[PATCH] timer: orion-timer: Fix problem in early_init_done()
It was noticed that Clearfog is currently broken with this newly introduced early_init_done() function. Apparently the timer is enabled here when U-Boot is run but not configured - at least not correctly. Resulting in a hangup in the timer reading functions.
To fix this, also read the value of the reload register and check it's value with the one written to by U-Boot. Only if this matches, the init has already been done.
Signed-off-by: Stefan Roese sr@denx.de Cc: Martin Rowe martin.p.rowe@gmail.com Cc: Tony Dinh mibodhi@gmail.com Cc: Pali Rohár pali@kernel.org Cc: Michael Walle michael@walle.cc --- drivers/timer/orion-timer.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/timer/orion-timer.c b/drivers/timer/orion-timer.c index 810a03d54960..9cab27f2e48b 100644 --- a/drivers/timer/orion-timer.c +++ b/drivers/timer/orion-timer.c @@ -25,7 +25,8 @@ struct orion_timer_priv {
static bool early_init_done(void *base) { - if (readl(base + TIMER_CTRL) & TIMER0_EN) + if ((readl(base + TIMER_CTRL) & TIMER0_EN) && + (readl(base + TIMER0_RELOAD) == ~0)) return true; return false; }
Looks good.
Acked-by: Pali Rohár pali@kernel.org
Maybe you should also fixed line:
Fixes: 5387b093cb79 ("timer: orion-timer: Fix problem with early static variable")
- if ((readl(base + TIMER_CTRL) & TIMER0_EN) &&
return true; return false;(readl(base + TIMER0_RELOAD) == ~0))
2.39.0
Hi Pali,
Looks good.
Will do when applying. Thanks.
Thanks, Stefan
return true; return false; }(readl(base + TIMER0_RELOAD) == ~0))
-- 2.39.0
Viele Grüße, Stefan Roese
Looks good.
Applied to u-boot-marvell/master
Thanks, Stefan
-- 2.39.0
Pali Rohár
Stefan Roese
