[U-Boot] [PATCHv3 0/6] dm: cache: add dm cache driver
This is V3 of the series to add a UCLASS_CACHE dm driver to handling the configuration of cache settings. Place this new driver under /drivers/cache. In this initial revision, the driver is only configuring what I think are essential cache settings. The more comprehensive cache settings can be done in the OS.
Diffs from v2: - Add cache_get_info() to check for non-zero value - Add comments to cache_info struct - Fix up nits from Simon Glass
Dinh Nguyen (6): Documentation: dts: Add pl310 cache controller dts documentation ARM: pl310: Add macro's for handling tag and data latency mask dm: cache: Create a uclass for cache dm: cache: add the pl310 cache controller driver ARM: socfpga: use the pl310 driver to configure the cache configs: socfpga: add imply pl310 cache controller
.../devicetree/bindings/arm/l2c2x0.txt | 114 ++++++++++++++++++ arch/arm/Kconfig | 1 + arch/arm/include/asm/pl310.h | 3 + arch/arm/mach-socfpga/misc.c | 16 +-- drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/cache/Kconfig | 25 ++++ drivers/cache/Makefile | 4 + drivers/cache/cache-l2x0.c | 76 ++++++++++++ drivers/cache/cache-uclass.c | 24 ++++ drivers/cache/sandbox_cache.c | 34 ++++++ include/cache.h | 38 ++++++ include/dm/uclass-id.h | 1 + test/dm/cache.c | 20 +++ 14 files changed, 346 insertions(+), 13 deletions(-) create mode 100644 Documentation/devicetree/bindings/arm/l2c2x0.txt create mode 100644 drivers/cache/Kconfig create mode 100644 drivers/cache/Makefile create mode 100644 drivers/cache/cache-l2x0.c create mode 100644 drivers/cache/cache-uclass.c create mode 100644 drivers/cache/sandbox_cache.c create mode 100644 include/cache.h create mode 100644 test/dm/cache.c
Linux commit 8ecd7f5970c5 ("ARM: 8483/1: Documentation: l2c: Rename l2cc to l2c2x0")
Linux docs: Documentation/devicetree/bindings/arm/l2c2x0.txt
Copied from Linux kernel v5.0.
"The documentation in the l2cc.txt is specific to the L2 cache controllers L2C210/L2C220/L2C310 (also known as PL210/PL220/PL310 and variants) and not generic as the file name implies. It's not valid for integrated L2 controllers as found in e.g. Cortex-A15/A7/A57/A53."
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- .../devicetree/bindings/arm/l2c2x0.txt | 114 ++++++++++++++++++ 1 file changed, 114 insertions(+) create mode 100644 Documentation/devicetree/bindings/arm/l2c2x0.txt
diff --git a/Documentation/devicetree/bindings/arm/l2c2x0.txt b/Documentation/devicetree/bindings/arm/l2c2x0.txt new file mode 100644 index 0000000000..fbe6cb21f4 --- /dev/null +++ b/Documentation/devicetree/bindings/arm/l2c2x0.txt @@ -0,0 +1,114 @@ +* ARM L2 Cache Controller + +ARM cores often have a separate L2C210/L2C220/L2C310 (also known as PL210/PL220/ +PL310 and variants) based level 2 cache controller. All these various implementations +of the L2 cache controller have compatible programming models (Note 1). +Some of the properties that are just prefixed "cache-*" are taken from section +3.7.3 of the Devicetree Specification which can be found at: +https://www.devicetree.org/specifications/ + +The ARM L2 cache representation in the device tree should be done as follows: + +Required properties: + +- compatible : should be one of: + "arm,pl310-cache" + "arm,l220-cache" + "arm,l210-cache" + "bcm,bcm11351-a2-pl310-cache": DEPRECATED by "brcm,bcm11351-a2-pl310-cache" + "brcm,bcm11351-a2-pl310-cache": For Broadcom bcm11351 chipset where an + offset needs to be added to the address before passing down to the L2 + cache controller + "marvell,aurora-system-cache": Marvell Controller designed to be + compatible with the ARM one, with system cache mode (meaning + maintenance operations on L1 are broadcasted to the L2 and L2 + performs the same operation). + "marvell,aurora-outer-cache": Marvell Controller designed to be + compatible with the ARM one with outer cache mode. + "marvell,tauros3-cache": Marvell Tauros3 cache controller, compatible + with arm,pl310-cache controller. +- cache-unified : Specifies the cache is a unified cache. +- cache-level : Should be set to 2 for a level 2 cache. +- reg : Physical base address and size of cache controller's memory mapped + registers. + +Optional properties: + +- arm,data-latency : Cycles of latency for Data RAM accesses. Specifies 3 cells of + read, write and setup latencies. Minimum valid values are 1. Controllers + without setup latency control should use a value of 0. +- arm,tag-latency : Cycles of latency for Tag RAM accesses. Specifies 3 cells of + read, write and setup latencies. Controllers without setup latency control + should use 0. Controllers without separate read and write Tag RAM latency + values should only use the first cell. +- arm,dirty-latency : Cycles of latency for Dirty RAMs. This is a single cell. +- arm,filter-ranges : <start length> Starting address and length of window to + filter. Addresses in the filter window are directed to the M1 port. Other + addresses will go to the M0 port. +- arm,io-coherent : indicates that the system is operating in an hardware + I/O coherent mode. Valid only when the arm,pl310-cache compatible + string is used. +- interrupts : 1 combined interrupt. +- cache-size : specifies the size in bytes of the cache +- cache-sets : specifies the number of associativity sets of the cache +- cache-block-size : specifies the size in bytes of a cache block +- cache-line-size : specifies the size in bytes of a line in the cache, + if this is not specified, the line size is assumed to be equal to the + cache block size +- cache-id-part: cache id part number to be used if it is not present + on hardware +- wt-override: If present then L2 is forced to Write through mode +- arm,double-linefill : Override double linefill enable setting. Enable if + non-zero, disable if zero. +- arm,double-linefill-incr : Override double linefill on INCR read. Enable + if non-zero, disable if zero. +- arm,double-linefill-wrap : Override double linefill on WRAP read. Enable + if non-zero, disable if zero. +- arm,prefetch-drop : Override prefetch drop enable setting. Enable if non-zero, + disable if zero. +- arm,prefetch-offset : Override prefetch offset value. Valid values are + 0-7, 15, 23, and 31. +- arm,shared-override : The default behavior of the L220 or PL310 cache + controllers with respect to the shareable attribute is to transform "normal + memory non-cacheable transactions" into "cacheable no allocate" (for reads) + or "write through no write allocate" (for writes). + On systems where this may cause DMA buffer corruption, this property must be + specified to indicate that such transforms are precluded. +- arm,parity-enable : enable parity checking on the L2 cache (L220 or PL310). +- arm,parity-disable : disable parity checking on the L2 cache (L220 or PL310). +- arm,outer-sync-disable : disable the outer sync operation on the L2 cache. + Some core tiles, especially ARM PB11MPCore have a faulty L220 cache that + will randomly hang unless outer sync operations are disabled. +- prefetch-data : Data prefetch. Value: <0> (forcibly disable), <1> + (forcibly enable), property absent (retain settings set by firmware) +- prefetch-instr : Instruction prefetch. Value: <0> (forcibly disable), + <1> (forcibly enable), property absent (retain settings set by + firmware) +- arm,dynamic-clock-gating : L2 dynamic clock gating. Value: <0> (forcibly + disable), <1> (forcibly enable), property absent (OS specific behavior, + preferably retain firmware settings) +- arm,standby-mode: L2 standby mode enable. Value <0> (forcibly disable), + <1> (forcibly enable), property absent (OS specific behavior, + preferably retain firmware settings) +- arm,early-bresp-disable : Disable the CA9 optimization Early BRESP (PL310) +- arm,full-line-zero-disable : Disable the CA9 optimization Full line of zero + write (PL310) + +Example: + +L2: cache-controller { + compatible = "arm,pl310-cache"; + reg = <0xfff12000 0x1000>; + arm,data-latency = <1 1 1>; + arm,tag-latency = <2 2 2>; + arm,filter-ranges = <0x80000000 0x8000000>; + cache-unified; + cache-level = <2>; + interrupts = <45>; +}; + +Note 1: The description in this document doesn't apply to integrated L2 + cache controllers as found in e.g. Cortex-A15/A7/A57/A53. These + integrated L2 controllers are assumed to be all preconfigured by + early secure boot code. Thus no need to deal with their configuration + in the kernel at all.
Add the PL310 macros for latency control setup, read and write bits.
Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- arch/arm/include/asm/pl310.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/pl310.h b/arch/arm/include/asm/pl310.h index b83978b1cc..f69e9e45f8 100644 --- a/arch/arm/include/asm/pl310.h +++ b/arch/arm/include/asm/pl310.h @@ -18,6 +18,9 @@ #define L310_SHARED_ATT_OVERRIDE_ENABLE (1 << 22) #define L310_AUX_CTRL_DATA_PREFETCH_MASK (1 << 28) #define L310_AUX_CTRL_INST_PREFETCH_MASK (1 << 29) +#define L310_LATENCY_CTRL_SETUP(n) ((n) << 0) +#define L310_LATENCY_CTRL_RD(n) ((n) << 4) +#define L310_LATENCY_CTRL_WR(n) ((n) << 8)
#define L2X0_CACHE_ID_PART_MASK (0xf << 6) #define L2X0_CACHE_ID_PART_L310 (3 << 6)
The cache UCLASS will be used for configure settings that can be found in a CPU's L2 cache controller.
Add a uclass and a test for cache.
Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- v3: Add cache_get_info() to check for non-zero value Add comments to cache_info struct v2: separate out uclass patch from driver and add test --- drivers/Kconfig | 2 ++ drivers/Makefile | 1 + drivers/cache/Kconfig | 16 +++++++++++++++ drivers/cache/Makefile | 3 +++ drivers/cache/cache-uclass.c | 24 ++++++++++++++++++++++ drivers/cache/sandbox_cache.c | 34 +++++++++++++++++++++++++++++++ include/cache.h | 38 +++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + test/dm/cache.c | 20 ++++++++++++++++++ 9 files changed, 139 insertions(+) create mode 100644 drivers/cache/Kconfig create mode 100644 drivers/cache/Makefile create mode 100644 drivers/cache/cache-uclass.c create mode 100644 drivers/cache/sandbox_cache.c create mode 100644 include/cache.h create mode 100644 test/dm/cache.c
diff --git a/drivers/Kconfig b/drivers/Kconfig index f24351ac4f..842201b753 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -14,6 +14,8 @@ source "drivers/block/Kconfig"
source "drivers/bootcount/Kconfig"
+source "drivers/cache/Kconfig" + source "drivers/clk/Kconfig"
source "drivers/cpu/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index a7bba3ed56..0a00096332 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -77,6 +77,7 @@ obj-$(CONFIG_BIOSEMU) += bios_emulator/ obj-y += block/ obj-y += board/ obj-$(CONFIG_BOOTCOUNT_LIMIT) += bootcount/ +obj-y += cache/ obj-$(CONFIG_CPU) += cpu/ obj-y += crypto/ obj-$(CONFIG_FASTBOOT) += fastboot/ diff --git a/drivers/cache/Kconfig b/drivers/cache/Kconfig new file mode 100644 index 0000000000..8b7c9c7f9f --- /dev/null +++ b/drivers/cache/Kconfig @@ -0,0 +1,16 @@ +# +# Cache controllers +# + +menu "Cache Controller drivers" + +config CACHE + bool "Enable Driver Model for Cache controllers" + depends on DM + help + Enable driver model for cache controllers that are found on + most CPU's. Cache is memory that the CPU can access directly and + is usually located on the same chip. This uclass can be used for + configuring settings that be found from a device tree file. + +endmenu diff --git a/drivers/cache/Makefile b/drivers/cache/Makefile new file mode 100644 index 0000000000..2ba68060c1 --- /dev/null +++ b/drivers/cache/Makefile @@ -0,0 +1,3 @@ + +obj-$(CONFIG_CACHE) += cache-uclass.o +obj-$(CONFIG_SANDBOX) += sandbox_cache.o diff --git a/drivers/cache/cache-uclass.c b/drivers/cache/cache-uclass.c new file mode 100644 index 0000000000..97ce0249a4 --- /dev/null +++ b/drivers/cache/cache-uclass.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <cache.h> +#include <dm.h> + +int cache_get_info(struct udevice *dev, struct cache_info *info) +{ + struct cache_ops *ops = cache_get_ops(dev); + + if (!ops->get_info) + return -ENOSYS; + + return ops->get_info(dev, info); +} + +UCLASS_DRIVER(cache) = { + .id = UCLASS_CACHE, + .name = "cache", + .post_bind = dm_scan_fdt_dev, +}; diff --git a/drivers/cache/sandbox_cache.c b/drivers/cache/sandbox_cache.c new file mode 100644 index 0000000000..b67ce31218 --- /dev/null +++ b/drivers/cache/sandbox_cache.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <cache.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int sandbox_get_info(struct udevice *dev, struct cache_info *info) +{ + info->base = 0; + + return 0; +} + +static const struct cache_ops sandbox_cache_ops = { + .get_info = sandbox_get_info, +}; + +static const struct udevice_id sandbox_cache_ids[] = { + { .compatible = "sandbox,cache" }, + { } +}; + +U_BOOT_DRIVER(cache_sandbox) = { + .name = "cache_sandbox", + .id = UCLASS_CACHE, + .of_match = sandbox_cache_ids, + .ops = &sandbox_cache_ops, +}; diff --git a/include/cache.h b/include/cache.h new file mode 100644 index 0000000000..c6334ca27f --- /dev/null +++ b/include/cache.h @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#ifndef __CACHE_H +#define __CACHE_H + +/* + * Structure for the cache controller + */ +struct cache_info { + phys_addr_t base; /* Base physical address of cache device. */ +}; + +struct cache_ops { + /** + * get_info() - Get basic cache info + * + * @dev: Device to check (UCLASS_CACHE) + * @info: Place to put info + * @return 0 if OK, -ve on error + */ + int (*get_info)(struct udevice *dev, struct cache_info *info); +}; + +#define cache_get_ops(dev) ((struct cache_ops *)(dev)->driver->ops) + +/** + * cache_get_info() - Get information about a cache controller + * + * @dev: Device to check (UCLASS_CACHE) + * @info: Returns cache info + * @return 0 if OK, -ve on error + */ +int cache_get_info(struct udevice *dev, struct cache_info *info); + +#endif diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 86e59781b0..09e0ad5391 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -34,6 +34,7 @@ enum uclass_id { UCLASS_BLK, /* Block device */ UCLASS_BOARD, /* Device information from hardware */ UCLASS_BOOTCOUNT, /* Bootcount backing store */ + UCLASS_CACHE, /* Cache controller */ UCLASS_CLK, /* Clock source, e.g. used by peripherals */ UCLASS_CPU, /* CPU, typically part of an SoC */ UCLASS_CROS_EC, /* Chrome OS EC */ diff --git a/test/dm/cache.c b/test/dm/cache.c new file mode 100644 index 0000000000..d4144aab76 --- /dev/null +++ b/test/dm/cache.c @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> + +static int dm_test_reset(struct unit_test_state *uts) +{ + struct udevice *dev_cache; + struct cache_info; + + ut_assertok(uclass_get_device(UCLASS_CACHE, 0, &dev_cache)); + ut_assertok(cache_get_info(dev, &info)); + + return 0; +} +DM_TEST(dm_test_reset, DM_TESTF_SCAN_FDT);
Hi Dinh,
One nit - make sure that cache.h becomes before dm.h in the include order.
Add a PL310 cache controller driver that is usually found on ARMv7(32-bit) devices. The driver configures the cache settings that can be found in the device tree files.
This initial revision only configures basic settings(data & instruction prefetch, shared-override, data & tag latency). I believe these are the settings that affect performance the most. Comprehensive settings can be done by the OS.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- v3: Add Reviewed-by and fix nits v2: split out patch and address comments from Simon Glass --- drivers/cache/Kconfig | 9 +++++ drivers/cache/Makefile | 1 + drivers/cache/cache-l2x0.c | 76 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 86 insertions(+) create mode 100644 drivers/cache/cache-l2x0.c
diff --git a/drivers/cache/Kconfig b/drivers/cache/Kconfig index 8b7c9c7f9f..24def7ac0f 100644 --- a/drivers/cache/Kconfig +++ b/drivers/cache/Kconfig @@ -13,4 +13,13 @@ config CACHE is usually located on the same chip. This uclass can be used for configuring settings that be found from a device tree file.
+config L2X0_CACHE + tristate "PL310 cache driver" + select CACHE + depends on ARM + help + This driver is for the PL310 cache controller commonly found on + ARMv7(32-bit) devices. The driver configures the cache settings + found in the device tree. + endmenu diff --git a/drivers/cache/Makefile b/drivers/cache/Makefile index 2ba68060c1..9deb961d91 100644 --- a/drivers/cache/Makefile +++ b/drivers/cache/Makefile @@ -1,3 +1,4 @@
obj-$(CONFIG_CACHE) += cache-uclass.o obj-$(CONFIG_SANDBOX) += sandbox_cache.o +obj-$(CONFIG_L2X0_CACHE) += cache-l2x0.o diff --git a/drivers/cache/cache-l2x0.c b/drivers/cache/cache-l2x0.c new file mode 100644 index 0000000000..67c752d076 --- /dev/null +++ b/drivers/cache/cache-l2x0.c @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ +#include <common.h> +#include <command.h> +#include <dm.h> + +#include <asm/io.h> +#include <asm/pl310.h> + +static void l2c310_of_parse_and_init(struct udevice *dev) +{ + u32 tag[3] = { 0, 0, 0 }; + u32 saved_reg, prefetch; + struct pl310_regs *regs = (struct pl310_regs *)dev_read_addr(dev); + + /* Disable the L2 Cache */ + clrbits_le32(®s->pl310_ctrl, L2X0_CTRL_EN); + + saved_reg = readl(®s->pl310_aux_ctrl); + if (!dev_read_u32(dev, "prefetch-data", &prefetch)) { + if (prefetch) + saved_reg |= L310_AUX_CTRL_DATA_PREFETCH_MASK; + else + saved_reg &= ~L310_AUX_CTRL_DATA_PREFETCH_MASK; + } + + if (!dev_read_u32(dev, "prefetch-instr", &prefetch)) { + if (prefetch) + saved_reg |= L310_AUX_CTRL_INST_PREFETCH_MASK; + else + saved_reg &= ~L310_AUX_CTRL_INST_PREFETCH_MASK; + } + + saved_reg |= dev_read_bool(dev, "arm,shared-override"); + writel(saved_reg, ®s->pl310_aux_ctrl); + + saved_reg = readl(®s->pl310_tag_latency_ctrl); + if (!dev_read_u32_array(dev, "arm,tag-latency", tag, 3)) + saved_reg |= L310_LATENCY_CTRL_RD(tag[0] - 1) | + L310_LATENCY_CTRL_WR(tag[1] - 1) | + L310_LATENCY_CTRL_SETUP(tag[2] - 1); + writel(saved_reg, ®s->pl310_tag_latency_ctrl); + + saved_reg = readl(®s->pl310_data_latency_ctrl); + if (!dev_read_u32_array(dev, "arm,data-latency", tag, 3)) + saved_reg |= L310_LATENCY_CTRL_RD(tag[0] - 1) | + L310_LATENCY_CTRL_WR(tag[1] - 1) | + L310_LATENCY_CTRL_SETUP(tag[2] - 1); + writel(saved_reg, ®s->pl310_data_latency_ctrl); + + /* Enable the L2 cache */ + setbits_le32(®s->pl310_ctrl, L2X0_CTRL_EN); +} + +static int l2x0_probe(struct udevice *dev) +{ + l2c310_of_parse_and_init(dev); + + return 0; +} + + +static const struct udevice_id l2x0_ids[] = { + { .compatible = "arm,pl310-cache" }, + {} +}; + +U_BOOT_DRIVER(pl310_cache) = { + .name = "pl310_cache", + .id = UCLASS_CACHE, + .of_match = l2x0_ids, + .probe = l2x0_probe, + .flags = DM_FLAG_PRE_RELOC, +};
Find the UCLASS_CACHE driver to configure the cache controller's settings.
Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- arch/arm/mach-socfpga/misc.c | 16 +++------------- 1 file changed, 3 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index ec8339e045..34d8c4c51b 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -59,20 +59,10 @@ void enable_caches(void) #ifdef CONFIG_SYS_L2_PL310 void v7_outer_cache_enable(void) { - /* Disable the L2 cache */ - clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); - - writel(0x0, &pl310->pl310_tag_latency_ctrl); - writel(0x10, &pl310->pl310_data_latency_ctrl); - - /* enable BRESP, instruction and data prefetch, full line of zeroes */ - setbits_le32(&pl310->pl310_aux_ctrl, - L310_AUX_CTRL_DATA_PREFETCH_MASK | - L310_AUX_CTRL_INST_PREFETCH_MASK | - L310_SHARED_ATT_OVERRIDE_ENABLE); + struct udevice *dev;
- /* Enable the L2 cache */ - setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); + if (uclass_get_device(UCLASS_CACHE, 0, &dev)) + pr_err("cache controller driver NOT found!\n"); }
void v7_outer_cache_disable(void)
Select the PL310 UCLASS_CACHE driver for SoCFPGA.
Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f42eccef80..f4c6262bb0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -845,6 +845,7 @@ config ARCH_SOCFPGA imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE imply SPL_SPI_FLASH_SUPPORT imply SPL_SPI_SUPPORT + imply L2X0_CACHE
config ARCH_SUNXI bool "Support sunxi (Allwinner) SoCs"
Dinh Nguyen
