[U-Boot] [PATCH 0/7] Add Device Tree for OMAP3 and omap3_logic
This patch series copies the Linux Device trees for the OMAP3 and OMAP3630 platforms as well as some additional device trees to support the Logic PD Torpedo and Logic PD SOM-LV both based on DM3730 (OMAP3630) processors. There are no changes to patches 2-7 from the initial version posted as RFC, but I added "Reviewed-by: Lokesh Vutla lokeshvutla@ti.com" to patches 2-7
Patch 1 removes the wrong comments I made when mixed up the am33xx datasheet. It should correctly supports the proper offsets on the OMAP34XX platforms and should not break the am33xx and newer boards with the different offset. I don't believe there is any debate on this. Sorry for the noise.
This series allows us to eliminate the board detection code as well as move to DM_I2C and DM_MMC and push the DM_SERIAL setup to the OF except when in SPL. This should give enough background for other OMAP3 boards to migrate to device tree.
The dm uclass dump is as follows:
uclass 0: root - * root_driver @ 8df38028, seq 0, (req -1)
uclass 9: simple_bus - * ocp@68000000 @ 8df382e0, seq 0, (req -1) - l4@48000000 @ 8df38348 - scm@2000 @ 8df383b0 - scm_conf@270 @ 8df38418
uclass 19: gpio - gpio_omap @ 8df380b0 - gpio_omap @ 8df38108 - gpio_omap @ 8df38160 - gpio_omap @ 8df381b8 - gpio_omap @ 8df38210 - gpio_omap @ 8df38268 - gpio@48310000 @ 8df38480 - gpio@49050000 @ 8df384e8 - gpio@49052000 @ 8df38550 - * gpio@49054000 @ 8df385b8, seq 0, (req -1) - gpio@49056000 @ 8df38620 - gpio@49058000 @ 8df38688
uclass 20: i2c - * i2c@48070000 @ 8df38880, seq 0, (req 0) - i2c@48072000 @ 8df388d8, seq -1, (req 1) - i2c@48060000 @ 8df38930, seq -1, (req 2)
uclass 22: i2c_generic - * generic_4b @ 8df4b178, seq 0, (req -1)
uclass 31: mmc - * mmc@4809c000 @ 8df389a8, seq 0, (req -1) - * mmc@480ad000 @ 8df38b80, seq 1, (req -1)
uclass 52: serial - * serial@4806a000 @ 8df38710, seq 0, (req 0) - serial@4806c000 @ 8df38780, seq -1, (req 1) - serial@49020000 @ 8df387f0, seq -1, (req 2) - serial@49042000 @ 8df38d58, seq -1, (req 3)
Adam Ford
