[U-Boot] [PATCH] Kconfig: Drop CONFIG_EMAC_MDIO_PHY_NUM
This particular macro hasn't been used in the code for some time, remove these references that were missed.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/calimain.h | 1 - include/configs/ea20.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/tam3517-common.h | 1 - scripts/config_whitelist.txt | 1 - 5 files changed, 5 deletions(-)
diff --git a/include/configs/calimain.h b/include/configs/calimain.h index 425a38f55197..6e2fd3356323 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -176,7 +176,6 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC -#define CONFIG_EMAC_MDIO_PHY_NUM 1 #define CONFIG_MII #define CONFIG_BOOTP_DNS #define CONFIG_BOOTP_DNS2 diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 75100718831d..3a5b5c7285d5 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -79,7 +79,6 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC -#define CONFIG_EMAC_MDIO_PHY_NUM 0 #define CONFIG_MII #define CONFIG_BOOTP_DNS #define CONFIG_BOOTP_DNS2 diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 4efddb620746..0cc0042bca3b 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -227,7 +227,6 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC -#define CONFIG_EMAC_MDIO_PHY_NUM 7 #define CONFIG_MII #undef CONFIG_DRIVER_TI_EMAC_USE_RMII #define CONFIG_BOOTP_DEFAULT diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index b1625b779c10..0bdf52eb684a 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -169,7 +169,6 @@ #define CONFIG_DRIVER_TI_EMAC #define CONFIG_DRIVER_TI_EMAC_USE_RMII #define CONFIG_MII -#define CONFIG_EMAC_MDIO_PHY_NUM 0 #define CONFIG_BOOTP_DNS #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cd0165f9344d..76d2b5a8e8a9 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -776,7 +776,6 @@ CONFIG_EHCI_MMIO_BIG_ENDIAN CONFIG_EHCI_MXS_PORT0 CONFIG_EHCI_MXS_PORT1 CONFIG_ELBC_NAND_SPL_STATIC_PGSIZE -CONFIG_EMAC_MDIO_PHY_NUM CONFIG_EMAC_NR_START CONFIG_EMAC_PHY_MODE CONFIG_EMIF4
