[PATCH v2 00/11] Add support for NVMEM API
This adds support for the nvmem-cells properties cropping up in manyb device trees. This is an easy way to load configuration, version information, or calibration data from a non-volatile memory source. For more information, refer to patch 6 ("misc: Add support for nvmem cells").
For the moment I have only added some integration tests using the ethernet addresses. This hits the main code paths (looking up nvmem cells) but doesn't test writing. I can add a few stand-alone tests if desired.
The patches are structured in the following manner: 1-5: These are general cleanups, and may be applied independently of the rest of the series. 6-7: Add NVMEM support 8-11: Support reading ethernet addresses using the NVMEM API and add some tests.
Changes in v2: - Call the appropriate API functions directly from nvmem_cell_(read|write). This means we can drop the nvmem_interface machinery.
Sean Anderson (11): sandbox: net: Remove fake-host-hwaddr sandbox: Remove eth2addr from environment test: eth: Add test for ethernet addresses sandbox: Move some mac addresses to device tree misc: i2c_eeprom: Make i2c_eeprom_write use a const buf misc: Add support for nvmem cells sandbox: Enable NVMEM net: Add support for reading mac addresses from nvmem cells test: Load mac address with i2c eeprom test: Load mac address using RTC test: Load mac address using misc device
MAINTAINERS | 7 ++ arch/sandbox/dts/sandbox.dts | 1 - arch/sandbox/dts/sandbox64.dts | 1 - arch/sandbox/dts/test.dts | 29 +++++- board/sandbox/sandbox.env | 4 - configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_noinst_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + doc/api/index.rst | 1 + doc/api/nvmem.rst | 7 ++ drivers/misc/Kconfig | 16 +++ drivers/misc/Makefile | 1 + drivers/misc/i2c_eeprom.c | 3 +- drivers/misc/i2c_eeprom_emul.c | 4 + drivers/misc/misc_sandbox.c | 3 + drivers/misc/nvmem.c | 142 +++++++++++++++++++++++++++ drivers/net/sandbox.c | 10 +- drivers/rtc/i2c_rtc_emul.c | 10 ++ include/i2c_eeprom.h | 3 +- include/nvmem.h | 151 +++++++++++++++++++++++++++++ net/eth-uclass.c | 13 ++- test/dm/eth.c | 28 ++++++ 24 files changed, 414 insertions(+), 25 deletions(-) create mode 100644 doc/api/nvmem.rst create mode 100644 drivers/misc/nvmem.c create mode 100644 include/nvmem.h
Instead of reading a pseudo-rom mac address from the device tree, just use whatever we get from write_hwaddr. This has the effect of using the mac address from the environment (or from the device tree, if it is specified).
Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Ramon Fried rfried.dev@gmail.com ---
(no changes since v1)
arch/sandbox/dts/sandbox.dts | 1 - arch/sandbox/dts/sandbox64.dts | 1 - arch/sandbox/dts/test.dts | 5 ----- drivers/net/sandbox.c | 10 ++-------- 4 files changed, 2 insertions(+), 15 deletions(-)
diff --git a/arch/sandbox/dts/sandbox.dts b/arch/sandbox/dts/sandbox.dts index 127f168f02..840b8b503f 100644 --- a/arch/sandbox/dts/sandbox.dts +++ b/arch/sandbox/dts/sandbox.dts @@ -63,7 +63,6 @@ eth@10002000 { compatible = "sandbox,eth"; reg = <0x10002000 0x1000>; - fake-host-hwaddr = [00 00 66 44 22 00]; };
i2c_0: i2c@0 { diff --git a/arch/sandbox/dts/sandbox64.dts b/arch/sandbox/dts/sandbox64.dts index ec53106af9..3eb0457089 100644 --- a/arch/sandbox/dts/sandbox64.dts +++ b/arch/sandbox/dts/sandbox64.dts @@ -58,7 +58,6 @@ eth@10002000 { compatible = "sandbox,eth"; reg = <0x0 0x10002000 0x0 0x1000>; - fake-host-hwaddr = [00 00 66 44 22 00]; };
i2c_0: i2c@0 { diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 05c1cd5e1a..3a83a6b4b4 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -509,31 +509,26 @@ eth@10002000 { compatible = "sandbox,eth"; reg = <0x10002000 0x1000>; - fake-host-hwaddr = [00 00 66 44 22 00]; };
eth_5: eth@10003000 { compatible = "sandbox,eth"; reg = <0x10003000 0x1000>; - fake-host-hwaddr = [00 00 66 44 22 11]; };
eth_3: sbe5 { compatible = "sandbox,eth"; reg = <0x10005000 0x1000>; - fake-host-hwaddr = [00 00 66 44 22 33]; };
eth@10004000 { compatible = "sandbox,eth"; reg = <0x10004000 0x1000>; - fake-host-hwaddr = [00 00 66 44 22 22]; };
dsa_eth0: dsa-test-eth { compatible = "sandbox,eth"; reg = <0x10006000 0x1000>; - fake-host-hwaddr = [00 00 66 44 22 66]; };
dsa-test { diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 37459dfa0a..13022addb6 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -395,9 +395,11 @@ static void sb_eth_stop(struct udevice *dev) static int sb_eth_write_hwaddr(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); + struct eth_sandbox_priv *priv = dev_get_priv(dev);
debug("eth_sandbox %s: Write HW ADDR - %pM\n", dev->name, pdata->enetaddr); + memcpy(priv->fake_host_hwaddr, pdata->enetaddr, ARP_HLEN); return 0; }
@@ -419,16 +421,8 @@ static int sb_eth_of_to_plat(struct udevice *dev) { struct eth_pdata *pdata = dev_get_plat(dev); struct eth_sandbox_priv *priv = dev_get_priv(dev); - const u8 *mac;
pdata->iobase = dev_read_addr(dev); - - mac = dev_read_u8_array_ptr(dev, "fake-host-hwaddr", ARP_HLEN); - if (!mac) { - printf("'fake-host-hwaddr' is missing from the DT\n"); - return -EINVAL; - } - memcpy(priv->fake_host_hwaddr, mac, ARP_HLEN); priv->disabled = false; priv->tx_handler = sb_default_handler;
DSA interfaces use the same mac address for each interface, unless instructed otherwise. Just set eth4addr and let eth2addr and eth7addr be set automatically.
Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Simon Glass sjg@chromium.org ---
board/sandbox/sandbox.env | 1 - 1 file changed, 1 deletion(-)
diff --git a/board/sandbox/sandbox.env b/board/sandbox/sandbox.env index b4c04635a4..3ff42a9cc1 100644 --- a/board/sandbox/sandbox.env +++ b/board/sandbox/sandbox.env @@ -6,7 +6,6 @@ stdout=serial,vidconsole stderr=serial,vidconsole
ethaddr=02:00:11:22:33:44 -eth2addr=02:00:11:22:33:48 eth3addr=02:00:11:22:33:45 eth4addr=02:00:11:22:33:48 eth5addr=02:00:11:22:33:46
This adds a test to make sure that all the ethernet interfaces have their addresses read properly. At the moment everything is read from the environment, but the next few commits will add additional sources.
test/dm/eth.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/test/dm/eth.c b/test/dm/eth.c index e4ee695610..d7b1d5a2d2 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -147,6 +147,34 @@ static int dm_test_eth_act(struct unit_test_state *uts) } DM_TEST(dm_test_eth_act, UT_TESTF_SCAN_FDT);
+/* Ensure that all addresses are loaded properly */ +static int dm_test_ethaddr(struct unit_test_state *uts) +{ + static const char *const addr[] = { + "02:00:11:22:33:44", + "02:00:11:22:33:48", /* dsa slave */ + "02:00:11:22:33:45", + "02:00:11:22:33:48", /* dsa master */ + "02:00:11:22:33:46", + "02:00:11:22:33:47", + "02:00:11:22:33:48", /* dsa slave */ + }; + int i; + + for (i = 0; i < ARRAY_SIZE(addr); i++) { + char addrname[10]; + + if (i) + snprintf(addrname, sizeof(addrname), "eth%daddr", i + 1); + else + strcpy(addrname, "ethaddr"); + ut_asserteq_str(addr[i], env_get(addrname)); + } + + return 0; +} +DM_TEST(dm_test_ethaddr, UT_TESTF_SCAN_FDT); + /* The asserts include a return on fail; cleanup in the caller */ static int _dm_test_eth_rotate1(struct unit_test_state *uts) {
- static const char *const addr[] = {
- int i;
- for (i = 0; i < ARRAY_SIZE(addr); i++) {
char addrname[10];
if (i)
else
This, and I guess something related to the lists of ethaddrs in board/sandbox/sandbox.env causes the test to fail. Can you please look in to it? Thanks.
- int i;
char addrname[10];
if (i)
else
Looks like f3dd213e15 ("net: introduce helpers to get PHY ofnode from MAC") added another fake-host-hwaddr property and messed up the ordering. I'll send v3 if there are no other comments.
--Sean
This prevents some conflicts when running sandbox with -D, since the "rom" mac address will be random and won't match the environment. We still need to keep addresses for eth1 and eth6 in the environment, because dm_test_eth_rotate expects to be able to disable them by removing their envaddr variables. This can likely be fixed in a future series by adding a function to cause sandbox eth_opts callback for a particular mac to fail immediately.
arch/sandbox/dts/test.dts | 3 +++ board/sandbox/sandbox.env | 3 --- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 3a83a6b4b4..a73ae1bed5 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -514,11 +514,13 @@ eth_5: eth@10003000 { compatible = "sandbox,eth"; reg = <0x10003000 0x1000>; + mac-address = [ 02 00 11 22 33 46 ]; };
eth_3: sbe5 { compatible = "sandbox,eth"; reg = <0x10005000 0x1000>; + mac-address = [ 02 00 11 22 33 45 ]; };
eth@10004000 { @@ -529,6 +531,7 @@ dsa_eth0: dsa-test-eth { compatible = "sandbox,eth"; reg = <0x10006000 0x1000>; + mac-address = [ 02 00 11 22 33 48 ]; };
dsa-test { diff --git a/board/sandbox/sandbox.env b/board/sandbox/sandbox.env index 3ff42a9cc1..a2c19702d6 100644 --- a/board/sandbox/sandbox.env +++ b/board/sandbox/sandbox.env @@ -6,9 +6,6 @@ stdout=serial,vidconsole stderr=serial,vidconsole
ethaddr=02:00:11:22:33:44 -eth3addr=02:00:11:22:33:45 -eth4addr=02:00:11:22:33:48 -eth5addr=02:00:11:22:33:46 eth6addr=02:00:11:22:33:47 ipaddr=192.0.2.1
i2c_eeprom_ops->write uses a const buf, so use one for the wrapper function as well.
drivers/misc/i2c_eeprom.c | 3 ++- include/i2c_eeprom.h | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index 89a450d0f8..4302e180ac 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -33,7 +33,8 @@ int i2c_eeprom_read(struct udevice *dev, int offset, uint8_t *buf, int size) return ops->read(dev, offset, buf, size); }
-int i2c_eeprom_write(struct udevice *dev, int offset, uint8_t *buf, int size) +int i2c_eeprom_write(struct udevice *dev, int offset, const uint8_t *buf, + int size) { const struct i2c_eeprom_ops *ops = device_get_ops(dev);
diff --git a/include/i2c_eeprom.h b/include/i2c_eeprom.h index 3ad565684f..90fdb25232 100644 --- a/include/i2c_eeprom.h +++ b/include/i2c_eeprom.h @@ -42,7 +42,8 @@ int i2c_eeprom_read(struct udevice *dev, int offset, uint8_t *buf, int size); * * Return: 0 on success, -ve on failure */ -int i2c_eeprom_write(struct udevice *dev, int offset, uint8_t *buf, int size); +int i2c_eeprom_write(struct udevice *dev, int offset, const uint8_t *buf, + int size);
/* * i2c_eeprom_size() - get size of I2C EEPROM chip
This adds support for "nvmem cells" as seen in Linux. The nvmem device class in Linux is used for various assorted ROMs and EEPROMs. In this sense, it is similar to UCLASS_MISC, but also includes UCLASS_I2C_EEPROM, UCLASS_RTC, and UCLASS_MTD. New drivers corresponding to a Linux-style nvmem device should be implemented as one of the previously-mentioned uclasses. The nvmem API acts as a compatibility layer to adapt the (slightly different) APIs of these uclasses. It also handles the lookup of nvmem cells.
While nvmem devices can be accessed directly, they are most often used by reading/writing contiguous values called "cells". Cells typically hold information like calibration, versions, or configuration (such as mac addresses).
nvmem devices can specify "cells" in their device tree:
qfprom: eeprom@700000 { #address-cells = <1>; #size-cells = <1>; reg = <0x00700000 0x100000>;
tsens_calibration: calib@404 { reg = <0x404 0x10>; }; };
which can then be referenced like:
tsens { /* ... */ nvmem-cells = <&tsens_calibration>; nvmem-cell-names = "calibration"; };
The tsens driver could then read the calibration value like:
struct nvmem_cell cal_cell; u8 cal[16]; nvmem_cell_get_by_name(dev, "calibration", &cal_cell); nvmem_cell_read(&cal_cell, cal, sizeof(cal));
Because nvmem devices are not all of the same uclass, supported uclasses must register a nvmem_interface struct. This allows CONFIG_NVMEM to be enabled without depending on specific uclasses. At the moment, nvmem_interface is very bare-bones, and assumes that no initialization is necessary. However, this could be amended in the future.
Although I2C_EEPROM and MISC are quite similar (and could likely be unified), they present different read/write function signatures. To abstract over this, NVMEM uses the same read/write signature as Linux. In particular, short read/writes are not allowed, which is allowed by MISC.
The functionality implemented by nvmem cells is very similar to that provided by i2c_eeprom_partition. "fixed-partition"s for eeproms does not seem to have made its way into Linux or into any device tree other than sandbox. It is possible that with the introduction of this API it would be possible to remove it.
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
MAINTAINERS | 7 ++ doc/api/index.rst | 1 + doc/api/nvmem.rst | 7 ++ drivers/misc/Kconfig | 16 +++++ drivers/misc/Makefile | 1 + drivers/misc/nvmem.c | 142 +++++++++++++++++++++++++++++++++++++++ include/nvmem.h | 151 ++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 325 insertions(+) create mode 100644 doc/api/nvmem.rst create mode 100644 drivers/misc/nvmem.c create mode 100644 include/nvmem.h
diff --git a/MAINTAINERS b/MAINTAINERS index aca97cd2a3..1084cc6e54 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1048,6 +1048,13 @@ F: cmd/nvme.c F: include/nvme.h F: doc/develop/driver-model/nvme.rst
+NVMEM +M: Sean Anderson seanga2@gmail.com +S: Maintained +F: doc/api/nvmem.rst +F: drivers/misc/nvmem.c +F: include/nvmem.h + NXP C45 TJA11XX PHY DRIVER M: Radu Pirea radu-nicolae.pirea@oss.nxp.com S: Maintained diff --git a/doc/api/index.rst b/doc/api/index.rst index 72fea981b7..a9338cfef9 100644 --- a/doc/api/index.rst +++ b/doc/api/index.rst @@ -14,6 +14,7 @@ U-Boot API documentation linker_lists lmb logging + nvmem pinctrl rng sandbox diff --git a/doc/api/nvmem.rst b/doc/api/nvmem.rst new file mode 100644 index 0000000000..15c9b5b839 --- /dev/null +++ b/doc/api/nvmem.rst @@ -0,0 +1,7 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +NVMEM API +========= + +.. kernel-doc:: include/nvmem.h + :internal: diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 7029bb7b5c..e968219aa9 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -31,6 +31,22 @@ config TPL_MISC set of generic read, write and ioctl methods may be used to access the device.
+config NVMEM + bool "NVMEM support" + help + This adds support for a common interface to different types of + non-volatile memory. Consumers can use nvmem-cells properties to look + up hardware configuration data such as MAC addresses and calibration + settings. + +config SPL_NVMEM + bool "NVMEM support in SPL" + help + This adds support for a common interface to different types of + non-volatile memory. Consumers can use nvmem-cells properties to look + up hardware configuration data such as MAC addresses and calibration + settings. + config ALTERA_SYSID bool "Altera Sysid support" depends on MISC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index f22eff601a..c393eed7f9 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -4,6 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-$(CONFIG_MISC) += misc-uclass.o +obj-$(CONFIG_$(SPL_TPL_)NVMEM) += nvmem.o
obj-$(CONFIG_$(SPL_TPL_)CROS_EC) += cros_ec.o obj-$(CONFIG_$(SPL_TPL_)CROS_EC_SANDBOX) += cros_ec_sandbox.o diff --git a/drivers/misc/nvmem.c b/drivers/misc/nvmem.c new file mode 100644 index 0000000000..fd80a72394 --- /dev/null +++ b/drivers/misc/nvmem.c @@ -0,0 +1,142 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Sean Anderson sean.anderson@seco.com + */ + +#include <common.h> +#include <i2c_eeprom.h> +#include <linker_lists.h> +#include <misc.h> +#include <nvmem.h> +#include <rtc.h> +#include <dm/device_compat.h> +#include <dm/ofnode.h> +#include <dm/read.h> +#include <dm/uclass.h> + +int nvmem_cell_read(struct nvmem_cell *cell, void *buf, size_t size) +{ + dev_dbg(cell->nvmem, "%s: off=%u size=%zu\n", __func__, cell->offset, size); + if (size != cell->size) + return -EINVAL; + + switch (cell->nvmem->driver->id) { + case UCLASS_I2C_EEPROM: + return i2c_eeprom_read(cell->nvmem, cell->offset, buf, size); + case UCLASS_MISC: { + int ret = misc_read(cell->nvmem, cell->offset, buf, size); + + if (ret < 0) + return ret; + if (ret != size) + return -EIO; + return 0; + } + case UCLASS_RTC: + return dm_rtc_read(cell->nvmem, cell->offset, buf, size); + default: + return -ENOSYS; + } +} + +int nvmem_cell_write(struct nvmem_cell *cell, const void *buf, size_t size) +{ + dev_dbg(cell->nvmem, "%s: off=%u size=%zu\n", __func__, cell->offset, size); + if (size != cell->size) + return -EINVAL; + + switch (cell->nvmem->driver->id) { + case UCLASS_I2C_EEPROM: + return i2c_eeprom_write(cell->nvmem, cell->offset, buf, size); + case UCLASS_MISC: { + int ret = misc_write(cell->nvmem, cell->offset, buf, size); + + if (ret < 0) + return ret; + if (ret != size) + return -EIO; + return 0; + } + case UCLASS_RTC: + return dm_rtc_write(cell->nvmem, cell->offset, buf, size); + default: + return -ENOSYS; + } +} + +/** + * nvmem_get_device() - Get an nvmem device for a cell + * @node: ofnode of the nvmem device + * @cell: Cell to look up + * + * Try to find a nvmem-compatible device by going through the nvmem interfaces. + * + * Return: + * * 0 on success + * * -ENODEV if we didn't find anything + * * A negative error if there was a problem looking up the device + */ +static int nvmem_get_device(ofnode node, struct nvmem_cell *cell) +{ + int i, ret; + enum uclass_id ids[] = { + UCLASS_I2C_EEPROM, + UCLASS_MISC, + UCLASS_RTC, + }; + + for (i = 0; i < ARRAY_SIZE(ids); i++) { + ret = uclass_get_device_by_ofnode(ids[i], node, &cell->nvmem); + if (!ret) + return 0; + if (ret != -ENODEV) + return ret; + } + + return -ENODEV; +} + +int nvmem_cell_get_by_index(struct udevice *dev, int index, + struct nvmem_cell *cell) +{ + fdt_addr_t offset; + fdt_size_t size = FDT_SIZE_T_NONE; + int ret; + struct ofnode_phandle_args args; + + dev_dbg(dev, "%s: index=%d\n", __func__, index); + + ret = dev_read_phandle_with_args(dev, "nvmem-cells", NULL, 0, index, + &args); + if (ret) + return ret; + + ret = nvmem_get_device(ofnode_get_parent(args.node), cell); + if (ret) + return ret; + + offset = ofnode_get_addr_size_index_notrans(args.node, 0, &size); + if (offset == FDT_ADDR_T_NONE || size == FDT_SIZE_T_NONE) { + dev_dbg(cell->nvmem, "missing address or size for %s\n", + ofnode_get_name(args.node)); + return -EINVAL; + } + + cell->offset = offset; + cell->size = size; + return 0; +} + +int nvmem_cell_get_by_name(struct udevice *dev, const char *name, + struct nvmem_cell *cell) +{ + int index; + + dev_dbg(dev, "%s, name=%s\n", __func__, name); + + index = dev_read_stringlist_search(dev, "nvmem-cell-names", name); + if (index < 0) + return index; + + return nvmem_cell_get_by_index(dev, index, cell); +} diff --git a/include/nvmem.h b/include/nvmem.h new file mode 100644 index 0000000000..2751713a68 --- /dev/null +++ b/include/nvmem.h @@ -0,0 +1,151 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Sean Anderson sean.anderson@seco.com + */ + +#ifndef NVMEM_H +#define NVMEM_H + +/** + * typedef nvmem_reg_read_t - Read a register from an nvmem device + * + * @dev: The device to read from + * @offset: The offset of the register from the beginning of @dev + * @buf: The buffer to read into + * @size: The size of @buf, in bytes + * + * Return: + * * 0 on success + * * A negative error on failure + */ +typedef int (*nvmem_reg_read_t)(struct udevice *dev, unsigned int offset, + void *buf, size_t size); + +/** + * typedef nvmem_reg_write_t - Write a register to an nvmem device + * @dev: The device to write + * @offset: The offset of the register from the beginning of @dev + * @buf: The buffer to write + * @size: The size of @buf, in bytes + * + * Return: + * * 0 on success + * * -ENOSYS if the device is read-only + * * A negative error on other failures + */ +typedef int (*nvmem_reg_write_t)(struct udevice *dev, unsigned int offset, + const void *buf, size_t size); + +/** + * struct nvmem_cell - One datum within non-volatile memory + * @nvmem: The backing storage device + * @offset: The offset of the cell from the start of @nvmem + * @size: The size of the cell, in bytes + */ +struct nvmem_cell { + struct udevice *nvmem; + unsigned int offset; + size_t size; +}; + +struct udevice; + +#if CONFIG_IS_ENABLED(NVMEM) + +/** + * nvmem_cell_read() - Read the value of an nvmem cell + * @cell: The nvmem cell to read + * @buf: The buffer to read into + * @size: The size of @buf + * + * Return: + * * 0 on success + * * -EINVAL if @buf is not the same size as @cell. + * * -ENOSYS if CONFIG_NVMEM is disabled + * * A negative error if there was a problem reading the underlying storage + */ +int nvmem_cell_read(struct nvmem_cell *cell, void *buf, size_t size); + +/** + * nvmem_cell_write() - Write a value to an nvmem cell + * @cell: The nvmem cell to write + * @buf: The buffer to write from + * @size: The size of @buf + * + * Return: + * * 0 on success + * * -EINVAL if @buf is not the same size as @cell + * * -ENOSYS if @cell is read-only, or if CONFIG_NVMEM is disabled + * * A negative error if there was a problem writing the underlying storage + */ +int nvmem_cell_write(struct nvmem_cell *cell, const void *buf, size_t size); + +/** + * nvmem_cell_get_by_index() - Get an nvmem cell from a given device and index + * @dev: The device that uses the nvmem cell + * @index: The index of the cell in nvmem-cells + * @cell: The cell to initialize + * + * Look up the nvmem cell referenced by the phandle at @index in nvmem-cells in + * @dev. + * + * Return: + * * 0 on success + * * -EINVAL if the regs property is missing, empty, or undersized + * * -ENODEV if the nvmem device is missing or unimplemented + * * -ENOSYS if CONFIG_NVMEM is disabled + * * A negative error if there was a problem reading nvmem-cells or getting the + * device + */ +int nvmem_cell_get_by_index(struct udevice *dev, int index, + struct nvmem_cell *cell); + +/** + * nvmem_cell_get_by_name() - Get an nvmem cell from a given device and name + * @dev: The device that uses the nvmem cell + * @name: The name of the nvmem cell + * @cell: The cell to initialize + * + * Look up the nvmem cell referenced by @name in the nvmem-cell-names property + * of @dev. + * + * Return: + * * 0 on success + * * -EINVAL if the regs property is missing, empty, or undersized + * * -ENODEV if the nvmem device is missing or unimplemented + * * -ENODATA if @name is not in nvmem-cell-names + * * -ENOSYS if CONFIG_NVMEM is disabled + * * A negative error if there was a problem reading nvmem-cell-names, + * nvmem-cells, or getting the device + */ +int nvmem_cell_get_by_name(struct udevice *dev, const char *name, + struct nvmem_cell *cell); + +#else /* CONFIG_NVMEM */ + +static inline int nvmem_cell_read(struct nvmem_cell *cell, void *buf, int size) +{ + return -ENOSYS; +} + +static inline int nvmem_cell_write(struct nvmem_cell *cell, const void *buf, + int size) +{ + return -ENOSYS; +} + +static inline int nvmem_cell_get_by_index(struct udevice *dev, int index, + struct nvmem_cell *cell) +{ + return -ENOSYS; +} + +static inline int nvmem_cell_get_by_name(struct udevice *dev, const char *name, + struct nvmem_cell *cell) +{ + return -ENOSYS; +} + +#endif /* CONFIG_NVMEM */ + +#endif /* NVMEM_H */
This enables NVMEM for all sandbox defconfigs, enabling it to be used in unit tests in the next few commits.
configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_noinst_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + 5 files changed, 5 insertions(+)
diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 4fbe148074..7cb4bd11e8 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -145,6 +145,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_SANDBOX_MBOX=y CONFIG_MISC=y +CONFIG_NVMEM=y CONFIG_CROS_EC=y CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 1826cf0195..899cc8d8d5 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -186,6 +186,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_SANDBOX_MBOX=y CONFIG_MISC=y +CONFIG_NVMEM=y CONFIG_CROS_EC=y CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index b6f7355d47..d81866626b 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -115,6 +115,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_SANDBOX_MBOX=y CONFIG_MISC=y +CONFIG_NVMEM=y CONFIG_CROS_EC=y CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index acf648f4a2..d3689fea7d 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -144,6 +144,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_SANDBOX_MBOX=y CONFIG_MISC=y +CONFIG_NVMEM=y CONFIG_CROS_EC=y CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 11967288cd..4f3a4a7d71 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -145,6 +145,7 @@ CONFIG_LED_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_SANDBOX_MBOX=y CONFIG_MISC=y +CONFIG_SPL_NVMEM=y CONFIG_CROS_EC=y CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y
This adds support for reading mac addresses from the "mac-address" nvmem cell. If there is no (local-)mac-address property, then we will try reading from an nvmem cell.
For some existing examples of this property, refer to imx8mn.dtsi and imx8mp.dtsi. Unfortunately, fuse drivers have not yet been converted to DM.
net/eth-uclass.c | 13 +++++++++---- 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 58c308f332..211e88fbbe 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -13,6 +13,7 @@ #include <env.h> #include <log.h> #include <net.h> +#include <nvmem.h> #include <asm/global_data.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> @@ -499,17 +500,21 @@ static bool eth_dev_get_mac_address(struct udevice *dev, u8 mac[ARP_HLEN]) { #if CONFIG_IS_ENABLED(OF_CONTROL) const uint8_t *p; + struct nvmem_cell mac_cell;
p = dev_read_u8_array_ptr(dev, "mac-address", ARP_HLEN); if (!p) p = dev_read_u8_array_ptr(dev, "local-mac-address", ARP_HLEN);
- if (!p) + if (p) { + memcpy(mac, p, ARP_HLEN); + return true; + } + + if (nvmem_cell_get_by_name(dev, "mac-address", &mac_cell)) return false;
- memcpy(mac, p, ARP_HLEN); - - return true; + return !nvmem_cell_read(&mac_cell, mac, ARP_HLEN); #else return false; #endif
This uses an i2c eeprom to load a mac address using the nvmem interface.
arch/sandbox/dts/test.dts | 9 ++++++++- drivers/misc/i2c_eeprom_emul.c | 4 ++++ 2 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index a73ae1bed5..72ba3b2cd6 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -520,7 +520,8 @@ eth_3: sbe5 { compatible = "sandbox,eth"; reg = <0x10005000 0x1000>; - mac-address = [ 02 00 11 22 33 45 ]; + nvmem-cells = <ð3_addr>; + nvmem-cell-names = "mac-address"; };
eth@10004000 { @@ -675,6 +676,8 @@ pinctrl-0 = <&pinmux_i2c0_pins>;
eeprom@2c { + #address-cells = <1>; + #size-cells = <1>; reg = <0x2c>; compatible = "i2c-eeprom"; sandbox,emul = <&emul_eeprom>; @@ -686,6 +689,10 @@ reg = <10 2>; }; }; + + eth3_addr: mac-address@24 { + reg = <24 6>; + }; };
rtc_0: rtc@43 { diff --git a/drivers/misc/i2c_eeprom_emul.c b/drivers/misc/i2c_eeprom_emul.c index 85b127c406..6f32087ede 100644 --- a/drivers/misc/i2c_eeprom_emul.c +++ b/drivers/misc/i2c_eeprom_emul.c @@ -171,11 +171,15 @@ static int sandbox_i2c_eeprom_probe(struct udevice *dev) { struct sandbox_i2c_flash_plat_data *plat = dev_get_plat(dev); struct sandbox_i2c_flash *priv = dev_get_priv(dev); + /* For eth3 */ + const u8 mac[] = { 0x02, 0x00, 0x11, 0x22, 0x33, 0x45 };
priv->data = calloc(1, plat->size); if (!priv->data) return -ENOMEM;
+ memcpy(&priv->data[24], mac, sizeof(mac)); + return 0; }
This uses the nvmem API to load a mac address from an RTC.
arch/sandbox/dts/test.dts | 9 ++++++++- drivers/rtc/i2c_rtc_emul.c | 10 ++++++++++ 2 files changed, 18 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 72ba3b2cd6..2ea4e2365c 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -532,7 +532,8 @@ dsa_eth0: dsa-test-eth { compatible = "sandbox,eth"; reg = <0x10006000 0x1000>; - mac-address = [ 02 00 11 22 33 48 ]; + nvmem-cells = <ð4_addr>; + nvmem-cell-names = "mac-address"; };
dsa-test { @@ -696,9 +697,15 @@ };
rtc_0: rtc@43 { + #address-cells = <1>; + #size-cells = <1>; reg = <0x43>; compatible = "sandbox-rtc"; sandbox,emul = <&emul0>; + + eth4_addr: mac-address@40 { + reg = <0x40 6>; + }; };
rtc_1: rtc@61 { diff --git a/drivers/rtc/i2c_rtc_emul.c b/drivers/rtc/i2c_rtc_emul.c index ba418c25da..c307d6036d 100644 --- a/drivers/rtc/i2c_rtc_emul.c +++ b/drivers/rtc/i2c_rtc_emul.c @@ -203,6 +203,15 @@ static int sandbox_i2c_rtc_bind(struct udevice *dev) return 0; }
+static int sandbox_i2c_rtc_probe(struct udevice *dev) +{ + const u8 mac[] = { 0x02, 0x00, 0x11, 0x22, 0x33, 0x48 }; + struct sandbox_i2c_rtc_plat_data *plat = dev_get_plat(dev); + + memcpy(&plat->reg[0x40], mac, sizeof(mac)); + return 0; +} + static const struct udevice_id sandbox_i2c_rtc_ids[] = { { .compatible = "sandbox,i2c-rtc-emul" }, { } @@ -213,6 +222,7 @@ U_BOOT_DRIVER(sandbox_i2c_rtc_emul) = { .id = UCLASS_I2C_EMUL, .of_match = sandbox_i2c_rtc_ids, .bind = sandbox_i2c_rtc_bind, + .probe = sandbox_i2c_rtc_probe, .priv_auto = sizeof(struct sandbox_i2c_rtc), .plat_auto = sizeof(struct sandbox_i2c_rtc_plat_data), .ops = &sandbox_i2c_rtc_emul_ops,
This loads a mac address using a misc device using the nvmem interface.
arch/sandbox/dts/test.dts | 9 ++++++++- drivers/misc/misc_sandbox.c | 3 +++ 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 2ea4e2365c..c43bd82796 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -514,7 +514,8 @@ eth_5: eth@10003000 { compatible = "sandbox,eth"; reg = <0x10003000 0x1000>; - mac-address = [ 02 00 11 22 33 46 ]; + nvmem-cells = <ð5_addr>; + nvmem-cell-names = "mac-address"; };
eth_3: sbe5 { @@ -887,7 +888,13 @@ };
misc-test { + #address-cells = <1>; + #size-cells = <1>; compatible = "sandbox,misc_sandbox"; + + eth5_addr: mac-address@10 { + reg = <0x10 6>; + }; };
mmc2 { diff --git a/drivers/misc/misc_sandbox.c b/drivers/misc/misc_sandbox.c index 0e4292fd0a..31cde2dbac 100644 --- a/drivers/misc/misc_sandbox.c +++ b/drivers/misc/misc_sandbox.c @@ -112,8 +112,11 @@ static const struct misc_ops misc_sandbox_ops = { int misc_sandbox_probe(struct udevice *dev) { struct misc_sandbox_priv *priv = dev_get_priv(dev); + /* For eth5 */ + const u8 mac[] = { 0x02, 0x00, 0x11, 0x22, 0x33, 0x46 };
priv->enabled = true; + memcpy(&priv->mem[16], mac, sizeof(mac));
return 0; }
Sean Anderson
