[U-Boot] [PATCH v2 1/4] tools: mkimage: hdr_size used to facilitate customized support
hdr_size variable is initialized at the begining of image creation algorithm instead of reading it each time. This facilitate to use the common code for other image type implementations for ex. kwbimage
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- hdr_size declaration moved at the top
tools/mkimage.c | 18 ++++++++---------- 1 files changed, 8 insertions(+), 10 deletions(-)
diff --git a/tools/mkimage.c b/tools/mkimage.c index 967fe9a..40363a9 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -66,6 +66,7 @@ main (int argc, char **argv) struct stat sbuf; unsigned char *ptr; char *name = ""; + int hdr_size;
cmdname = *argv;
@@ -250,9 +251,9 @@ NXTARG: ; * * write dummy header, to be fixed later */ - memset (hdr, 0, image_get_header_size ()); - - if (write(ifd, hdr, image_get_header_size ()) != image_get_header_size ()) { + hdr_size = image_get_header_size (); + memset (hdr, 0, hdr_size); + if (write(ifd, hdr, hdr_size) != hdr_size) { fprintf (stderr, "%s: Write error on %s: %s\n", cmdname, imagefile, strerror(errno)); exit (EXIT_FAILURE); @@ -339,14 +340,12 @@ NXTARG: ; hdr = (image_header_t *)ptr;
checksum = crc32 (0, - (const char *)(ptr + image_get_header_size ()), - sbuf.st_size - image_get_header_size () - ); - + (const char *)(ptr + hdr_size), + sbuf.st_size - hdr_size); /* Build new header */ image_set_magic (hdr, IH_MAGIC); image_set_time (hdr, sbuf.st_mtime); - image_set_size (hdr, sbuf.st_size - image_get_header_size ()); + image_set_size (hdr, sbuf.st_size - hdr_size); image_set_load (hdr, addr); image_set_ep (hdr, ep); image_set_dcrc (hdr, checksum); @@ -354,10 +353,9 @@ NXTARG: ; image_set_arch (hdr, opt_arch); image_set_type (hdr, opt_type); image_set_comp (hdr, opt_comp); - image_set_name (hdr, name);
- checksum = crc32 (0, (const char *)hdr, image_get_header_size ()); + checksum = crc32 (0, (const char *)hdr, hdr_size);
image_set_hcrc (hdr, checksum);
For more details refer docs/README.kwbimage
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- Change log: v2: strtok_r() used for simple parser algorithm updated as per feedback for v1 all line checked to be below 78 :-)
Makefile | 5 + common/image.c | 1 + doc/README.kwbimage | 93 ++++++++++++++++++ include/image.h | 1 + tools/Makefile | 1 + tools/kwbimage.c | 264 +++++++++++++++++++++++++++++++++++++++++++++++++++ tools/kwbimage.h | 104 ++++++++++++++++++++ tools/mkimage.c | 26 +++++- 8 files changed, 494 insertions(+), 1 deletions(-) create mode 100644 doc/README.kwbimage create mode 100644 tools/kwbimage.c create mode 100644 tools/kwbimage.h
diff --git a/Makefile b/Makefile index 55fc2a3..ebe00dc 100644 --- a/Makefile +++ b/Makefile @@ -339,6 +339,10 @@ $(obj)u-boot.img: $(obj)u-boot.bin sed -e 's/"[ ]*$$/ for $(BOARD) board"/') \ -d $< $@
+$(obj)u-boot.kwb: $(obj)u-boot.bin + $(obj)tools/mkimage -n $(KWD_CONFIG) -T kwbimage \ + -a $(TEXT_BASE) -e $(TEXT_BASE) -d $< $@ + $(obj)u-boot.sha1: $(obj)u-boot.bin $(obj)tools/ubsha1 $(obj)u-boot.bin
@@ -3638,6 +3642,7 @@ clobber: clean @rm -f $(OBJS) $(obj)*.bak $(obj)ctags $(obj)etags $(obj)TAGS \ $(obj)cscope.* $(obj)*.*~ @rm -f $(obj)u-boot $(obj)u-boot.map $(obj)u-boot.hex $(ALL) + @rm -f $(obj)u-boot.kwb @rm -f $(obj)tools/{env/crc32.c,inca-swap-bytes} @rm -f $(obj)cpu/mpc824x/bedbug_603e.c @rm -f $(obj)include/asm/proc $(obj)include/asm/arch $(obj)include/asm diff --git a/common/image.c b/common/image.c index e22c974..845006f 100644 --- a/common/image.c +++ b/common/image.c @@ -145,6 +145,7 @@ static table_entry_t uimage_type[] = { { IH_TYPE_SCRIPT, "script", "Script", }, { IH_TYPE_STANDALONE, "standalone", "Standalone Program", }, { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, + { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, { -1, "", "", }, };
diff --git a/doc/README.kwbimage b/doc/README.kwbimage new file mode 100644 index 0000000..b8a9b6b --- /dev/null +++ b/doc/README.kwbimage @@ -0,0 +1,93 @@ +--------------------------------------------- +Kirkwood Boot Image generation using mkimage +--------------------------------------------- + +This document describes the U-Boot feature as it +is implemented for the Kirkwood family of SoCs. + +The Kirkwood SoC's can boot directly from NAND FLASH, +SPI FLASH, SATA etc. using its internal bootRom support. + +for more details refer section 24.2 of Kirkwood functional specifications. +ref: www.marvell.com/products/embedded.../kirkwood/index.jsp + +Commad syntax: +-------------- +./tools/mkimage -l <kwboot_file> + to list the kwb image file details + +./tools/mkimage -n <board specific configuration file> \ + -T kwbimage -a <start address> -e <execution address> \ + -d <input_raw_binary> <output_kwboot_file> + +for ex. +./tools/mkimage -n ./board/Marvell/openrd_base/kwbimage.cfg \ + -T kwbimage -a 0x00600000 -e 0x00600000 \ + -d u-boot.bin u-boot.kwb + +kwimage support available with mkimage utility will generate kirkwood boot +image that can be flashed on the board NAND/SPI flash + +Board specific configuration file specifications: +------------------------------------------------ +1. This file must present in the $(BOARDDIR) and the name should be + kwbimage.cfg (since this is used in Makefile) +2. This file can have empty lines and lines starting with "#" as first + character to put comments +3. This file can have configuration command lines as mentioned below, + any other information in this file is treated as invalid. + +Configuration command line syntax: +--------------------------------- +1. Each command line is must have two strings, first one command or address + and second one data string +2. Following are the valid command strings and associated data strings:- + Command string data string + -------------- ----------- + BOOT_FROM nand/spi/sata + NAND_ECC_MODE default/rs/hamming/disabled + NAND_PAGE_SIZE any uint16_t hex value + SATA_PIO_MODE any uint32_t hex value + DDR_INIT_DELAY any uint32_t hex value + <uint32_t reg addr> <uint32_t vlaue for it>, + you can have maximum 55 such register programming commands + +3. All commands are optional to program + +Typical example of kwimage.cfg file: +----------------------------------- + +# Boot Media configurations +BOOT_FROM nand +NAND_ECC_MODE default +NAND_PAGE_SIZE 0x0800 + +# Configure RGMII-0 interface pad voltage to 1.8V +0xFFD100e0 0x1b1b1b9b +# DRAM Configuration +0xFFD01400 0x43000c30 +0xFFD01404 0x37543000 +0xFFD01408 0x22125451 +0xFFD0140C 0x00000a33 +0xFFD01410 0x000000cc +0xFFD01414 0x00000000 +0xFFD01418 0x00000000 +0xFFD0141C 0x00000C52 +0xFFD01420 0x00000040 +0xFFD01424 0x0000F17F +0xFFD01428 0x00085520 +0xFFD0147C 0x00008552 +0xFFD01504 0x0FFFFFF1 +0xFFD01508 0x10000000 +0xFFD0150C 0x0FFFFFF5 +0xFFD01514 0x00000000 +0xFFD0151C 0x00000000 +0xFFD01494 0x00030000 +0xFFD01498 0x00000000 +0xFFD0149C 0x0000E803 +0xFFD01480 0x00000001 +# End of Header extension +0x0 0x0 + +------------------------------------------------ +Author: Prafulla Wadaskar prafulla@marvell.com diff --git a/include/image.h b/include/image.h index f183757..be322bd 100644 --- a/include/image.h +++ b/include/image.h @@ -158,6 +158,7 @@ #define IH_TYPE_SCRIPT 6 /* Script file */ #define IH_TYPE_FILESYSTEM 7 /* Filesystem Image (any type) */ #define IH_TYPE_FLATDT 8 /* Binary Flat Device Tree Blob */ +#define IH_TYPE_KWBIMAGE 9 /* Kirkwood Boot Image */
/* * Compression Types diff --git a/tools/Makefile b/tools/Makefile index 43c284c..5ead74c 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -167,6 +167,7 @@ $(obj)img2srec$(SFX): $(obj)img2srec.o $(STRIP) $@
$(obj)mkimage$(SFX): $(obj)mkimage.o $(obj)crc32.o $(obj)image.o $(obj)md5.o \ + $(obj)kwbimage.o \ $(obj)sha1.o $(LIBFDT_OBJS) $(obj)os_support.o $(CC) $(CFLAGS) $(HOST_LDFLAGS) -o $@ $^ $(STRIP) $@ diff --git a/tools/kwbimage.c b/tools/kwbimage.c new file mode 100644 index 0000000..b1ad37a --- /dev/null +++ b/tools/kwbimage.c @@ -0,0 +1,264 @@ +/* + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdlib.h> +#include <string.h> +#include <sys/mman.h> +#include <sys/stat.h> +#include <sys/types.h> +#include <unistd.h> +#include "kwbimage.h" + +static struct kwb_header kwbimage_header; +static int datacmd_cnt = 0; + +/* + * Generates 8 bit checksum + */ +uint8_t kwbimage_checksum8(void *start, uint32_t len, uint8_t csum) +{ + register uint8_t sum = csum; + volatile uint8_t *startp = (volatile uint8_t *)start; + + do { + sum += *startp; + startp++; + } while (--len); + return (sum); +} + +/* + * Generates 32 bit checksum + */ +uint32_t kwbimage_checksum32(uint32_t *start, uint32_t len, uint32_t csum) +{ + register uint32_t sum = csum; + volatile uint32_t *startp = start; + + do { + sum += *startp; + startp++; + len -= sizeof(uint32_t); + } while (len > 0); + return (sum); +} + +void *kwbimage_get_header_ptr (void) +{ + return ((void *)&kwbimage_header); +} + +int kwbimage_get_header_size (void) +{ + return (sizeof (struct kwb_header)); +} + +enum kwbimage_cmd kwbimage_check_cfgcmd(char *token, + struct kwb_header *kwbhdr) +{ + extbhr_t *exthdr = &kwbhdr->kwb_exthdr; + char tempptr[MAX_TEMPBUF_LEN]; + + /* command string processing */ + if (strcmp(token, "BOOT_FROM") == 0) + return CMD_BOOT_FROM; + else if (strcmp(token, "NAND_ECC_MODE") == 0) + return CMD_NAND_ECC_MODE; + else if (strcmp(token, "NAND_PAGE_SIZE") == 0) + return CMD_NAND_PAGE_SIZE; + else if (strcmp(token, "SATA_PIO_MODE") == 0) + return CMD_SATA_PIO_MODE; + else if (strcmp(token, "DDR_INIT_DELAY") == 0) + return CMD_DDR_INIT_DELAY; + else { + exthdr->rcfg[datacmd_cnt].raddr = + (uint32_t) strtoul (token, tempptr, 16); + return CMD_DDR_DATA; + } +} + +void kwbimage_check_cfgdata(char *token, enum kwbimage_cmd cmdsw, + struct kwb_header *kwbhdr) +{ + bhr_t *mhdr = &kwbhdr->kwb_hdr; + extbhr_t *exthdr = &kwbhdr->kwb_exthdr; + char tempptr[MAX_TEMPBUF_LEN]; + + switch(cmdsw) { + case CMD_BOOT_FROM: + if (strcmp(token, "spi") == 0) { + mhdr->blockid = IBR_HDR_SPI_ID; + } else if (strcmp(token, "nand") == 0) { + mhdr->blockid = IBR_HDR_NAND_ID; + } else if (strcmp(token, "sata") == 0) { + mhdr->blockid = IBR_HDR_SATA_ID; + } else { + printf("Err.. Invalid kwimage data\n"); + exit (EXIT_FAILURE); + } + printf("Preparing kirkwood boot image to boot " + "from %s\n", token); + break; + case CMD_NAND_ECC_MODE: + if (strcmp(token, "default") == 0) { + mhdr->nandeccmode = IBR_HDR_ECC_DEFAULT; + } else if (strcmp(token, "hamming") == 0) { + mhdr->nandeccmode = + IBR_HDR_ECC_FORCED_HAMMING; + } else if (strcmp(token, "rs") == 0) { + mhdr->nandeccmode = + IBR_HDR_ECC_FORCED_RS; + } else if (strcmp(token, "disabled") == 0) { + mhdr->nandeccmode = IBR_HDR_ECC_DISABLED; + } else { + printf("Err.. Invalid kwimage data\n"); + exit (EXIT_FAILURE); + } + printf("Nand ECC mode = %s\n", token); + break; + case CMD_NAND_PAGE_SIZE: + mhdr->nandpagesize = + (uint16_t) strtoul (token, tempptr, 16); + printf("Nand page size = %x\n", mhdr->nandpagesize); + break; + case CMD_SATA_PIO_MODE: + mhdr->satapiomode = + (uint8_t) strtoul (token, tempptr, 16); + printf("Sata PIO mode = %x\n", mhdr->satapiomode); + break; + case CMD_DDR_INIT_DELAY: + mhdr->ddrinitdelay = + (uint16_t) strtoul (token, tempptr, 16); + printf("DDR init delay = %d msec\n", + mhdr->ddrinitdelay); + break; + case CMD_DDR_DATA: + exthdr->rcfg[datacmd_cnt].rdata = + (uint32_t) strtoul (token, tempptr, 16); + + if (datacmd_cnt > KWBIMAGE_MAX_CONFIG ) { + printf("Err.. found more than max " + "allowed(%d) configurations\n", + KWBIMAGE_MAX_CONFIG); + exit (EXIT_FAILURE); + } else + datacmd_cnt++; + break; + case CMD_INVALID: + default: + printf("Error.. invalid data %s\n",token); + exit (EXIT_FAILURE); + } +} + +void kwdimage_set_ext_header(struct kwb_header *kwbhdr, char* fname) { + bhr_t *mhdr = &kwbhdr->kwb_hdr; + extbhr_t *exthdr = &kwbhdr->kwb_exthdr; + int fd = -1; + int lineno, j; + char *line = NULL; + char * token, *saveptr1, *saveptr2; + size_t len = 0; + enum kwbimage_cmd cmd; + + /* set dram register offset */ + exthdr->dramregsoffs = (uint32_t)&exthdr->rcfg - (uint32_t)mhdr; + + if ((fd = fopen(fname, "r")) == 0) { + if (strlen(fname)) + fprintf (stderr, "Err: Can't open %s: %s\n", + fname, strerror(errno)); + else + fprintf (stderr, "Err: kwbimage.cfg not specified " + "%s\n" + "add -n <file>/<kwbimage.cfg> to the cmd\n", + strerror(errno)); + exit (EXIT_FAILURE); + } + + /* Simple kwimage.cfg file parser */ + lineno=0; + while ((getline(&line, &len, fd)) != -1) { + lineno++; + token = strtok_r(line, "\r\n", &saveptr1); + /* drop all lines with zero tokens (= empty lines) */ + if (token == NULL) + continue; + + for (j = 0, cmd = CMD_INVALID, line = token; ; line = NULL) { + token = strtok_r(line, " ", &saveptr2); + if (token == NULL) + break; + /* Drop all text starting with '#' as comments */ + if (token[0] == '#') + break; + + /* Process rest as valid config command line */ + if (j == 0) { + cmd = kwbimage_check_cfgcmd(token, kwbhdr); + if (cmd == CMD_INVALID) + break; + } else if (j == 1) { + kwbimage_check_cfgdata(token, cmd, kwbhdr); + } else { + /* + * Command format permits only two strings + * on a line, i.e. command and data + * if more than two are observed, then error + * will be reported + */ + printf("Error.. Invalid command line(%d)\n", + lineno); + exit (EXIT_FAILURE); + } + j++; + } + } + if (line) + free(line); + + fclose(fd); +} + +void kwbimage_set_header (struct kwb_header *hdr, struct stat *sbuf, + uint32_t dadr, uint32_t eadr, char *fname) +{ + bhr_t *mhdr = &hdr->kwb_hdr; + extbhr_t *exthdr = &hdr->kwb_exthdr; + + mhdr->blocksize = sbuf->st_size - kwbimage_get_header_size(); + mhdr->srcaddr = kwbimage_get_header_size(); + mhdr->destaddr= dadr; + mhdr->execaddr =eadr; + mhdr->ext = 0x1; /* header extension appended */ + + kwdimage_set_ext_header(hdr, fname); + /* calculate checksums */ + mhdr->checkSum = kwbimage_checksum8((void *)mhdr, sizeof(bhr_t), 0); + exthdr->checkSum = kwbimage_checksum8((void *)exthdr, + sizeof(extbhr_t), 0); +} diff --git a/tools/kwbimage.h b/tools/kwbimage.h new file mode 100644 index 0000000..98ab34f --- /dev/null +++ b/tools/kwbimage.h @@ -0,0 +1,104 @@ +/* + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * iWritten-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _KWBIMAGE_H_ +#define _KWBIMAGE_H_ + +#include <stdint.h> + +#define KWBIMAGE_MAX_CONFIG ((0x1dc - 0x20)/sizeof(struct reg_config)) +#define MAX_TEMPBUF_LEN 32 + +/* NAND ECC Mode */ +#define IBR_HDR_ECC_DEFAULT 0x00 +#define IBR_HDR_ECC_FORCED_HAMMING 0x01 +#define IBR_HDR_ECC_FORCED_RS 0x02 +#define IBR_HDR_ECC_DISABLED 0x03 + +/* Boot Type - block ID */ +#define IBR_HDR_I2C_ID 0x4D +#define IBR_HDR_SPI_ID 0x5A +#define IBR_HDR_NAND_ID 0x8B +#define IBR_HDR_SATA_ID 0x78 +#define IBR_HDR_PEX_ID 0x9C +#define IBR_HDR_UART_ID 0x69 +#define IBR_DEF_ATTRIB 0x00 + +enum kwbimage_cmd { + CMD_INVALID, + CMD_BOOT_FROM, + CMD_NAND_ECC_MODE, + CMD_NAND_PAGE_SIZE, + CMD_SATA_PIO_MODE, + CMD_DDR_INIT_DELAY, + CMD_DDR_DATA +}; + +/* typedefs */ +typedef struct bhr_t { + uint8_t blockid; /*0 */ + uint8_t nandeccmode; /*1 */ + uint16_t nandpagesize; /*2-3 */ + uint32_t blocksize; /*4-7 */ + uint32_t rsvd1; /*8-11 */ + uint32_t srcaddr; /*12-15 */ + uint32_t destaddr; /*16-19 */ + uint32_t execaddr; /*20-23 */ + uint8_t satapiomode; /*24 */ + uint8_t rsvd3; /*25 */ + uint16_t ddrinitdelay; /*26-27 */ + uint16_t rsvd2; /*28-29 */ + uint8_t ext; /*30 */ + uint8_t checkSum; /*31 */ +} bhr_t, *pbhr_t; + +struct reg_config { + uint32_t raddr; + uint32_t rdata; +}; + +typedef struct extbhr_t { + uint32_t dramregsoffs; + uint8_t rsrvd1[0x20 - sizeof(uint32_t)]; + struct reg_config rcfg[KWBIMAGE_MAX_CONFIG]; + uint8_t rsrvd2[7]; + uint8_t checkSum; +} extbhr_t, *pextbhr_t; + +struct kwb_header { + bhr_t kwb_hdr; + extbhr_t kwb_exthdr; +}; + +/* + * functions + */ +uint8_t kwbimage_checksum8(void *start, uint32_t len, uint8_t csum); +uint32_t kwbimage_checksum32(uint32_t *start, uint32_t len, uint32_t csum); +void *kwbimage_get_header_ptr(void); +int kwbimage_get_header_size (void); +void kwbimage_set_header (struct kwb_header *hdr, struct stat *sbuf, + uint32_t dadr, uint32_t eadr, char *fname); + +#endif /* _KWBIMAGE_H_ */ diff --git a/tools/mkimage.c b/tools/mkimage.c index 40363a9..ba71874 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -24,6 +24,7 @@
#include "mkimage.h" #include <image.h> +#include "kwbimage.h"
extern int errno;
@@ -164,6 +165,10 @@ NXTARG: ; (lflag && (dflag || fflag))) usage();
+ if (((argc != 1) && (opt_type == IH_TYPE_KWBIMAGE)) && + (xflag || lflag)) + usage(); + if (!eflag) { ep = addr; /* If XIP, entry point must be after the U-Boot header */ @@ -251,7 +256,12 @@ NXTARG: ; * * write dummy header, to be fixed later */ - hdr_size = image_get_header_size (); + if (opt_type == IH_TYPE_KWBIMAGE) { + hdr = kwbimage_get_header_ptr(); + hdr_size = kwbimage_get_header_size (); + } else + hdr_size = image_get_header_size (); + memset (hdr, 0, hdr_size); if (write(ifd, hdr, hdr_size) != hdr_size) { fprintf (stderr, "%s: Write error on %s: %s\n", @@ -339,6 +349,19 @@ NXTARG: ;
+ /* Build new header */ + if (opt_type == IH_TYPE_KWBIMAGE) { + checksum = kwbimage_checksum32((uint32_t *)ptr, sbuf.st_size, 0); + + if (write(ifd, &checksum, sizeof(uint32_t)) + != sizeof(uint32_t)) { + fprintf (stderr, "%s: Checksum wr err on %s: %s\n", + cmdname, imagefile, strerror(errno)); + exit (EXIT_FAILURE); + } + sbuf.st_size += sizeof(uint32_t); + kwbimage_set_header (hdr, &sbuf, addr, ep, name); + } else { checksum = crc32 (0, (const char *)(ptr + hdr_size), sbuf.st_size - hdr_size); @@ -361,6 +384,7 @@ NXTARG: ;
image_print_contents (hdr);
+ } (void) munmap((void *)ptr, sbuf.st_size);
/* We're a bit of paranoid */
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- common/image.c | 4 ++-- tools/kwbimage.c | 41 +++++++++++++++++++++++++++++++++++++++++ tools/mkimage.c | 7 ++++++- 3 files changed, 49 insertions(+), 3 deletions(-)
diff --git a/common/image.c b/common/image.c index 845006f..e3ad3e5 100644 --- a/common/image.c +++ b/common/image.c @@ -159,7 +159,7 @@ static table_entry_t uimage_comp[] = {
uint32_t crc32 (uint32_t, const unsigned char *, uint); uint32_t crc32_wd (uint32_t, const unsigned char *, uint, uint); -static void genimg_print_size (uint32_t size); +void genimg_print_size (uint32_t size); #if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) || defined(USE_HOSTCC) static void genimg_print_time (time_t timestamp); #endif @@ -473,7 +473,7 @@ void memmove_wd (void *to, void *from, size_t len, ulong chunksz) } #endif /* !USE_HOSTCC */
-static void genimg_print_size (uint32_t size) +void genimg_print_size (uint32_t size) { #ifndef USE_HOSTCC printf ("%d Bytes = ", size); diff --git a/tools/kwbimage.c b/tools/kwbimage.c index b1ad37a..13bd57f 100644 --- a/tools/kwbimage.c +++ b/tools/kwbimage.c @@ -33,6 +33,8 @@ #include <unistd.h> #include "kwbimage.h"
+extern void genimg_print_size (uint32_t size); + static struct kwb_header kwbimage_header; static int datacmd_cnt = 0;
@@ -262,3 +264,42 @@ void kwbimage_set_header (struct kwb_header *hdr, struct stat *sbuf, exthdr->checkSum = kwbimage_checksum8((void *)exthdr, sizeof(extbhr_t), 0); } + +/* -l support functions */ +int kwbimage_check_header (struct kwb_header *hdr) +{ + bhr_t *mhdr = &hdr->kwb_hdr; + extbhr_t *exthdr = &hdr->kwb_exthdr; + uint8_t calc_hdrcsum; + uint8_t calc_exthdrcsum; + + calc_hdrcsum = kwbimage_checksum8((void *)mhdr, + sizeof(bhr_t) - sizeof(uint8_t), 0); + if (calc_hdrcsum != mhdr->checkSum) { + return -1; /* main header csum not matched */ + } + calc_exthdrcsum = kwbimage_checksum8((void *)exthdr, + sizeof(extbhr_t) - sizeof(uint8_t), 0); + if (calc_hdrcsum != mhdr->checkSum) { + return -2; /* ext header csum not matched */ + } + return 0; +} + +void kwbimage_print_contents (struct kwb_header *hdr) { + bhr_t *mhdr = &hdr->kwb_hdr; + char * bootdev = "Unknown"; + + if (mhdr->blockid == IBR_HDR_SPI_ID) + bootdev = "spi"; + if (mhdr->blockid == IBR_HDR_NAND_ID) + bootdev = "nand"; + if (mhdr->blockid == IBR_HDR_SATA_ID) + bootdev = "sata"; + + printf("Image Type: Kirkwood Boot from %s Image\n", bootdev); + printf("Data Size: "); + genimg_print_size (mhdr->blocksize - sizeof(uint32_t)); + printf("Load Address: %08x\n", mhdr->destaddr); + printf("Entry Point: %08x\n", mhdr->execaddr); +} diff --git a/tools/mkimage.c b/tools/mkimage.c index ba71874..0d46bda 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -166,7 +166,7 @@ NXTARG: ; usage();
if (((argc != 1) && (opt_type == IH_TYPE_KWBIMAGE)) && - (xflag || lflag)) + (xflag)) usage();
if (!eflag) { @@ -231,6 +231,11 @@ NXTARG: ; exit (EXIT_FAILURE); }
+ if (!(kwbimage_check_header ((struct kwb_header *)ptr))) { + kwbimage_print_contents ((struct kwb_header *)ptr); + exit (EXIT_SUCCESS); + } + if (fdt_check_header (ptr)) { /* old-style image */ image_verify_header ((char *)ptr, sbuf.st_size);
Just some quick nitpicking comment below.
- bhr_t *mhdr = &hdr->kwb_hdr;
- extbhr_t *exthdr = &hdr->kwb_exthdr;
- uint8_t calc_hdrcsum;
- uint8_t calc_exthdrcsum;
- calc_hdrcsum = kwbimage_checksum8((void *)mhdr,
- if (calc_hdrcsum != mhdr->checkSum) {
No braces needed on single-line statements.
- calc_exthdrcsum = kwbimage_checksum8((void *)exthdr,
Perhaps use some defines for those errors (-1, -2 etc).
Again, no braces here.
- char * bootdev = "Unknown";
- if (mhdr->blockid == IBR_HDR_SPI_ID)
bootdev = "spi";
- if (mhdr->blockid == IBR_HDR_NAND_ID)
bootdev = "nand";
- if (mhdr->blockid == IBR_HDR_SATA_ID)
bootdev = "sata";
- printf("Image Type: Kirkwood Boot from %s Image\n", bootdev);
- printf("Data Size: ");
- genimg_print_size (mhdr->blocksize - sizeof(uint32_t));
- printf("Load Address: %08x\n", mhdr->destaddr);
- printf("Entry Point: %08x\n", mhdr->execaddr);
You are mixing coding styles here. func() vs. func () (space before "("). Please use only one style per file.
Thanks.
Best regards, Stefan
Prafulla Wadaskar
Stefan Roese
