib/memcmp.c create mode 100644 arch/c6x/lib/memcpy_64plus.S create mode 100644 arch/c6x/lib/memmove.c create mode 100644 arch/c6x/lib/memset.c create mode 100644 arch/c6x/lib/mpyll.S create mode 100644 arch/c6x/lib/negll.S create mode 100644 arch/c6x/lib/pop_rts.S create mode 100644 arch/c6x/lib/push_rts.S create mode 100644 arch/c6x/lib/remi.S create mode 100644 arch/c6x/lib/remu.S create mode 100644 arch/c6x/lib/strasgi.S create mode 100644 arch/c6x/lib/strasgi_64plus.S create mode 100644 arch/c6x/lib/unaligned.S
diff --git a/arch/c6x/config.mk b/arch/c6x/config.mk new file mode 100644 index 0000000..9cbddbc --- /dev/null +++ b/arch/c6x/config.mk @@ -0,0 +1 @@ +CROSS_COMPILE ?= c6x-uclinux- diff --git a/arch/c6x/include/asm/bitops.h b/arch/c6x/include/asm/bitops.h new file mode 100644 index 0000000..5896b5e --- /dev/null +++ b/arch/c6x/include/asm/bitops.h @@ -0,0 +1,88 @@ +/* + * linux/include/asm-c6x/bitops.h + * + * Port on Texas Instruments TMS320C6x architecture + * + * Copyright (C) 2004, 2009, 2010 Texas Instruments Incorporated + * Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#ifndef __ASM_C6X_BITOPS_H_ +#define __ASM_C6X_BITOPS_H_ + +#ifdef __KERNEL__ + +#include <linux/bitops.h> +#include <asm/byteorder.h> + +/* + * We are lucky, DSP is perfect for bitops: do it in 3 cycles + */ + +/** + * __ffs - find first bit in word. + * @word: The word to search + * + * Undefined if no bit exists, so code should check against 0 first. + * Note __ffs(0) = undef, __ffs(1) = 0, __ffs(0x80000000) = 31. + * + */ +static inline unsigned long __ffs(unsigned long x) +{ + asm (" bitr .M1 %0,%0\n" + " nop\n" + " lmbd .L1 1,%0,%0\n" + : "+a"(x)); + + return x; +} + +/* + * ffz - find first zero in word. + * @word: The word to search + * + * Undefined if no zero exists, so code should check against ~0UL first. + */ +#define ffz(x) __ffs(~(x)) + +/** + * fls - find last (most-significant) bit set + * @x: the word to search + * + * This is defined the same way as ffs. + * Note fls(0) = 0, fls(1) = 1, fls(0x80000000) = 32. + */ +static inline unsigned long fls(unsigned long x) +{ + if (!x) + return 0; + + asm (" lmbd .L1 1,%0,%0\n" : "+a"(x)); + + return 32 - x; +} + +/** + * ffs - find first bit set + * @x: the word to search + * + * This is defined the same way as + * the libc and compiler builtin ffs routines, therefore + * differs in spirit from the above ffz (man ffs). + * Note ffs(0) = 0, ffs(1) = 1, ffs(0x80000000) = 32. + */ +static inline int ffs(int x) +{ + if (!x) + return 0; + + return __ffs(x) + 1; +} + +#define hweight8(x) generic_hweight8(x) + +#endif /* __KERNEL__ */ +#endif /* __ASM_C6X_BITOPS_H */ diff --git a/arch/c6x/include/asm/byteorder.h b/arch/c6x/include/asm/byteorder.h new file mode 100644 index 0000000..9558416 --- /dev/null +++ b/arch/c6x/include/asm/byteorder.h @@ -0,0 +1 @@ +#include <linux/byteorder/little_endian.h> diff --git a/arch/c6x/include/asm/cache.h b/arch/c6x/include/asm/cache.h new file mode 100644 index 0000000..75b2043 --- /dev/null +++ b/arch/c6x/include/asm/cache.h @@ -0,0 +1,29 @@ +/* + * (C) Copyright 2011, Stefan Kristiansson stefan.kristiansson@saunalahti.fi + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_C6X_CACHE_H_ +#define __ASM_C6X_CACHE_H_ + +#ifdef CONFIG_SYS_CACHELINE_SIZE +#define ARCH_DMA_MINALIGN CONFIG_SYS_CACHELINE_SIZE +#else +#define ARCH_DMA_MINALIGN 128 +#endif + +#endif /* __ASM_C6X_CACHE_H_ */ diff --git a/arch/c6x/include/asm/config.h b/arch/c6x/include/asm/config.h new file mode 100644 index 0000000..db59e8a --- /dev/null +++ b/arch/c6x/include/asm/config.h @@ -0,0 +1,3 @@ +#ifndef _ASM_CONFIG_H_ +#define _ASM_CONFIG_H_ +#endif diff --git a/arch/c6x/include/asm/errno.h b/arch/c6x/include/asm/errno.h new file mode 100644 index 0000000..4c82b50 --- /dev/null +++ b/arch/c6x/include/asm/errno.h @@ -0,0 +1 @@ +#include <asm-generic/errno.h> diff --git a/arch/c6x/include/asm/global_data.h b/arch/c6x/include/asm/global_data.h new file mode 100644 index 0000000..a8e0766 --- /dev/null +++ b/arch/c6x/include/asm/global_data.h @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2002-2010 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __ASM_GBL_DATA_H +#define __ASM_GBL_DATA_H +/* + * The following data structure is placed in some memory which is + * available very early after boot (like DPRAM on MPC8xx/MPC82xx, or + * some locked parts of the data cache) to allow for a minimum set of + * global variables during system initialization (until we have set + * up the memory controller so that we can use RAM). + * + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) + */ + +typedef struct global_data { + bd_t *bd; + unsigned long flags; + unsigned long baudrate; + unsigned long have_console; /* serial_init() was called */ +#ifdef CONFIG_PRE_CONSOLE_BUFFER + unsigned long precon_buf_idx; /* Pre-Console buffer index */ +#endif + unsigned long env_addr; /* Address of Environment struct */ + unsigned long env_valid; /* Checksum of Environment valid? */ + unsigned long fb_base; /* base address of frame buffer */ + + /* "static data" needed by most of timer.c (like on ARM platform) */ + unsigned long timer_rate_hz; + unsigned long tbl; + unsigned long tbu; + unsigned long long timer_reset_value; + unsigned long lastinc; + + phys_size_t ram_size; /* RAM size */ +#if 0 + unsigned long relocaddr; /* Start address of U-Boot in RAM */ + phys_size_t ram_size; /* RAM size */ + unsigned long mon_len; /* monitor len */ + unsigned long irq_sp; /* irq stack pointer */ + unsigned long start_addr_sp; /* start_addr_stackpointer */ + unsigned long reloc_off; +#endif + + void **jt; /* jump table */ + char env_buf[32]; /* buffer for getenv() before reloc. */ +#if defined(CONFIG_POST) || defined(CONFIG_LOGBUFFER) + unsigned long post_log_word; /* Record POST activities */ + unsigned long post_log_res; /* success of POST test */ + unsigned long post_init_f_time; /* When post_init_f started */ +#endif +} gd_t; + +/* + * Global Data Flags + */ +/* Code was relocated to RAM */ +#define GD_FLG_RELOC 0x00001 +/* Devices have been initialized */ +#define GD_FLG_DEVINIT 0x00002 +/* Silent mode */ +#define GD_FLG_SILENT 0x00004 +/* Critical POST test failed */ +#define GD_FLG_POSTFAIL 0x00008 +/* POST seqeunce aborted */ +#define GD_FLG_POSTSTOP 0x00010 +/* Log Buffer has been initialized */ +#define GD_FLG_LOGINIT 0x00020 +/* Disable console (in & out) */ +#define GD_FLG_DISABLE_CONSOLE 0x00040 +/* Environment imported into hash table */ +#define GD_FLG_ENV_READY 0x00080 + +#define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("B31") + +#endif /* __ASM_GBL_DATA_H */ diff --git a/arch/c6x/include/asm/gpio.h b/arch/c6x/include/asm/gpio.h new file mode 100644 index 0000000..d49ad08 --- /dev/null +++ b/arch/c6x/include/asm/gpio.h @@ -0,0 +1,2 @@ +#include <asm/arch/gpio.h> +#include <asm-generic/gpio.h> diff --git a/arch/c6x/include/asm/io.h b/arch/c6x/include/asm/io.h new file mode 100644 index 0000000..7c4ab87 --- /dev/null +++ b/arch/c6x/include/asm/io.h @@ -0,0 +1,68 @@ +/* + * linux/include/asm-c6x/io.h + * + * Port on Texas Instruments TMS320C6x architecture + * + * Copyright (C) 2004, 2009, 2010, 2011 Texas Instruments Incorporated + * Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#define __arch_getb(a) (*(volatile unsigned char *)(a)) +#define __arch_getw(a) (*(volatile unsigned short *)(a)) +#define __arch_getl(a) (*(volatile unsigned int *)(a)) + +#define __arch_putb(v, a) (*(volatile unsigned char *)(a) = (v)) +#define __arch_putw(v, a) (*(volatile unsigned short *)(a) = (v)) +#define __arch_putl(v, a) (*(volatile unsigned int *)(a) = (v)) + +#define __raw_writeb(v, a) __arch_putb(v, a) +#define __raw_writew(v, a) __arch_putw(v, a) +#define __raw_writel(v, a) __arch_putl(v, a) + +#define __raw_readb(a) __arch_getb(a) +#define __raw_readw(a) __arch_getw(a) +#define __raw_readl(a) __arch_getl(a) + +#define dmb() __asm__ __volatile__ ("" : : : "memory") +#define __iormb() dmb() +#define __iowmb() dmb() + +#define writeb(v, c) ({ u8 __v = v; __iowmb(); __arch_putb(__v, c); __v; }) +#define writew(v, c) ({ u16 __v = v; __iowmb(); __arch_putw(__v, c); __v; }) +#define writel(v, c) ({ u32 __v = v; __iowmb(); __arch_putl(__v, c); __v; }) + +#define readb(c) ({ u8 __v = __arch_getb(c); __iormb(); __v; }) +#define readw(c) ({ u16 __v = __arch_getw(c); __iormb(); __v; }) +#define readl(c) ({ u32 __v = __arch_getl(c); __iormb(); __v; }) + + +#define in_le16(addr) \ + ({ \ + unsigned short __v = le16_to_cpu(readw(addr)); \ + __v; \ + }) +#define in_le32(addr) \ + ({ \ + unsigned int __v = le32_to_cpu(readl(addr)); \ + __v; \ + }) +#define out_le16(addr, w) (writew(cpu_to_le16(w), addr)) +#define out_le32(addr, l) (writel(cpu_to_le32(l), addr)) + +#define clrbits(type, addr, clear) \ + out_##type((addr), in_##type(addr) & ~(clear)) + +#define setbits(type, addr, set) \ + out_##type((addr), in_##type(addr) | (set)) + +#define clrsetbits(type, addr, clear, set) \ + out_##type((addr), (in_##type(addr) & ~(clear)) | (set)) + +#define clrbits_le32(addr, clear) clrbits(le32, addr, clear) +#define setbits_le32(addr, set) setbits(le32, addr, set) +#define clrsetbits_le32(addr, clear, set) clrsetbits(le32, addr, clear, set) + diff --git a/arch/c6x/include/asm/posix_types.h b/arch/c6x/include/asm/posix_types.h new file mode 100644 index 0000000..d1fffe0 --- /dev/null +++ b/arch/c6x/include/asm/posix_types.h @@ -0,0 +1,72 @@ +/* + * Based on microblaze implementation: + * Copyright (C) 2003 John Williams jwilliams@itee.uq.edu.au + * Copyright (C) 2001,2002 NEC Corporation + * Copyright (C) 2001,2002 Miles Bader miles@gnu.org + * + * This file is subject to the terms and conditions of the GNU General + * Public License. See the file COPYING in the main directory of this + * archive for more details. + * + * Written by Miles Bader miles@gnu.org + * Microblaze port by John Williams + */ + +#ifndef __ASM_OPENRISC_POSIX_TYPES_H +#define __ASM_OPENRISC_POSIX_TYPES_H + +typedef unsigned int __kernel_dev_t; +typedef unsigned long __kernel_ino_t; +typedef unsigned long long __kernel_ino64_t; +typedef unsigned int __kernel_mode_t; +typedef unsigned int __kernel_nlink_t; +typedef long __kernel_off_t; +typedef long long __kernel_loff_t; +typedef int __kernel_pid_t; +typedef unsigned short __kernel_ipc_pid_t; +typedef unsigned int __kernel_uid_t; +typedef unsigned int __kernel_gid_t; +typedef unsigned int __kernel_size_t; +typedef int __kernel_ssize_t; +typedef int __kernel_ptrdiff_t; +typedef long __kernel_time_t; +typedef long __kernel_suseconds_t; +typedef long __kernel_clock_t; +typedef int __kernel_daddr_t; +typedef char *__kernel_caddr_t; +typedef unsigned short __kernel_uid16_t; +typedef unsigned short __kernel_gid16_t; +typedef unsigned int __kernel_uid32_t; +typedef unsigned int __kernel_gid32_t; + +typedef unsigned short __kernel_old_uid_t; +typedef unsigned short __kernel_old_gid_t; + + +typedef struct { +#if defined(__KERNEL__) || defined(__USE_ALL) + int val[2]; +#else /* !defined(__KERNEL__) && !defined(__USE_ALL) */ + int __val[2]; +#endif /* !defined(__KERNEL__) && !defined(__USE_ALL) */ +} __kernel_fsid_t; + + +#if defined(__KERNEL__) || !defined(__GLIBC__) || (__GLIBC__ < 2) + +#undef __FD_SET +#define __FD_SET(fd, fd_set) \ + __set_bit(fd, (void *)&((__kernel_fd_set *)fd_set)->fds_bits) +#undef __FD_CLR +#define __FD_CLR(fd, fd_set) \ + __clear_bit(fd, (void *)&((__kernel_fd_set *)fd_set)->fds_bits) +#undef __FD_ISSET +#define __FD_ISSET(fd, fd_set) \ + __test_bit(fd, (void *)&((__kernel_fd_set *)fd_set)->fds_bits) +#undef __FD_ZERO +#define __FD_ZERO(fd_set) \ + memset(fd_set, 0, sizeof(*(fd_set *)fd_set)) + +#endif /* defined(__KERNEL__) || !defined(__GLIBC__) || (__GLIBC__ < 2) */ + +#endif /* __ASM_OPENRISC_POSIX_TYPES_H */ diff --git a/arch/c6x/include/asm/processor.h b/arch/c6x/include/asm/processor.h new file mode 100644 index 0000000..ec98171 --- /dev/null +++ b/arch/c6x/include/asm/processor.h @@ -0,0 +1,4 @@ +#ifndef __ASM_C6X_PROCESSOR_H +#define __ASM_C6X_PROCESSOR_H + +#endif diff --git a/arch/c6x/include/asm/ptrace.h b/arch/c6x/include/asm/ptrace.h new file mode 100644 index 0000000..2eaeb11 --- /dev/null +++ b/arch/c6x/include/asm/ptrace.h @@ -0,0 +1,310 @@ +/* + * linux/include/asm-c6x/ptrace.h + * + * Port on Texas Instruments TMS320C6x architecture + * + * Copyright (C) 2004, 2006, 2009, 2010, 2011 Texas Instruments Incorporated + * Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) + * + * Updated for 2.6.34: Mark Salter msalter@redhat.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#ifndef __ASM_C6X_PTRACE_H +#define __ASM_C6X_PTRACE_H + +#if defined(__TMS320C6XPLUS__) || defined(_TMS320C6400_PLUS) \ + || defined(__TMS320C66X__) +#define BKPT_OPCODE 0x56454314 /* illegal opcode */ +#else +#define BKPT_OPCODE 0x0000a122 /* BNOP .S2 0,5 */ +#endif + +#ifdef _BIG_ENDIAN +#define PT_LO(odd, even) odd +#define PT_HI(odd, even) even +#else +#define PT_LO(odd, even) even +#define PT_HI(odd, even) odd +#endif + +#if defined(__TMS320C6XPLUS__) || defined(_TMS320C6400_PLUS) || \ + defined(__TMS320C66X__) + +#define PT_A4_ORG PT_LO(1, 0) +#define PT_TSR PT_HI(1, 0) +#define PT_ILC PT_LO(3, 2) +#define PT_RILC PT_HI(3, 2) +#define PT_CSR PT_LO(5, 4) +#define PT_PC PT_HI(5, 4) +#define PT_B16 PT_LO(7, 6) +#define PT_B17 PT_HI(7, 6) +#define PT_B18 PT_LO(9, 8) +#define PT_B19 PT_HI(9, 8) +#define PT_B20 PT_LO(11, 10) +#define PT_B21 PT_HI(11, 10) +#define PT_B22 PT_LO(13, 12) +#define PT_B23 PT_HI(13, 12) +#define PT_B24 PT_LO(15, 14) +#define PT_B25 PT_HI(15, 14) +#define PT_B26 PT_LO(17, 16) +#define PT_B27 PT_HI(17, 16) +#define PT_B28 PT_LO(19, 18) +#define PT_B29 PT_HI(19, 18) +#define PT_B30 PT_LO(21, 20) +#define PT_B31 PT_HI(21, 20) +#define PT_B0 PT_LO(23, 22) +#define PT_B1 PT_HI(23, 22) +#define PT_B2 PT_LO(25, 24) +#define PT_B3 PT_HI(25, 24) +#define PT_B4 PT_LO(27, 26) +#define PT_B5 PT_HI(27, 26) +#define PT_B6 PT_LO(29, 28) +#define PT_B7 PT_HI(29, 28) +#define PT_B8 PT_LO(31, 30) +#define PT_B9 PT_HI(31, 30) +#define PT_B10 PT_LO(33, 32) +#define PT_B11 PT_HI(33, 32) +#define PT_B12 PT_LO(35, 34) +#define PT_B13 PT_HI(35, 34) +#define PT_A16 PT_LO(37, 36) +#define PT_A17 PT_HI(37, 36) +#define PT_A18 PT_LO(39, 38) +#define PT_A19 PT_HI(39, 38) +#define PT_A20 PT_LO(41, 40) +#define PT_A21 PT_HI(41, 40) +#define PT_A22 PT_LO(43, 42) +#define PT_A23 PT_HI(43, 42) +#define PT_A24 PT_LO(45, 44) +#define PT_A25 PT_HI(45, 44) +#define PT_A26 PT_LO(47, 46) +#define PT_A27 PT_HI(47, 46) +#define PT_A28 PT_LO(49, 48) +#define PT_A29 PT_HI(49, 48) +#define PT_A30 PT_LO(51, 50) +#define PT_A31 PT_HI(51, 50) +#define PT_A0 PT_LO(53, 52) +#define PT_A1 PT_HI(53, 52) +#define PT_A2 PT_LO(55, 54) +#define PT_A3 PT_HI(55, 54) +#define PT_A4 PT_LO(57, 56) +#define PT_A5 PT_HI(57, 56) +#define PT_A6 PT_LO(59, 58) +#define PT_A7 PT_HI(59, 58) +#define PT_A8 PT_LO(61, 60) +#define PT_A9 PT_HI(61, 60) +#define PT_A10 PT_LO(63, 62) +#define PT_A11 PT_HI(63, 62) +#define PT_A12 PT_LO(65, 64) +#define PT_A13 PT_HI(65, 64) +#define PT_A14 PT_LO(67, 66) +#define PT_A15 PT_HI(67, 66) +#define PT_B14 PT_LO(69, 68) +#define PT_B15 PT_HI(69, 68) + +#else /* defined(__TMS320C6XPLUS__) */ + +#define PT_A4_ORG PT_LO(1, 0) +#define PT_STKADJ PT_HI(1, 0) +#define PT_CSR PT_LO(3, 2) +#define PT_PC PT_HI(3, 2) +#if defined(_TMS320C6400) +#define PT_B16 PT_LO(5, 4) +#define PT_B17 PT_HI(5, 4) +#define PT_B18 PT_LO(7, 6) +#define PT_B19 PT_HI(7, 6) +#define PT_B20 PT_LO(9, 8) +#define PT_B21 PT_HI(9, 8) +#define PT_B22 PT_LO(11, 10) +#define PT_B23 PT_HI(11, 10) +#define PT_B24 PT_LO(13, 12) +#define PT_B25 PT_HI(13, 12) +#define PT_B26 PT_LO(15, 14) +#define PT_B27 PT_HI(15, 14) +#define PT_B28 PT_LO(17, 16) +#define PT_B29 PT_HI(17, 16) +#define PT_B30 PT_LO(19, 18) +#define PT_B31 PT_HI(19, 18) +#endif /* defined(_TMS320C6400) */ +#define PT_B0 PT_LO(21, 20) +#define PT_B1 PT_HI(21, 20) +#define PT_B2 PT_LO(23, 22) +#define PT_B3 PT_HI(23, 22) +#define PT_B4 PT_LO(25, 24) +#define PT_B5 PT_HI(25, 24) +#define PT_B6 PT_LO(27, 26) +#define PT_B7 PT_HI(27, 26) +#define PT_B8 PT_LO(29, 28) +#define PT_B9 PT_HI(29, 28) +#define PT_B10 PT_LO(31, 30) +#define PT_B11 PT_HI(31, 30) +#define PT_B12 PT_LO(33, 32) +#define PT_B13 PT_HI(33, 32) +#if defined(_TMS320C6400) +#define PT_A16 PT_LO(35, 34) +#define PT_A17 PT_HI(35, 34) +#define PT_A18 PT_LO(37, 36) +#define PT_A19 PT_HI(37, 36) +#define PT_A20 PT_LO(39, 38) +#define PT_A21 PT_HI(39, 38) +#define PT_A22 PT_LO(41, 40) +#define PT_A23 PT_HI(41, 40) +#define PT_A24 PT_LO(43, 42) +#define PT_A25 PT_HI(43, 42) +#define PT_A26 PT_LO(45, 44) +#define PT_A27 PT_HI(45, 44) +#define PT_A28 PT_LO(47, 46) +#define PT_A29 PT_HI(47, 46) +#define PT_A30 PT_LO(49, 48) +#define PT_A31 PT_HI(49, 48) +#endif /* defined(_TMS320C6400) */ +#define PT_A0 PT_LO(51, 50) +#define PT_A1 PT_HI(51, 50) +#define PT_A2 PT_LO(53, 52) +#define PT_A3 PT_HI(53, 52) +#define PT_A4 PT_LO(55, 54) +#define PT_A5 PT_HI(55, 54) +#define PT_A6 PT_LO(57, 56) +#define PT_A7 PT_HI(57, 56) +#define PT_A8 PT_LO(59, 58) +#define PT_A9 PT_HI(59, 58) +#define PT_A10 PT_LO(61, 60) +#define PT_A11 PT_HI(61, 60) +#define PT_A12 PT_LO(63, 62) +#define PT_A13 PT_HI(63, 62) +#define PT_A14 PT_LO(65, 64) +#define PT_A15 PT_HI(65, 64) +#define PT_B14 PT_LO(67, 66) +#define PT_B15 PT_HI(67, 66) + +#endif /* defined(__TMS320C6XPLUS__) */ + +#define PT_DP PT_B14 /* Data Segment Pointer (B14) */ +#define PT_SP PT_B15 /* Stack Pointer (B15) */ + +#ifndef __ASSEMBLY__ + +#ifdef _BIG_ENDIAN +#define REG_PAIR(odd, even) unsigned long odd; unsigned long even +#else +#define REG_PAIR(odd, even) unsigned long even; unsigned long odd +#endif + +/* + * this struct defines the way the registers are stored on the + * stack during a system call. fields defined with REG_PAIR + * are saved and restored using double-word memory operations + * which means the word ordering of the pair depends on endianess. + */ +struct pt_regs { +#if defined(__TMS320C6XPLUS__) || defined(_TMS320C6400_PLUS) || \ + defined(__TMS320C66X__) + REG_PAIR(tsr, orig_a4); + REG_PAIR(rilc, ilc); +#else + REG_PAIR(stkadj, orig_a4); +#endif + REG_PAIR(pc, csr); + +#if defined(_TMS320C6400) + REG_PAIR(b17, b16); + REG_PAIR(b19, b18); + REG_PAIR(b21, b20); + REG_PAIR(b23, b22); + REG_PAIR(b25, b24); + REG_PAIR(b27, b26); + REG_PAIR(b29, b28); + REG_PAIR(b31, b30); +#endif /* defined(_TMS320C6400) */ + + REG_PAIR(b1, b0); + REG_PAIR(b3, b2); + REG_PAIR(b5, b4); + REG_PAIR(b7, b6); + REG_PAIR(b9, b8); + REG_PAIR(b11, b10); + REG_PAIR(b13, b12); + +#if defined(_TMS320C6400) + REG_PAIR(a17, a16); + REG_PAIR(a19, a18); + REG_PAIR(a21, a20); + REG_PAIR(a23, a22); + REG_PAIR(a25, a24); + REG_PAIR(a27, a26); + REG_PAIR(a29, a28); + REG_PAIR(a31, a30); +#endif /* defined(_TMS320C6400) */ + + REG_PAIR(a1, a0); + REG_PAIR(a3, a2); + REG_PAIR(a5, a4); + REG_PAIR(a7, a6); + REG_PAIR(a9, a8); + REG_PAIR(a11, a10); + REG_PAIR(a13, a12); + + REG_PAIR(a15, a14); + REG_PAIR(sp, dp); +}; + +/* + * This is the extended stack used by the context switcher + */ +struct switch_stack { +#if defined(__TMS320C6XPLUS__) || defined(_TMS320C6400_PLUS) || \ + defined(__TMS320C66X__) + REG_PAIR(rilc, ilc); +#endif + REG_PAIR(a11, a10); + REG_PAIR(a13, a12); + REG_PAIR(a15, a14); + REG_PAIR(b11, b10); + REG_PAIR(b13, b12); + + unsigned long retpc; + unsigned long pad; +}; + +/* + * These are 'magic' values for PTRACE_PEEKUSR that return info about where a + * process is located in memory. + */ +#define PT_TEXT_ADDR 0x10000 +#define PT_DATA_ADDR 0x10004 +#define PT_TEXT_END_ADDR 0x10008 + +/* Arbitrarily choose the same ptrace numbers as used by the Sparc code. */ +#define PTRACE_GETREGS 12 +#define PTRACE_SETREGS 13 +#define PTRACE_GETFPREGS 14 +#define PTRACE_SETFPREGS 15 + +/* get the ELF DSBT loadmap address */ +#define PTRACE_GETDSBT 31 +/* [addr] request the executable loadmap */ +#define PTRACE_GETDSBT_EXEC 0 +/* [addr] request the interpreter loadmap */ +#define PTRACE_GETDSBT_INTERP 1 + +#ifdef __KERNEL__ + +/* interrupt enable by default */ +/* used in /include/asm/processor.h*/ +#define DEFAULT_CSR 0x0001 + +#if !defined(CONFIG_TMS320C64XPLUS) && !defined(CONFIG_TMS320C66X) +extern unsigned long current_ksp; +#define user_mode(regs) (((((regs)->sp) ^ current_ksp) >> PAGE_SHIFT) != 0) +#else +#define user_mode(regs) ((((regs)->tsr) & 0x40) != 0) +#endif +#define instruction_pointer(regs) ((regs)->pc) +#define profile_pc(regs) instruction_pointer(regs) +extern void show_regs(struct pt_regs *); + +#endif /* __KERNEL__ */ +#endif /* __ASSEMBLY__ */ +#endif /* __ASM_C6X_PTRACE_H */ diff --git a/arch/c6x/include/asm/sizes.h b/arch/c6x/include/asm/sizes.h new file mode 100644 index 0000000..b0b4f6a --- /dev/null +++ b/arch/c6x/include/asm/sizes.h @@ -0,0 +1,51 @@ +/* + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +/* Size defintions + * Copyright (C) ARM Limited 1998. All rights reserved. + */ + +#ifndef __sizes_h +#define __sizes_h 1 + +/* handy sizes */ +#define SZ_1K 0x00000400 +#define SZ_4K 0x00001000 +#define SZ_8K 0x00002000 +#define SZ_16K 0x00004000 +#define SZ_32K 0x00008000 +#define SZ_64K 0x00010000 +#define SZ_128K 0x00020000 +#define SZ_256K 0x00040000 +#define SZ_512K 0x00080000 + +#define SZ_1M 0x00100000 +#define SZ_2M 0x00200000 +#define SZ_4M 0x00400000 +#define SZ_8M 0x00800000 +#define SZ_16M 0x01000000 +#define SZ_31M 0x01F00000 +#define SZ_32M 0x02000000 +#define SZ_64M 0x04000000 +#define SZ_128M 0x08000000 +#define SZ_256M 0x10000000 +#define SZ_512M 0x20000000 + +#define SZ_1G 0x40000000 +#define SZ_2G 0x80000000 + +#endif + +/* END */ diff --git a/arch/c6x/include/asm/string.h b/arch/c6x/include/asm/string.h new file mode 100644 index 0000000..98e26ed --- /dev/null +++ b/arch/c6x/include/asm/string.h @@ -0,0 +1,26 @@ +/* + * linux/include/asm-c6x/string.h + * + * Port on Texas Instruments TMS320C6x architecture + * + * Copyright (C) 2004, 2009 Texas Instruments Incorporated + * Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#ifndef __ASM_C6X_STRING_H +#define __ASM_C6X_STRING_H + +extern void *memcpy(void *to, const void *from, size_t n); +extern void *memset(void *s, int c, size_t count); +extern int memcmp(const void *cs, const void *ct, size_t count); +extern void *memmove(void *s1, const void *s2, size_t n); + +#define __HAVE_ARCH_MEMCPY +#define __HAVE_ARCH_MEMMOVE +#define __HAVE_ARCH_MEMSET +#define __HAVE_ARCH_MEMCMP + +#endif /* __ASM_C6X_STRING_H */ diff --git a/arch/c6x/include/asm/types.h b/arch/c6x/include/asm/types.h new file mode 100644 index 0000000..857c792 --- /dev/null +++ b/arch/c6x/include/asm/types.h @@ -0,0 +1,53 @@ +#ifndef __ASM_C6X_TYPES_H +#define __ASM_C6X_TYPES_H + +typedef unsigned short umode_t; + +/* + * __xx is ok: it doesn't pollute the POSIX namespace. Use these in the + * header files exported to user space + */ + +typedef __signed__ char __s8; +typedef unsigned char __u8; + +typedef __signed__ short __s16; +typedef unsigned short __u16; + +typedef __signed__ int __s32; +typedef unsigned int __u32; + +#if defined(__GNUC__) +__extension__ typedef __signed__ long long __s64; +__extension__ typedef unsigned long long __u64; +#endif + +/* + * These aren't exported outside the kernel to avoid name space clashes + */ +#ifdef __KERNEL__ + +typedef signed char s8; +typedef unsigned char u8; + +typedef signed short s16; +typedef unsigned short u16; + +typedef signed int s32; +typedef unsigned int u32; + +typedef signed long long s64; +typedef unsigned long long u64; + +#define BITS_PER_LONG 32 + +/* Dma addresses are 32-bits wide. */ + +typedef u32 dma_addr_t; + +typedef unsigned long phys_addr_t; +typedef unsigned long phys_size_t; + +#endif /* __KERNEL__ */ + +#endif diff --git a/arch/c6x/include/asm/u-boot-c6x.h b/arch/c6x/include/asm/u-boot-c6x.h new file mode 100644 index 0000000..2367516 --- /dev/null +++ b/arch/c6x/include/asm/u-boot-c6x.h @@ -0,0 +1,14 @@ +/* (C) Copyright 2012 Dmitry Bondar bond@inmys.ru + * + * This file is released under the terms of GPL v2 and any later version. + * See the file COPYING in the root directory of the source tree for details. +*/ + +#ifndef _U_BOOT_C6X_H_ +#define _U_BOOT_C6X_H_ 1 + +extern ulong __bss_start; +extern ulong __bss_end__; + +#endif /* _U_BOOT_C6X_H_ */ + diff --git a/arch/c6x/include/asm/u-boot.h b/arch/c6x/include/asm/u-boot.h new file mode 100644 index 0000000..759d976 --- /dev/null +++ b/arch/c6x/include/asm/u-boot.h @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + ******************************************************************** + * NOTE: This header file defines an interface to U-Boot. Including + * this (unmodified) header file in another file is considered normal + * use of U-Boot, and does *not* fall under the heading of "derived + * work". + ******************************************************************** + */ + +#ifndef _U_BOOT_H_ +#define _U_BOOT_H_ 1 + +typedef struct bd_info { + int bi_baudrate; /* serial console baudrate */ + unsigned long bi_ip_addr; /* IP Address */ + ulong bi_arch_number; /* unique id for this board */ + ulong bi_boot_params; /* where this board expects params */ + unsigned long bi_arm_freq; /* arm frequency */ + unsigned long bi_dsp_freq; /* dsp core frequency */ + unsigned long bi_ddr_freq; /* ddr frequency */ + struct /* RAM configuration */ + { + ulong start; + ulong size; + } bi_dram[CONFIG_NR_DRAM_BANKS]; +} bd_t; + +/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_ARM + +#endif /* _U_BOOT_H_ */ diff --git a/arch/c6x/include/asm/unaligned.h b/arch/c6x/include/asm/unaligned.h new file mode 100644 index 0000000..6cecbbb --- /dev/null +++ b/arch/c6x/include/asm/unaligned.h @@ -0,0 +1 @@ +#include <asm-generic/unaligned.h> diff --git a/arch/c6x/lib/Makefile b/arch/c6x/lib/Makefile new file mode 100644 index 0000000..8214df7 --- /dev/null +++ b/arch/c6x/lib/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(ARCH).o + +SOBJS-y += csum_64plus.o memcpy_64plus.o strasgi_64plus.o +SOBJS-y += unaligned.o divu.o divi.o pop_rts.o push_rts.o remi.o remu.o \ + strasgi.o llshru.o llshr.o llshl.o negll.o mpyll.o \ + divremi.o divremu.o delay.o + +COBJS-y += memcmp.o memmove.o memset.o divull.o + +COBJS-y += board.o +COBJS-y += bootm.o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/c6x/lib/board.c b/arch/c6x/lib/board.c new file mode 100644 index 0000000..00a5a49 --- /dev/null +++ b/arch/c6x/lib/board.c @@ -0,0 +1,196 @@ +/* + * (C) Copyright 2012 Dmitry Bondar bond@inmys.ru + * + * (C) Copyright 2011 + * Julius Baxter, julius@opencores.org + * + * (C) Copyright 2003, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * (C) Copyright 2000-2002 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <stdio_dev.h> +#include <watchdog.h> +#include <malloc.h> +#include <mmc.h> +#include <net.h> +#ifdef CONFIG_STATUS_LED +#include <status_led.h> +#endif +#ifdef CONFIG_CMD_NAND +#include <nand.h> /* cannot even include nand.h if it isnt configured */ +#endif + +#include <timestamp.h> +#include <version.h> +#include <asm/u-boot-c6x.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int display_banner(void) +{ + printf("\n\n%s\n\n", version_string); + return 0; +} + +#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) +static int init_func_i2c(void) +{ + puts("I2C: "); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + puts("ready\n"); + return 0; +} +#endif + + +/* + * Initialization sequence + */ +static int (* const init_sequence[])(void) = { +#if defined(CONFIG_ARCH_CPU_INIT) + arch_cpu_init, /* basic arch cpu dependent setup */ +#endif +#if defined(CONFIG_BOARD_EARLY_INIT_F) + board_early_init_f, +#endif + timer_init, /* initialize timer */ + env_init, + serial_init, + console_init_f, + + display_banner, /* say that we are here */ +#if defined(CONFIG_DISPLAY_BOARDINFO) + checkboard, /* display board info */ +#endif +#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) + init_func_i2c, +#endif +}; + + +static int clear_bss(void) +{ + ulong dst_addr = (ulong)&__bss_start; + size_t len = (size_t)&__bss_end__ - (size_t)&__bss_start; + memset((void *)dst_addr, 0x00, len); + return 0; +} + +/***********************************************************************/ +void board_init_f(ulong bootflag) +{ + bd_t *bd; + int i; + + clear_bss(); + + gd = (gd_t *)CONFIG_SYS_GBL_DATA_ADDR; + __asm__ __volatile__("" : : : "memory"); + memset((void *)gd, 0, GENERATED_GBL_DATA_SIZE); + + gd->bd = (bd_t *)(gd+1); /* At end of global data */ + gd->baudrate = CONFIG_BAUDRATE; + + bd = gd->bd; +#ifndef CONFIG_SYS_NO_FLASH + bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; +#endif + bd->bi_baudrate = CONFIG_BAUDRATE; + + for (i = 0; i < ARRAY_SIZE(init_sequence); i++) { + WATCHDOG_RESET(); + if (init_sequence[i]()) + hang(); + } + + WATCHDOG_RESET(); + + /* The Malloc area is immediately below the monitor copy in RAM */ + mem_malloc_init(CONFIG_SYS_MALLOC_BASE, CONFIG_SYS_MALLOC_LEN); + + board_init(); + +#ifndef CONFIG_SYS_NO_FLASH + WATCHDOG_RESET(); + bd->bi_flashsize = flash_init(); +#endif + +#ifdef CONFIG_CMD_NAND + puts("NAND: "); + nand_init(); +#endif + +#ifdef CONFIG_GENERIC_MMC + puts("MMC: "); + mmc_initialize(bd); +#endif + + WATCHDOG_RESET(); + env_relocate(); + + WATCHDOG_RESET(); + stdio_init(); + jumptable_init(); + console_init_r(); + + WATCHDOG_RESET(); +/* interrupt_init();*/ + +#if defined(CONFIG_BOARD_LATE_INIT) + board_late_init(); +#endif + +#if defined(CONFIG_CMD_NET) + puts("NET: "); + eth_initialize(bd); +#endif + + /* main_loop */ + for (;;) { + WATCHDOG_RESET(); + main_loop(); + } +} + + +/***********************************************************************/ + +void hang(void) +{ + disable_interrupts(); + puts("### ERROR ### Please reset board ###\n"); + + while (1) + /*nothing*/; +} + +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + reset_cpu(0); + return 0; +} + diff --git a/arch/c6x/lib/bootm.c b/arch/c6x/lib/bootm.c new file mode 100644 index 0000000..4bafacf --- /dev/null +++ b/arch/c6x/lib/bootm.c @@ -0,0 +1,60 @@ +/* + * (C) Copyright 2003, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> + +int disable_interrupts() +{ + return 0; +} + +void enable_interrupts() +{ +} + +int do_bootm_linux(int flag, int argc, char * const argv[], + bootm_headers_t *images) +{ + void (*kernel)() = (void *)images->ep; + char *commandline = getenv("bootargs"); + if (commandline) { + char *dst = (char *)images->ep + 0x1000; + strncpy(dst, commandline, 1023); + dst[1023] = 0; + } + { + unsigned int *ptr = (unsigned int *)0xc1f00000; + ptr[0] = 0x64000001; /*TAG_SOL*/ + ptr[1] = 0; /*size SOL*/ + ptr[2] = 0x64000002; /*TAG_EOL*/ + ptr[3] = 0; + } + asm("MVKL .S1 0x54694265,A4"); + asm("MVKH .S1 0x54694265,A4"); + asm("MVKL .S2 0xc1f00000,B4"); + asm("MVKH .S2 0xc1f00000,B4"); + kernel(); + printf("after kernel\n"); + return 1; +} diff --git a/arch/c6x/lib/csum_64plus.S b/arch/c6x/lib/csum_64plus.S new file mode 100644 index 0000000..db26ed4 --- /dev/null +++ b/arch/c6x/lib/csum_64plus.S @@ -0,0 +1,408 @@ +; +; linux/arch/c6x/lib/csum_64plus.s +; +; Port on Texas Instruments TMS320C6x architecture +; +; Copyright (C) 2006, 2009, 2010 Texas Instruments Incorporated +; Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) +; +; This program is free software; you can redistribute it and/or modify +; it under the terms of the GNU General Public License version 2 as +; published by the Free Software Foundation. +; + +; +;unsigned int csum_partial_copy(const char *src, char * dst, +; int len, int sum) +; +; A4: src +; B4: dst +; A6: len +; B6: sum +; return csum in A4 +; + + .global csum_partial_copy + .text + +csum_partial_copy: + MVC .S2 ILC,B30 + + MV .D1X B6,A31 ; given csum + ZERO .D1 A9 ; csum (a side) +|| ZERO .D2 B9 ; csum (b side) +|| SHRU .S2X A6,2,B5 ; len / 4 + + ;; Check alignment and size + AND .S1 3,A4,A1 +|| AND .S2 3,B4,B0 + OR .L2X B0,A1,B0 ; non aligned condition +|| MVC .S2 B5,ILC +|| MVK .D2 1,B2 +|| MV .D1X B5,A1 ; words condition + [!A1] B .S1 L8 + [B0] BNOP .S1 L6,5 + + SPLOOP 1 + + ;; Main loop for aligned words + LDW .D1T1 *A4++,A7 + NOP 4 + MV .S2X A7,B7 +|| EXTU .S1 A7,0,16,A16 + STW .D2T2 B7,*B4++ +|| MPYU .M2 B7,B2,B8 +|| ADD .L1 A16,A9,A9 + NOP + SPKERNEL 8,0 +|| ADD .L2 B8,B9,B9 + + ZERO .D1 A1 +|| ADD .L1X A9,B9,A9 ; add csum from a and b sides + +L6: + [!A1] BNOP .S1 L8,5 + + ;; Main loop for non-aligned words + SPLOOP 2 + || MVK .L1 1,A2 + + LDNW .D1T1 *A4++,A7 + NOP 3 + + NOP + MV .S2X A7,B7 + || EXTU .S1 A7,0,16,A16 + || MPYU .M1 A7,A2,A8 + + ADD .L1 A16,A9,A9 + SPKERNEL 6,0 + || STNW .D2T2 B7,*B4++ + || ADD .L1 A8,A9,A9 + +L8: AND .S2X 2,A6,B5 + CMPGT .L2 B5,0,B0 + [!B0] BNOP .S1 L82,4 + + ;; Manage half-word + ZERO .L1 A7 +|| ZERO .D1 A8 + +#ifdef CONFIG_CPU_BIG_ENDIAN + + LDBU .D1T1 *A4++,A7 + LDBU .D1T1 *A4++,A8 + NOP 3 + SHL .S1 A7,8,A0 + ADD .S1 A8,A9,A9 + STB .D2T1 A7,*B4++ +|| ADD .S1 A0,A9,A9 + STB .D2T1 A8,*B4++ + +#else + + LDBU .D1T1 *A4++,A7 + LDBU .D1T1 *A4++,A8 + NOP 3 + ADD .S1 A7,A9,A9 + SHL .S1 A8,8,A0 + + STB .D2T1 A7,*B4++ +|| ADD .S1 A0,A9,A9 + STB .D2T1 A8,*B4++ + +#endif + + ;; Manage eventually the last byte +L82: AND .S2X 1,A6,B0 + [!B0] BNOP .S1 L9,5 + +|| ZERO .L1 A7 + +L83: LDBU .D1T1 *A4++,A7 + NOP 4 + + MV .L2X A7,B7 + +#ifdef CONFIG_CPU_BIG_ENDIAN + + STB .D2T2 B7,*B4++ +|| SHL .S1 A7,8,A7 + ADD .S1 A7,A9,A9 + +#else + + STB .D2T2 B7,*B4++ +|| ADD .S1 A7,A9,A9 + +#endif + + ;; Fold the csum +L9: SHRU .S2X A9,16,B0 + [!B0] BNOP .S1 L10,5 + +L91: SHRU .S2X A9,16,B4 +|| EXTU .S1 A9,16,16,A3 + ADD .D1X A3,B4,A9 + + SHRU .S1 A9,16,A0 + [A0] BNOP .S1 L91,5 + +L10: ADD .D1 A31,A9,A9 + MV .D1 A9,A4 + + BNOP .S2 B3,4 + MVC .S2 B30,ILC + + .global csum_partial_copy_old + .text + +; +;unsigned short +;ip_fast_csum(unsigned char *iph, unsigned int ihl) +;{ +; unsigned int checksum = 0; +; unsigned short *tosum = (unsigned short *) iph; +; int len; +; +; len = ihl*4; +; +; if (len <= 0) +; return 0; +; +; while(len) { +; len -= 2; +; checksum += *tosum++; +; } +; if (len & 1) +; checksum += *(unsigned char*) tosum; +; +; while(checksum >> 16) +; checksum = (checksum & 0xffff) + (checksum >> 16); +; +; return ~checksum; +;} +; +; A4: iph +; B4: ihl +; return checksum in A4 +; + + .global ip_fast_csum + .text + +ip_fast_csum: + ZERO .D1 A5 + || MVC .S2 ILC,B30 + SHL .S2 B4,2,B0 + CMPGT .L2 B0,0,B1 + [!B1] BNOP .S1 L15,4 + [!B1] ZERO .D1 A3 + + [!B0] B .S1 L12 + SHRU .S2 B0,1,B0 + MVC .S2 B0,ILC + NOP 3 + + SPLOOP 1 + LDHU .D1T1 *A4++,A3 + NOP 3 + NOP + SPKERNEL 5,0 + || ADD .L1 A3,A5,A5 + +L12: SHRU .S1 A5,16,A0 + [!A0] BNOP .S1 L14,5 + +L13: SHRU .S2X A5,16,B4 + EXTU .S1 A5,16,16,A3 + ADD .D1X A3,B4,A5 + SHRU .S1 A5,16,A0 + [A0] BNOP .S1 L13,5 + +L14: NOT .D1 A5,A3 + EXTU .S1 A3,16,16,A3 + +L15: BNOP .S2 B3,3 + MVC .S2 B30,ILC + MV .D1 A3,A4 + +; +;unsigned short +;do_csum(unsigned char *buff, unsigned int len) +;{ +; int odd, count; +; unsigned int result = 0; +; +; if (len <= 0) +; goto out; +; odd = 1 & (unsigned long) buff; +; if (odd) { +;#ifdef __LITTLE_ENDIAN +; result += (*buff << 8); +;#else +; result = *buff; +;#endif +; len--; +; buff++; +; } +; count = len >> 1; /* nr of 16-bit words.. */ +; if (count) { +; if (2 & (unsigned long) buff) { +; result += *(unsigned short *) buff; +; count--; +; len -= 2; +; buff += 2; +; } +; count >>= 1; /* nr of 32-bit words.. */ +; if (count) { +; unsigned int carry = 0; +; do { +; unsigned int w = *(unsigned int *) buff; +; count--; +; buff += 4; +; result += carry; +; result += w; +; carry = (w > result); +; } while (count); +; result += carry; +; result = (result & 0xffff) + (result >> 16); +; } +; if (len & 2) { +; result += *(unsigned short *) buff; +; buff += 2; +; } +; } +; if (len & 1) +;#ifdef __LITTLE_ENDIAN +; result += *buff; +;#else +; result += (*buff << 8); +;#endif +; result = (result & 0xffff) + (result >> 16); +; /* add up carry.. */ +; result = (result & 0xffff) + (result >> 16); +; if (odd) +; result = ((result >> 8) & 0xff) | ((result & 0xff) << 8); +;out: +; return result; +;} +; +; A4: buff +; B4: len +; return checksum in A4 +; + .global do_csum + .text +do_csum: + CMPGT .L2 B4,0,B0 + [!B0] BNOP .S1 L26,3 + EXTU .S1 A4,31,31,A0 + + MV .L1 A0,A3 +|| MV .S1X B3,A5 +|| MV .L2 B4,B3 +|| ZERO .D1 A1 + +#ifdef CONFIG_CPU_BIG_ENDIAN + [A0] SUB .L2 B3,1,B3 +|| [A0] LDBU .D1T1 *A4++,A1 +#else + [!A0] BNOP .S1 L21,5 +|| [A0] LDBU .D1T1 *A4++,A0 + SUB .L2 B3,1,B3 +|| SHL .S1 A0,8,A1 +L21: +#endif + SHR .S2 B3,1,B0 + [!B0] BNOP .S1 L24,3 + MVK .L1 2,A0 + AND .L1 A4,A0,A0 + + [!A0] BNOP .S1 L22,5 +|| [A0] LDHU .D1T1 *A4++,A0 + SUB .L2 B0,1,B0 +|| SUB .S2 B3,2,B3 +|| ADD .L1 A0,A1,A1 +L22: + SHR .S2 B0,1,B0 +|| ZERO .L1 A0 + + [!B0] BNOP .S1 L23,5 +|| [B0] MVC .S2 B0,ILC + + SPLOOP 3 + SPMASK L1 +|| MV .L1 A1,A2 +|| LDW .D1T1 *A4++,A1 + + NOP 4 + ADD .L1 A0,A1,A0 + ADD .L1 A2,A0,A2 + + SPKERNEL 1,2 +|| CMPGTU .L1 A1,A2,A0 + + ADD .L1 A0,A2,A6 + EXTU .S1 A6,16,16,A7 + SHRU .S2X A6,16,B0 + NOP 1 + ADD .L1X A7,B0,A1 +L23: + MVK .L2 2,B0 + AND .L2 B3,B0,B0 + [B0] LDHU .D1T1 *A4++,A0 + NOP 4 + [B0] ADD .L1 A0,A1,A1 +L24: + EXTU .S2 B3,31,31,B0 +#ifdef CONFIG_CPU_BIG_ENDIAN + [!B0] BNOP .S1 L25,4 +|| [B0] LDBU .D1T1 *A4,A0 + SHL .S1 A0,8,A0 + ADD .L1 A0,A1,A1 +L25: +#else + [B0] LDBU .D1T1 *A4,A0 + NOP 4 + [B0] ADD .L1 A0,A1,A1 +#endif + EXTU .S1 A1,16,16,A0 + SHRU .S2X A1,16,B0 + NOP 1 + ADD .L1X A0,B0,A0 + SHRU .S1 A0,16,A1 + ADD .L1 A0,A1,A0 + EXTU .S1 A0,16,16,A1 + EXTU .S1 A1,16,24,A2 + + EXTU .S1 A1,24,16,A0 +|| MV .L2X A3,B0 + + [B0] OR .L1 A0,A2,A1 +L26: + NOP 1 + BNOP .S2X A5,4 + MV .L1 A1,A4 + +;__wsum csum_partial(const void *buff, int len, __wsum wsum) +;{ +; unsigned int sum = (__force unsigned int)wsum; +; unsigned int result = do_csum(buff, len); +; +; /* add in old sum, and carry.. */ +; result += sum; +; if (sum > result) +; result += 1; +; return (__force __wsum)result; +;} +; + .global csum_partial +csum_partial: + MV .L1X B3,A9 +|| CALLP .S2 do_csum,B3 +|| MV .S1 A6,A8 + BNOP .S2X A9,2 + ADD .L1 A8,A4,A1 + CMPGTU .L1 A8,A1,A0 + ADD .L1 A1,A0,A4 diff --git a/arch/c6x/lib/delay.S b/arch/c6x/lib/delay.S new file mode 100644 index 0000000..44f2a7f --- /dev/null +++ b/arch/c6x/lib/delay.S @@ -0,0 +1,39 @@ +; +; linux/arch/c6x/lib/delay.s +; +; Port on Texas Instruments TMS320C6x architecture +; +; Copyright (C) 2004, 2009, 2010 Texas Instruments Incorporated +; Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) +; +; This program is free software; you can redistribute it and/or modify +; it under the terms of the GNU General Public License version 2 as +; published by the Free Software Foundation. +; + .sect ".text" + .global _c6x_delay + +_c6x_delay: + bdec .s1 _c6x_delay,A4 + nop 5 + b .s2 B3 + nop 5 + +#ifdef CONFIG_TI_C6X_COMPILER + ;; this is inlined with gcc + + .global _c6x_tickdelay +_c6x_tickdelay: + mvc .s2 TSCL,B1 + add .s2x B1,A4,B1 + || mvk .l2 1,B0 +$0: + [B0] b .s2 $0 + mvc .s2 TSCL,B0 + sub .s2 B0,B1,B0 + cmpgt .l2 0,B0,B0 + nop + nop + b .s2 B3 + nop 5 +#endif diff --git a/arch/c6x/lib/divi.S b/arch/c6x/lib/divi.S new file mode 100644 index 0000000..cfa1e4c --- /dev/null +++ b/arch/c6x/lib/divi.S @@ -0,0 +1,54 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + ;; ABI considerations for the divide functions + ;; The following registers are call-used: + ;; __c6xabi_divi A0,A1,A2,A4,A6,B0,B1,B2,B4,B5 + ;; __c6xabi_divu A0,A1,A2,A4,A6,B0,B1,B2,B4 + ;; __c6xabi_remi A1,A2,A4,A5,A6,B0,B1,B2,B4 + ;; __c6xabi_remu A1,A4,A5,A7,B0,B1,B2,B4 + ;; + ;; In our implementation, divu and remu are leaf functions, + ;; while both divi and remi call into divu. + ;; A0 is not clobbered by any of the functions. + ;; divu does not clobber B2 either, which is taken advantage of + ;; in remi. + ;; divi uses B5 to hold the original return address during + ;; the call to divu. + ;; remi uses B2 and A5 to hold the input values during the + ;; call to divu. It stores B3 in on the stack. + +#ifdef CONFIG_TI_C6X_COMPILER + .ref __c6xabi_divu +#endif + .text + .global __c6xabi_divi +__c6xabi_divi: + call .s2 __c6xabi_divu +|| mv .d2 B3, B5 +|| cmpgt .l1 0, A4, A1 +|| cmpgt .l2 0, B4, B1 + + [A1] neg .l1 A4, A4 +|| [B1] neg .l2 B4, B4 +|| xor .s1x A1, B1, A1 + [A1] addkpc .s2 _divu_ret, B3, 4 +_divu_ret: + neg .l1 A4, A4 +|| mv .l2 B3,B5 +|| ret .s2 B5 + nop 5 diff --git a/arch/c6x/lib/divremi.S b/arch/c6x/lib/divremi.S new file mode 100644 index 0000000..b7664c3 --- /dev/null +++ b/arch/c6x/lib/divremi.S @@ -0,0 +1,61 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + +#ifdef CONFIG_TI_C6X_COMPILER + .ref __c6xabi_divu +#endif + .text + .global __c6xabi_divremi + +__c6xabi_divremi: + stw .d2t2 B3, *B15--[2] +|| cmpgt .l1 0, A4, A1 +|| cmpgt .l2 0, B4, B2 +|| mv .s1 A4, A5 +|| call .s2 __c6xabi_divu + + [A1] neg .l1 A4, A4 +|| [B2] neg .l2 B4, B4 +|| xor .s2x B2, A1, B0 +|| mv .d2 B4, B2 + + [B0] addkpc .s2 _divu_ret_1, B3, 1 + [!B0] addkpc .s2 _divu_ret_2, B3, 1 + nop 2 +_divu_ret_1: + neg .l1 A4, A4 +_divu_ret_2: + ldw .d2t2 *++B15[2], B3 + +#if defined(CONFIG_TMS320C64XPLUS) || defined(CONFIG_TMS320C66X) + mpy32 .m1x A4, B2, A6 + nop 3 + ret .s2 B3 + sub .l1 A5, A6, A5 + nop 4 +#else + mpyu .m1x A4, B2, A1 + nop 1 + mpylhu .m1x A4, B2, A6 +|| mpylhu .m2x B2, A4, B2 +|| ret .s2 B3 + nop 1 + add .l1x A6, B2, A6 + shl .s1 A6, 16, A6 + add .d1 A6, A1, A6 + sub .l1 A5, A6, A5 +#endif diff --git a/arch/c6x/lib/divremu.S b/arch/c6x/lib/divremu.S new file mode 100644 index 0000000..83e2bb7 --- /dev/null +++ b/arch/c6x/lib/divremu.S @@ -0,0 +1,86 @@ +;; Copyright 2011 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + .text + .global __c6xabi_divremu + +__c6xabi_divremu: + ;; We use a series of up to 31 subc instructions. First, we find + ;; out how many leading zero bits there are in the divisor. This + ;; gives us both a shift count for aligning (shifting) the divisor + ;; to the, and the number of times we have to execute subc. + + ;; At the end, we have both the remainder and most of the quotient + ;; in A4. The top bit of the quotient is computed first and is + ;; placed in A2. + + ;; Return immediately if the dividend is zero. Setting B4 to 1 + ;; is a trick to allow us to leave the following insns in the jump + ;; delay slot without affecting the result. + mv .s2x A4, B1 + +[b1] lmbd .l2 1, B4, B1 +||[!b1] b .s2 B3 ; RETURN A +||[!b1] mvk .d2 1, B4 + +||[!b1] zero .s1 A5 + mv .l1x B1, A6 +|| shl .s2 B4, B1, B4 + + ;; The loop performs a maximum of 28 steps, so we do the + ;; first 3 here. + cmpltu .l1x A4, B4, A2 +[!A2] sub .l1x A4, B4, A4 +|| shru .s2 B4, 1, B4 +|| xor .s1 1, A2, A2 + + shl .s1 A2, 31, A2 +|| [b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 +[b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 + + ;; RETURN A may happen here (note: must happen before the next branch) +0: + cmpgt .l2 B1, 7, B0 +|| [b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 +[b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 +|| [b0] b .s1 0b +[b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 +[b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 +[b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 +[b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 +[b1] subc .l1x A4,B4,A4 +|| [b1] add .s2 -1, B1, B1 + ;; loop backwards branch happens here + + ret .s2 B3 +|| mvk .s1 32, A1 + sub .l1 A1, A6, A6 +|| extu .s1 A4, A6, A5 + shl .s1 A4, A6, A4 + shru .s1 A4, 1, A4 +|| sub .l1 A6, 1, A6 + or .l1 A2, A4, A4 + shru .s1 A4, A6, A4 + nop diff --git a/arch/c6x/lib/divu.S b/arch/c6x/lib/divu.S new file mode 100644 index 0000000..340b536 --- /dev/null +++ b/arch/c6x/lib/divu.S @@ -0,0 +1,100 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + ;; ABI considerations for the divide functions + ;; The following registers are call-used: + ;; __c6xabi_divi A0,A1,A2,A4,A6,B0,B1,B2,B4,B5 + ;; __c6xabi_divu A0,A1,A2,A4,A6,B0,B1,B2,B4 + ;; __c6xabi_remi A1,A2,A4,A5,A6,B0,B1,B2,B4 + ;; __c6xabi_remu A1,A4,A5,A7,B0,B1,B2,B4 + ;; + ;; In our implementation, divu and remu are leaf functions, + ;; while both divi and remi call into divu. + ;; A0 is not clobbered by any of the functions. + ;; divu does not clobber B2 either, which is taken advantage of + ;; in remi. + ;; divi uses B5 to hold the original return address during + ;; the call to divu. + ;; remi uses B2 and A5 to hold the input values during the + ;; call to divu. It stores B3 in on the stack. + +#ifdef CONFIG_TI_C6X_COMPILER + .def __c6xabi_divu +#endif + .text + .global __c6xabi_divu +__c6xabi_divu: + ;; We use a series of up to 31 subc instructions. First, we find + ;; out how many leading zero bits there are in the divisor. This + ;; gives us both a shift count for aligning (shifting) the divisor + ;; to the, and the number of times we have to execute subc. + + ;; At the end, we have both the remainder and most of the quotient + ;; in A4. The top bit of the quotient is computed first and is + ;; placed in A2. + + ;; Return immediately if the dividend is zero. + mv .s2x A4, B1 + [B1] lmbd .l2 1, B4, B1 +|| [!B1] b .s2 B3 ; RETURN A +|| [!B1] mvk .d2 1, B4 + mv .l1x B1, A6 +|| shl .s2 B4, B1, B4 + + ;; The loop performs a maximum of 28 steps, so we do the + ;; first 3 here. + cmpltu .l1x A4, B4, A2 + [!A2] sub .l1x A4, B4, A4 +|| shru .s2 B4, 1, B4 +|| xor .s1 1, A2, A2 + + shl .s1 A2, 31, A2 +|| [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + + ;; RETURN A may happen here (note: must happen before the next branch) +_divu_loop: + cmpgt .l2 B1, 7, B0 +|| [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 +|| [B0] b .s1 _divu_loop + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + ;; loop backwards branch happens here + + ret .s2 B3 +|| mvk .s1 32, A1 + sub .l1 A1, A6, A6 + shl .s1 A4, A6, A4 + shru .s1 A4, 1, A4 +|| sub .l1 A6, 1, A6 + or .l1 A2, A4, A4 + shru .s1 A4, A6, A4 + nop + diff --git a/arch/c6x/lib/divull.c b/arch/c6x/lib/divull.c new file mode 100644 index 0000000..8c00edc --- /dev/null +++ b/arch/c6x/lib/divull.c @@ -0,0 +1,336 @@ +/* Copyright (C) 1989, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, + 2000, 2001, 2002 Free Software Foundation, Inc. + +This code was pulled from an old (GPLv2) libgcc. + +This program is free software; you can redistribute it and/or modify it under +the terms of the GNU General Public License as published by the Free Software +Foundation; either version 2, or (at your option) any later version. + +In addition to the permissions in the GNU General Public License, the +Free Software Foundation gives you unlimited permission to link the +compiled version of this file into combinations with other programs, +and to distribute those combinations without any restriction coming +from the use of this file. (The General Public License restrictions +do apply in other respects; for example, they cover modification of +the file, and distribution when not linked into a combine +executable.) + +This program is distributed in the hope that it will be useful, but WITHOUT +ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or +FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License +for more details. + +You should have received a copy of the GNU General Public License +along with GCC; see the file COPYING. If not, write to the Free +Software Foundation, 59 Temple Place - Suite 330, Boston, MA +02111-1307, USA. */ + +#include <linux/types.h> +#include <linux/bitops.h> + +#ifdef CONFIG_TI_C6X_COMPILER +#define count_leading_zeros(count, x) (count) = _lmbd(1, (x)) +#else +static inline unsigned __clz(unsigned x) +{ + asm(" lmbd .l1 1,%0,%0\n" : "+a"(x)); + return x; +} +#define count_leading_zeros(count, x) (count) = __clz(x) +#endif + +#define W_TYPE_SIZE 32 + +#define __BITS4 (W_TYPE_SIZE / 4) +#define __ll_B ((uint32_t) 1 << (W_TYPE_SIZE / 2)) +#define __ll_lowpart(t) ((uint32_t) (t) & (__ll_B - 1)) +#define __ll_highpart(t) ((uint32_t) (t) >> (W_TYPE_SIZE / 2)) + + +#define sub_ddmmss(sh, sl, ah, al, bh, bl) \ + do { \ + uint32_t __x; \ + __x = (al) - (bl); \ + (sh) = (ah) - (bh) - (__x > (al)); \ + (sl) = __x; \ + } while (0) + +#define umul_ppmm(w1, w0, u, v) \ + do { \ + uint32_t __x0, __x1, __x2, __x3; \ + uint16_t __ul, __vl, __uh, __vh; \ + \ + __ul = __ll_lowpart(u); \ + __uh = __ll_highpart(u); \ + __vl = __ll_lowpart(v); \ + __vh = __ll_highpart(v); \ + \ + __x0 = (uint32_t) __ul * __vl; \ + __x1 = (uint32_t) __ul * __vh; \ + __x2 = (uint32_t) __uh * __vl; \ + __x3 = (uint32_t) __uh * __vh; \ + \ + __x1 += __ll_highpart(__x0);/* this can't give carry */ \ + __x1 += __x2; /* but this indeed can */ \ + if (__x1 < __x2) /* did we get it? */ \ + __x3 += __ll_B; /* yes, add it in the proper pos. */ \ + \ + (w1) = __x3 + __ll_highpart(__x1); \ + (w0) = __ll_lowpart(__x1) * __ll_B + __ll_lowpart(__x0); \ + } while (0) + +#define __udiv_qrnnd_c(q, r, n1, n0, d) \ + do { \ + uint32_t __d1, __d0, __q1, __q0; \ + uint32_t __r1, __r0, __m; \ + __d1 = __ll_highpart(d); \ + __d0 = __ll_lowpart(d); \ + \ + __r1 = (n1) % __d1; \ + __q1 = (n1) / __d1; \ + __m = (uint32_t) __q1 * __d0; \ + __r1 = __r1 * __ll_B | __ll_highpart(n0); \ + if (__r1 < __m) { \ + __q1--, __r1 += (d); \ + /* i.e. we didn't get carry when adding to __r1 */ \ + if (__r1 >= (d)) \ + if (__r1 < __m) \ + __q1--, __r1 += (d); \ + } \ + __r1 -= __m; \ + \ + __r0 = __r1 % __d1; \ + __q0 = __r1 / __d1; \ + __m = (uint32_t) __q0 * __d0; \ + __r0 = __r0 * __ll_B | __ll_lowpart(n0); \ + if (__r0 < __m) { \ + __q0--, __r0 += (d); \ + if (__r0 >= (d)) \ + if (__r0 < __m) \ + __q0--, __r0 += (d); \ + } \ + __r0 -= __m; \ + \ + (q) = (uint32_t) __q1 * __ll_B | __q0; \ + (r) = __r0; \ + } while (0) + +#define UDIV_NEEDS_NORMALIZATION 1 +#define udiv_qrnnd __udiv_qrnnd_c + +struct llstruct { +#ifdef CONFIG_CPU_BIG_ENDIAN + uint32_t high; + uint32_t low; +#else + uint32_t low; + uint32_t high; +#endif +}; + +typedef union { + struct llstruct s; + int64_t ll; +} llunion_t; + +static inline uint64_t __udivmoddi4(uint64_t n, uint64_t d, uint64_t *rp) +{ + llunion_t ww; + llunion_t nn, dd; + llunion_t rr; + uint32_t d0, d1, n0, n1, n2; + uint32_t q0, q1; + uint32_t b, bm; + + nn.ll = n; + dd.ll = d; + + d0 = dd.s.low; + d1 = dd.s.high; + n0 = nn.s.low; + n1 = nn.s.high; + +#if !UDIV_NEEDS_NORMALIZATION + if (d1 == 0) { + if (d0 > n1) { + /* 0q = nn / 0D */ + + udiv_qrnnd(q0, n0, n1, n0, d0); + q1 = 0; + + /* Remainder in n0. */ + } else { + /* qq = NN / 0d */ + + if (d0 == 0) + d0 = 1 / d0; /* Divide intentionally by zero. */ + + udiv_qrnnd(q1, n1, 0, n1, d0); + udiv_qrnnd(q0, n0, n1, n0, d0); + + /* Remainder in n0. */ + } + + if (rp != 0) { + rr.s.low = n0; + rr.s.high = 0; + *rp = rr.ll; + } + } + +#else /* UDIV_NEEDS_NORMALIZATION */ + + if (d1 == 0) { + if (d0 > n1) { + /* 0q = nn / 0D */ + + count_leading_zeros(bm, d0); + + if (bm != 0) { + /* Normalize, i.e. make the most significant + bit of the denominator set. */ + + d0 = d0 << bm; + n1 = (n1 << bm) | (n0 >> (W_TYPE_SIZE - bm)); + n0 = n0 << bm; + } + + udiv_qrnnd(q0, n0, n1, n0, d0); + q1 = 0; + + /* Remainder in n0 >> bm. */ + } else { + /* qq = NN / 0d */ + + if (d0 == 0) + d0 = 1 / d0; /* Divide intentionally by zero. */ + + count_leading_zeros(bm, d0); + + if (bm == 0) { + /* From (n1 >= d0) /\ (the most significant bit + of d0 is set), conclude (the most significant + bit of n1 is set) /\ (the leading quotient + digit q1 = 1). + + This special case is necessary, not an + optimization. (Shifts counts of W_TYPE_SIZE + are undefined.) */ + + n1 -= d0; + q1 = 1; + } else { + /* Normalize. */ + + b = W_TYPE_SIZE - bm; + + d0 = d0 << bm; + n2 = n1 >> b; + n1 = (n1 << bm) | (n0 >> b); + n0 = n0 << bm; + + udiv_qrnnd(q1, n1, n2, n1, d0); + } + + /* n1 != d0... */ + + udiv_qrnnd(q0, n0, n1, n0, d0); + + /* Remainder in n0 >> bm. */ + } + + if (rp != 0) { + rr.s.low = n0 >> bm; + rr.s.high = 0; + *rp = rr.ll; + } + } +#endif /* UDIV_NEEDS_NORMALIZATION */ + + else { + if (d1 > n1) { + /* 00 = nn / DD */ + + q0 = 0; + q1 = 0; + + /* Remainder in n1n0. */ + if (rp != 0) { + rr.s.low = n0; + rr.s.high = n1; + *rp = rr.ll; + } + } else { + /* 0q = NN / dd */ + + count_leading_zeros(bm, d1); + if (bm == 0) { + /* From (n1 >= d1) /\ (the most significant bit + of d1 is set), conclude (the most significant + bit of n1 is set) /\ (the quotient digit + q0 = 0 or 1). + + This special case is necessary, not an + optimization. */ + + /* The condition on the next line takes + advantage of that n1 >= d1 (true due to + program flow). */ + if (n1 > d1 || n0 >= d0) { + q0 = 1; + sub_ddmmss(n1, n0, n1, n0, d1, d0); + } else + q0 = 0; + + q1 = 0; + + if (rp != 0) { + rr.s.low = n0; + rr.s.high = n1; + *rp = rr.ll; + } + } else { + uint32_t m1, m0; + /* Normalize. */ + + b = W_TYPE_SIZE - bm; + + d1 = (d1 << bm) | (d0 >> b); + d0 = d0 << bm; + n2 = n1 >> b; + n1 = (n1 << bm) | (n0 >> b); + n0 = n0 << bm; + + udiv_qrnnd(q0, n1, n2, n1, d1); + umul_ppmm(m1, m0, q0, d0); + + if (m1 > n1 || (m1 == n1 && m0 > n0)) { + q0--; + sub_ddmmss(m1, m0, m1, m0, d1, d0); + } + + q1 = 0; + + /* Remainder in (n1n0 - m1m0) >> bm. */ + if (rp != 0) { + sub_ddmmss(n1, n0, n1, n0, m1, m0); + rr.s.low = (n1 << b) | (n0 >> bm); + rr.s.high = n1 >> bm; + *rp = rr.ll; + } + } + } + } + + ww.s.low = q0; + ww.s.high = q1; + return ww.ll; +} + +uint64_t +__c6xabi_divull(uint64_t n, uint64_t d) +{ + return __udivmoddi4(n, d, (uint64_t *)0); +} + diff --git a/arch/c6x/lib/llshl.S b/arch/c6x/lib/llshl.S new file mode 100644 index 0000000..99b739e --- /dev/null +++ b/arch/c6x/lib/llshl.S @@ -0,0 +1,36 @@ +;; Copyright (C) 2010 Texas Instruments Incorporated +;; Contributed by Mark Salter msalter@redhat.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + +;; uint64_t __c6xabi_llshl(uint64_t val, uint shift) + + .text + .global __c6xabi_llshl +__c6xabi_llshl: + mv .l1x B4,A1 + [!A1] b .s2 B3 ; just return if zero shift + mvk .s1 32,A0 + sub .d1 A0,A1,A0 + cmplt .l1 0,A0,A2 + [A2] shru .s1 A4,A0,A0 + [!A2] neg .l1 A0,A5 +|| [A2] shl .s1 A5,A1,A5 + [!A2] shl .s1 A4,A5,A5 +|| [A2] or .d1 A5,A0,A5 +|| [!A2] mvk .l1 0,A4 + [A2] shl .s1 A4,A1,A4 + bnop .s2 B3,5 + diff --git a/arch/c6x/lib/llshr.S b/arch/c6x/lib/llshr.S new file mode 100644 index 0000000..989feed --- /dev/null +++ b/arch/c6x/lib/llshr.S @@ -0,0 +1,36 @@ +;; Copyright (C) 2010 Texas Instruments Incorporated +;; Contributed by Mark Salter msalter@redhat.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + +;; uint64_t __c6xabi_llshr(uint64_t val, uint shift) + + .text + .global __c6xabi_llshr +__c6xabi_llshr: + mv .l1x B4,A1 + [!A1] b .s2 B3 ; return if zero shift count + mvk .s1 32,A0 + sub .d1 A0,A1,A0 + cmplt .l1 0,A0,A2 + [A2] shl .s1 A5,A0,A0 + nop + [!A2] neg .l1 A0,A4 +|| [A2] shru .s1 A4,A1,A4 + [!A2] shr .s1 A5,A4,A4 +|| [A2] or .d1 A4,A0,A4 + [!A2] shr .s1 A5,0x1f,A5 + [A2] shr .s1 A5,A1,A5 + bnop .s2 B3,5 diff --git a/arch/c6x/lib/llshru.S b/arch/c6x/lib/llshru.S new file mode 100644 index 0000000..07a4631 --- /dev/null +++ b/arch/c6x/lib/llshru.S @@ -0,0 +1,36 @@ +;; Copyright (C) 2010 Texas Instruments Incorporated +;; Contributed by Mark Salter msalter@redhat.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + +;; uint64_t __c6xabi_llshru(uint64_t val, uint shift) + + .text + .global __c6xabi_llshru +__c6xabi_llshru: + mv .l1x B4,A1 + [!A1] b .s2 B3 ; return if zero shift count + mvk .s1 32,A0 + sub .d1 A0,A1,A0 + cmplt .l1 0,A0,A2 + [A2] shl .s1 A5,A0,A0 + nop + [!A2] neg .l1 A0,A4 +|| [A2] shru .s1 A4,A1,A4 + [!A2] shru .s1 A5,A4,A4 +|| [A2] or .d1 A4,A0,A4 +|| [!A2] mvk .l1 0,A5 + [A2] shru .s1 A5,A1,A5 + bnop .s2 B3,5 diff --git a/arch/c6x/lib/memcmp.c b/arch/c6x/lib/memcmp.c new file mode 100644 index 0000000..e3a98bc --- /dev/null +++ b/arch/c6x/lib/memcmp.c @@ -0,0 +1,24 @@ +/* + * linux/arch/c6x/lib/memcmp.c + * + * Port on Texas Instruments TMS320C6x architecture + * + * Copyright (C) 2004, 2009 Texas Instruments Incorporated + * Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#include <linux/types.h> + +int memcmp(const void *cs, const void *ct, size_t count) +{ + const unsigned char *su1, *su2; + + for (su1 = cs, su2 = ct; 0 < count; ++su1, ++su2, count--) + if (*su1 != *su2) + return (*su1 < *su2) ? -1 : 1; + return 0; +} + diff --git a/arch/c6x/lib/memcpy_64plus.S b/arch/c6x/lib/memcpy_64plus.S new file mode 100644 index 0000000..ce1d7c6 --- /dev/null +++ b/arch/c6x/lib/memcpy_64plus.S @@ -0,0 +1,45 @@ +; Port on Texas Instruments TMS320C6x architecture +; +; Copyright (C) 2006, 2009, 2010 Texas Instruments Incorporated +; Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) +; +; This program is free software; you can redistribute it and/or modify +; it under the terms of the GNU General Public License version 2 as +; published by the Free Software Foundation. +; + + .global memcpy + .text + +memcpy: + AND .L1 0x1,A6,A0 + || AND .S1 0x2,A6,A1 + || AND .L2X 0x4,A6,B0 + || MV .D1 A4,A3 + || MVC .S2 ILC,B2 + + [A0] LDB .D2T1 *B4++,A5 + [A1] LDB .D2T1 *B4++,A7 + [A1] LDB .D2T1 *B4++,A8 + [B0] LDNW .D2T1 *B4++,A9 + || SHRU .S2X A6,0x3,B1 + [!B1] BNOP .S2 B3,1 + + [A0] STB .D1T1 A5,*A3++ + ||[B1] MVC .S2 B1,ILC + [A1] STB .D1T1 A7,*A3++ + [A1] STB .D1T1 A8,*A3++ + [B0] STNW .D1T1 A9,*A3++ ; return when len < 8 + + SPLOOP 2 + + LDNDW .D2T1 *B4++,A9:A8 + NOP 3 + + NOP + SPKERNEL 0,0 + || STNDW .D1T1 A9:A8,*A3++ + + BNOP .S2 B3,4 + MVC .S2 B2,ILC + diff --git a/arch/c6x/lib/memmove.c b/arch/c6x/lib/memmove.c new file mode 100644 index 0000000..5672937 --- /dev/null +++ b/arch/c6x/lib/memmove.c @@ -0,0 +1,30 @@ +/* + * linux/arch/c6x/lib/memmove.c + * + * Port on Texas Instruments TMS320C6x architecture + * + * Copyright (C) 2005, 2009 Texas Instruments Incorporated + * Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#include <linux/types.h> +#include <linux/string.h> + +void *memmove(void *s1, const void *s2, size_t n) +{ + register char *s = (char *) s1; + register const char *p = (const char *) s2; + + if (p >= s) { + return memcpy(s, p, n); + } else { + while (n) { + --n; + s[n] = p[n]; + } + } + return s1; +} diff --git a/arch/c6x/lib/memset.c b/arch/c6x/lib/memset.c new file mode 100644 index 0000000..da4275b --- /dev/null +++ b/arch/c6x/lib/memset.c @@ -0,0 +1,20 @@ +/* + * linux/arch/c6x/lib/memcmp.c + * + * Port on Texas Instruments TMS320C6x architecture + * + * Copyright (C) 2004, 2009 Texas Instruments Incorporated + * Author: Aurelien Jacquiot (aurelien.jacquiot@jaluna.com) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#include <linux/types.h> +void *memset(void *mem, register int ch, register size_t length) +{ + register char *m = (char *)mem - 1; + while (length--) + *++m = ch; + return mem; +} diff --git a/arch/c6x/lib/mpyll.S b/arch/c6x/lib/mpyll.S new file mode 100644 index 0000000..8da8417 --- /dev/null +++ b/arch/c6x/lib/mpyll.S @@ -0,0 +1,47 @@ +;; Copyright (C) 2010 Texas Instruments Incorporated +;; Contributed by Mark Salter msalter@redhat.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + ;; uint64_t __c6xabi_mpyll(uint64_t x, uint64_t y) + ;; + ;; 64x64 multiply + ;; First compute partial results using 32-bit parts of x and y: + ;; + ;; b63 b32 b31 b0 + ;; ----------------------------- + ;; | 1 | 0 | + ;; ----------------------------- + ;; + ;; P0 = X0*Y0 + ;; P1 = X0*Y1 + X1*Y0 + ;; P2 = X1*Y1 + ;; + ;; result = (P2 << 64) + (P1 << 32) + P0 + ;; + ;; Since the result is also 64-bit, we can skip the P2 term. + + .text + .global __c6xabi_mpyll +__c6xabi_mpyll: + mpy32u .m1x A4,B4,A1:A0 ; X0*Y0 + b .s2 B3 + || mpy32u .m2x B5,A4,B1:B0 ; X0*Y1 (don't need upper 32-bits) + || mpy32u .m1x A5,B4,A3:A2 ; X1*Y0 (don't need upper 32-bits) + nop + nop + mv .s1 A0,A4 + add .l1x A2,B0,A5 + add .s1 A1,A5,A5 diff --git a/arch/c6x/lib/negll.S b/arch/c6x/lib/negll.S new file mode 100644 index 0000000..7747521 --- /dev/null +++ b/arch/c6x/lib/negll.S @@ -0,0 +1,29 @@ +;; Copyright (C) 2010 Texas Instruments Incorporated +;; Contributed by Mark Salter msalter@redhat.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + +;; int64_t __c6xabi_negll(int64_t val) + + .text + .global __c6xabi_negll +__c6xabi_negll: + b .s2 B3 + mvk .l1 0,A0 + subu .l1 A0,A4,A3:A2 + sub .l1 A0,A5,A0 +|| ext .s1 A3,24,24,A5 + add .l1 A5,A0,A5 + mv .s1 A2,A4 diff --git a/arch/c6x/lib/pop_rts.S b/arch/c6x/lib/pop_rts.S new file mode 100644 index 0000000..e1847fb --- /dev/null +++ b/arch/c6x/lib/pop_rts.S @@ -0,0 +1,30 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + .text + .global __c6xabi_pop_rts + +__c6xabi_pop_rts: + lddw .d2t2 *++B15, B3:B2 + lddw .d2t1 *++B15, A11:A10 + lddw .d2t2 *++B15, B11:B10 + lddw .d2t1 *++B15, A13:A12 + lddw .d2t2 *++B15, B13:B12 + lddw .d2t1 *++B15, A15:A14 +|| b .s2 B3 + ldw .d2t2 *++B15[2], B14 + nop 4 diff --git a/arch/c6x/lib/push_rts.S b/arch/c6x/lib/push_rts.S new file mode 100644 index 0000000..637d56a --- /dev/null +++ b/arch/c6x/lib/push_rts.S @@ -0,0 +1,28 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + .text + .global __c6xabi_push_rts +__c6xabi_push_rts: + stw .d2t2 B14, *B15--[2] + stdw .d2t1 A15:A14, *B15-- +|| b .s2x A3 + stdw .d2t2 B13:B12, *B15-- + stdw .d2t1 A13:A12, *B15-- + stdw .d2t2 B11:B10, *B15-- + stdw .d2t1 A11:A10, *B15-- + stdw .d2t2 B3:B2, *B15-- diff --git a/arch/c6x/lib/remi.S b/arch/c6x/lib/remi.S new file mode 100644 index 0000000..2760d77 --- /dev/null +++ b/arch/c6x/lib/remi.S @@ -0,0 +1,78 @@ +;; Copyright 2010, 2011 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + ;; ABI considerations for the divide functions + ;; The following registers are call-used: + ;; __c6xabi_divi A0,A1,A2,A4,A6,B0,B1,B2,B4,B5 + ;; __c6xabi_divu A0,A1,A2,A4,A6,B0,B1,B2,B4 + ;; __c6xabi_remi A1,A2,A4,A5,A6,B0,B1,B2,B4 + ;; __c6xabi_remu A1,A4,A5,A7,B0,B1,B2,B4 + ;; + ;; In our implementation, divu and remu are leaf functions, + ;; while both divi and remi call into divu. + ;; A0 is not clobbered by any of the functions. + ;; divu does not clobber B2 either, which is taken advantage of + ;; in remi. + ;; divi uses B5 to hold the original return address during + ;; the call to divu. + ;; remi uses B2 and A5 to hold the input values during the + ;; call to divu. It stores B3 in on the stack. + +#ifdef CONFIG_TI_C6X_COMPILER + .ref __c6xabi_divu +#endif + .text + .global __c6xabi_remi + +__c6xabi_remi: + stw .d2t2 B3, *B15--[2] +|| cmpgt .l1 0, A4, A1 +|| cmpgt .l2 0, B4, B2 +|| mv .s1 A4, A5 +|| call .s2 __c6xabi_divu + + [A1] neg .l1 A4, A4 +|| [B2] neg .l2 B4, B4 +|| xor .s2x B2, A1, B0 +|| mv .d2 B4, B2 + + [B0] addkpc .s2 _divu_ret_1, B3, 1 + [!B0] addkpc .s2 _divu_ret_2, B3, 1 + nop 2 +_divu_ret_1: + neg .l1 A4, A4 +_divu_ret_2: + ldw .d2t2 *++B15[2], B3 + +#if defined(CONFIG_TMS320C64XPLUS) || defined(CONFIG_TMS320C66X) + mpy32 .m1x A4, B2, A6 + nop 3 + ret .s2 B3 + sub .l1 A5, A6, A4 + nop 4 +#else + mpyu .m1x A4, B2, A1 + nop 1 + mpylhu .m1x A4, B2, A6 +|| mpylhu .m2x B2, A4, B2 +|| ret .s2 B3 + nop 1 + add .l1x A6, B2, A6 + shl .s1 A6, 16, A6 + add .d1 A6, A1, A6 + sub .l1 A5, A6, A4 +#endif diff --git a/arch/c6x/lib/remu.S b/arch/c6x/lib/remu.S new file mode 100644 index 0000000..e1d9f30 --- /dev/null +++ b/arch/c6x/lib/remu.S @@ -0,0 +1,81 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + ;; ABI considerations for the divide functions + ;; The following registers are call-used: + ;; __c6xabi_divi A0,A1,A2,A4,A6,B0,B1,B2,B4,B5 + ;; __c6xabi_divu A0,A1,A2,A4,A6,B0,B1,B2,B4 + ;; __c6xabi_remi A1,A2,A4,A5,A6,B0,B1,B2,B4 + ;; __c6xabi_remu A1,A4,A5,A7,B0,B1,B2,B4 + ;; + ;; In our implementation, divu and remu are leaf functions, + ;; while both divi and remi call into divu. + ;; A0 is not clobbered by any of the functions. + ;; divu does not clobber B2 either, which is taken advantage of + ;; in remi. + ;; divi uses B5 to hold the original return address during + ;; the call to divu. + ;; remi uses B2 and A5 to hold the input values during the + ;; call to divu. It stores B3 in on the stack. + + + .text + .global __c6xabi_remu + +__c6xabi_remu: + ;; The ABI seems designed to prevent these functions calling each other, + ;; so we duplicate most of the divsi3 code here. + mv .s2x A4, B1 + lmbd .l2 1, B4, B1 +|| [!B1] b .s2 B3 ; RETURN A +|| [!B1] mvk .d2 1, B4 + + mv .l1x B1, A7 +|| shl .s2 B4, B1, B4 + + cmpltu .l1x A4, B4, A1 + [!A1] sub .l1x A4, B4, A4 + shru .s2 B4, 1, B4 + +_remu_loop: + cmpgt .l2 B1, 7, B0 +|| [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + ;; RETURN A may happen here (note: must happen before the next branch) + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 +|| [B0] b .s1 _remu_loop + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + ;; loop backwards branch happens here + + ret .s2 B3 + [B1] subc .l1x A4,B4,A4 +|| [B1] add .s2 -1, B1, B1 + [B1] subc .l1x A4,B4,A4 + + extu .s1 A4, A7, A4 + nop 2 + diff --git a/arch/c6x/lib/strasgi.S b/arch/c6x/lib/strasgi.S new file mode 100644 index 0000000..6861e25 --- /dev/null +++ b/arch/c6x/lib/strasgi.S @@ -0,0 +1,88 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + .text + .global __c6xabi_strasgi + +__c6xabi_strasgi: + + ;; This is essentially memcpy, with alignment known to be at least + ;; 4, and the size a multiple of 4 greater than or equal to 28. + ldw .d2t1 *B4++, A0 +|| mvk .s2 16, B1 + ldw .d2t1 *B4++, A1 +|| mvk .s2 20, B2 +|| sub .d1 A6, 24, A6 + ldw .d2t1 *B4++, A5 + ldw .d2t1 *B4++, A7 +|| mv .l2x A6, B7 + ldw .d2t1 *B4++, A8 + ldw .d2t1 *B4++, A9 +|| mv .s2x A0, B5 +|| cmpltu .l2 B2, B7, B0 + +_strasgi_loop: + stw .d1t2 B5, *A4++ +|| [B0] ldw .d2t1 *B4++, A0 +|| mv .s2x A1, B5 +|| mv .l2 B7, B6 + + [B0] sub .d2 B6, 24, B7 +|| [B0] b .s2 _strasgi_loop +|| cmpltu .l2 B1, B6, B0 + + [B0] ldw .d2t1 *B4++, A1 +|| stw .d1t2 B5, *A4++ +|| mv .s2x A5, B5 +|| cmpltu .l2 12, B6, B0 + + [B0] ldw .d2t1 *B4++, A5 +|| stw .d1t2 B5, *A4++ +|| mv .s2x A7, B5 +|| cmpltu .l2 8, B6, B0 + + [B0] ldw .d2t1 *B4++, A7 +|| stw .d1t2 B5, *A4++ +|| mv .s2x A8, B5 +|| cmpltu .l2 4, B6, B0 + + [B0] ldw .d2t1 *B4++, A8 +|| stw .d1t2 B5, *A4++ +|| mv .s2x A9, B5 +|| cmpltu .l2 0, B6, B0 + + [B0] ldw .d2t1 *B4++, A9 +|| stw .d1t2 B5, *A4++ +|| mv .s2x A0, B5 +|| cmpltu .l2 B2, B7, B0 + + ;; loop back branch happens here + + cmpltu .l2 B1, B6, B0 +|| ret .s2 b3 + + [B0] stw .d1t1 A1, *A4++ +|| cmpltu .l2 12, B6, B0 + [B0] stw .d1t1 A5, *A4++ +|| cmpltu .l2 8, B6, B0 + [B0] stw .d1t1 A7, *A4++ +|| cmpltu .l2 4, B6, B0 + [B0] stw .d1t1 A8, *A4++ +|| cmpltu .l2 0, B6, B0 + [B0] stw .d1t1 A9, *A4++ + + ;; return happens here diff --git a/arch/c6x/lib/strasgi_64plus.S b/arch/c6x/lib/strasgi_64plus.S new file mode 100644 index 0000000..cbeab22 --- /dev/null +++ b/arch/c6x/lib/strasgi_64plus.S @@ -0,0 +1,37 @@ +;; Copyright 2010 Free Software Foundation, Inc. +;; Contributed by Bernd Schmidt bernds@codesourcery.com. +;; +;; This program is free software; you can redistribute it and/or modify +;; it under the terms of the GNU General Public License as published by +;; the Free Software Foundation; either version 2 of the License, or +;; (at your option) any later version. +;; +;; This program is distributed in the hope that it will be useful, +;; but WITHOUT ANY WARRANTY; without even the implied warranty of +;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +;; GNU General Public License for more details. +;; +;; You should have received a copy of the GNU General Public License +;; along with this program; if not, write to the Free Software +;; Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + + .text + .global __c6xabi_strasgi_64plus + +__c6xabi_strasgi_64plus: + shru .s2x a6, 2, b31 +|| mv .s1 a4, a30 +|| mv .d2 b4, b30 + + add .s2 -4, b31, b31 + + sploopd 1 +|| mvc .s2 b31, ilc + ldw .d2t2 *b30++, b31 + nop 4 + mv .s1x b31,a31 + spkernel 6, 0 +|| stw .d1t1 a31, *a30++ + + ret .s2 b3 + nop 5 diff --git a/arch/c6x/lib/unaligned.S b/arch/c6x/lib/unaligned.S new file mode 100644 index 0000000..a825b4d --- /dev/null +++ b/arch/c6x/lib/unaligned.S @@ -0,0 +1,117 @@ +; +; arch/c6x/kernel/unaligned.S +; +; Port on Texas Instruments TMS320C6x architecture +; +; Copyright (C) 2010 Texas Instruments Incorporated +; Author: Mark Salter (msalter@redhat.com) +; +; This program is free software; you can redistribute it and/or modify +; it under the terms of the GNU General Public License version 2 as +; published by the Free Software Foundation. +; + + .text + .global get_unaligned_le64 + .global get_unaligned_be64 + .global get_unaligned_le32 + .global get_unaligned_be32 + .global put_unaligned_le64 + .global put_unaligned_be64 + .global put_unaligned_le32 + .global put_unaligned_be32 + +; u64 get_unaligned_le64(void *ptr); +; u64 get_unaligned_be64(void *ptr); +; +#ifdef CONFIG_CPU_BIG_ENDIAN +get_unaligned_le64: +#else +get_unaligned_be64: +#endif + LDNDW .D1T1 *A4,A5:A4 + NOP 2 + BNOP .S2 B3,1 + MV .D2X A4,B0 + SWAP2 .S2 B0,B1 + || SWAP2 .S1 A5,A0 + SWAP4 .L2 B1,B0 + || SWAP4 .L1 A0,A4 + MV .D1X B0,A5 + +#ifdef CONFIG_CPU_BIG_ENDIAN +get_unaligned_be64: +#else +get_unaligned_le64: +#endif + BNOP .S2 B3,5 + || LDNDW .D1T1 *A4,A5:A4 + +; u32 get_unaligned_le32(void *ptr, int size); +; u32 get_unaligned_be32(void *ptr, int size); +; +#ifdef CONFIG_CPU_BIG_ENDIAN +get_unaligned_le32: +#else +get_unaligned_be32: +#endif + LDNW .D1T1 *A4,A4 + BNOP .S2 B3,3 + SWAP2 .S1 A4,A0 + SWAP4 .L1 A0,A4 + +#ifdef CONFIG_CPU_BIG_ENDIAN +get_unaligned_be32: +#else +get_unaligned_le32: +#endif + BNOP .S2 B3,5 + || LDNW .D1T1 *A4,A4 + + +; void put_unaligned_le64(u64 val, void *ptr); +; void put_unaligned_be64(u64 val, void *ptr); +; +#ifdef CONFIG_CPU_BIG_ENDIAN +put_unaligned_le64: +#else +put_unaligned_be64: +#endif + B .S2 B3 + MV .D2X A4,B0 + SWAP2 .S2 B0,B1 + || SWAP2 .S1 A5,A0 + SWAP4 .L2 B1,B0 + || SWAP4 .L1 A0,A4 + MV .D1X B0,A5 + STNDW .D2T1 A5:A4,*B4 + +#ifdef CONFIG_CPU_BIG_ENDIAN +put_unaligned_be64: +#else +put_unaligned_le64: +#endif + BNOP .S2 B3,5 + || STNDW .D2T1 A5:A4,*B4 + +; void put_unaligned_le32(u32 val, void *ptr); +; void put_unaligned_be32(u32 val, void *ptr); +; +#ifdef CONFIG_CPU_BIG_ENDIAN +put_unaligned_le32: +#else +put_unaligned_be32: +#endif + BNOP .S2 B3,2 + SWAP2 .S1 A4,A5 + SWAP4 .L1 A5,A4 + STNW .D2T1 A4,*B4 + +#ifdef CONFIG_CPU_BIG_ENDIAN +put_unaligned_be32: +#else +put_unaligned_le32: +#endif + BNOP .S2 B3,5 + || STNW .D2T1 A4,*B4 + diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 42f08fd..faf534b 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -513,6 +513,11 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 0; } +#elif defined(CONFIG_C6X) +int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return 0; +}
#else #error "a case for this architecture does not exist!" diff --git a/common/image.c b/common/image.c index 91954ac..0fff687 100644 --- a/common/image.c +++ b/common/image.c @@ -456,8 +456,12 @@ phys_size_t getenv_bootm_size(void) #if defined(CONFIG_ARM) return gd->bd->bi_dram[0].size - tmp; #else +#if defined(CONFIG_C6X) + return gd->bd->bi_dram[0].size - tmp; +#else return gd->bd->bi_memsize - tmp; #endif +#endif }
phys_size_t getenv_bootm_mapsize(void) diff --git a/examples/standalone/stubs.c b/examples/standalone/stubs.c index 15e9afc..c9e0819 100644 --- a/examples/standalone/stubs.c +++ b/examples/standalone/stubs.c @@ -195,6 +195,21 @@ gd_t *global_data; " l.jr r13\n" \ " l.nop\n" \ : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r13"); + +#elif defined(CONFIG_C6X) +/* + * b31 holds the pointer to the global_data, a0 is a call-clobbered + * register + */ +#define EXPORT_FUNC(x) \ + asm volatile ( \ +" .globl " #x "\n" \ +#x ":\n" \ +" B .S2X A0\n" \ +" NOP 3\n" \ + : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "A0"); + + #else /*" addi $sp, $sp, -24\n" \ " br $r16\n" */
On Mon, Jun 25, 2012 at 10:02:38PM +0400, Dmitry Bondar wrote:
C6X (C6000) is Texas Instruments architecture of fixed and floating-point DSPs. This patch add basic support. Many of code in arch/c6x/include/asm come from c6x-linux project (http://linux-c6x.org)
Signed-off-by: Dmitry Bondar bond@inmys.ru Cc: Tom Rini trini@ti.com
Please cite the exact commit from upstream where this comes from (I imagine you could even use kernel.org proper, but I didn't check all files just a few) and say for example: Backport from linux commit 27406e978f596a646b87941cba5247eb0ccc8916
+#ifndef __ASM_GBL_DATA_H
Tabs instead of spaces. I don't know why checkpatch didn't complain but please give all of the files a quick check for things like <tab><space> and '#define<tab>' and '#ifndef<tab>.
I spot-checked a few of the library files and they seem to match the kernel which is important so I'll set aside disliking ';' as a comment char.
[snip]
You should be able to define a minimal set of prints here, see the OpenRISC example above it.
- return gd->bd->bi_dram[0].size - tmp;
Here and possibly another place or two in the file, just change the check from defined(CONFIG_ARM) to defined(CONFIG_ARM) || defined(CONFIG_C6X).
Thanks!
Must I say it in each file, or in commit message?
If in commit, how about something like this: " Many of code in arch/c6x/include/asm and arch/c6x/lib come from linux kernel, c6x headers (arch/c6x/include/asm) in linux kernel mainline from commit a7f626c1948ab6178d2338831c5ffea7385e9f7f c6x libs (arch/c6x/lib) in linux kernel mainline from 09831ca73443bd819ad7993db5409b19c899ba33 "
[snip]
Thanks!
-- Tom
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Just the commit message.
Yes, or just make sure that both parts are still in sync with the kernel at whichever of those commits is later. That'll make any future re-syncs easier on you :)
- -- Tom
Dear bond@inmys.ru,
How about reading the documentation? It answers such questions, with examples and all that.
you should also update README and doc/README.standalone with some notes about the C6X architecture. just search for "blackfin" for the areas you should fill in.
--- /dev/null +++ b/arch/c6x/config.mk @@ -0,0 +1 @@ +CROSS_COMPILE ?= c6x-uclinux-
missing intro comment block w/copyright/licnese. look at any other arch's config.mk to see an example.
you should prob also add a default CONFIG_STANDALONE_LOAD_ADDR
--- /dev/null +++ b/arch/c6x/include/asm/global_data.h
should be space after the ifndef, not a tab
+typedef struct global_data {
- bd_t *bd;
- unsigned long flags;
- unsigned long baudrate;
- unsigned long have_console; /* serial_init() was called */
+#ifdef CONFIG_PRE_CONSOLE_BUFFER
- unsigned long precon_buf_idx; /* Pre-Console buffer index */
- unsigned long env_addr; /* Address of Environment struct */
- unsigned long env_valid; /* Checksum of Environment valid? */
- unsigned long fb_base; /* base address of frame buffer */
- /* "static data" needed by most of timer.c (like on ARM platform) */
- unsigned long timer_rate_hz;
- unsigned long tbl;
- unsigned long tbu;
- unsigned long long timer_reset_value;
- unsigned long lastinc;
- phys_size_t ram_size; /* RAM size */
+#if 0
- unsigned long relocaddr; /* Start address of U-Boot in RAM */
- unsigned long mon_len; /* monitor len */
- unsigned long irq_sp; /* irq stack pointer */
- unsigned long start_addr_sp; /* start_addr_stackpointer */
- unsigned long reloc_off;
delete dead code. you should also kill any fields you don't actually need rather than just copying from another arch. the timer_rate_hz/tbl/tbu/timer_reset_value/lastinc look suspicious to me.
--- /dev/null +++ b/arch/c6x/include/asm/sizes.h
do you actually need this ? i don't think you do, so kill it. if you have some file that includes it, fix it and get rid of this file.
--- /dev/null +++ b/arch/c6x/include/asm/u-boot-c6x.h
please rename to sections.h
+#ifndef _U_BOOT_C6X_H_ +#define _U_BOOT_C6X_H_ 1
no need to define to 1
--- /dev/null +++ b/arch/c6x/include/asm/u-boot.h
+typedef struct bd_info {
- int bi_baudrate; /* serial console baudrate */
- unsigned long bi_ip_addr; /* IP Address */
- ulong bi_arch_number; /* unique id for this board */
- ulong bi_boot_params; /* where this board expects params */
- unsigned long bi_arm_freq; /* arm frequency */
- unsigned long bi_dsp_freq; /* dsp core frequency */
- unsigned long bi_ddr_freq; /* ddr frequency */
- struct /* RAM configuration */
ulong start;
ulong size;
- } bi_dram[CONFIG_NR_DRAM_BANKS];
+} bd_t;
again, please go through here and delete members you don't actually need
+/* For image.h:image_check_target_arch() */ +#define IH_ARCH_DEFAULT IH_ARCH_ARM
brrrr-wrong
--- /dev/null +++ b/arch/c6x/lib/board.c
+#ifdef CONFIG_STATUS_LED +#include <status_led.h> +#endif
no need to conditionalize the include
+static int display_banner(void) +{
- printf("\n\n%s\n\n", version_string);
just call display_options()
- WATCHDOG_RESET();
delete dead code
- char *const argv[])
- reset_cpu(0);
delete trailing newlines
(void)
(void)
- const unsigned char *su1, *su2;
- for (su1 = cs, su2 = ct; 0 < count; ++su1, ++su2, count--)
if (*su1 != *su2)
- register char *s = (char *) s1;
- register const char *p = (const char *) s2;
- if (p >= s) {
- } else {
while (n) {
--n;
s[n] = p[n];
- return s1;
- register char *m = (char *)mem - 1;
- while (length--)
*++m = ch;
- return mem;
i can't see how these would be any better than the ones we already have in lib/string.c. i say delete these files and don't bother. -mike
participants (5)
bond@inmys.ru
Dmitry Bondar
Mike Frysinger
