[PATCH] imx8mp_evk: Increase CONFIG_SYS_MALLOC_F_LEN
When booting imx8mp-evk the following allocation error message is seen:
U-Boot 2021.01-rc3-00200-ge668bec96a5f (Dec 21 2020 - 14:36:42 -0300)
alloc space exhausted
Fix it by increasing CONFIG_SYS_MALLOC_F_LEN to 0x10000 like it is done on other i.MX8MM/8MN boards.
Reported-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Signed-off-by: Fabio Estevam festevam@gmail.com --- configs/imx8mp_evk_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index cd5724e811ab..c34a10c2d906 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40200000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SYS_MALLOC_F_LEN=0x10000 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_SYS_I2C_MXC_I2C1=y
Hello Fabio,
-----Original Message----- From: Fabio Estevam festevam@gmail.com Sent: Monday, December 21, 2020 7:41 PM To: sbabic@denx.de Cc: peng.fan@nxp.com; u-boot@lists.denx.de; ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com; uboot-imx@nxp.com; Fabio Estevam festevam@gmail.com Subject: [PATCH] imx8mp_evk: Increase CONFIG_SYS_MALLOC_F_LEN
It would be really great to get a review from Peng here, as his commit 28fff3fa1c ("imx: imx8mp_evk: fix boot issue") changed exactly this option from 0x10000 to 0x8000.
I've tested my local build with your patch and it boots OK, hence I cannot seem to find a reasoning why the early malloc area size has been halved with above commit.
diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index cd5724e811ab..c34a10c2d906 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40200000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SYS_MALLOC_F_LEN=0x10000 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_SYS_I2C_MXC_I2C1=y -- 2.17.1
Tested-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com
Hi Andrey,
On Mon, Dec 21, 2020 at 7:04 PM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote:
Yes, agreed.
Peng,
Please let us know if you are happy with this change.
Thanks for reporting and testing it.
Reviewed-by: Peng Fan peng.fan@nxp.com
I think it might be the DM clk exhausted the space, we need find a way to improve that.
Thanks, Peng.
Hi Tom and Stefano,
Please consider this one for 2021.01.
Thanks
On 22.12.20 11:59, Fabio Estevam wrote:
Hi Tom and Stefano,
Yes, I pick it up.
Regards, Stefano
Thanks
All,
Subject: RE: [PATCH] imx8mp_evk: Increase CONFIG_SYS_MALLOC_F_LEN
I am thinking to remove the CLK CCF support for i.MX8M, and use simple CLK DM. Do you agree?
Thanks, Peng.
Thanks, Peng.
100644
Hi Peng,
As a minimal fix for 2021.01, I suggest that we go with my patch.
After 2021.01 is released we can consider using simple CLK DM.
Thanks
Subject: Re: [PATCH] imx8mp_evk: Increase CONFIG_SYS_MALLOC_F_LEN
Hi Peng,
I agree.
Sure. I need people agree on this before action, then prepare the stuff.
Thanks, Peng
Thanks
When booting imx8mp-evk the following allocation error message is seen: U-Boot 2021.01-rc3-00200-ge668bec96a5f (Dec 21 2020 - 14:36:42 -0300) alloc space exhausted Fix it by increasing CONFIG_SYS_MALLOC_F_LEN to 0x10000 like it is done on other i.MX8MM/8MN boards. Reported-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Signed-off-by: Fabio Estevam festevam@gmail.com Tested-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Reviewed-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
participants (5)
Fabio Estevam
Peng Fan
sbabic@denx.de
Stefano Babic
ZHIZHIKIN Andrey
