[U-Boot] [PATCH] Fix typo: firstly -> first.
Signed-off-by: Vagrant Cascadian vagrant@debian.org ---
drivers/block/ahci.c | 4 ++-- drivers/mtd/nand/pxa3xx_nand.c | 2 +- drivers/serial/serial.c | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 734fdcc..5efa821 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -818,7 +818,7 @@ static int ata_scsiop_read_capacity10(ccb *pccb) if (!ataid[pccb->target]) { printf("scsi_ahci: SCSI READ CAPACITY10 command failure. " "\tNo ATA info!\n" - "\tPlease run SCSI command INQUIRY firstly!\n"); + "\tPlease run SCSI command INQUIRY first!\n"); return -EPERM; }
@@ -847,7 +847,7 @@ static int ata_scsiop_read_capacity16(ccb *pccb) if (!ataid[pccb->target]) { printf("scsi_ahci: SCSI READ CAPACITY16 command failure. " "\tNo ATA info!\n" - "\tPlease run SCSI command INQUIRY firstly!\n"); + "\tPlease run SCSI command INQUIRY first!\n"); return -EPERM; }
diff --git a/drivers/mtd/nand/pxa3xx_nand.c b/drivers/mtd/nand/pxa3xx_nand.c index 1565a9a..f65b499 100644 --- a/drivers/mtd/nand/pxa3xx_nand.c +++ b/drivers/mtd/nand/pxa3xx_nand.c @@ -451,7 +451,7 @@ static void pxa3xx_set_datasize(struct pxa3xx_nand_info *info, }
/** - * NOTE: it is a must to set ND_RUN firstly, then write + * NOTE: it is a must to set ND_RUN first, then write * command buffer, otherwise, it does not work. * We enable all the interrupt at the same time, and * let pxa3xx_nand_irq to handle all logic. diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index 422d3ae..f1bd15b 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -527,7 +527,7 @@ static const int bauds[] = CONFIG_SYS_BAUDRATE_TABLE; * * Do a loopback test of the currently selected serial port. This * function is only useful in the context of the POST testing framwork. - * The serial port is firstly configured into loopback mode and then + * The serial port is first configured into loopback mode and then * characters are sent through it. * * Returns 0 on success, value otherwise.
Firstly, thanks.
Secondly, Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
On Tue, Nov 24, 2015 at 02:46:24PM -0800, Vagrant Cascadian wrote:
Signed-off-by: Vagrant Cascadian vagrant@debian.org Acked-by: Marek Vasut marex@denx.de
Vagrant Cascadian
