[U-Boot-Users] [PATCH 9/9] 85xx: Remove old style of LAW init
All boards are now using the new fsl_law code so we can drop the old version.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/spd_sdram.c | 10 ---------- cpu/mpc85xx/start.S | 18 ------------------ 2 files changed, 0 insertions(+), 28 deletions(-)
diff --git a/cpu/mpc85xx/spd_sdram.c b/cpu/mpc85xx/spd_sdram.c index bb5dc1f..90c3d44 100644 --- a/cpu/mpc85xx/spd_sdram.c +++ b/cpu/mpc85xx/spd_sdram.c @@ -1023,9 +1023,6 @@ spd_sdram(void) static unsigned int setup_laws_and_tlbs(unsigned int memsize) { -#ifndef CONFIG_FSL_LAW - volatile ccsr_local_ecm_t *ecm = (void *)(CFG_MPC85xx_ECM_ADDR); -#endif unsigned int tlb_size; unsigned int law_size; unsigned int ram_tlb_index; @@ -1104,13 +1101,6 @@ setup_laws_and_tlbs(unsigned int memsize)
#ifdef CONFIG_FSL_LAW set_law(1, CFG_DDR_SDRAM_BASE, law_size, LAW_TRGT_IF_DDR); -#else - ecm->lawbar1 = ((CFG_DDR_SDRAM_BASE >> 12) & 0xfffff); - ecm->lawar1 = (LAWAR_EN - | LAWAR_TRGT_IF_DDR - | (LAWAR_SIZE & law_size)); - debug("DDR: LAWBAR1=0x%08x\n", ecm->lawbar1); - debug("DDR: LARAR1=0x%08x\n", ecm->lawar1); #endif
/* diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index 346369c..2044722 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -201,24 +201,6 @@ _start_e500: lis r7,CFG_CCSRBAR@h ori r7,r7,CFG_CCSRBAR@l
-#ifndef CONFIG_FSL_LAW - bl law_entry - mr r6,r0 - lwzu r5,0(r6) /* how many windows we actually use */ - mtctr r5 - - li r2,0x0c28 /* the first pair is reserved for */ - li r1,0x0c30 /* boot-over-rio-or-pci */ - -0: lwzu r4,4(r6) - lwzu r3,4(r6) - stwx r4,r7,r2 - stwx r3,r7,r1 - addi r2,r2,0x0020 - addi r1,r1,0x0020 - bdnz 0b -#endif - /* Clear and set up some registers. */ li r0,0 mtmsr r0
Kumar Gala
