[U-Boot] [PATCH 00/16] Raspberry Pi 32/64 support
This PR consolidates the work we've done to support the new Raspberry Pi 4 board. It also includes commits from https://github.com/mbgg/u-boot.git (credits to Matthias Brugger).
Andrei Gherzan (13): dts: Create a dtsi for BCM2835/6/7 specific configuration dts: Add initial support for bcm2838 arm: mach-bcm283x: Define configs for RaspberryPi 4 arm: mach-bcm283x: Define mbox address for BCM2838 rpi: Add rpi_model entry for RaspberryPi 4 dt-bindings: Define BCM2838_CLOCK_EMMC2 needed for RaspberryPi 4 arm: bcm283x: Include definition for additional emmc clock arm: bcm283x: Define device base addresses for bcm2835 config: rpi4: Add defconfig for rpi4-32 dts: bcm2838-rpi-4-b: Use the emmc2 interface for sdhci rpi: Add memory map for bcm2838 configs: rpi4: Remove DWC2 and USB_ETHER configs dts: bcm2838-rpi-4-b: Use the emmc2/2811 compatible string for SDHCI
Fabian Vogt (2): bcm2835 video: Bail out early if querying video information fails bcm283x mbox: Correctly wait for space to send
Matthias Brugger (1): mmc: bcm2835_sdhci: Add support for bcm2711 device
arch/arm/dts/Makefile | 4 +- arch/arm/dts/bcm2835-common.dtsi | 53 +++++ arch/arm/dts/bcm2835.dtsi | 1 + arch/arm/dts/bcm2836.dtsi | 1 + arch/arm/dts/bcm2837.dtsi | 1 + arch/arm/dts/bcm2838-rpi-4-b.dts | 52 +++++ arch/arm/dts/bcm2838.dtsi | 237 +++++++++++++++++++++ arch/arm/dts/bcm283x.dtsi | 45 +--- arch/arm/mach-bcm283x/Kconfig | 35 +++ arch/arm/mach-bcm283x/include/mach/mbox.h | 13 +- arch/arm/mach-bcm283x/include/mach/sdhci.h | 4 + arch/arm/mach-bcm283x/include/mach/timer.h | 4 + arch/arm/mach-bcm283x/include/mach/wdog.h | 4 + arch/arm/mach-bcm283x/mbox.c | 6 +- board/raspberrypi/rpi/rpi.c | 32 ++- configs/rpi_4_32b_defconfig | 40 ++++ configs/rpi_4_defconfig | 3 - drivers/mmc/bcm2835_sdhci.c | 12 +- drivers/video/bcm2835.c | 4 +- include/dt-bindings/clock/bcm2835.h | 2 + 20 files changed, 494 insertions(+), 59 deletions(-) create mode 100644 arch/arm/dts/bcm2835-common.dtsi create mode 100644 arch/arm/dts/bcm2838-rpi-4-b.dts create mode 100644 arch/arm/dts/bcm2838.dtsi create mode 100644 configs/rpi_4_32b_defconfig
This follows a similar change in kernel[1]. The change moves configuration that was not applicable for all bcm2835/6/7/8 out of bcm283x.dtsi. The new file is bcm2835-common.dtsi and contains conifguration that is common for bcm2835/6/7 (not bcm2838).
[1] https://github.com/raspberrypi/linux/commit/769a7330aa5bebcc98b1ff12ecb767db...
Signed-off-by: Andrei Gherzan andrei@gherzan.ro --- arch/arm/dts/bcm2835-common.dtsi | 53 ++++++++++++++++++++++++++++++++ arch/arm/dts/bcm2835.dtsi | 1 + arch/arm/dts/bcm2836.dtsi | 1 + arch/arm/dts/bcm2837.dtsi | 1 + arch/arm/dts/bcm283x.dtsi | 45 +-------------------------- 5 files changed, 57 insertions(+), 44 deletions(-) create mode 100644 arch/arm/dts/bcm2835-common.dtsi
diff --git a/arch/arm/dts/bcm2835-common.dtsi b/arch/arm/dts/bcm2835-common.dtsi new file mode 100644 index 0000000000..17771730a3 --- /dev/null +++ b/arch/arm/dts/bcm2835-common.dtsi @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0 + +/* This include file covers the common peripherals and configuration between + * bcm2835, bcm2836 and bcm2837 implementations. + */ + +/ { + soc { + timer@7e003000 { + compatible = "brcm,bcm2835-system-timer"; + reg = <0x7e003000 0x1000>; + interrupts = <1 0>, <1 1>, <1 2>, <1 3>; + /* This could be a reference to BCM2835_CLOCK_TIMER, + * but we don't have the driver using the common clock + * support yet. + */ + clock-frequency = <1000000>; + }; + + intc: interrupt-controller@7e00b200 { + compatible = "brcm,bcm2835-armctrl-ic"; + reg = <0x7e00b200 0x200>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + thermal: thermal@7e212000 { + compatible = "brcm,bcm2835-thermal"; + reg = <0x7e212000 0x8>; + clocks = <&clocks BCM2835_CLOCK_TSENS>; + #thermal-sensor-cells = <0>; + status = "disabled"; + }; + + v3d: v3d@7ec00000 { + compatible = "brcm,bcm2835-v3d"; + reg = <0x7ec00000 0x1000>; + interrupts = <1 10>; + }; + }; +}; + +&gpio { + i2c_slave_gpio18: i2c_slave_gpio18 { + brcm,pins = <18 19 20 21>; + brcm,function = <BCM2835_FSEL_ALT3>; + }; + + jtag_gpio4: jtag_gpio4 { + brcm,pins = <4 5 6 12 13>; + brcm,function = <BCM2835_FSEL_ALT5>; + }; +}; diff --git a/arch/arm/dts/bcm2835.dtsi b/arch/arm/dts/bcm2835.dtsi index a5c3824c80..53bf4579cc 100644 --- a/arch/arm/dts/bcm2835.dtsi +++ b/arch/arm/dts/bcm2835.dtsi @@ -1,5 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 #include "bcm283x.dtsi" +#include "bcm2835-common.dtsi"
/ { compatible = "brcm,bcm2835"; diff --git a/arch/arm/dts/bcm2836.dtsi b/arch/arm/dts/bcm2836.dtsi index c933e84138..82d6c4662a 100644 --- a/arch/arm/dts/bcm2836.dtsi +++ b/arch/arm/dts/bcm2836.dtsi @@ -1,5 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 #include "bcm283x.dtsi" +#include "bcm2835-common.dtsi"
/ { compatible = "brcm,bcm2836"; diff --git a/arch/arm/dts/bcm2837.dtsi b/arch/arm/dts/bcm2837.dtsi index beb6c502da..9e95fee78e 100644 --- a/arch/arm/dts/bcm2837.dtsi +++ b/arch/arm/dts/bcm2837.dtsi @@ -1,4 +1,5 @@ #include "bcm283x.dtsi" +#include "bcm2835-common.dtsi"
/ { compatible = "brcm,bcm2837"; diff --git a/arch/arm/dts/bcm283x.dtsi b/arch/arm/dts/bcm283x.dtsi index 9777644c6c..a024727e4d 100644 --- a/arch/arm/dts/bcm283x.dtsi +++ b/arch/arm/dts/bcm283x.dtsi @@ -56,17 +56,6 @@ #address-cells = <1>; #size-cells = <1>;
- timer@7e003000 { - compatible = "brcm,bcm2835-system-timer"; - reg = <0x7e003000 0x1000>; - interrupts = <1 0>, <1 1>, <1 2>, <1 3>; - /* This could be a reference to BCM2835_CLOCK_TIMER, - * but we don't have the driver using the common clock - * support yet. - */ - clock-frequency = <1000000>; - }; - txp@7e004000 { compatible = "brcm,bcm2835-txp"; reg = <0x7e004000 0x20>; @@ -114,13 +103,6 @@ brcm,dma-channel-mask = <0x7f35>; };
- intc: interrupt-controller@7e00b200 { - compatible = "brcm,bcm2835-armctrl-ic"; - reg = <0x7e00b200 0x200>; - interrupt-controller; - #interrupt-cells = <2>; - }; - pm: watchdog@7e100000 { compatible = "brcm,bcm2835-pm", "brcm,bcm2835-pm-wdt"; #power-domain-cells = <1>; @@ -184,8 +166,7 @@ interrupt-controller; #interrupt-cells = <2>;
- /* Defines pin muxing groups according to - * BCM2835-ARM-Peripherals.pdf page 102. + /* Defines common pin muxing groups * * While each pin can have its mux selected * for various functions individually, some @@ -263,15 +244,6 @@ brcm,pins = <44 45>; brcm,function = <BCM2835_FSEL_ALT2>; }; - i2c_slave_gpio18: i2c_slave_gpio18 { - brcm,pins = <18 19 20 21>; - brcm,function = <BCM2835_FSEL_ALT3>; - }; - - jtag_gpio4: jtag_gpio4 { - brcm,pins = <4 5 6 12 13>; - brcm,function = <BCM2835_FSEL_ALT5>; - }; jtag_gpio22: jtag_gpio22 { brcm,pins = <22 23 24 25 26 27>; brcm,function = <BCM2835_FSEL_ALT4>; @@ -488,14 +460,6 @@
- thermal: thermal@7e212000 { - compatible = "brcm,bcm2835-thermal"; - reg = <0x7e212000 0x8>; - clocks = <&clocks BCM2835_CLOCK_TSENS>; - #thermal-sensor-cells = <0>; - status = "disabled"; - }; - aux: aux@7e215000 { compatible = "brcm,bcm2835-aux"; #clock-cells = <1>; @@ -635,13 +599,6 @@ phy-names = "usb2-phy"; };
- v3d: v3d@7ec00000 { - compatible = "brcm,bcm2835-v3d"; - reg = <0x7ec00000 0x1000>; - interrupts = <1 10>; - power-domains = <&pm BCM2835_POWER_DOMAIN_GRAFX_V3D>; - }; - vc4: gpu { compatible = "brcm,bcm2835-vc4"; };
My opinion is that we should wait for official dts instead of using some work-in-progress ones. So my opinion is to use the DTB from the FW for now until we have something stable.
- bcm2835, bcm2836 and bcm2837 implementations.
- soc {
timer@7e003000 {
* support yet.
v3d: v3d@7ec00000 {
+&gpio {
timer@7e003000 {
* support yet.
v3d: v3d@7ec00000 {
Signed-off-by: Andrei Gherzan andrei@gherzan.ro --- arch/arm/dts/Makefile | 4 +- arch/arm/dts/bcm2838-rpi-4-b.dts | 56 ++++++++ arch/arm/dts/bcm2838.dtsi | 237 +++++++++++++++++++++++++++++++ 3 files changed, 296 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/bcm2838-rpi-4-b.dts create mode 100644 arch/arm/dts/bcm2838.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 20dbc2ff84..16790af1e1 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -749,7 +749,9 @@ dtb-$(CONFIG_ARCH_BCM283X) += \ bcm2837-rpi-3-a-plus.dtb \ bcm2837-rpi-3-b.dtb \ bcm2837-rpi-3-b-plus.dtb \ - bcm2837-rpi-cm3-io3.dtb + bcm2837-rpi-cm3-io3.dtb \ + bcm2837-rpi-3-b.dtb \ + bcm2838-rpi-4-b.dtb
dtb-$(CONFIG_ARCH_BCM63158) += \ bcm963158.dtb diff --git a/arch/arm/dts/bcm2838-rpi-4-b.dts b/arch/arm/dts/bcm2838-rpi-4-b.dts new file mode 100644 index 0000000000..07e9a78e8d --- /dev/null +++ b/arch/arm/dts/bcm2838-rpi-4-b.dts @@ -0,0 +1,56 @@ +/dts-v1/; +#include "bcm2838.dtsi" + +/ { + compatible = "raspberrypi,4-model-b","brcm,bcm2838","brcm,bcm2837"; + model = "Raspberry Pi 4 Model B"; + + memory { + reg = <0 0 0x40000000>; + }; + + leds { + act { + gpios = <&gpio 47 0>; + }; + }; +}; + +/* uart0 communicates with the BT module */ +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_gpio32 &gpclk2_gpio43>; + status = "okay"; +}; + +/* uart1 is mapped to the pin header */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "okay"; +}; + +/* SDHCI is used to control the SDIO for wireless */ +&sdhci { + pinctrl-names = "default"; + pinctrl-0 = <&emmc_gpio34>; + status = "okay"; + bus-width = <4>; + non-removable; +}; + +/* SDHOST is used to drive the SD card */ +&sdhost { + pinctrl-names = "default"; + pinctrl-0 = <&sdhost_gpio48>; + status = "okay"; + bus-width = <4>; +}; + +&gpio { + uart1_pins: uart1_pins { + brcm,pins; + brcm,function; + brcm,pull; + }; +}; diff --git a/arch/arm/dts/bcm2838.dtsi b/arch/arm/dts/bcm2838.dtsi new file mode 100644 index 0000000000..19b2d7b905 --- /dev/null +++ b/arch/arm/dts/bcm2838.dtsi @@ -0,0 +1,237 @@ +#include "bcm283x.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/power/raspberrypi-power.h> + +/ { + compatible = "brcm,bcm2838"; + + #address-cells = <2>; + #size-cells = <1>; + + interrupt-parent = <&gic>; + + soc { + ranges = <0x7e000000 0x0 0xfe000000 0x01800000>, + <0x7c000000 0x0 0xfc000000 0x02000000>, + <0x40000000 0x0 0xff800000 0x00800000>; + dma-ranges = <0xc0000000 0x0 0x00000000 0x3c000000>; + + gic: gic400@40041000 { + interrupt-controller; + #interrupt-cells = <3>; + compatible = "arm,gic-400"; + reg = <0x40041000 0x1000>, + <0x40042000 0x2000>, + <0x40044000 0x2000>, + <0x40046000 0x2000>; + }; + + thermal: thermal@7d5d2200 { + compatible = "brcm,avs-tmon-bcm2838"; + reg = <0x7d5d2200 0x2c>; + interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "tmon"; + clocks = <&clocks BCM2835_CLOCK_TSENS>; + #thermal-sensor-cells = <0>; + status = "okay"; + }; + + spi@7e204000 { + reg = <0x7e204000 0x0200>; + interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + }; + + pixelvalve@7e206000 { + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + }; + + pixelvalve@7e207000 { + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + }; + + hvs@7e400000 { + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + }; + + emmc2: emmc2@7e340000 { + compatible = "brcm,bcm2711-emmc2"; + status = "okay"; + interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clocks BCM2838_CLOCK_EMMC2>; + reg = <0x7e340000 0x100>; + }; + + pixelvalve@7e807000 { + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + + }; + + arm-pmu { + /* + * N.B. the A72 PMU support only exists in arch/arm64, hence + * the fallback to the A53 version. + */ + compatible = "arm,cortex-a72-pmu", "arm,cortex-a53-pmu"; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | + IRQ_TYPE_LEVEL_LOW)>; + arm,cpu-registers-not-fw-configured; + always-on; + }; + + cpus: cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "brcm,bcm2836-smp"; // for ARM 32-bit + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a72"; + reg = <0>; + enable-method = "spin-table"; + cpu-release-addr = <0x0 0x000000d8>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a72"; + reg = <1>; + enable-method = "spin-table"; + cpu-release-addr = <0x0 0x000000e0>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a72"; + reg = <2>; + enable-method = "spin-table"; + cpu-release-addr = <0x0 0x000000e8>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a72"; + reg = <3>; + enable-method = "spin-table"; + cpu-release-addr = <0x0 0x000000f0>; + }; + }; +}; + +&clk_osc { + clock-frequency = <54000000>; +}; + +&clocks { + compatible = "brcm,bcm2838-cprman"; +}; + +&cpu_thermal { + coefficients = <(-487) 410040>; +}; + +&dsi0 { + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; +}; + +&dsi1 { + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; +}; + +&gpio { + compatible = "brcm,bcm2838-gpio", "brcm,bcm2835-gpio"; + interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; +}; + +&vec { + interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>; +}; + +&usb { + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; +}; + +&hdmi { + interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; +}; + +&uart1 { + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; +}; + +&spi1 { + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; +}; + +&spi2 { + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; +}; + +&i2c0 { + interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; +}; + +&i2c1 { + interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; +}; + +&i2c2 { + interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; +}; + +&mailbox { + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; +}; + +&sdhost { + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; +}; + +&uart0 { + interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; +}; + +&dma { + reg = <0x7e007000 0xb00>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, /* dmalite 7 */ + <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, /* dmalite 8 */ + <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, /* dmalite 9 */ + <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; /* dmalite 10 */ + interrupt-names = "dma0", + "dma1", + "dma2", + "dma3", + "dma4", + "dma5", + "dma6", + "dma7", + "dma8", + "dma9", + "dma10"; + brcm,dma-channel-mask = <0x07f5>; +};
- bcm2837-rpi-cm3-io3.dtb \
- bcm2837-rpi-3-b.dtb \
You added rpi-3-b again, no need for that.
- bcm2838-rpi-4-b.dtb
- compatible = "raspberrypi,4-model-b","brcm,bcm2838","brcm,bcm2837";
- model = "Raspberry Pi 4 Model B";
- memory {
- leds {
act {
- pinctrl-names = "default";
- pinctrl-0 = <&uart0_gpio32 &gpclk2_gpio43>;
- status = "okay";
- pinctrl-0 = <&uart1_pins>;
- status = "okay";
- pinctrl-0 = <&emmc_gpio34>;
- status = "okay";
- bus-width = <4>;
- non-removable;
- pinctrl-0 = <&sdhost_gpio48>;
- status = "okay";
- bus-width = <4>;
+&gpio {
- uart1_pins: uart1_pins {
brcm,pins;
brcm,function;
brcm,pull;
- compatible = "brcm,bcm2838";
- #address-cells = <2>;
- #size-cells = <1>;
- interrupt-parent = <&gic>;
- soc {
status = "okay";
spi@7e204000 {
hvs@7e400000 {
status = "okay";
arm-pmu {
- timer {
always-on;
- cpus: cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0>;
cpu1: cpu@1 {
reg = <1>;
cpu2: cpu@2 {
reg = <2>;
cpu3: cpu@3 {
reg = <3>;
+&clk_osc {
- clock-frequency = <54000000>;
+&clocks {
- compatible = "brcm,bcm2838-cprman";
+&cpu_thermal {
- coefficients = <(-487) 410040>;
+&dsi0 {
+&dsi1 {
+&gpio {
- compatible = "brcm,bcm2838-gpio", "brcm,bcm2835-gpio";
- interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>,
+&vec {
+&usb {
+&hdmi {
+&uart1 {
- interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>;
+&spi1 {
+&spi2 {
+&i2c0 {
+&i2c1 {
+&i2c2 {
+&mailbox {
+&sdhost {
+&uart0 {
+&dma {
"dma1",
"dma2",
"dma3",
"dma4",
"dma5",
"dma6",
"dma7",
"dma8",
"dma9",
"dma10";
Signed-off-by: Andrei Gherzan andrei@gherzan.ro --- arch/arm/mach-bcm283x/Kconfig | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index 3eb5a9a897..d5069fe688 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -26,6 +26,23 @@ config BCM2837_64B select BCM2837 select ARM64
+config BCM2838 + bool "Broadcom BCM2838 SoC support" + depends on ARCH_BCM283X + +config BCM2838_32B + bool "Broadcom BCM2838 SoC 32-bit support" + depends on ARCH_BCM283X + select BCM2838 + select ARMV7_LPAE + select CPU_V7A + +config BCM2838_64B + bool "Broadcom BCM2838 SoC 64-bit support" + depends on ARCH_BCM283X + select BCM2838 + select ARM64 + menu "Broadcom BCM283X family" depends on ARCH_BCM283X
@@ -127,6 +144,24 @@ config TARGET_RPI_3 This option creates a build targeting the ARMv8/AArch64 ISA. select BCM2837_64B
+config TARGET_RPI_4 + bool "Raspberry Pi 4 64-bit build" + help + Support for all BCM2838-based Raspberry Pi variants, such as + the RPi 4 model B, in AArch64 (64-bit) mode. + + This option creates a build targeting the ARMv8/AArch64 ISA. + select BCM2838_64B + +config TARGET_RPI_4_32B + bool "Raspberry Pi 4 32-bit build" + help + Support for all BCM2838-based Raspberry Pi variants, such as + the RPi 4 model B, in AArch32 (32-bit) mode. + + This option creates a build targeting the ARMv7/AArch32 ISA. + select BCM2838_32B + endchoice
config SYS_BOARD
Signed-off-by: Andrei Gherzan andrei@gherzan.ro --- arch/arm/mach-bcm283x/include/mach/mbox.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index e3a893e49c..2d711daaa8 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -38,11 +38,16 @@ /* Raw mailbox HW */
#ifndef CONFIG_BCM2835 +#ifdef CONFIG_BCM2838 +#define BCM2835_MBOX_PHYSADDR 0xfe00b880 +#else #define BCM2835_MBOX_PHYSADDR 0x3f00b880 +#endif #else #define BCM2835_MBOX_PHYSADDR 0x2000b880 #endif
+ struct bcm2835_mbox_regs { u32 read; u32 rsvd0[5];
That gets really complicated. I prefer to add CONFIG_BCM283x_BASE or something like that and then add the offset in the header files.
Signed-off-by: Andrei Gherzan andrei@gherzan.ro --- board/raspberrypi/rpi/rpi.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 617c892dde..6d6f1ef39a 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -148,6 +148,11 @@ static const struct rpi_model rpi_models_new_scheme[] = { DTB_DIR "bcm2837-rpi-cm3.dtb", false, }, + [0x11] = { + "4 Model B", + DTB_DIR "bcm2711-rpi-4-b.dtb", + true, + }, };
static const struct rpi_model rpi_models_old_scheme[] = {
Commit message missing.
- [0x11] = {
"4 Model B",
true,
On BCM2838 there is an additional clock. This clock was added in the same bcm2835-cprman driver and is used by the emmc2 dt node.
Signed-off-by: Andrei Gherzan andrei@gherzan.ro --- include/dt-bindings/clock/bcm2835.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/dt-bindings/clock/bcm2835.h b/include/dt-bindings/clock/bcm2835.h index 2cec01f968..457fd4e23c 100644 --- a/include/dt-bindings/clock/bcm2835.h +++ b/include/dt-bindings/clock/bcm2835.h @@ -58,3 +58,5 @@ #define BCM2835_CLOCK_DSI1E 48 #define BCM2835_CLOCK_DSI0P 49 #define BCM2835_CLOCK_DSI1P 50 + +#define BCM2838_CLOCK_EMMC2 51
no new line please.
This clock has a different mbox ID[1] so have this included in the relevant header file.
[1] https://github.com/raspberrypi/firmware/issues/1179
Signed-off-by: Andrei Gherzan andrei@balena.io --- arch/arm/mach-bcm283x/include/mach/mbox.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index 2d711daaa8..cad035e8cd 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -239,6 +239,7 @@ struct bcm2835_mbox_tag_set_power_state { #define BCM2835_MBOX_CLOCK_ID_SDRAM 8 #define BCM2835_MBOX_CLOCK_ID_PIXEL 9 #define BCM2835_MBOX_CLOCK_ID_PWM 10 +#define BCM2835_MBOX_CLOCK_ID_EMMC2 12
struct bcm2835_mbox_tag_get_clock_rate { struct bcm2835_mbox_tag_hdr tag_hdr;
The bcm2711 has two emmc controller. The difference is the clocks they use. Add support for the second emmc contoller.
Signed-off-by: Matthias Brugger mbrugger@suse.com --- drivers/mmc/bcm2835_sdhci.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/bcm2835_sdhci.c b/drivers/mmc/bcm2835_sdhci.c index 08bddd410e..e68dec3be7 100644 --- a/drivers/mmc/bcm2835_sdhci.c +++ b/drivers/mmc/bcm2835_sdhci.c @@ -178,12 +178,13 @@ static int bcm2835_sdhci_probe(struct udevice *dev) fdt_addr_t base; int emmc_freq; int ret; + int clock_id = (int)dev_get_driver_data(dev);
base = devfdt_get_addr(dev); if (base == FDT_ADDR_T_NONE) return -EINVAL;
- ret = bcm2835_get_mmc_clock(BCM2835_MBOX_CLOCK_ID_EMMC); + ret = bcm2835_get_mmc_clock(clock_id); if (ret < 0) { debug("%s: Failed to set MMC clock (err=%d)\n", __func__, ret); return ret; @@ -228,7 +229,14 @@ static int bcm2835_sdhci_probe(struct udevice *dev) }
static const struct udevice_id bcm2835_sdhci_match[] = { - { .compatible = "brcm,bcm2835-sdhci" }, + { + .compatible = "brcm,bcm2835-sdhci", + .data = BCM2835_MBOX_CLOCK_ID_EMMC + }, + { + .compatible = "brcm,bcm2711-emmc2", + .data = BCM2835_MBOX_CLOCK_ID_EMMC2 + }, { /* sentinel */ } };
missing your signed-off-by.
- ret = bcm2835_get_mmc_clock(clock_id); if (ret < 0) { debug("%s: Failed to set MMC clock (err=%d)\n", __func__, ret); return ret;
- }, { /* sentinel */ }
Signed-off-by: Andrei Gherzan andrei@balena.io --- arch/arm/mach-bcm283x/include/mach/sdhci.h | 4 ++++ arch/arm/mach-bcm283x/include/mach/timer.h | 4 ++++ arch/arm/mach-bcm283x/include/mach/wdog.h | 4 ++++ 3 files changed, 12 insertions(+)
diff --git a/arch/arm/mach-bcm283x/include/mach/sdhci.h b/arch/arm/mach-bcm283x/include/mach/sdhci.h index 5cb6ec3340..262b016a1b 100644 --- a/arch/arm/mach-bcm283x/include/mach/sdhci.h +++ b/arch/arm/mach-bcm283x/include/mach/sdhci.h @@ -7,7 +7,11 @@ #define _BCM2835_SDHCI_H_
#ifndef CONFIG_BCM2835 +#ifdef CONFIG_BCM2838 +#define BCM2835_SDHCI_BASE 0xfe300000 +#else #define BCM2835_SDHCI_BASE 0x3f300000 +#endif #else #define BCM2835_SDHCI_BASE 0x20300000 #endif diff --git a/arch/arm/mach-bcm283x/include/mach/timer.h b/arch/arm/mach-bcm283x/include/mach/timer.h index 56b0c356bb..dc3ed98879 100644 --- a/arch/arm/mach-bcm283x/include/mach/timer.h +++ b/arch/arm/mach-bcm283x/include/mach/timer.h @@ -7,7 +7,11 @@ #define _BCM2835_TIMER_H
#ifndef CONFIG_BCM2835 +#ifdef CONFIG_BCM2838 +#define BCM2835_TIMER_PHYSADDR 0xfe003000 +#else #define BCM2835_TIMER_PHYSADDR 0x3f003000 +#endif #else #define BCM2835_TIMER_PHYSADDR 0x20003000 #endif diff --git a/arch/arm/mach-bcm283x/include/mach/wdog.h b/arch/arm/mach-bcm283x/include/mach/wdog.h index 99c88e5df7..ef040f385d 100644 --- a/arch/arm/mach-bcm283x/include/mach/wdog.h +++ b/arch/arm/mach-bcm283x/include/mach/wdog.h @@ -7,7 +7,11 @@ #define _BCM2835_WDOG_H
#ifndef CONFIG_BCM2835 +#ifdef CONFIG_BCM2838 +#define BCM2835_WDOG_PHYSADDR 0xfe100000 +#else #define BCM2835_WDOG_PHYSADDR 0x3f100000 +#endif #else #define BCM2835_WDOG_PHYSADDR 0x20100000 #endif
Otherwise there is a crash with newer RPi firmware, see https://github.com/raspberrypi/firmware/issues/1157 --- drivers/video/bcm2835.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/video/bcm2835.c b/drivers/video/bcm2835.c index bc41090aed..4c7962cad8 100644 --- a/drivers/video/bcm2835.c +++ b/drivers/video/bcm2835.c @@ -19,13 +19,15 @@ static int bcm2835_video_probe(struct udevice *dev)
debug("bcm2835: Query resolution...\n"); ret = bcm2835_get_video_size(&w, &h); - if (ret) + if (ret || w == 0 || h == 0) return -EIO;
debug("bcm2835: Setting up display for %d x %d\n", w, h); ret = bcm2835_set_video_params(&w, &h, 32, BCM2835_MBOX_PIXEL_ORDER_RGB, BCM2835_MBOX_ALPHA_MODE_IGNORED, &fb_base, &fb_size, &pitch); + if(ret) + return -EIO;
debug("bcm2835: Final resolution is %d x %d\n", w, h);
For sending, the second mailbox is used, but previously the status register of the first one was read. --- arch/arm/mach-bcm283x/include/mach/mbox.h | 7 +++++-- arch/arm/mach-bcm283x/mbox.c | 6 +++--- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index cad035e8cd..cd78966150 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -51,9 +51,12 @@ struct bcm2835_mbox_regs { u32 read; u32 rsvd0[5]; - u32 status; - u32 config; + u32 status_r; + u32 config_r; u32 write; + u32 rsvd1[5]; + u32 status_w; + u32 config_w; };
#define BCM2835_MBOX_STATUS_WR_FULL 0x80000000 diff --git a/arch/arm/mach-bcm283x/mbox.c b/arch/arm/mach-bcm283x/mbox.c index 1642ebd103..f7483bf423 100644 --- a/arch/arm/mach-bcm283x/mbox.c +++ b/arch/arm/mach-bcm283x/mbox.c @@ -27,7 +27,7 @@ int bcm2835_mbox_call_raw(u32 chan, u32 send, u32 *recv) /* Drain any stale responses */
for (;;) { - val = readl(®s->status); + val = readl(®s->status_r); if (val & BCM2835_MBOX_STATUS_RD_EMPTY) break; if (get_timer(0) >= endtime) { @@ -40,7 +40,7 @@ int bcm2835_mbox_call_raw(u32 chan, u32 send, u32 *recv) /* Wait for space to send */
for (;;) { - val = readl(®s->status); + val = readl(®s->status_w); if (!(val & BCM2835_MBOX_STATUS_WR_FULL)) break; if (get_timer(0) >= endtime) { @@ -58,7 +58,7 @@ int bcm2835_mbox_call_raw(u32 chan, u32 send, u32 *recv) /* Wait for the response */
for (;;) { - val = readl(®s->status); + val = readl(®s->status_r); if (!(val & BCM2835_MBOX_STATUS_RD_EMPTY)) break; if (get_timer(0) >= endtime) {
Signed-off-by: Andrei Gherzan andrei@balena.io --- configs/rpi_4_32b_defconfig | 43 +++++++++++++++++++++++++++++++++++++ 1 file changed, 43 insertions(+) create mode 100644 configs/rpi_4_32b_defconfig
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig new file mode 100644 index 0000000000..9f2b805d0f --- /dev/null +++ b/configs/rpi_4_32b_defconfig @@ -0,0 +1,43 @@ +CONFIG_ARM=y +CONFIG_ARCH_BCM283X=y +CONFIG_SYS_TEXT_BASE=0x00008000 +CONFIG_TARGET_RPI_4_32B=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_PROMPT="U-Boot> " +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_FS_UUID=y +CONFIG_OF_EMBED=y +CONFIG_DEFAULT_DEVICE_TREE="bcm2838-rpi-4-b" +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_BCM2835=y +CONFIG_PHYLIB=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +# CONFIG_REQUIRE_SERIAL_CONSOLE is not set +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_DWC2=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_LAN78XX=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_CONSOLE_SCROLL_LINES=10 +CONFIG_PHYS_TO_BUS=y +CONFIG_OF_LIBFDT_OVERLAY=y
Network is connected via PCI, why do we need this options here?
On Tue, Jul 16, 2019 at 3:25 PM Matthias Brugger matthias.bgg@gmail.com wrote:
Network is attached to a PHY not via PCI, that would be the USB.
It seems they're removed in patch 15 but the two should be squashed together.
Signed-off-by: Andrei Gherzan andrei@balena.io --- arch/arm/dts/bcm2838-rpi-4-b.dts | 16 ++++++---------- 1 file changed, 6 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/bcm2838-rpi-4-b.dts b/arch/arm/dts/bcm2838-rpi-4-b.dts index 07e9a78e8d..168179c17c 100644 --- a/arch/arm/dts/bcm2838-rpi-4-b.dts +++ b/arch/arm/dts/bcm2838-rpi-4-b.dts @@ -30,21 +30,17 @@ status = "okay"; };
-/* SDHCI is used to control the SDIO for wireless */ &sdhci { - pinctrl-names = "default"; - pinctrl-0 = <&emmc_gpio34>; - status = "okay"; - bus-width = <4>; - non-removable; + status = "disabled"; };
-/* SDHOST is used to drive the SD card */ &sdhost { - pinctrl-names = "default"; - pinctrl-0 = <&sdhost_gpio48>; + status = "disabled"; +}; + +&emmc2 { + compatible = "brcm,bcm2835-sdhci"; status = "okay"; - bus-width = <4>; };
&gpio {
Commit message. You fix a file that you introduced in this series. Any reason why you don't just send the file already fixed?
- status = "okay";
- bus-width = <4>;
- non-removable;
+&emmc2 {
- compatible = "brcm,bcm2835-sdhci"; status = "okay";
- bus-width = <4>;
&gpio {
Signed-off-by: Andrei Gherzan andrei@balena.io --- board/raspberrypi/rpi/rpi.c | 27 ++++++++++++++++++++++++--- 1 file changed, 24 insertions(+), 3 deletions(-)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 6d6f1ef39a..4242ef35a4 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -249,7 +249,8 @@ static uint32_t rev_type; static const struct rpi_model *model;
#ifdef CONFIG_ARM64 -static struct mm_region bcm2837_mem_map[] = { +#ifndef CONFIG_BCM2838 +static struct mm_region bcm283x_mem_map[] = { { .virt = 0x00000000UL, .phys = 0x00000000UL, @@ -268,8 +269,28 @@ static struct mm_region bcm2837_mem_map[] = { 0, } }; - -struct mm_region *mem_map = bcm2837_mem_map; +#else +static struct mm_region bcm283x_mem_map[] = { + { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0xf3000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xfe000000UL, + .phys = 0xfe000000UL, + .size = 0x01800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; +#endif +struct mm_region *mem_map = bcm283x_mem_map; #endif
int dram_init(void)
dwc2 is only connected to the usb-c port so we don't have any real benefit in having it enabled in uboot.
Also, the GENET interface is connected directly to the SoC so we can drop the USB_ETHER configs.
Signed-off-by: Andrei Gherzan andrei@balena.io --- configs/rpi_4_32b_defconfig | 3 --- configs/rpi_4_defconfig | 3 --- 2 files changed, 6 deletions(-)
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index 9f2b805d0f..b71a14735a 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -31,11 +31,8 @@ CONFIG_PINCTRL=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_DM_USB=y -CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_LAN78XX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 83d1bd0cdb..b27e3f823b 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -31,11 +31,8 @@ CONFIG_PINCTRL=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_DM_USB=y -CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_LAN78XX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10
Signed-off-by: Andrei Gherzan andrei@balena.io --- arch/arm/dts/bcm2838-rpi-4-b.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/bcm2838-rpi-4-b.dts b/arch/arm/dts/bcm2838-rpi-4-b.dts index 168179c17c..b7241be3fd 100644 --- a/arch/arm/dts/bcm2838-rpi-4-b.dts +++ b/arch/arm/dts/bcm2838-rpi-4-b.dts @@ -39,7 +39,7 @@ };
&emmc2 { - compatible = "brcm,bcm2835-sdhci"; + compatible = "brcm,bcm2711-emmc2"; status = "okay"; };
I don't understand why you posted these while you asked me if I'll submit them. That's not a good way to collaborate on upstream.
Please use get_maintainers.pl to see whom you have to send the patches to.
Both not needed with FW at 025759b86 ("firmware: Rename hdmi_enable_4k to hdmi_enable_4kp60") Apart from that they have already been posted.
Pi
As I have mentioned privately, I've done that due to the fact that I haven't gotten any feedback from you. Nevertheless, I will sync up with you for the next iteration for this PR which will include the changes requested.
-- Andrei Gherzan gpg: rsa4096/D4D94F67AD0E9640 | t: @agherzan
Changes for v2: - Removed patches that are not needed anymore due to firmware update - Removed usage of embedded dtb as opposed to reusing the loaded dtb by the firmware - Removed known unsupported/not applicable peripherals (i.e USB) from defconfigs - Make sure the memory/reg is left untouched as configured by the firmware
Andrei Gherzan (6): RPI: Add defconfigs for rpi4 (32/64) ARM: bcm283x: Define configs for RaspberryPi 4 RPI: Add entry for Raspberry Pi 4 model B ARM: bcm283x: Include definition for additional emmc clock RPI: Add memory map for bcm2838 git-mailrc: Add rpi and bcm283x maintainer
Matthias Brugger (2): ARM: bcm283x: Add BCM283x_BASE define mmc: bcm283x: Add support for bcm2711 device in bcm2835_sdhci
arch/arm/mach-bcm283x/Kconfig | 67 ++++++++++++++++++++++ arch/arm/mach-bcm283x/include/mach/mbox.h | 7 +-- arch/arm/mach-bcm283x/include/mach/sdhci.h | 6 +- arch/arm/mach-bcm283x/include/mach/timer.h | 6 +- arch/arm/mach-bcm283x/include/mach/wdog.h | 6 +- board/raspberrypi/rpi/rpi.c | 32 ++++++++++- configs/rpi_4_32b_defconfig | 33 +++++++++++ configs/rpi_4_defconfig | 33 +++++++++++ doc/git-mailrc | 4 ++ drivers/mmc/bcm2835_sdhci.c | 12 +++- 10 files changed, 181 insertions(+), 25 deletions(-) create mode 100644 configs/rpi_4_32b_defconfig create mode 100644 configs/rpi_4_defconfig
This defines a minimum defconfig for each of the two Raspberry Pi 4 variants. One notable difference is that we don't have a embedded dt for this board given that the fw supplies us with one which we can reuse. Furthermore, the ram size is not queryable through mbox interface as the maximum reported size is 1G. The fw patches the dt with the right memory configuration and uboot uses it as it is. We avoid u-boot touching this configuration by making sure CONFIG_ARCH_FIXUP_FDT_MEMORY is deactivated.
Signed-off-by: Andrei Gherzan andrei@balena.io --- configs/rpi_4_32b_defconfig | 33 +++++++++++++++++++++++++++++++++ configs/rpi_4_defconfig | 33 +++++++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+) create mode 100644 configs/rpi_4_32b_defconfig create mode 100644 configs/rpi_4_defconfig
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig new file mode 100644 index 0000000000..a31a617a5f --- /dev/null +++ b/configs/rpi_4_32b_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_ARCH_BCM283X=y +CONFIG_SYS_TEXT_BASE=0x00008000 +CONFIG_TARGET_RPI_4_32B=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=1 +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_OF_BOARD=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_PROMPT="U-Boot> " +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_FS_UUID=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_BCM2835=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +# CONFIG_REQUIRE_SERIAL_CONSOLE is not set +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_CONSOLE_SCROLL_LINES=10 +CONFIG_PHYS_TO_BUS=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig new file mode 100644 index 0000000000..da8c960a2a --- /dev/null +++ b/configs/rpi_4_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_ARCH_BCM283X=y +CONFIG_SYS_TEXT_BASE=0x00080000 +CONFIG_TARGET_RPI_4=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=1 +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_OF_BOARD=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SYS_PROMPT="U-Boot> " +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_FS_UUID=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM_KEYBOARD=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_BCM2835=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +# CONFIG_REQUIRE_SERIAL_CONSOLE is not set +CONFIG_DM_VIDEO=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_CONSOLE_SCROLL_LINES=10 +CONFIG_PHYS_TO_BUS=y +CONFIG_OF_LIBFDT_OVERLAY=y
Devices of bcm283x have different base address, depending if they are on bcm2835 or bcm2836/7. Use BCM283x_BASE depending on the SoC you want to build and only add the offset in the header files.
Signed-off-by: Matthias Brugger mbrugger@suse.com Signed-off-by: Andrei Gherzan andrei@balena.io --- arch/arm/mach-bcm283x/Kconfig | 5 +++++ arch/arm/mach-bcm283x/include/mach/mbox.h | 6 +----- arch/arm/mach-bcm283x/include/mach/sdhci.h | 6 +----- arch/arm/mach-bcm283x/include/mach/timer.h | 6 +----- arch/arm/mach-bcm283x/include/mach/wdog.h | 6 +----- 5 files changed, 9 insertions(+), 20 deletions(-)
diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index 3eb5a9a897..8e69914a83 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -141,4 +141,9 @@ config SYS_SOC config SYS_CONFIG_NAME default "rpi"
+config BCM283x_BASE + hex + default "0x20000000" if BCM2835 + default "0x3f000000" if BCM2836 || BCM2837 + endmenu diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index e3a893e49c..e44c7577da 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -37,11 +37,7 @@
-#ifndef CONFIG_BCM2835 -#define BCM2835_MBOX_PHYSADDR 0x3f00b880 -#else -#define BCM2835_MBOX_PHYSADDR 0x2000b880 -#endif +#define BCM2835_MBOX_PHYSADDR (CONFIG_BCM283x_BASE + 0x0000b880)
struct bcm2835_mbox_regs { u32 read; diff --git a/arch/arm/mach-bcm283x/include/mach/sdhci.h b/arch/arm/mach-bcm283x/include/mach/sdhci.h index 5cb6ec3340..b443c379d8 100644 --- a/arch/arm/mach-bcm283x/include/mach/sdhci.h +++ b/arch/arm/mach-bcm283x/include/mach/sdhci.h @@ -6,11 +6,7 @@ #ifndef _BCM2835_SDHCI_H_ #define _BCM2835_SDHCI_H_
-#ifndef CONFIG_BCM2835 -#define BCM2835_SDHCI_BASE 0x3f300000 -#else -#define BCM2835_SDHCI_BASE 0x20300000 -#endif +#define BCM2835_SDHCI_BASE (CONFIG_BCM283x_BASE + 0x00300000)
int bcm2835_sdhci_init(u32 regbase, u32 emmc_freq);
diff --git a/arch/arm/mach-bcm283x/include/mach/timer.h b/arch/arm/mach-bcm283x/include/mach/timer.h index 56b0c356bb..014355e759 100644 --- a/arch/arm/mach-bcm283x/include/mach/timer.h +++ b/arch/arm/mach-bcm283x/include/mach/timer.h @@ -6,11 +6,7 @@ #ifndef _BCM2835_TIMER_H #define _BCM2835_TIMER_H
-#ifndef CONFIG_BCM2835 -#define BCM2835_TIMER_PHYSADDR 0x3f003000 -#else -#define BCM2835_TIMER_PHYSADDR 0x20003000 -#endif +#define BCM2835_TIMER_PHYSADDR (CONFIG_BCM283x_BASE + 0x00003000)
#define BCM2835_TIMER_CS_M3 (1 << 3) #define BCM2835_TIMER_CS_M2 (1 << 2) diff --git a/arch/arm/mach-bcm283x/include/mach/wdog.h b/arch/arm/mach-bcm283x/include/mach/wdog.h index 99c88e5df7..8292b3cf1f 100644 --- a/arch/arm/mach-bcm283x/include/mach/wdog.h +++ b/arch/arm/mach-bcm283x/include/mach/wdog.h @@ -6,11 +6,7 @@ #ifndef _BCM2835_WDOG_H #define _BCM2835_WDOG_H
-#ifndef CONFIG_BCM2835 -#define BCM2835_WDOG_PHYSADDR 0x3f100000 -#else -#define BCM2835_WDOG_PHYSADDR 0x20100000 -#endif +#define BCM2835_WDOG_PHYSADDR (CONFIG_BCM283x_BASE + 0x00100000)
struct bcm2835_wdog_regs { u32 unknown0[7];
- hex
- default "0x20000000" if BCM2835
- default "0x3f000000" if BCM2836 || BCM2837
How hard would it be to make the base a global variable instead and just set it early on board init based on the FDT or maybe even CPU core revision registers?
That would allow us to support RPi3 & 4 with the same U-Boot binary.
Alex
Define two target configs for Raspberry Pi 4 (32 and 64bit) and the corresponding BCM2838* configs.
Be aware of the current limitation in firmware which requires an explicit configuration to force the arm in 64bit mode when the respective target is used.
Signed-off-by: Andrei Gherzan andrei@balena.io Signed-off-by: Matthias Brugger mbrugger@suse.com --- arch/arm/mach-bcm283x/Kconfig | 62 +++++++++++++++++++++++++++++++++++ 1 file changed, 62 insertions(+)
diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index 8e69914a83..09a5b42bbb 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -26,6 +26,23 @@ config BCM2837_64B select BCM2837 select ARM64
@@ -127,6 +144,50 @@ config TARGET_RPI_3 This option creates a build targeting the ARMv8/AArch64 ISA. select BCM2837_64B
+config TARGET_RPI_4_32B + bool "Raspberry Pi 4 32-bit build" + help + Support for all BCM2838-based Raspberry Pi variants, such as + the RPi 4 model B, in AArch32 (32-bit) mode. + + This option assumes the VideoCore firmware is configured to use the + mini UART (rather than PL011) for the serial console. This is the + default on the RPi 4. To enable the UART console, the following non- + default option must be present in config.txt: enable_uart=1. This is + required for U-Boot to operate correctly, even if you only care + about the HDMI/usbkbd console. + + Due to hardware incompatibilities, this can't be used with + BCM283/5/6/7. + + This option creates a build targeting the ARMv7/AArch32 ISA. + select BCM2838_32B + +config TARGET_RPI_4 + bool "Raspberry Pi 4 64-bit build" + help + Support for all BCM2838-based Raspberry Pi variants, such as + the RPi 4 model B, in AArch64 (64-bit) mode. + + This option assumes the VideoCore firmware is configured to use the + mini UART (rather than PL011) for the serial console. This is the + default on the RPi 4. To enable the UART console, the following non- + default option must be present in config.txt: enable_uart=1. This is + required for U-Boot to operate correctly, even if you only care + about the HDMI/usbkbd console. + + Due to hardware incompatibilities, this can't be used with + BCM283/5/6/7. + + Also, due to a bug in firmware, switching to 64bit mode doesn't + happen automatically based on the kernel's image filename. See + https://github.com/raspberrypi/firmware/issues/1193 for more details. + Until that is resolved, the configuration (config.txt) needs to + explicitly set: arm_64bit=1. + + This option creates a build targeting the ARMv8/AArch64 ISA. + select BCM2838_64B + endchoice
config SYS_BOARD @@ -145,5 +206,6 @@ config BCM283x_BASE hex default "0x20000000" if BCM2835 default "0x3f000000" if BCM2836 || BCM2837 + default "0xfe000000" if BCM2838
endmenu
+config BCM2838
- bool "Broadcom BCM2838 SoC support"
- depends on ARCH_BCM283X
+config BCM2838_32B
- bool "Broadcom BCM2838 SoC 32-bit support"
- select BCM2838
- select ARMV7_LPAE
- select CPU_V7A
+config BCM2838_64B
- bool "Broadcom BCM2838 SoC 64-bit support"
- select BCM2838
- select ARM64
- bool "Raspberry Pi 4 32-bit build"
- help
BCM283/5/6/7.
- select BCM2838_32B
- bool "Raspberry Pi 4 64-bit build"
- help
BCM283/5/6/7.
- select BCM2838_64B
endchoice
- default "0xfe000000" if BCM2838
In upstream kernel the SoC uses bcm2711 as identifier. So this get's messy here, because we have all the bcm283x stuff. Anyway we should try to keep the confusion as low as possible, so I propose to rename all BCM2838 in here to BCM2711.
It's not perfect but I think it's the best we can get right now.
Regards, Matthias
The Raspebrry Pi 4 uses the new revision code scheme as documented by the foundation. This change adds an entry for this board as well.
Signed-off-by: Andrei Gherzan andrei@balena.io --- board/raspberrypi/rpi/rpi.c | 5 +++++ 1 file changed, 5 insertions(+)
This clock has a different mbox ID so have this included in the relevant header file.
diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index e44c7577da..f2a98acddd 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -230,6 +230,7 @@ struct bcm2835_mbox_tag_set_power_state { #define BCM2835_MBOX_CLOCK_ID_SDRAM 8 #define BCM2835_MBOX_CLOCK_ID_PIXEL 9 #define BCM2835_MBOX_CLOCK_ID_PWM 10 +#define BCM2835_MBOX_CLOCK_ID_EMMC2 12
The bcm2711 has two emmc controllers. The difference is the clocks they use. Add support for the second emmc controller.
Signed-off-by: Matthias Brugger mbrugger@suse.com Signed-off-by: Andrei Gherzan andrei@balena.io --- drivers/mmc/bcm2835_sdhci.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
Define the memory map for the BCM2838 based on the dt configuration available in the Raspberry Pi kernel fork.
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 6d6f1ef39a..1c4fae9166 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -249,7 +249,8 @@ static uint32_t rev_type; static const struct rpi_model *model;
#ifdef CONFIG_ARM64 -static struct mm_region bcm2837_mem_map[] = { +#ifndef CONFIG_BCM2838 +static struct mm_region bcm283x_mem_map[] = { { .virt = 0x00000000UL, .phys = 0x00000000UL, @@ -268,8 +269,28 @@ static struct mm_region bcm2837_mem_map[] = { 0, } }; - -struct mm_region *mem_map = bcm2837_mem_map; +#else +static struct mm_region bcm283x_mem_map[] = { + { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0xfe000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xfe000000UL, + .phys = 0xfe000000UL, + .size = 0x01800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; +#endif +struct mm_region *mem_map = bcm283x_mem_map; #endif
int dram_init(void)
Signed-off-by: Andrei Gherzan andrei@balena.io --- doc/git-mailrc | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/doc/git-mailrc b/doc/git-mailrc index a63b76befc..68110e1963 100644 --- a/doc/git-mailrc +++ b/doc/git-mailrc @@ -35,6 +35,7 @@ alias mariosix Mario Six mario.six@gdsys.cc alias masahiro Masahiro Yamada yamada.masahiro@socionext.com alias mateusz Mateusz Kulikowski mateusz.kulikowski@gmail.com alias maxime Maxime Ripard maxime.ripard@free-electrons.com +alias mbrugger Matthias Brugger mbrugger@suse.com alias monstr Michal Simek monstr@monstr.eu alias prom Minkyu Kang mk7.kang@samsung.com alias ptomsich Philipp Tomsich philipp.tomsich@theobroma-systems.com @@ -74,6 +75,9 @@ alias uniphier uboot, masahiro alias zynq uboot, monstr alias rockchip uboot, sjg, kevery, ptomsich
+alias bcm283x uboot,mbrugger +alias rpi uboot,mbrugger + alias m68k uboot, alisonwang, angelo_ts alias coldfire m68k
Missing commit message. Maybe something like: Add entries for bcm283x and rpi prefix.
Other then that: Acked-by: Matthias Brugger mbrugger@suse.com
participants (6)
Alexander Graf
Andrei Gherzan
Andrei Gherzan
andrei@gherzan.ro
Matthias Brugger
Peter Robinson
