[U-Boot] [PATCH] drivers/usb/host/ehci-mxc.c: Fix GCC 4.6 warning
Fix: ehci-mxc.c: In function 'ehci_hcd_init': ehci-mxc.c:113:6: warning: variable 'tmp' set but not used [-Wunused-but-set-variable]
Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/usb/host/ehci-mxc.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ehci-mxc.c b/drivers/usb/host/ehci-mxc.c index f403d49..61dbccd 100644 --- a/drivers/usb/host/ehci-mxc.c +++ b/drivers/usb/host/ehci-mxc.c @@ -110,11 +110,10 @@ int ehci_hcd_init(void) { struct usb_ehci *ehci; #ifdef CONFIG_MX31 - u32 tmp; struct clock_control_regs *sc_regs = (struct clock_control_regs *)CCM_BASE;
- tmp = __raw_readl(&sc_regs->ccmr); + __raw_readl(&sc_regs->ccmr); __raw_writel(__raw_readl(&sc_regs->ccmr) | (1 << 9), &sc_regs->ccmr) ; #endif
2011/11/19 Anatolij Gustschin agust@denx.de:
Applied to u-boot-usb. Thanks.
Remy
Dear Anatolij Gustschin,
Applied, thanks.
Remy, you wrote you had applied this to u-boot-usb, so this is probably OK with you. Sorry that I did not want to wait any longer for your pull request, at least not for these simple fixes.
Anatolij Gustschin
Remy Bohmer
