[U-Boot] [PATCH v2] sunxi: add NanoPi NEO Air defconfig
Add support for the NanoPi NEO Air H3 board from friendlyarm.com . This board contains WiFi, Bluetooth, 8GB eMMC storage and 512 MB DDR3 ram.
Signed-off-by: Jelle van der Waa jelle@vdwaa.nl --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-h3-nanopi-neo-air.dts | 97 ++++++++++++++++++++++++++++++++ configs/nanopi_neo_air_defconfig | 17 ++++++ 3 files changed, 116 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-h3-nanopi-neo-air.dts create mode 100644 configs/nanopi_neo_air_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index eb68c204bb..d3ded5a58e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -293,7 +293,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-pc-plus.dtb \ sun8i-h3-orangepi-plus.dtb \ sun8i-h3-orangepi-plus2e.dtb \ - sun8i-h3-nanopi-neo.dtb + sun8i-h3-nanopi-neo.dtb \ + sun8i-h3-nanopi-neo-air.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb diff --git a/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts b/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts new file mode 100644 index 0000000000..3ba081c1f5 --- /dev/null +++ b/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts @@ -0,0 +1,97 @@ +/* + * Copyright (C) 2017 Jelle van der Waa jelle@vdwaa.nl + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-h3.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "FriendlyARM NanoPi NEO Air"; + compatible = "friendlyarm,nanopi-neo-air", "allwinner,sun8i-h3"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + + pwr { + label = "nanopi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ + default-state = "on"; + }; + + status { + label = "nanopi:blue:status"; + gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; /* PA10 */ + }; + }; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */ + cd-inverted; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + /* USB VBUS is always on */ + status = "okay"; +}; diff --git a/configs/nanopi_neo_air_defconfig b/configs/nanopi_neo_air_defconfig new file mode 100644 index 0000000000..9598bd5cd5 --- /dev/null +++ b/configs/nanopi_neo_air_defconfig @@ -0,0 +1,17 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=408 +CONFIG_DRAM_ZQ=3881979 +CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo-air" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_EHCI_HCD=y
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Thanks, Maxime
On Mon, Feb 13, 2017 at 1:22 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Fixed, error while 'git am' and
Applied to u-boot-sunxi/master
thanks!
This is missing an entry to boards/sunxi/MAINTAINERS though.
Jelle, can you send another patch adding yourself as a board maintainer?
ChenYu
Sure, will do.
Chen-Yu Tsai
Jagan Teki
Jelle van der Waa
Maxime Ripard
