[U-Boot] DHCP doesn't update environment if file download fails.
If you run DHCP and it gets an ip address, but fails to download the file, it doesn put the ip address in the environment - arguably it should update the environment before going for the file?
maybe again an argument for a separate dodhcp command
David Collier
www.dexdyne.com
Dear "David Collier",
In message <memo.20091023104659.2092K@postmaster+dexdyne.com.cix.co.uk> you wrote:
Not needed. If you just want to get the IP configuration then adjust the "autoload" environment variable to fit your purposes.
David, you should _really_ RTFM.
David Collier
