[U-Boot] [FASTBOOT] increase envstr[] length from 32 to 64
19 Sep
2016
19 Sep
'16
4:41 p.m.
The following commit has been pushed in order to retrieve envrionment variables for fastboot: fastboot: allow retrieving fastboot variables from env (74322201dde4593dc3194c702e95e5760e6b497a)
The file is drivers/usb/gadget/f_fastboot.c, function is cb_getvar
It uses à 32-char array (char envstr[32]), knowing that it should ends by '\0', so it has 31 usable characters.
In my case, we use the variable: ‘fastboot.partition-type:userdata’, his length is 32 characters, so this is a problem.
As information, this variable is used in the Android context, but we can imagine to face this same issue with any framework.
Would it be possible to increase the length from 32 to 64 ?
Thanks in advance. Best Regards Nicolas
3160
Nicolas le bayon
