[U-Boot] Fw:Re: Fw:How can I use yaffs2 in uboot
Sounds like a pretty clear error message - doesn't it?
Increase CONFIG_SYS_MALLOC_LEN in your bard config file.
[It might make sense to improve the error message in fs/yaffs2/yaffs_guts.c to include information how many bytes were to be allocated, so you get an idea on how uch to increase the malloc arena size.]
thanks a lot
Change CONFIG_SYS_MALLOC_LEN ,Now I can write a yaffs2 file system image (59M) in nand flash (/flash/a )
but The Linux how to find the file system image?(the system support yaffs2)
set bootargs noinitrd root=/dev/mtdblock3 rootfstype=yaffs2 rw console=ttySAC0,115200 init=/linuxrc mem=64M
this way doesn't work
I use
my2440# nand write.yaffs 30008000 0x580000 3b00000
NAND write: device 0 offset 0x580000, size 0x3b00000
written: OK
my2440#tftp zImage.img
and then bootm linux can find the file system image
Dear jackfriend,
thanks a lot
Please use quoting so one can see what was written by you and what was written by others. And remove unneeded lines. See http://www.netmeister.org/news/learn2quote.html
And how are your MTD partitions set up in Linux?
jackfriend
