[U-Boot] [PATCH] cmd_fuse: return CMD_RET_FAILURE on error
Fuse drivers, like the mxs_ocotp.c, may return negative error codes but the commands are not allowed to return negative error codes to the shell, otherwise the following error appears:
"exit not allowed from main input shell."
Signed-off-by: Hector Palacios hector.palacios@digi.com --- common/cmd_fuse.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_fuse.c b/common/cmd_fuse.c index abab9789b0df..d4bc0f6c94a1 100644 --- a/common/cmd_fuse.c +++ b/common/cmd_fuse.c @@ -128,7 +128,7 @@ static int do_fuse(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[])
err: puts("ERROR\n"); - return ret; + return CMD_RET_FAILURE; }
U_BOOT_CMD(
Dear Hector Palacios,
On Wed, Nov 19, 2014 at 4:52 PM, Hector Palacios hector.palacios@digi.com wrote:
Correct, except -1 for CMD_RET_USAGE.
Not for any negative error.
The change is correct, but maybe the commit message should be reworded to be more precise. You could perhaps just say that this error message may appear because of unsupported return codes, and that only the CMD_RET_* enum values should be used as command return values.
return ret;
Correct. BTW, you could perhaps replace the 'return 0;' above 'err:' with 'return CMD_RET_SUCCESS;' as a cosmetic change enforcing the use of CMD_RET_* values.
U_BOOT_CMD(
Best regards, Benoît
Benoît Thébaudeau
Hector Palacios
