[U-Boot] [PATCH] spl: Kconfig: Fix typo in 'Upgrade'
Correct the spelling of 'Upgrade'.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- common/spl/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index b44b741..2e79d7d 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -738,12 +738,12 @@ config SPL_USB_ETHER See also SPL_NET_SUPPORT and SPL_ETH_SUPPORT.
config SPL_DFU_SUPPORT - bool "Support DFU (Device Firmware Upgarde)" + bool "Support DFU (Device Firmware Upgrade)" select SPL_HASH_SUPPORT select SPL_DFU_NO_RESET depends on SPL_RAM_SUPPORT help - This feature enables the DFU (Device Firmware Upgarde) in SPL with + This feature enables the DFU (Device Firmware Upgrade) in SPL with RAM memory device support. The ROM code will load and execute the SPL built with dfu. The user can load binaries (u-boot/kernel) to selected device partition from host-pc using dfu-utils.
Fabio Estevam
