[U-Boot] [PATCH] nios2: convert nios2 cpu to driver model
Convert nios2 cpu to driver model. The cpu parameters are extracted from device tree and saved to global data structure. We will use them to replace the custom_fpga.h .
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/Kconfig | 3 ++ arch/nios2/cpu/cpu.c | 80 ++++++++++++++++++++++++++++++++++-- arch/nios2/dts/3c120_devboard.dts | 1 + arch/nios2/include/asm/global_data.h | 8 ++++ configs/nios2-generic_defconfig | 2 - 5 files changed, 89 insertions(+), 5 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 207c778..9be1538 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -64,6 +64,9 @@ config NIOS2 select HAVE_GENERIC_BOARD select SYS_GENERIC_BOARD select SUPPORT_OF_CONTROL + select OF_CONTROL + select DM + select CPU
config OPENRISC bool "OpenRISC architecture" diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 39ae972..f2cb022 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -6,7 +6,9 @@ */
#include <common.h> -#include <asm/nios2.h> +#include <cpu.h> +#include <dm.h> +#include <errno.h> #include <asm/cache.h>
DECLARE_GLOBAL_DATA_PTR; @@ -51,10 +53,82 @@ void dcache_disable(void) flush_dcache(CONFIG_SYS_DCACHE_SIZE, CONFIG_SYS_DCACHELINE_SIZE); }
-int arch_cpu_init(void) +int arch_cpu_init_dm(void) { - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; + struct udevice *dev; + + uclass_first_device(UCLASS_CPU, &dev); gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
return 0; } + +static int altera_nios2_get_desc(struct udevice *dev, char *buf, int size) +{ + const char *cpu_name = "Nios-II"; + + if (size < strlen(cpu_name)) + return -ENOSPC; + strcpy(buf, cpu_name); + + return 0; +} + +static int altera_nios2_get_info(struct udevice *dev, struct cpu_info *info) +{ + + info->cpu_freq = gd->cpu_clk; + info->features = 1 << CPU_FEAT_L1_CACHE + | (gd->arch.has_mmu ? 1 << CPU_FEAT_MMU : 0); + + return 0; +} + +static int altera_nios2_get_count(struct udevice *dev) +{ + return 1; +} + +static int altera_nios2_probe(struct udevice *dev) +{ + gd->cpu_clk = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "clock-frequency", 0); + gd->arch.dcache_line_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "dcache-line-size", 0); + gd->arch.icache_line_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "icache-line-size", 0); + gd->arch.dcache_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "dcache-size", 0); + gd->arch.icache_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "icache-size", 0); + gd->arch.reset_addr = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "altr,reset-addr", 0); + gd->arch.exception_addr = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "altr,exception-addr", 0); + gd->arch.has_mmu = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "altr,has-mmu", 0); + gd->arch.io_region_base = gd->arch.has_mmu ? 0xe0000000 : 0x8000000; + + return 0; +} + +static const struct cpu_ops altera_nios2_ops = { + .get_desc = altera_nios2_get_desc, + .get_info = altera_nios2_get_info, + .get_count = altera_nios2_get_count, +}; + +static const struct udevice_id altera_nios2_ids[] = { + { .compatible = "altr,nios2-1.0" }, + { .compatible = "altr,nios2-1.1" }, + { } +}; + +U_BOOT_DRIVER(altera_nios2) = { + .name = "altera_nios2", + .id = UCLASS_CPU, + .of_match = altera_nios2_ids, + .probe = altera_nios2_probe, + .ops = &altera_nios2_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/arch/nios2/dts/3c120_devboard.dts b/arch/nios2/dts/3c120_devboard.dts index 781a652..2e2956f 100644 --- a/arch/nios2/dts/3c120_devboard.dts +++ b/arch/nios2/dts/3c120_devboard.dts @@ -41,6 +41,7 @@ altr,exception-addr = <0xd0000020>; altr,has-initda = <1>; altr,has-mmu = <1>; + u-boot,dm-pre-reloc; }; };
diff --git a/arch/nios2/include/asm/global_data.h b/arch/nios2/include/asm/global_data.h index 580b019..ee5180b 100644 --- a/arch/nios2/include/asm/global_data.h +++ b/arch/nios2/include/asm/global_data.h @@ -9,6 +9,14 @@
/* Architecture-specific global data */ struct arch_global_data { + u32 dcache_line_size; + u32 icache_line_size; + u32 dcache_size; + u32 icache_size; + u32 reset_addr; + u32 exception_addr; + int has_mmu; + u32 io_region_base; };
#include <asm-generic/global_data.h> diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index ad72272..63d99d8 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -13,9 +13,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y -CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_DM=y CONFIG_ALTERA_PIO=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 move cpu param setup to arch_cpu_init_dm, remove probe.
arch/Kconfig | 3 ++ arch/nios2/cpu/cpu.c | 76 ++++++++++++++++++++++++++++++++++-- arch/nios2/dts/3c120_devboard.dts | 1 + arch/nios2/include/asm/global_data.h | 8 ++++ configs/nios2-generic_defconfig | 2 - 5 files changed, 85 insertions(+), 5 deletions(-)
config OPENRISC bool "OpenRISC architecture" diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 39ae972..88984e2 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -6,7 +6,9 @@ */
DECLARE_GLOBAL_DATA_PTR; @@ -51,10 +53,78 @@ void dcache_disable(void) flush_dcache(CONFIG_SYS_DCACHE_SIZE, CONFIG_SYS_DCACHELINE_SIZE); }
-int arch_cpu_init(void) +int arch_cpu_init_dm(void) { - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; + struct udevice *dev; + + uclass_first_device(UCLASS_CPU, &dev); + if (!dev) + return -ENODEV; + + gd->cpu_clk = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "clock-frequency", 0); + gd->arch.dcache_line_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "dcache-line-size", 0); + gd->arch.icache_line_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "icache-line-size", 0); + gd->arch.dcache_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "dcache-size", 0); + gd->arch.icache_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "icache-size", 0); + gd->arch.reset_addr = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "altr,reset-addr", 0); + gd->arch.exception_addr = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "altr,exception-addr", 0); + gd->arch.has_mmu = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "altr,has-mmu", 0); + gd->arch.io_region_base = gd->arch.has_mmu ? 0xe0000000 : 0x8000000; gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
return 0; } + +static int altera_nios2_get_desc(struct udevice *dev, char *buf, int size) +{ + const char *cpu_name = "Nios-II"; + + if (size < strlen(cpu_name)) + return -ENOSPC; + strcpy(buf, cpu_name); + + return 0; +} + +static int altera_nios2_get_info(struct udevice *dev, struct cpu_info *info) +{ + + info->cpu_freq = gd->cpu_clk; + info->features = 1 << CPU_FEAT_L1_CACHE + | (gd->arch.has_mmu ? 1 << CPU_FEAT_MMU : 0); + + return 0; +} + +static int altera_nios2_get_count(struct udevice *dev) +{ + return 1; +} + +static const struct cpu_ops altera_nios2_ops = { + .get_desc = altera_nios2_get_desc, + .get_info = altera_nios2_get_info, + .get_count = altera_nios2_get_count, +}; + +static const struct udevice_id altera_nios2_ids[] = { + { .compatible = "altr,nios2-1.0" }, + { .compatible = "altr,nios2-1.1" }, + { } +}; + +U_BOOT_DRIVER(altera_nios2) = { + .name = "altera_nios2", + .id = UCLASS_CPU, + .of_match = altera_nios2_ids, + .ops = &altera_nios2_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/arch/nios2/dts/3c120_devboard.dts b/arch/nios2/dts/3c120_devboard.dts index 781a652..2e2956f 100644 --- a/arch/nios2/dts/3c120_devboard.dts +++ b/arch/nios2/dts/3c120_devboard.dts @@ -41,6 +41,7 @@ altr,exception-addr = <0xd0000020>; altr,has-initda = <1>; altr,has-mmu = <1>; + u-boot,dm-pre-reloc; }; };
Hi!
Minor nitpicks below.
- select OF_CONTROL
- select DM
- select CPU
What's this CONFIG_CPU for please ?
- struct udevice *dev;
- uclass_first_device(UCLASS_CPU, &dev);
- if (!dev)
return -ENODEV;
- gd->cpu_clk = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
- gd->arch.dcache_line_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
- gd->arch.icache_line_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
- gd->arch.dcache_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
"dcache-size", 0);
- gd->arch.icache_size = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
"icache-size", 0);
- gd->arch.reset_addr = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
- gd->arch.exception_addr = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
- gd->arch.has_mmu = fdtdec_get_int(gd->fdt_blob, dev->of_offset,
"altr,has-mmu", 0);
Shouldn't there be some sort of return value checking here ?
- const char *cpu_name = "Nios-II";
- if (size < strlen(cpu_name))
return -ENOSPC;
- strcpy(buf, cpu_name);
- info->cpu_freq = gd->cpu_clk;
- info->features = 1 << CPU_FEAT_L1_CACHE
I'd add parenthesis around the bitshifts, for the sake of clarity. Also, please put the ORR operator at the end of the line.
Thanks a lot :)
Hi Marek,
- select OF_CONTROL
- select DM
- select CPU
drivers/cpu/Kconfig
It is "Enable CPU drivers using Driver Model". I think it should have been named as CONFIG_DM_CPU to avoid confusion.
- if (!dev)
return -ENODEV;
"dcache-size", 0);
"icache-size", 0);
"altr,has-mmu", 0);
There might be some. Though I would like to depend upon the sopc2dts which generates the dts. I don't think these values should be tweaked by a human. :)
Will do as suggested.
Thanks a lot for your review.
Best regards, Thomas Chou
+Simon
On Tue, Sep 29, 2015 at 3:18 PM, Thomas Chou thomas@wytron.com.tw wrote:
Hi Marek,
select OF_CONTROL
select DM
select CPU
drivers/cpu/Kconfig
I remember Simon intended to name it as CONFIG_DM_CPU as I raised similar comments before.
[snip]
Regards, Bin
On Tue, Sep 29, 2015 at 10:28 PM, Bin Meng bmeng.cn@gmail.com wrote:
+Simon
Hi Marek,
select OF_CONTROL
select DM
select CPU
drivers/cpu/Kconfig
Oops, I must be drunk! I mean CONFIG_CPU ...
[snip]
Regards, Bin
+Simon
Hi Marek,
select OF_CONTROL
select DM
select CPU
drivers/cpu/Kconfig
Yes. The CONFIG_DM_xxx options will go away as each subsystem is converted to driver model.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 move cpu param setup to arch_cpu_init_dm, remove probe. v3 fix coding style as Marek suggested. select CMD_CPU.
arch/Kconfig | 3 ++ arch/nios2/cpu/cpu.c | 75 ++++++++++++++++++++++++++++++++++-- arch/nios2/dts/3c120_devboard.dts | 1 + arch/nios2/include/asm/global_data.h | 8 ++++ configs/nios2-generic_defconfig | 3 +- 5 files changed, 85 insertions(+), 5 deletions(-)
config OPENRISC bool "OpenRISC architecture" diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 39ae972..9e98742 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -6,7 +6,9 @@ */
DECLARE_GLOBAL_DATA_PTR; @@ -51,10 +53,77 @@ void dcache_disable(void) flush_dcache(CONFIG_SYS_DCACHE_SIZE, CONFIG_SYS_DCACHELINE_SIZE); }
return 0; } + +static int altera_nios2_get_desc(struct udevice *dev, char *buf, int size) +{ + const char *cpu_name = "Nios-II"; + + if (size < strlen(cpu_name)) + return -ENOSPC; + strcpy(buf, cpu_name); + + return 0; +} + +static int altera_nios2_get_info(struct udevice *dev, struct cpu_info *info) +{ + info->cpu_freq = gd->cpu_clk; + info->features = (1 << CPU_FEAT_L1_CACHE) | + (gd->arch.has_mmu ? (1 << CPU_FEAT_MMU) : 0); + + return 0; +} + +static int altera_nios2_get_count(struct udevice *dev) +{ + return 1; +} + +static const struct cpu_ops altera_nios2_ops = { + .get_desc = altera_nios2_get_desc, + .get_info = altera_nios2_get_info, + .get_count = altera_nios2_get_count, +}; + +static const struct udevice_id altera_nios2_ids[] = { + { .compatible = "altr,nios2-1.0" }, + { .compatible = "altr,nios2-1.1" }, + { } +}; + +U_BOOT_DRIVER(altera_nios2) = { + .name = "altera_nios2", + .id = UCLASS_CPU, + .of_match = altera_nios2_ids, + .ops = &altera_nios2_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/arch/nios2/dts/3c120_devboard.dts b/arch/nios2/dts/3c120_devboard.dts index 781a652..2e2956f 100644 --- a/arch/nios2/dts/3c120_devboard.dts +++ b/arch/nios2/dts/3c120_devboard.dts @@ -41,6 +41,7 @@ altr,exception-addr = <0xd0000020>; altr,has-initda = <1>; altr,has-mmu = <1>; + u-boot,dm-pre-reloc; }; };
#include <asm-generic/global_data.h> diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index ad72272..707ee33 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_GPIO=y CONFIG_TARGET_NIOS2_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set @@ -13,9 +14,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y -CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_DM=y CONFIG_ALTERA_PIO=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y
Hi Thomas,
Looks good, a few minor comments below.
select OF_CONTROL
select DM
select CPU
Should check the error return too.
ret = uclass_first_device(...) if (ret) return ret;
if (!dev)
return -ENODEV;
This code should go in a probe() method in this driver. Then when the device is probed (by your arch_cpu_init_dm() function this code will be executed. The problem here is that you are looking at dev->of_offset, which is the drivers's responsibility. I know this code is in the same file, but this is not a driver method function.
You could make this briefer by declaring a few locals:
const void *blob = gd->fdt_blob; int node = dev->of_offset;
"dcache-size", 0);
"icache-size", 0);
"altr,has-mmu", 0);
Should that be fdtdec_get_bool()? Also is there a device tree binding file for these settings?
gd->arch.io_region_base = gd->arch.has_mmu ? 0xe0000000 : 0x8000000; gd->ram_size = CONFIG_SYS_SDRAM_SIZE; return 0;
return -ENOSPC;
return 1;
.id = UCLASS_CPU,
u32 dcache_size;
u32 icache_size;
u32 reset_addr;
u32 exception_addr;
int has_mmu;
u32 io_region_base;
#include <asm-generic/global_data.h> diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index ad72272..707ee33 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_GPIO=y CONFIG_TARGET_NIOS2_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set @@ -13,9 +14,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y -CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_DM=y CONFIG_ALTERA_PIO=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y -- 2.1.4
Hi Simon,
"altr,has-mmu", 0);
With fdtdec_get_bool(), a boolean properly is true if present in the device tree and false if not present, regardless of its value.
It will be wrong if there is "altr,has-mmu = <0>;" .
A dts binding file will be added.
Thanks for your review.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 move cpu param setup to arch_cpu_init_dm, remove probe. v3 fix coding style as Marek suggested. select CMD_CPU. v4 revert to v1 probe method. doc dts binding. check uclass_first_device() return. clean up as Simon suggested.
arch/Kconfig | 3 ++ arch/nios2/cpu/cpu.c | 88 ++++++++++++++++++++++++++++++++-- arch/nios2/dts/3c120_devboard.dts | 1 + arch/nios2/include/asm/global_data.h | 8 ++++ configs/nios2-generic_defconfig | 3 +- doc/device-tree-bindings/cpu/nios2.txt | 54 +++++++++++++++++++++ 6 files changed, 152 insertions(+), 5 deletions(-) create mode 100644 doc/device-tree-bindings/cpu/nios2.txt
config OPENRISC bool "OpenRISC architecture" diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 39ae972..bd11abc 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -6,7 +6,9 @@ */
DECLARE_GLOBAL_DATA_PTR; @@ -51,10 +53,90 @@ void dcache_disable(void) flush_dcache(CONFIG_SYS_DCACHE_SIZE, CONFIG_SYS_DCACHELINE_SIZE); }
-int arch_cpu_init(void) +int arch_cpu_init_dm(void) { - gd->cpu_clk = CONFIG_SYS_CLK_FREQ; + struct udevice *dev; + int ret; + + ret = uclass_first_device(UCLASS_CPU, &dev); + if (ret) + return ret; + if (!dev) + return -ENODEV; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
return 0; } + +static int altera_nios2_get_desc(struct udevice *dev, char *buf, int size) +{ + const char *cpu_name = "Nios-II"; + + if (size < strlen(cpu_name)) + return -ENOSPC; + strcpy(buf, cpu_name); + + return 0; +} + +static int altera_nios2_get_info(struct udevice *dev, struct cpu_info *info) +{ + info->cpu_freq = gd->cpu_clk; + info->features = (1 << CPU_FEAT_L1_CACHE) | + (gd->arch.has_mmu ? (1 << CPU_FEAT_MMU) : 0); + + return 0; +} + +static int altera_nios2_get_count(struct udevice *dev) +{ + return 1; +} + +static int altera_nios2_probe(struct udevice *dev) +{ + const void *blob = gd->fdt_blob; + int node = dev->of_offset; + + gd->cpu_clk = fdtdec_get_int(blob, node, + "clock-frequency", 0); + gd->arch.dcache_line_size = fdtdec_get_int(blob, node, + "dcache-line-size", 0); + gd->arch.icache_line_size = fdtdec_get_int(blob, node, + "icache-line-size", 0); + gd->arch.dcache_size = fdtdec_get_int(blob, node, + "dcache-size", 0); + gd->arch.icache_size = fdtdec_get_int(blob, node, + "icache-size", 0); + gd->arch.reset_addr = fdtdec_get_int(blob, node, + "altr,reset-addr", 0); + gd->arch.exception_addr = fdtdec_get_int(blob, node, + "altr,exception-addr", 0); + gd->arch.has_mmu = fdtdec_get_int(blob, node, + "altr,has-mmu", 0); + gd->arch.io_region_base = gd->arch.has_mmu ? 0xe0000000 : 0x8000000; + + return 0; +} + +static const struct cpu_ops altera_nios2_ops = { + .get_desc = altera_nios2_get_desc, + .get_info = altera_nios2_get_info, + .get_count = altera_nios2_get_count, +}; + +static const struct udevice_id altera_nios2_ids[] = { + { .compatible = "altr,nios2-1.0" }, + { .compatible = "altr,nios2-1.1" }, + { } +}; + +U_BOOT_DRIVER(altera_nios2) = { + .name = "altera_nios2", + .id = UCLASS_CPU, + .of_match = altera_nios2_ids, + .probe = altera_nios2_probe, + .ops = &altera_nios2_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/arch/nios2/dts/3c120_devboard.dts b/arch/nios2/dts/3c120_devboard.dts index 781a652..2e2956f 100644 --- a/arch/nios2/dts/3c120_devboard.dts +++ b/arch/nios2/dts/3c120_devboard.dts @@ -41,6 +41,7 @@ altr,exception-addr = <0xd0000020>; altr,has-initda = <1>; altr,has-mmu = <1>; + u-boot,dm-pre-reloc; }; };
#include <asm-generic/global_data.h> diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index ad72272..707ee33 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_GPIO=y CONFIG_TARGET_NIOS2_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set @@ -13,9 +14,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y -CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_DM=y CONFIG_ALTERA_PIO=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y diff --git a/doc/device-tree-bindings/cpu/nios2.txt b/doc/device-tree-bindings/cpu/nios2.txt new file mode 100644 index 0000000..0ed2f44 --- /dev/null +++ b/doc/device-tree-bindings/cpu/nios2.txt @@ -0,0 +1,54 @@ +* Nios II Processor Binding + +This binding specifies what properties available in the device tree +representation of a Nios II Processor Core. + +Users can use sopc2dts tool for generating device tree sources (dts) from a +Qsys system. See more detail in: http://www.alterawiki.com/wiki/Sopc2dts + +Required properties: + +- compatible: Compatible property value should be "altr,nios2-1.0" or + "altr,nios2-1.1". +- reg: Contains CPU index. +- clock-frequency: Contains the clock frequency for CPU, in Hz. +- dcache-line-size: Contains data cache line size. +- icache-line-size: Contains instruction line size. +- dcache-size: Contains data cache size. +- icache-size: Contains instruction cache size. +- altr,reset-addr: Specifies CPU reset address +- altr,exception-addr: Specifies CPU exception address + +Optional properties: +- altr,has-initda: Specifies CPU support initda instruction, should be 1. +- altr,has-mmu: Specifies CPU support MMU support. +- altr,has-mul: Specifies CPU hardware multipy support. +- altr,has-div: Specifies CPU hardware divide support +- altr,implementation: Nios II core implementation, this should be "fast"; + +Example: + +cpu@0x0 { + device_type = "cpu"; + compatible = "altr,nios2-1.0"; + reg = <0>; + interrupt-controller; + #interrupt-cells = <1>; + clock-frequency = <125000000>; + dcache-line-size = <32>; + icache-line-size = <32>; + dcache-size = <32768>; + icache-size = <32768>; + altr,implementation = "fast"; + altr,pid-num-bits = <8>; + altr,tlb-num-ways = <16>; + altr,tlb-num-entries = <128>; + altr,tlb-ptr-sz = <7>; + altr,has-div = <1>; + altr,has-mul = <1>; + altr,reset-addr = <0xc2800000>; + altr,fast-tlb-miss-addr = <0xc7fff400>; + altr,exception-addr = <0xd0000020>; + altr,has-initda = <1>; + altr,has-mmu = <1>; +};
Applied to u-boot-nios.
Bin Meng
Thomas Chou
