[U-Boot-Users] [PATCH] Xilinx PowerPC XPS_LL_TEMAC driver
Signed-off-by: Yoshio Kashiwagi kashiwagi@co-nss.co.jp --- drivers/net/Makefile | 1 + drivers/net/xilinx_ll_temac.c | 371 ++++++++++++++++++++++++++++++++++ +++++++ 2 files changed, 372 insertions(+), 0 deletions(-) create mode 100644 drivers/net/xilinx_ll_temac.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index d5e413b..a11238b 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -63,6 +63,7 @@ COBJS-y += uli526x.o COBJS-y += vsc7385.o COBJS-$(CONFIG_XILINX_EMAC) += xilinx_emac.o COBJS-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o +COBJS-$(CONFIG_XILINX_LL_TEMAC)) += xilinx_ll_temac.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/xilinx_ll_temac.c b/drivers/net/xilinx_ll_temac. c new file mode 100644 index 0000000..2f75ebc --- /dev/null +++ b/drivers/net/xilinx_ll_temac.c @@ -0,0 +1,371 @@ +/* + * + * Xilinx xps_ll_temac ethernet driver for u-boot + * + * Author: Yoshio Kashiwagi kashiwagi@co-nss.co.jp + * + * Copyright (c) 2008 Nissin Systems Co.,Ltd. + * + * March 2008 created + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * +*/ +#include <config.h> +#include <common.h> +#include <net.h> +#include <malloc.h> +#include <asm/errno.h> +#include <asm/processor.h> + +#define S_DMA_CTRL_BASEADDR XPAR_LLTEMAC_0_LLINK_CONNECTED_BASEADDR +#define XPS_LLTEMAC_BASEADDR XPAR_LLTEMAC_0_BASEADDR + +/* XPS_LL_TEMAC SDMA registers definition */ + +#define TX_NXTDESC_PTR (S_DMA_CTRL_BASEADDR + 0x00) +#define TX_CURBUF_ADDR (S_DMA_CTRL_BASEADDR + 0x04) +#define TX_CURBUF_LENGTH (S_DMA_CTRL_BASEADDR + 0x08) +#define TX_CURDESC_PTR (S_DMA_CTRL_BASEADDR + 0x0c) +#define TX_TAILDESC_PTR (S_DMA_CTRL_BASEADDR + 0x10) +#define TX_CHNL_CTRL (S_DMA_CTRL_BASEADDR + 0x14) +#define TX_IRQ_REG (S_DMA_CTRL_BASEADDR + 0x18) +#define TX_CHNL_STS (S_DMA_CTRL_BASEADDR + 0x1c) + +#define RX_NXTDESC_PTR (S_DMA_CTRL_BASEADDR + 0x20) +#define RX_CURBUF_ADDR (S_DMA_CTRL_BASEADDR + 0x24) +#define RX_CURBUF_LENGTH (S_DMA_CTRL_BASEADDR + 0x28) +#define RX_CURDESC_PTR (S_DMA_CTRL_BASEADDR + 0x2c) +#define RX_TAILDESC_PTR (S_DMA_CTRL_BASEADDR + 0x30) +#define RX_CHNL_CTRL (S_DMA_CTRL_BASEADDR + 0x34) +#define RX_IRQ_REG (S_DMA_CTRL_BASEADDR + 0x38) +#define RX_CHNL_STS (S_DMA_CTRL_BASEADDR + 0x3c) + +#define DMA_CONTROL_REG (S_DMA_CTRL_BASEADDR + 0x40) + +/* XPS_LL_TEMAC direct registers definition */ + +#define TEMAC_RAF0 (XPS_LLTEMAC_BASEADDR + 0x00) +#define TEMAC_TPF0 (XPS_LLTEMAC_BASEADDR + 0x04) +#define TEMAC_IFGP0 (XPS_LLTEMAC_BASEADDR + 0x08) +#define TEMAC_IS0 (XPS_LLTEMAC_BASEADDR + 0x0c) +#define TEMAC_IP0 (XPS_LLTEMAC_BASEADDR + 0x10) +#define TEMAC_IE0 (XPS_LLTEMAC_BASEADDR + 0x14) + +#define TEMAC_MSW0 (XPS_LLTEMAC_BASEADDR + 0x20) +#define TEMAC_LSW0 (XPS_LLTEMAC_BASEADDR + 0x24) +#define TEMAC_CTL0 (XPS_LLTEMAC_BASEADDR + 0x28) +#define TEMAC_RDY0 (XPS_LLTEMAC_BASEADDR + 0x2c) + +#define XTE_RSE_MIIM_RR_MASK 0x0002 +#define XTE_RSE_MIIM_WR_MASK 0x0004 +#define XTE_RSE_CFG_RR_MASK 0x0020 +#define XTE_RSE_CFG_WR_MASK 0x0040 + +/* XPS_LL_TEMAC indirect registers offset definition */ + +#define RCW0 0x200 +#define RCW1 0x240 +#define TC 0x280 +#define FCC 0x2c0 +#define EMMC 0x300 +#define PHYC 0x320 +#define MC 0x340 +#define UAW0 0x380 +#define UAW1 0x384 +#define MAW0 0x388 +#define MAW1 0x38c +#define AFM 0x390 +#define TIS 0x3a0 +#define TIE 0x3a4 +#define MIIMWD 0x3b0 +#define MIIMAI 0x3b4 + +#define CNTLREG_WRITE_ENABLE_MASK 0x8000 +#define CNTLREG_EMAC1SEL_MASK 0x0400 +#define CNTLREG_ADDRESSCODE_MASK 0x03ff + +#define MDIO_ENABLE_MASK 0x40 +#define MDIO_CLOCK_DIV_MASK 0x3F +#define MDIO_CLOCK_DIV_100MHz 0x28 + +#define ETHER_MTU 1520 +#define CACHE_LINE_SIZE 32 + +/* SDMA descriptor status bit definitions */ + +#define BDSTAT_ERROR_MASK 0x80 +#define BDSTAT_INT_ON_END_MASK 0x40 +#define BDSTAT_STOP_ON_END_MASK 0x20 +#define BDSTAT_COMPLETED_MASK 0x10 +#define BDSTAT_SOP_MASK 0x08 +#define BDSTAT_EOP_MASK 0x04 +#define BDSTAT_CHANBUSY_MASK 0x02 +#define BDSTAT_CHANRESET_MASK 0x01 + +/* SDMA Buffer Descriptor */ + +typedef struct cdmac_bd_t { + struct cdmac_bd_t *next_p; + unsigned char *phys_buf_p; + unsigned long buf_len; + unsigned char stat; + unsigned char app1_1; + unsigned short app1_2; + unsigned long app2; + unsigned long app3; + unsigned long app4; + unsigned long app5; +} cdmac_bd __attribute((aligned(32))) ; + +static cdmac_bd tx_bd; +static cdmac_bd rx_bd; +static unsigned char tx_buffer[ETHER_MTU] __attribute((aligned(32))); +static unsigned char rx_buffer[ETHER_MTU] __attribute((aligned(32))); + +struct xps_ll_temac_private { + int idx; + unsigned char dev_addr[6]; +}; + +static void flush_dcache_range(unsigned int addr, unsigned size) +{ + unsigned int end = addr + size; + + if(size) { + addr = addr & ~(CACHE_LINE_SIZE - 1); + while(addr < end) { + __asm__ __volatile__("dcbf 0,%0; sync;" : : "r" (addr)); + addr += CACHE_LINE_SIZE; + } + } +} + +static void invalidate_dcache_range(unsigned int addr, unsigned size) +{ + unsigned int end = addr + size; + + if(size) { + addr = addr & ~(CACHE_LINE_SIZE - 1); + while(addr < end) { + __asm__ __volatile__("dcbi 0,%0; sync;" : : "r" (addr)); + addr += CACHE_LINE_SIZE; + } + } +} + +static unsigned int xps_ll_temac_hostif_get(int emac, int phy_addr, int reg_addr) +{ + *(unsigned int *)TEMAC_LSW0 = phy_addr << 5 | reg_addr; + *(unsigned int *)TEMAC_CTL0 = MIIMAI | emac << 10; + + while(! (*(volatile unsigned int *)TEMAC_RDY0 & XTE_RSE_MIIM_RR_MASK) ); + return *(unsigned int *)TEMAC_LSW0; +} + +static void xps_ll_temac_indirect_set(int emac, int reg_offset, int reg_data) +{ + *(unsigned int *)TEMAC_LSW0 = reg_data; + *(unsigned int *)TEMAC_CTL0 = CNTLREG_WRITE_ENABLE_MASK | emac << 10 | reg_offset; + while(! (*(volatile unsigned int *)TEMAC_RDY0 & XTE_RSE_CFG_WR_MASK)) ; +} + +static int xps_ll_temac_phy_ctrl(void) +{ + static int phy_addr = -1; + static int link = 0; + int i; + unsigned int result; + + if(phy_addr == -1) { + for(i = 0;i < 32;i++) { + result = xps_ll_temac_hostif_get(0, i, 1); + if((result & 0x0ffff) != 0x0ffff) { + phy_addr = i; + break; + } + } + } else { + result = xps_ll_temac_hostif_get(0, phy_addr, 1); + } + if((result & 0x24) != 0x24) { + if(link) { + link = 0; + printf("Link down\n"); + } + return 0; + } + if(link == 0) { + link = 1; + } else { + return 1; + } + + result = xps_ll_temac_hostif_get(0, phy_addr, 10); + if((result & 0x0800) == 0x0800) { + xps_ll_temac_indirect_set(0, EMMC, 0x80000000); + printf("1000BASE-T/FD\n"); + return 1; + } + result = xps_ll_temac_hostif_get(0, phy_addr, 5); + if((result & 0x0100) == 0x0100) { + xps_ll_temac_indirect_set(0, EMMC, 0x40000000); + printf("100BASE-T/FD\n"); + } else if((result & 0x0040) == 0x0040) { + xps_ll_temac_indirect_set(0, EMMC, 0x00000000); + printf("10BASE-T/FD\n"); + } else { + printf("Half Duplex not supported\n"); + } + return 1; +} + +static void xps_ll_temac_bd_init(void) +{ + memset((void *)&tx_bd, 0, sizeof(cdmac_bd)); + memset((void *)&rx_bd, 0, sizeof(cdmac_bd)); + + rx_bd.phys_buf_p = &rx_buffer[0]; + rx_bd.next_p = &rx_bd; + rx_bd.buf_len = ETHER_MTU; + flush_dcache_range((unsigned int)&rx_bd, sizeof(cdmac_bd)); + *(unsigned int *)RX_CURDESC_PTR = (unsigned int)&rx_bd; + *(unsigned int *)RX_TAILDESC_PTR = (unsigned int)&rx_bd; + + tx_bd.phys_buf_p = &tx_buffer[0]; + tx_bd.next_p = &tx_bd; + flush_dcache_range((unsigned int)&tx_bd, sizeof(cdmac_bd)); + *(unsigned int *)TX_CURDESC_PTR = (unsigned int)&tx_bd; +} + +static int xps_ll_temac_send(unsigned char *buffer, int length) +{ + if(xps_ll_temac_phy_ctrl() == 0) return 0; + + memcpy(tx_buffer, buffer, length); + flush_dcache_range((unsigned int)tx_buffer, length); + + tx_bd.stat = BDSTAT_SOP_MASK | BDSTAT_EOP_MASK | BDSTAT_STOP_ON_END_ MASK; + tx_bd.buf_len = length; + flush_dcache_range((unsigned int)&tx_bd, sizeof(cdmac_bd)); + + *(unsigned int *)TX_CURDESC_PTR = (unsigned int)&tx_bd; + *(unsigned int *)TX_TAILDESC_PTR = (unsigned int)&tx_bd; /* DMA start */ + + do { + invalidate_dcache_range((unsigned int)&tx_bd, sizeof(cdmac_bd)); + } while(!((volatile int)tx_bd.stat & BDSTAT_COMPLETED_MASK)); + + return length; +} + +static int xps_ll_temac_recv(void) +{ + int length; + + invalidate_dcache_range((unsigned int)&rx_bd, sizeof(cdmac_bd)); + if(!(rx_bd.stat & BDSTAT_COMPLETED_MASK)) return 0; + + length = rx_bd.app5; + invalidate_dcache_range((unsigned int)rx_bd.phys_buf_p, length); + + rx_bd.buf_len = ETHER_MTU; + rx_bd.stat = 0; + rx_bd.app5 = 0; + flush_dcache_range((unsigned int)&rx_bd, sizeof(cdmac_bd)); + *(unsigned int *)RX_TAILDESC_PTR = (unsigned int)&rx_bd; + + if(length > 0) { + NetReceive(rx_bd.phys_buf_p, length); + } + + return length; +} + +static int xps_ll_temac_addr_setup(struct xps_ll_temac_private * lp) +{ + char * env_p; + char * end; + int i, val; + + env_p = getenv("ethaddr"); + if (env_p == NULL) { + printf("cannot get enviroment for "ethaddr".\n"); + return -1; + } + + for (i = 0; i < 6; i++) { + lp->dev_addr[i] = env_p ? simple_strtoul(env_p, &end, 16) : 0; + if (env_p) env_p = (*end) ? end + 1 : end; + } + + /* set up unicast MAC address filter */ + val = lp->dev_addr[3] << 24 | lp->dev_addr[2] << 16 | + lp->dev_addr[1] << 8 | lp->dev_addr[0]; + xps_ll_temac_indirect_set(0, UAW0, val); + val = lp->dev_addr[5] << 8 | lp->dev_addr[4]; + xps_ll_temac_indirect_set(0, UAW1, val); + + return 0; +} + +static void xps_ll_temac_init(struct eth_device *dev, bd_t *bis) +{ + struct xps_ll_temac_private *lp = (struct xps_ll_temac_private *) dev->priv; + + xps_ll_temac_bd_init(); + xps_ll_temac_indirect_set(0, MC, MDIO_ENABLE_MASK | MDIO_CLOCK_DIV_ 100MHz); + + xps_ll_temac_addr_setup(lp); + xps_ll_temac_indirect_set(0, AFM, 0x00000000); /* Promiscuos mode disable */ + xps_ll_temac_indirect_set(0, RCW1, 0x10000000); /* Enable Receiver * / + xps_ll_temac_indirect_set(0, TC, 0x10000000); /* Enable Transmitter */ + +} + +int eth_init(bd_t *bis) +{ + static int first = 1; + struct eth_device *dev; + struct xps_ll_temac_private *lp; + int i; + + if(!first) return 0; + first = 0; + dev = (struct eth_device *) calloc(1, sizeof(struct eth_device)) ; + if (NULL == dev) return 0; + + lp = (struct xps_ll_temac_private *) calloc(1, sizeof(struct xps_ll_temac_private)); + if (lp == NULL) return 0; + dev->priv = lp; + sprintf(dev->name, "eth0"); + + xps_ll_temac_init(dev, bis); + + printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08X.\ n", + dev->name, 0, XPS_LLTEMAC_BASEADDR); + + for(i = 0;i < 3;i++) { + if(xps_ll_temac_phy_ctrl()) break; + udelay(10000); /* wait second */ + } + return 1; +} + +int eth_send(volatile void *packet, int length) +{ + return xps_ll_temac_send((unsigned char *)packet, length); +} + +int eth_rx(void) +{ + return xps_ll_temac_recv(); +} + +void eth_halt(void) +{ +} +
^ Please remove, it will never compile
use tab for indentation not space and your patch is line wrapped
Best Regards, J.
Hi Yoshio,
my description is in patch
^^ two brackets.
- Xilinx xps_ll_temac ethernet driver for u-boot
- Author: Yoshio Kashiwagi kashiwagi@co-nss.co.jp
- Copyright (c) 2008 Nissin Systems Co.,Ltd.
- March 2008 created
- This program is free software; you can redistribute it and/or modify
it
- under the terms of the GNU General Public License as published by
the
- Free Software Foundation; either version 2 of the License, or (at
your
- option) any later version.
you don't use values from errno.h. You can remove it. Microblaze cpu don't have this header too.
- struct cdmac_bd_t *next_p;
- unsigned char *phys_buf_p;
- unsigned long buf_len;
- unsigned char stat;
- unsigned char app1_1;
- unsigned short app1_2;
- unsigned long app2;
- unsigned long app3;
- unsigned long app4;
- unsigned long app5;
- int idx;
- unsigned char dev_addr[6];
- unsigned int end = addr + size;
- if(size) {
while(addr < end) {
Your previous set of patches was better than this style. You can't add assembler code to c code which is not in ppc specific folder. Please use macros for it.
- if(size) {
while(addr < end) {
- *(unsigned int *)TEMAC_LSW0 = phy_addr << 5 | reg_addr;
- *(unsigned int *)TEMAC_CTL0 = MIIMAI | emac << 10;
- while(! (*(volatile unsigned int *)TEMAC_RDY0 & XTE_RSE_MIIM_RR_MASK)
- return *(unsigned int *)TEMAC_LSW0;
- *(unsigned int *)TEMAC_LSW0 = reg_data;
- *(unsigned int *)TEMAC_CTL0 = CNTLREG_WRITE_ENABLE_MASK | emac << 10
| reg_offset;
- while(! (*(volatile unsigned int *)TEMAC_RDY0 & XTE_RSE_CFG_WR_MASK))
- static int phy_addr = -1;
- static int link = 0;
- int i;
- unsigned int result;
- if(phy_addr == -1) {
phy_addr = i;
break;
- } else {
- if((result & 0x24) != 0x24) {
if(link) {
link = 0;
- if(link == 0) {
link = 1;
- } else {
return 1;
- result = xps_ll_temac_hostif_get(0, phy_addr, 10);
- if((result & 0x0800) == 0x0800) {
return 1;
- result = xps_ll_temac_hostif_get(0, phy_addr, 5);
- if((result & 0x0100) == 0x0100) {
- } else if((result & 0x0040) == 0x0040) {
- } else {
- return 1;
- memset((void *)&tx_bd, 0, sizeof(cdmac_bd));
- memset((void *)&rx_bd, 0, sizeof(cdmac_bd));
- rx_bd.phys_buf_p = &rx_buffer[0];
- rx_bd.next_p = &rx_bd;
- rx_bd.buf_len = ETHER_MTU;
- flush_dcache_range((unsigned int)&rx_bd, sizeof(cdmac_bd));
- *(unsigned int *)RX_CURDESC_PTR = (unsigned int)&rx_bd;
- *(unsigned int *)RX_TAILDESC_PTR = (unsigned int)&rx_bd;
- tx_bd.phys_buf_p = &tx_buffer[0];
- tx_bd.next_p = &tx_bd;
- flush_dcache_range((unsigned int)&tx_bd, sizeof(cdmac_bd));
- *(unsigned int *)TX_CURDESC_PTR = (unsigned int)&tx_bd;
- if(xps_ll_temac_phy_ctrl() == 0) return 0;
- memcpy(tx_buffer, buffer, length);
- flush_dcache_range((unsigned int)tx_buffer, length);
- tx_bd.stat = BDSTAT_SOP_MASK | BDSTAT_EOP_MASK | BDSTAT_STOP_ON_END_
MASK;
- tx_bd.buf_len = length;
- *(unsigned int *)TX_TAILDESC_PTR = (unsigned int)&tx_bd; /* DMA
start */
- do {
- } while(!((volatile int)tx_bd.stat & BDSTAT_COMPLETED_MASK));
- return length;
- int length;
- invalidate_dcache_range((unsigned int)&rx_bd, sizeof(cdmac_bd));
- if(!(rx_bd.stat & BDSTAT_COMPLETED_MASK)) return 0;
- length = rx_bd.app5;
- invalidate_dcache_range((unsigned int)rx_bd.phys_buf_p, length);
- rx_bd.stat = 0;
- rx_bd.app5 = 0;
- if(length > 0) {
- return length;
char * env_p;
char * end;
int i, val;
printf("cannot get enviroment for \"ethaddr\".\n");
return -1;
- : 0;
- xps_ll_temac_indirect_set(0, UAW0, val);
- xps_ll_temac_indirect_set(0, UAW1, val);
- struct xps_ll_temac_private *lp = (struct xps_ll_temac_private *)
dev->priv;
- xps_ll_temac_bd_init();
- xps_ll_temac_indirect_set(0, MC, MDIO_ENABLE_MASK | MDIO_CLOCK_DIV_
100MHz);
- xps_ll_temac_addr_setup(lp);
- xps_ll_temac_indirect_set(0, AFM, 0x00000000); /* Promiscuos mode
disable */
- xps_ll_temac_indirect_set(0, RCW1, 0x10000000); /* Enable Receiver *
- xps_ll_temac_indirect_set(0, TC, 0x10000000); /* Enable
Transmitter */
- static int first = 1;
- struct eth_device *dev;
- struct xps_ll_temac_private *lp;
- int i;
- if(!first) return 0;
- first = 0;
- dev->priv = lp;
- sprintf(dev->name, "eth0");
- xps_ll_temac_init(dev, bis);
- printf("%s: Xilinx XPS LocalLink Tri-Mode Ether MAC #%d at 0x%08X.\
n",
- for(i = 0;i < 3;i++) {
- return 1;
- return xps_ll_temac_send((unsigned char *)packet, length);
- return xps_ll_temac_recv();
BTW. Good work. Please clean it and resubmit. I check it again.
Regards, Michal Simek
Jean-Christophe PLAGNIOL-VILLARD
Michal Simek
Yoshio Kashiwagi
