[U-Boot] [PATCH] omap3evm: Move function to identify board revision
Function omap3_evm_get_revision() - to identify the board revision was called at end of setup_net_chip().
Board revision can be ascertained only by identifying the Ethernet chipset - but combining setup operations with revision detection isn;t a good idea.
Moved the function and added detailed comment to set the context.
Signed-off-by: Sanjeev Premi premi@ti.com --- board/ti/evm/evm.c | 9 ++++++--- 1 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index 73330db..6163b12 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -109,6 +109,12 @@ int misc_init_r(void)
#if defined(CONFIG_CMD_NET) setup_net_chip(); + + /* + * Board revision can be ascertained only by identifying + * the Ethernet chipset. + */ + omap3_evm_get_revision(); #endif
dieid_num_r(); @@ -163,9 +169,6 @@ static void setup_net_chip(void) writel(GPIO0, &gpio3_base->cleardataout); udelay(1); writel(GPIO0, &gpio3_base->setdataout); - - /* determine omap3evm revision */ - omap3_evm_get_revision(); }
int board_eth_init(bd_t *bis)
-----Original Message----- From: Premi, Sanjeev Sent: Tuesday, October 19, 2010 6:37 PM To: u-boot@lists.denx.de Cc: Premi, Sanjeev Subject: [PATCH] omap3evm: Move function to identify board revision
#endif
[sp] While reviewing the code, I realized a "latent" bug that can hit us when CONFIG_CMD_NET is not defined.
omap3_evm_get_revision() never gets called - value of omap3_evm_version is never set. So, value returned by get_omap3_evm_rev() depends upon compiler used.
Please disregard this patch. I will submit a cleaned-up patch with takes care of this "latent" bug as well.
~sanjeev
1.7.2.2
Premi, Sanjeev
Sanjeev Premi
